[PATCH 2/2] spec/aarch64: Only apply SUBALIGN(4) to ILP32
Kinsey Moore
kinsey.moore at oarcorp.com
Fri Nov 13 14:53:57 UTC 2020
-----Original Message-----
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
Sent: Friday, November 13, 2020 08:16
To: Kinsey Moore <kinsey.moore at oarcorp.com>; devel at rtems.org
Subject: Re: [PATCH 2/2] spec/aarch64: Only apply SUBALIGN(4) to ILP32
>> From: Sebastian Huber<sebastian.huber at embedded-brains.de>
>> Sent: Friday, November 13, 2020 04:26
>> To: Kinsey Moore<kinsey.moore at oarcorp.com>;devel at rtems.org
>>> On 12/11/2020 14:32, Kinsey Moore wrote:
>>>> The SUBALIGN(4) required on rtemsroset and rtemsrwset for ILP32
>>>> builds was previously present on LP64 builds and causes no issues
>>>> within RTEMS, but causes relocation/alignment issues when building libbsd.
>>>> This restricts those alignment changes to ILP32 builds.
>>> The SUBALIGN() is currently only used on aarch64 in RTEMS. Why is it necessary? The PowerPC port for example uses a single linkcmds.base for the 32-bit and 64-bit without a SUBALIGN().
>> The SUBALIGN was necessary because the default alignment was 8 bytes and the ILP32 code would fail during initialization while iterating over the linker sets since the upper half-word of every address was zeroed out and was being treated as another init call. Is there a preferred way to accomplish this that doesn't involve SUBALIGN?
> Why can't you remove all the SUBALIGN() from the linker script?
> For example
> aarch64-rtems6-ld --verbose | grep SUBALIGN
> has no output.
That output is specifically for LP64 AArch64. ILP32 linker scripts have different OUTPUT_ARCH and OUTPUT_FORMAT directives. I wasn't able to get aarch64-rtems6-ld to output an ILP32 default linker script.
Kinsey
