[PATCH rtems-tools] bsps/a53_*: Fix typo in qemu options
Kinsey Moore
kinsey.moore at oarcorp.com
Sun Nov 15 04:21:38 UTC 2020
Odd, "gic_version" works just fine in the version of qemu-system-aarch64 in the Debian package repos which is what I've been testing against. As you've provided in the patch, the official option name is "gic-version" and that also works. Just out of curiosity, does this cause Qemu to fail for you?
Either way, this change looks good to me.
Kinsey
-----Original Message-----
From: devel <devel-bounces at rtems.org> On Behalf Of Vijay Kumar Banerjee
Sent: Saturday, November 14, 2020 14:51
To: devel at rtems.org
Subject: [PATCH rtems-tools] bsps/a53_*: Fix typo in qemu options
tester/rtems/testing/bsps/a53_ilp32_qemu.ini | 2 +- tester/rtems/testing/bsps/a53_lp64_qemu.ini | 2 +-
2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/tester/rtems/testing/bsps/a53_ilp32_qemu.ini b/tester/rtems/testing/bsps/a53_ilp32_qemu.ini
index 6dfc883..3beba06 100644
--- a/tester/rtems/testing/bsps/a53_ilp32_qemu.ini
+++ b/tester/rtems/testing/bsps/a53_ilp32_qemu.ini
@@ -35,4 +35,4 @@
bsp = a53_ilp32_qemu
arch = aarch64
tester = %{_rtscripts}/qemu.cfg
-bsp_qemu_opts = %{qemu_opts_base} -serial mon:stdio -machine virt,gic_version=3 -cpu cortex-a53 -m 4096
+bsp_qemu_opts = %{qemu_opts_base} -serial mon:stdio -machine
+virt,gic-version=3 -cpu cortex-a53 -m 4096
diff --git a/tester/rtems/testing/bsps/a53_lp64_qemu.ini b/tester/rtems/testing/bsps/a53_lp64_qemu.ini
index f29ab13..1b89284 100644
--- a/tester/rtems/testing/bsps/a53_lp64_qemu.ini
+++ b/tester/rtems/testing/bsps/a53_lp64_qemu.ini
@@ -35,4 +35,4 @@
bsp = a53_lp64_qemu
arch = aarch64
2.21.1
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
