Proposal: Add BSP documentation to BSP build specification
Chris Johns
chrisj at rtems.org
Thu Nov 12 21:40:31 UTC 2020
On 12/11/20 6:50 pm, Sebastian Huber wrote:
> On 12/11/2020 08:30, Chris Johns wrote:
>> I am not sure. For example ...
>> https://docs.rtems.org/branches/master/user/bsps/bsps-arm.html#debugging
>> ... has a picture of the wire links needed to enable debugging. We need to be
>> able to quickly and easily produce this sort of documentation.
>> We need the more formal part for the options etc and we need this flexibility
>> including images and more. I am concerned not providing something will result in
>> the Wiki being used with the issues that brings.
> You just have to add the image to the documentation repository to use it. This
> separates the pieces a bit, but we always have to make some trade-offs. We could
> also add a specification item for images, but I think this is a bit too much for
> now.
The key point is not needing to touch rtems-central for more general
information. IMO doing so moves the balance a bit too far. This may change and
evolve over time which I am happy to see but I think we need a separation at
this early stage.
