Proposal for hardware configuration dependent performance limits
Fri Nov 13 19:01:28 UTC 2020
On Fri, Nov 13, 2020 at 3:48 AM Sebastian Huber
> Hello,
> there is one aspect with respect to performance limits which is
> currently not considered in this proposal:
> https://lists.rtems.org/pipermail/devel/2020-November/063213.html
> You can run the some BSPs such as sparc/gr712rc on several boards.
> However, each board may have different settings which affect the system
> performance, for example the CPU frequency, memory controller settings,
> memory chips, etc. In the proposal, limits are specified like this:
> limits:
>    sparc/gr712rc:
>      DirtyCache:
>        max-upper-bound: 0.000005
>        mean-upper-bound: 0.000005
>      FullCache:
>      HotCache:
>      Load/1:
>        max-upper-bound: 0.00001
>        mean-upper-bound: 0.00001
>      Load/2:
>      Load/3:
>      Load/4:
> This neglects that the limits are subject to a board configuration. One
> approach to cover this is the addition of a new BSP provided function:
> const char *rtems_get_hardware_performance_hash();
> The BSP feeds all performance related data into a hash function and
"data" here means configuration?
> returns a string encoding (for example a MD5 digest in base64 encoding).
> The example from above with the performance hash:
> limits:
>    sparc/gr712rc/XrY7u+Ae7tCTyyK7j1rNww==:
>      DirtyCache:
> The test suite could report the performance has and a test output analyser coudl check that the reported values are in the specified bounds.
This will work for fixed sets of configurations. I wonder if it is
reasonable instead to define ranges over configuration values? Or to
use board variant mnemonic names instead?  How many possible
configurations are we talking about?
The hash output is fairly opaque, and really small configuration
changes would result in totally different hashes, so if I change a
board from 2 MiB RAM to 3 MiB RAM, I might like to know which
configuration this is closest to in case there is no matching hash.
To invert the hash we will need to keep the table of all the
configurations mapped to hash values, which is fine I suppose.
I can see that the advantage of a hash is that we don't need to create
a namespace for configuration options that may influence performance.
This can give some flexibility for boards that have different sets of
configuration options that matter.
> embedded brains GmbH
> Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> Phone: +49-89-18 94 741 - 16
> Fax:   +49-89-18 94 741 - 08
> PGP: Public key available on request.
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier: https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
