[PATCH 2/2] spec/aarch64: Only apply SUBALIGN(4) to ILP32
Kinsey Moore kinsey.moore at oarcorp.com
Fri Nov 13 14:13:47 UTC 2020
-----Original Message-----
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
Sent: Friday, November 13, 2020 04:26
To: Kinsey Moore <kinsey.moore at oarcorp.com>; devel at rtems.org
Subject: Re: [PATCH 2/2] spec/aarch64: Only apply SUBALIGN(4) to ILP32
>On 12/11/2020 14:32, Kinsey Moore wrote:
>> The SUBALIGN(4) required on rtemsroset and rtemsrwset for ILP32 builds
>> was previously present on LP64 builds and causes no issues within
>> RTEMS, but causes relocation/alignment issues when building libbsd.
>> This restricts those alignment changes to ILP32 builds.
>The SUBALIGN() is currently only used on aarch64 in RTEMS. Why is it necessary? The PowerPC port for example uses a single linkcmds.base for the 32-bit and 64-bit without a SUBALIGN().
The SUBALIGN was necessary because the default alignment was 8 bytes and the ILP32 code would fail during initialization while iterating over the linker sets since the upper half-word of every address was zeroed out and was being treated as another init call. Is there a preferred way to accomplish this that doesn't involve SUBALIGN?
Given my experience with AArch64, I would expect the PowerPC linker script to need to do the same though upon review it obviously doesn't. The difference may be due to a bug in the ILP32 portions of the AArch64 toolchain since it's relatively new.
Kinsey
