[PATCH 7/8] validation/ts-performance-0: Add test suite
Sebastian Huber
Fri Nov 13 10:07:56 UTC 2020
Share a default test suite with ts-validation-0.
spec/build/testsuites/validation/grp.yml | 2 +
.../testsuites/validation/performance-0.yml | 19 ++
testsuites/validation/ts-default.h | 237 ++++++++++++++++++
testsuites/validation/ts-performance-0.c | 74 ++++++
testsuites/validation/ts-validation-0.c | 155 +-----------
5 files changed, 333 insertions(+), 154 deletions(-)
create mode 100644 spec/build/testsuites/validation/performance-0.yml
create mode 100644 testsuites/validation/ts-default.h
create mode 100644 testsuites/validation/ts-performance-0.c
diff --git a/spec/build/testsuites/validation/grp.yml b/spec/build/testsuites/validation/grp.yml
index 390fb48803..1a903a4198 100644
--- a/spec/build/testsuites/validation/grp.yml
+++ b/spec/build/testsuites/validation/grp.yml
@@ -10,6 +10,8 @@ includes:
install: []
ldflags: []
links:
+- role: build-dependency
+ uid: performance-0
uid: validation-0
type: build
diff --git a/spec/build/testsuites/validation/performance-0.yml b/spec/build/testsuites/validation/performance-0.yml
new file mode 100644
index 0000000000..ba14066dd3
--- /dev/null
+++ b/spec/build/testsuites/validation/performance-0.yml
@@ -0,0 +1,19 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+cppflags: []
+cxxflags: []
+enabled-by: true
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/validation/ts-performance-0.c
+stlib: []
+target: testsuites/validation/ts-performance-0.exe
+type: build
+use-after: []
+use-before: []
diff --git a/testsuites/validation/ts-default.h b/testsuites/validation/ts-default.h
index 0000000000..0f7db65a8e
--- /dev/null
+++ b/testsuites/validation/ts-default.h
@@ -0,0 +1,237 @@
+ * @file
+ * @brief This header file provides the default validation test suite runner
+ * and application configuration.
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#include <rtems.h>
+#include <rtems/bspIo.h>
+#include <rtems/chain.h>
+#include <rtems/sysinit.h>
+#include <rtems/test-info.h>
+#include <rtems/testopts.h>
+#include <rtems/test.h>
+static char buffer[ 512 ];
+static const T_action actions[] = {
+ T_report_hash_sha256,
+ T_memory_action,
+ T_check_task_context,
+ T_check_rtems_barriers,
+ T_check_rtems_extensions,
+ T_check_rtems_message_queues,
+ T_check_rtems_partitions,
+ T_check_rtems_periods,
+ T_check_rtems_semaphores,
+ T_check_rtems_tasks,
+ T_check_rtems_timers
+static const T_config test_config = {
+ .name = rtems_test_name,
+ .buf = buffer,
+ .buf_size = sizeof( buffer ),
+ .putchar = rtems_put_char,
+ .verbosity = RTEMS_TEST_VERBOSITY,
+ .now = T_now_clock,
+ .allocate = T_memory_allocate,
+ .deallocate = T_memory_deallocate,
+ .action_count = T_ARRAY_SIZE( actions ),
+ .actions = actions
+static void runner_task( rtems_task_argument arg )
+ int exit_code;
+ (void) arg;
+ rtems_test_begin( rtems_test_name, TEST_STATE );
+ T_register();
+ exit_code = T_main( &test_config );
+ if ( exit_code == 0 ) {
+ rtems_test_end( rtems_test_name );
+ rtems_fatal( RTEMS_FATAL_SOURCE_EXIT, (uint32_t) exit_code );
+#define MAX_TLS_SIZE RTEMS_ALIGN_UP( 64, RTEMS_TASK_STORAGE_ALIGNMENT )
+#define ATTRIBUTES RTEMS_FLOATING_POINT
+#define TASK_STORAGE_SIZE \
+ RTEMS_TASK_STORAGE_SIZE( \
+ MAX_TLS_SIZE + RTEMS_MINIMUM_STACK_SIZE, \
+ ATTRIBUTES \
+#define MAX_TASKS 32
+RTEMS_ALIGNED( RTEMS_TASK_STORAGE_ALIGNMENT )
+static char runner_task_storage[ TASK_STORAGE_SIZE ];
+static const rtems_task_config runner_task_config = {
+ .name = rtems_build_name( 'R', 'U', 'N', ' ' ),
+ .initial_priority = 1,
+ .storage_area = runner_task_storage,
+ .storage_size = sizeof( runner_task_storage ),
+ .maximum_thread_local_storage_size = MAX_TLS_SIZE,
+ .initial_modes = RTEMS_DEFAULT_MODES,
+ .attributes = ATTRIBUTES
+static rtems_chain_control free_task_storage =
+ RTEMS_CHAIN_INITIALIZER_EMPTY( free_task_storage );
+static union {
+ RTEMS_ALIGNED( RTEMS_TASK_STORAGE_ALIGNMENT ) char
+ storage[ TASK_STORAGE_SIZE ];
+ rtems_chain_node node;
+} task_storage[ MAX_TASKS ];
+static void *task_stack_allocate( size_t size )
+ if ( size > sizeof( task_storage[ 0 ] ) ) {
+ return NULL;
+ return rtems_chain_get_unprotected( &free_task_storage );
+static void task_stack_deallocate( void *stack )
+ rtems_chain_append_unprotected(
+ &free_task_storage,
+ (rtems_chain_node *) stack
+static void init_runner_task( void )
+ rtems_id id;
+ rtems_status_code sc;
+ rtems_chain_initialize(
+ task_storage,
+ RTEMS_ARRAY_SIZE( task_storage ),
+ sizeof( task_storage[ 0 ] )
+ sc = rtems_task_construct( &runner_task_config, &id );
+ if ( sc != RTEMS_SUCCESSFUL ) {
+ rtems_fatal( RTEMS_FATAL_SOURCE_EXIT, 1 );
+ sc = rtems_task_start( id, runner_task, 0 );
+RTEMS_SYSINIT_ITEM(
+ init_runner_task,
+ RTEMS_SYSINIT_CLASSIC_USER_TASKS,
+ RTEMS_SYSINIT_ORDER_MIDDLE
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_MAXIMUM_PROCESSORS 4
+#define CONFIGURE_MAXIMUM_BARRIERS 3
+#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 3
+#define CONFIGURE_MAXIMUM_PARTITIONS 3
+#define CONFIGURE_MAXIMUM_PERIODS 3
+#define CONFIGURE_MAXIMUM_SEMAPHORES 3
+#define CONFIGURE_MAXIMUM_TASKS ( 1 + MAX_TASKS )
+#define CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE 1
+#define CONFIGURE_MAXIMUM_TIMERS 3
+#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 3
+#define CONFIGURE_MICROSECONDS_PER_TICK 1000
+#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 0
+#define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
+#define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
+#define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
+#define CONFIGURE_IDLE_TASK_BODY _CPU_Thread_Idle_body
+#define CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE
+#define CONFIGURE_TASK_STACK_ALLOCATOR task_stack_allocate
+#define CONFIGURE_TASK_STACK_DEALLOCATOR task_stack_deallocate
+#if defined(RTEMS_SMP)
+#define CONFIGURE_SCHEDULER_EDF_SMP
+#include <rtems/scheduler.h>
+RTEMS_SCHEDULER_EDF_SMP(a);
+RTEMS_SCHEDULER_EDF_SMP(b);
+RTEMS_SCHEDULER_EDF_SMP(c);
+#define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
+ RTEMS_SCHEDULER_TABLE_EDF_SMP(a, rtems_build_name('A', ' ', ' ', ' ')), \
+ RTEMS_SCHEDULER_TABLE_EDF_SMP(b, rtems_build_name('B', ' ', ' ', ' ')), \
+ RTEMS_SCHEDULER_TABLE_EDF_SMP(c, rtems_build_name('C', ' ', ' ', ' '))
+#define CONFIGURE_SCHEDULER_ASSIGNMENTS \
+ RTEMS_SCHEDULER_ASSIGN(0, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY), \
+ RTEMS_SCHEDULER_ASSIGN(1, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+ RTEMS_SCHEDULER_ASSIGN(2, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
+#endif /* RTEMS_SMP */
+#define CONFIGURE_INIT
+#include <rtems/confdefs.h>
diff --git a/testsuites/validation/ts-performance-0.c b/testsuites/validation/ts-performance-0.c
index 0000000000..cc61547ef9
--- /dev/null
+++ b/testsuites/validation/ts-performance-0.c
@@ -0,0 +1,74 @@
+ * @file
+ * @ingroup RTEMSTestSuiteTestsuitesPerformance0
+ * are met:
+ * This file is part of the RTEMS quality process and was automatically
+ * generated. If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://docs.rtems.org/branches/master/user/support/bugs.html
+ * For information on updating and regenerating please refer to:
+ * https://docs.rtems.org/branches/master/eng/req/howto.html
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+ * @defgroup RTEMSTestSuiteTestsuitesPerformance0 \
+ * spec:/testsuites/performance-0
+ * @ingroup RTEMSTestSuites
+ * @brief This general purpose performance test suite provides enough resources
+ * to run basic performance tests for all specified managers and functions.
+ * In SMP configurations, up to three scheduler instances using the SMP EDF
+ * scheduler are provided using up to four processors.
+const char rtems_test_name[] = "Performance0";
+#include "ts-default.h"
diff --git a/testsuites/validation/ts-validation-0.c b/testsuites/validation/ts-validation-0.c
index 801023e249..1b5ea795cd 100644
--- a/testsuites/validation/ts-validation-0.c
+++ b/testsuites/validation/ts-validation-0.c
@@ -48,11 +48,7 @@
#include "config.h"
#endif
-#include <rtems.h>
-#include <rtems/bspIo.h>
-#include <rtems/sysinit.h>
-#include <rtems/testopts.h>
@@ -72,155 +68,6 @@
const char rtems_test_name[] = "Validation0";
-static char buffer[ 512 ];
-static const T_action actions[] = {
- T_report_hash_sha256,
- T_check_task_context,
- T_check_rtems_barriers,
- T_check_rtems_extensions,
- T_check_rtems_message_queues,
- T_check_rtems_partitions,
- T_check_rtems_periods,
- T_check_rtems_semaphores,
- T_check_rtems_tasks,
- T_check_rtems_timers
-static const T_config test_config = {
- .name = rtems_test_name,
- .buf = buffer,
- .buf_size = sizeof( buffer ),
- .putchar = rtems_put_char,
- .verbosity = RTEMS_TEST_VERBOSITY,
- .now = T_now_clock,
- .action_count = T_ARRAY_SIZE( actions ),
- .actions = actions
-static void runner_task( rtems_task_argument arg )
- int exit_code;
- (void) arg;
- rtems_test_begin( rtems_test_name, TEST_STATE );
- T_register();
- exit_code = T_main( &test_config );
- if ( exit_code == 0 ) {
- rtems_test_end( rtems_test_name );
- rtems_fatal( RTEMS_FATAL_SOURCE_EXIT, (uint32_t) exit_code );
-#define MAX_TLS_SIZE RTEMS_ALIGN_UP( 64, RTEMS_TASK_STORAGE_ALIGNMENT )
-#define ATTRIBUTES RTEMS_FLOATING_POINT
-RTEMS_ALIGNED( RTEMS_TASK_STORAGE_ALIGNMENT )
-static char runner_task_storage[
- RTEMS_TASK_STORAGE_SIZE(
- MAX_TLS_SIZE + RTEMS_MINIMUM_STACK_SIZE,
- ATTRIBUTES
-static const rtems_task_config runner_task_config = {
- .name = rtems_build_name( 'R', 'U', 'N', ' ' ),
- .initial_priority = 1,
- .storage_area = runner_task_storage,
- .storage_size = sizeof( runner_task_storage ),
- .maximum_thread_local_storage_size = MAX_TLS_SIZE,
- .initial_modes = RTEMS_DEFAULT_MODES,
- .attributes = ATTRIBUTES
-static void init_runner_task(void)
- rtems_id id;
- rtems_status_code sc;
- sc = rtems_task_construct( &runner_task_config, &id );
- if ( sc != RTEMS_SUCCESSFUL ) {
- rtems_fatal( RTEMS_FATAL_SOURCE_EXIT, 1 );
- sc = rtems_task_start( id, runner_task, 0 );
-RTEMS_SYSINIT_ITEM(
- init_runner_task,
- RTEMS_SYSINIT_CLASSIC_USER_TASKS,
- RTEMS_SYSINIT_ORDER_MIDDLE
-#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
-#define CONFIGURE_MAXIMUM_PROCESSORS 4
-#define CONFIGURE_MAXIMUM_BARRIERS 3
-#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 3
-#define CONFIGURE_MAXIMUM_PARTITIONS 3
-#define CONFIGURE_MAXIMUM_PERIODS 3
-#define CONFIGURE_MAXIMUM_SEMAPHORES 3
-#define CONFIGURE_MAXIMUM_TASKS 3
-#define CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE \
- CONFIGURE_MAXIMUM_TASKS
-#define CONFIGURE_MAXIMUM_TIMERS 3
-#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 3
-#define CONFIGURE_MICROSECONDS_PER_TICK 1000
-#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 0
-#define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
-#define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
-#define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
-#define CONFIGURE_IDLE_TASK_BODY _CPU_Thread_Idle_body
-#if defined(RTEMS_SMP)
-#define CONFIGURE_SCHEDULER_EDF_SMP
-#include <rtems/scheduler.h>
-RTEMS_SCHEDULER_EDF_SMP(a);
-RTEMS_SCHEDULER_EDF_SMP(b);
-RTEMS_SCHEDULER_EDF_SMP(c);
-#define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
- RTEMS_SCHEDULER_TABLE_EDF_SMP(a, rtems_build_name('A', ' ', ' ', ' ')), \
- RTEMS_SCHEDULER_TABLE_EDF_SMP(b, rtems_build_name('B', ' ', ' ', ' ')), \
- RTEMS_SCHEDULER_TABLE_EDF_SMP(c, rtems_build_name('C', ' ', ' ', ' '))
-#define CONFIGURE_SCHEDULER_ASSIGNMENTS \
- RTEMS_SCHEDULER_ASSIGN(0, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY), \
- RTEMS_SCHEDULER_ASSIGN(1, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
- RTEMS_SCHEDULER_ASSIGN(2, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
-#endif /* RTEMS_SMP */
-#define CONFIGURE_INIT
-#include <rtems/confdefs.h>
2.26.2
