[PATCH 7/8] validation/ts-performance-0: Add test suite
Sun Nov 15 23:53:28 UTC 2020
On 13/11/20 9:07 pm, Sebastian Huber wrote:
> Share a default test suite with ts-validation-0.
>  spec/build/testsuites/validation/grp.yml      |   2 +
>  .../testsuites/validation/performance-0.yml   |  19 ++
>  testsuites/validation/ts-default.h            | 237 ++++++++++++++++++
>  testsuites/validation/ts-performance-0.c      |  74 ++++++
>  testsuites/validation/ts-validation-0.c       | 155 +-----------
>  5 files changed, 333 insertions(+), 154 deletions(-)
>  create mode 100644 spec/build/testsuites/validation/performance-0.yml
>  create mode 100644 testsuites/validation/ts-default.h
>  create mode 100644 testsuites/validation/ts-performance-0.c
> diff --git a/spec/build/testsuites/validation/grp.yml b/spec/build/testsuites/validation/grp.yml
> index 390fb48803..1a903a4198 100644
> --- a/spec/build/testsuites/validation/grp.yml
> +++ b/spec/build/testsuites/validation/grp.yml
> @@ -10,6 +10,8 @@ includes:
>  install: []
>  ldflags: []
>  links:
> +- role: build-dependency
> +  uid: performance-0
>    uid: validation-0
>  type: build
> diff --git a/spec/build/testsuites/validation/performance-0.yml b/spec/build/testsuites/validation/performance-0.yml
> new file mode 100644
> index 0000000000..ba14066dd3
> --- /dev/null
> +++ b/spec/build/testsuites/validation/performance-0.yml
> @@ -0,0 +1,19 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +build-type: test-program
> +cflags: []
> +copyrights:
> +- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
> +cppflags: []
> +cxxflags: []
> +enabled-by: true
> +features: c cprogram
> +includes: []
> +ldflags: []
> +links: []
> +source:
> +- testsuites/validation/ts-performance-0.c
> +stlib: []
> +target: testsuites/validation/ts-performance-0.exe
> +type: build
> +use-after: []
> +use-before: []
> diff --git a/testsuites/validation/ts-default.h b/testsuites/validation/ts-default.h
Who's defaults are these?
> index 0000000000..0f7db65a8e
> --- /dev/null
> +++ b/testsuites/validation/ts-default.h
> @@ -0,0 +1,237 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @brief This header file provides the default validation test suite runner
> + *   and application configuration.
> + * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#include <rtems.h>
> +#include <rtems/bspIo.h>
> +#include <rtems/chain.h>
> +#include <rtems/sysinit.h>
> +#include <rtems/test-info.h>
> +#include <rtems/testopts.h>
> +#include <rtems/test.h>
> +static char buffer[ 512 ];
> +static const T_action actions[] = {
> +  T_report_hash_sha256,
> +  T_memory_action,
> +  T_check_task_context,
> +  T_check_rtems_barriers,
> +  T_check_rtems_extensions,
> +  T_check_rtems_message_queues,
> +  T_check_rtems_partitions,
> +  T_check_rtems_periods,
> +  T_check_rtems_semaphores,
> +  T_check_rtems_tasks,
> +  T_check_rtems_timers
> +static const T_config test_config = {
> +  .name = rtems_test_name,
> +  .buf = buffer,
> +  .buf_size = sizeof( buffer ),
> +  .putchar = rtems_put_char,
> +  .verbosity = RTEMS_TEST_VERBOSITY,
> +  .now = T_now_clock,
> +  .allocate = T_memory_allocate,
> +  .deallocate = T_memory_deallocate,
> +  .action_count = T_ARRAY_SIZE( actions ),
> +  .actions = actions
> +static void runner_task( rtems_task_argument arg )
> +  int exit_code;
> +  (void) arg;
> +  rtems_test_begin( rtems_test_name, TEST_STATE );
> +  T_register();
> +  exit_code = T_main( &test_config );
> +  if ( exit_code == 0 ) {
> +    rtems_test_end( rtems_test_name );
> +  rtems_fatal( RTEMS_FATAL_SOURCE_EXIT, (uint32_t) exit_code );
> +#define MAX_TLS_SIZE RTEMS_ALIGN_UP( 64, RTEMS_TASK_STORAGE_ALIGNMENT )
> +#define ATTRIBUTES RTEMS_FLOATING_POINT
> +#define TASK_STORAGE_SIZE \
> +  RTEMS_TASK_STORAGE_SIZE( \
> +    MAX_TLS_SIZE + RTEMS_MINIMUM_STACK_SIZE, \
> +    ATTRIBUTES \
> +#define MAX_TASKS 32
> +RTEMS_ALIGNED( RTEMS_TASK_STORAGE_ALIGNMENT )
> +static char runner_task_storage[ TASK_STORAGE_SIZE ];
> +static const rtems_task_config runner_task_config = {
> +  .name = rtems_build_name( 'R', 'U', 'N', ' ' ),
> +  .initial_priority = 1,
> +  .storage_area = runner_task_storage,
> +  .storage_size = sizeof( runner_task_storage ),
> +  .maximum_thread_local_storage_size = MAX_TLS_SIZE,
> +  .initial_modes = RTEMS_DEFAULT_MODES,
> +  .attributes = ATTRIBUTES
> +static rtems_chain_control free_task_storage =
> +  RTEMS_CHAIN_INITIALIZER_EMPTY( free_task_storage );
> +static union {
> +  RTEMS_ALIGNED( RTEMS_TASK_STORAGE_ALIGNMENT ) char
> +    storage[ TASK_STORAGE_SIZE ];
> +  rtems_chain_node node;
> +} task_storage[ MAX_TASKS ];
> +static void *task_stack_allocate( size_t size )
> +  if ( size > sizeof( task_storage[ 0 ] ) ) {
> +    return NULL;
> +  return rtems_chain_get_unprotected( &free_task_storage );
> +static void task_stack_deallocate( void *stack )
> +  rtems_chain_append_unprotected(
> +    &free_task_storage,
> +    (rtems_chain_node *) stack
> +static void init_runner_task( void )
> +  rtems_id id;
> +  rtems_status_code sc;
> +  rtems_chain_initialize(
> +    task_storage,
> +    RTEMS_ARRAY_SIZE( task_storage ),
> +    sizeof( task_storage[ 0 ] )
> +  sc = rtems_task_construct( &runner_task_config, &id );
> +  if ( sc != RTEMS_SUCCESSFUL ) {
> +    rtems_fatal( RTEMS_FATAL_SOURCE_EXIT, 1 );
> +  sc = rtems_task_start( id, runner_task, 0 );
> +RTEMS_SYSINIT_ITEM(
> +  init_runner_task,
> +  RTEMS_SYSINIT_CLASSIC_USER_TASKS,
> +  RTEMS_SYSINIT_ORDER_MIDDLE
> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> +#define CONFIGURE_MAXIMUM_PROCESSORS 4
> +#define CONFIGURE_MAXIMUM_BARRIERS 3
> +#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 3
> +#define CONFIGURE_MAXIMUM_PARTITIONS 3
> +#define CONFIGURE_MAXIMUM_PERIODS 3
> +#define CONFIGURE_MAXIMUM_SEMAPHORES 3
> +#define CONFIGURE_MAXIMUM_TASKS ( 1 + MAX_TASKS )
> +#define CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE 1
> +#define CONFIGURE_MAXIMUM_TIMERS 3
> +#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 3
> +#define CONFIGURE_MICROSECONDS_PER_TICK 1000
> +#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 0
> +#define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
> +#define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
> +#define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
> +#define CONFIGURE_IDLE_TASK_BODY _CPU_Thread_Idle_body
> +#define CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE
> +#define CONFIGURE_TASK_STACK_ALLOCATOR task_stack_allocate
> +#define CONFIGURE_TASK_STACK_DEALLOCATOR task_stack_deallocate
> +#if defined(RTEMS_SMP)
> +#define CONFIGURE_SCHEDULER_EDF_SMP
> +#include <rtems/scheduler.h>
> +RTEMS_SCHEDULER_EDF_SMP(a);
> +RTEMS_SCHEDULER_EDF_SMP(b);
> +RTEMS_SCHEDULER_EDF_SMP(c);
> +#define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
> +  RTEMS_SCHEDULER_TABLE_EDF_SMP(a, rtems_build_name('A', ' ', ' ', ' ')), \
> +  RTEMS_SCHEDULER_TABLE_EDF_SMP(b, rtems_build_name('B', ' ', ' ', ' ')), \
> +  RTEMS_SCHEDULER_TABLE_EDF_SMP(c, rtems_build_name('C', ' ', ' ', ' '))
> +#define CONFIGURE_SCHEDULER_ASSIGNMENTS \
> +  RTEMS_SCHEDULER_ASSIGN(0, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY), \
> +  RTEMS_SCHEDULER_ASSIGN(1, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
> +  RTEMS_SCHEDULER_ASSIGN(2, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
These seems specific but I ma not sure.
Do tests depend on this configuration?
Does the number of cores available effect this or the dependent tests? I assume
this is included in a number of tests.
> +#endif /* RTEMS_SMP */
> +#define CONFIGURE_INIT
> +#include <rtems/confdefs.h>
> diff --git a/testsuites/validation/ts-performance-0.c b/testsuites/validation/ts-performance-0.c
> index 0000000000..cc61547ef9
> --- /dev/null
> +++ b/testsuites/validation/ts-performance-0.c
> @@ -0,0 +1,74 @@
> + * @file
> + * @ingroup RTEMSTestSuiteTestsuitesPerformance0
> + * are met:
> + * This file is part of the RTEMS quality process and was automatically
> + * generated.  If you find something that needs to be fixed or
> + * worded better please post a report or patch to an RTEMS mailing list
> + * or raise a bug report:
> + * https://docs.rtems.org/branches/master/user/support/bugs.html
> + * For information on updating and regenerating please refer to:
> + * https://docs.rtems.org/branches/master/eng/req/howto.html
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> + * @defgroup RTEMSTestSuiteTestsuitesPerformance0 \
> + *   spec:/testsuites/performance-0
> + * @ingroup RTEMSTestSuites
> + * @brief This general purpose performance test suite provides enough resources
> + *   to run basic performance tests for all specified managers and functions.
> + * In SMP configurations, up to three scheduler instances using the SMP EDF
> + * scheduler are provided using up to four processors.
> +const char rtems_test_name[] = "Performance0";
> +#include "ts-default.h"
> diff --git a/testsuites/validation/ts-validation-0.c b/testsuites/validation/ts-validation-0.c
> index 801023e249..1b5ea795cd 100644
> --- a/testsuites/validation/ts-validation-0.c
> +++ b/testsuites/validation/ts-validation-0.c
> @@ -48,11 +48,7 @@
>  #include "config.h"
>  #endif
> -#include <rtems.h>
> -#include <rtems/bspIo.h>
> -#include <rtems/sysinit.h>
> -#include <rtems/testopts.h>
> @@ -72,155 +68,6 @@
>  const char rtems_test_name[] = "Validation0";
> -static char buffer[ 512 ];
> -static const T_action actions[] = {
> -  T_report_hash_sha256,
> -  T_check_task_context,
> -  T_check_rtems_barriers,
> -  T_check_rtems_extensions,
> -  T_check_rtems_message_queues,
> -  T_check_rtems_partitions,
> -  T_check_rtems_periods,
> -  T_check_rtems_semaphores,
> -  T_check_rtems_tasks,
> -  T_check_rtems_timers
> -static const T_config test_config = {
> -  .name = rtems_test_name,
> -  .buf = buffer,
> -  .buf_size = sizeof( buffer ),
> -  .putchar = rtems_put_char,
> -  .verbosity = RTEMS_TEST_VERBOSITY,
> -  .now = T_now_clock,
> -  .action_count = T_ARRAY_SIZE( actions ),
> -  .actions = actions
> -static void runner_task( rtems_task_argument arg )
> -  int exit_code;
> -  (void) arg;
> -  rtems_test_begin( rtems_test_name, TEST_STATE );
> -  T_register();
> -  exit_code = T_main( &test_config );
> -  if ( exit_code == 0 ) {
> -    rtems_test_end( rtems_test_name );
> -  rtems_fatal( RTEMS_FATAL_SOURCE_EXIT, (uint32_t) exit_code );
> -#define MAX_TLS_SIZE RTEMS_ALIGN_UP( 64, RTEMS_TASK_STORAGE_ALIGNMENT )
> -#define ATTRIBUTES RTEMS_FLOATING_POINT
> -RTEMS_ALIGNED( RTEMS_TASK_STORAGE_ALIGNMENT )
> -static char runner_task_storage[
> -  RTEMS_TASK_STORAGE_SIZE(
> -    MAX_TLS_SIZE + RTEMS_MINIMUM_STACK_SIZE,
> -    ATTRIBUTES
> -static const rtems_task_config runner_task_config = {
> -  .name = rtems_build_name( 'R', 'U', 'N', ' ' ),
> -  .initial_priority = 1,
> -  .storage_area = runner_task_storage,
> -  .storage_size = sizeof( runner_task_storage ),
> -  .maximum_thread_local_storage_size = MAX_TLS_SIZE,
> -  .initial_modes = RTEMS_DEFAULT_MODES,
> -  .attributes = ATTRIBUTES
> -static void init_runner_task(void)
> -  rtems_id id;
> -  rtems_status_code sc;
> -  sc = rtems_task_construct( &runner_task_config, &id );
> -  if ( sc != RTEMS_SUCCESSFUL ) {
> -    rtems_fatal( RTEMS_FATAL_SOURCE_EXIT, 1 );
> -  sc = rtems_task_start( id, runner_task, 0 );
> -RTEMS_SYSINIT_ITEM(
> -  init_runner_task,
> -  RTEMS_SYSINIT_CLASSIC_USER_TASKS,
> -  RTEMS_SYSINIT_ORDER_MIDDLE
> -#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> -#define CONFIGURE_MAXIMUM_PROCESSORS 4
> -#define CONFIGURE_MAXIMUM_BARRIERS 3
> -#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 3
> -#define CONFIGURE_MAXIMUM_PARTITIONS 3
> -#define CONFIGURE_MAXIMUM_PERIODS 3
> -#define CONFIGURE_MAXIMUM_SEMAPHORES 3
> -#define CONFIGURE_MAXIMUM_TASKS 3
> -#define CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE \
> -  CONFIGURE_MAXIMUM_TASKS
> -#define CONFIGURE_MAXIMUM_TIMERS 3
> -#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 3
> -#define CONFIGURE_MICROSECONDS_PER_TICK 1000
> -#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 0
> -#define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
> -#define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
> -#define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
> -#define CONFIGURE_IDLE_TASK_BODY _CPU_Thread_Idle_body
> -#if defined(RTEMS_SMP)
> -#define CONFIGURE_SCHEDULER_EDF_SMP
> -#include <rtems/scheduler.h>
> -RTEMS_SCHEDULER_EDF_SMP(a);
> -RTEMS_SCHEDULER_EDF_SMP(b);
> -RTEMS_SCHEDULER_EDF_SMP(c);
> -#define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
> -  RTEMS_SCHEDULER_TABLE_EDF_SMP(a, rtems_build_name('A', ' ', ' ', ' ')), \
> -  RTEMS_SCHEDULER_TABLE_EDF_SMP(b, rtems_build_name('B', ' ', ' ', ' ')), \
> -  RTEMS_SCHEDULER_TABLE_EDF_SMP(c, rtems_build_name('C', ' ', ' ', ' '))
> -#define CONFIGURE_SCHEDULER_ASSIGNMENTS \
> -  RTEMS_SCHEDULER_ASSIGN(0, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY), \
> -  RTEMS_SCHEDULER_ASSIGN(1, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
> -  RTEMS_SCHEDULER_ASSIGN(2, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
> -#endif /* RTEMS_SMP */
> -#define CONFIGURE_INIT
> -#include <rtems/confdefs.h>
