[PATCH 1/2] spec/aarch64: Ensure that libbsd can build properly
Sat Nov 14 12:22:58 UTC 2020
On 13/11/2020 16:04, Kinsey Moore wrote:
> -----Original Message-----
> From: Sebastian Huber<sebastian.huber at embedded-brains.de>
> Sent: Friday, November 13, 2020 04:23
> To: Kinsey Moore<kinsey.moore at oarcorp.com>;devel at rtems.org
> Subject: Re: [PATCH 1/2] spec/aarch64: Ensure that libbsd can build properly
> On 12/11/2020 14:32, Kinsey Moore wrote:
>>>    install:
>>> +- destination: ${BSP_INCLUDEDIR}/bsp
>>> +  source:
>>> +  - bsps/arm/include/bsp/linker-symbols.h
>>> +  - bsps/arm/include/bsp/start.h
>>>    - destination: ${BSP_INCLUDEDIR}/dev/clock
>>>      source:
>>>      - bsps/include/dev/clock/arm-generic-timer.h
>> This is a bit strange. You install files which are not used to build the BSP?
> They are used by bspstart.c and bspstarthooks.c so they're used to build the BSP, but they're only required for some external applications and libraries which is why they weren't already being installed. This matches how ARM, RISC-V, and other BSPs install start.h and linker-symbols.h.
How did you add "bsps/arm/include" to the include path used for the
aarch64 BSPs?
embedded brains GmbH
Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 16
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
Registernummer: HRB 157899
Unsere Datenschutzerklärung finden Sie hier: https://embedded-brains.de/datenschutzerklaerung/
