[PATCH 1/2] spec/aarch64: Ensure that libbsd can build properly
Kinsey Moore
kinsey.moore at oarcorp.com
Sun Nov 15 04:06:11 UTC 2020
-----Original Message-----
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
Sent: Saturday, November 14, 2020 06:23
To: Kinsey Moore <kinsey.moore at oarcorp.com>; devel at rtems.org
Subject: Re: [PATCH 1/2] spec/aarch64: Ensure that libbsd can build properly
>> From: Sebastian Huber<sebastian.huber at embedded-brains.de>
>> Sent: Friday, November 13, 2020 04:23
>> To: Kinsey Moore<kinsey.moore at oarcorp.com>;devel at rtems.org
>> properly
>> On 12/11/2020 14:32, Kinsey Moore wrote:
>>>> install:
>>>> +- destination: ${BSP_INCLUDEDIR}/bsp
>>>> + source:
>>>> + - bsps/arm/include/bsp/linker-symbols.h
>>>> + - bsps/arm/include/bsp/start.h
>>>> - destination: ${BSP_INCLUDEDIR}/dev/clock
>>>> source:
>>>> - bsps/include/dev/clock/arm-generic-timer.h
>>> This is a bit strange. You install files which are not used to build the BSP?
>> They are used by bspstart.c and bspstarthooks.c so they're used to build the BSP, but they're only required for some external applications and libraries which is why they weren't already being installed. This matches how ARM, RISC-V, and other BSPs install start.h and linker-symbols.h.
> How did you add "bsps/arm/include" to the include path used for the
> aarch64 BSPs?
Ah, sorry. I was missing the point you were trying to make. Those files are similar enough that it would allow compilation, but you're right. Those are the wrong file paths. I'll update the patch.
Kinsey
