[PATCH 00/11] Generate some header files
Gedare Bloom
gedare at rtems.org
Wed Nov 11 17:30:42 UTC 2020
I checked the content of the 11 patches, I just noticed one
inconsistency in 11/11.
On Tue, Nov 10, 2020 at 11:51 PM Sebastian Huber
> On 11/11/2020 01:18, Chris Johns wrote:
> > On 10/11/20 5:41 pm, Sebastian Huber wrote:
> >> On 10/11/2020 00:05, Chris Johns wrote:
> >>> On 10/11/20 1:49 am, Sebastian Huber wrote:
> >>>> This patch set replaces some hand written header files of the Classic
> >>>> API with header files generated from specification items. The main
> >>>> parts are the Event Manager and the Partition Manager. The patches for
> >>>> the RTEMS Classic API Guide of these two managers is available here:
> >>>> https://lists.rtems.org/pipermail/devel/2020-November/063122.html
> >>>> I tried to follow the updated Doxygen guidelines:
> >>>> https://lists.rtems.org/pipermail/devel/2020-November/063119.html
> >>>> Sebastian Huber (11):
> >>>> rtems: Include missing header file
> >>>> rtems: Generate <rtems/config.h>
> >>>> rtems: Generate <rtems/rtems/config.h>
> >>>> rtems: Generate <rtems/rtems/status.h>
> >>>> rtems: Generate <rtems/rtems/modes.h>
> >>>> rtems: Generate <rtems/rtems/options.h>
> >>>> rtems: Generate <rtems/rtems/types.h>
> >>>> rtems: Generate <rtems/rtems/attr.h>
> >>>> rtems: Generate <rtems/rtems/event.h>
> >>>> rtems: Generate <rtems/rtems/part.h>
> >>>> rtems: Generate <rtems/score/basedefs.h>
> >>> Do these files need something that indicates they are generated and part of the
> >>> RTEMS Quality Process (RQP?)?
> >>> I could not see anything.
> >> All the generated files have the standard header and the generated by comments
> >> or do you mean something else?
> > I was thinking of something like the recent change to the documentation source:
> > * This file is part of the RTEMS quality process and was automatically
> > * generated. If you find something that needs to be fixed or changed
> > * please post a report or patch to an RTEMS mailing list or raise a bug
> > * report.
> > I do not think we need the links as someone wanting to change an API header file
> > should know there are mailing lists and a bug reporting system.
> I would keep the links. It is not a lot of text. The header files
> contain the directive documentation which is also in the manuals. So,
> every user reviewing the API header file has a chance to fix typos,
> suggest a better wording, or otherwise improve the documentation.
> embedded brains GmbH
> Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> Phone: +49-89-18 94 741 - 16
> Fax: +49-89-18 94 741 - 08
> PGP: Public key available on request.
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier: https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
