[PATCH rtems-tools] bsps/a53_*: Fix typo in qemu options
Vijay Kumar Banerjee
vijay at rtems.org
Sat Nov 14 20:51:04 UTC 2020
tester/rtems/testing/bsps/a53_ilp32_qemu.ini | 2 +-
tester/rtems/testing/bsps/a53_lp64_qemu.ini | 2 +-
2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/tester/rtems/testing/bsps/a53_ilp32_qemu.ini b/tester/rtems/testing/bsps/a53_ilp32_qemu.ini
index 6dfc883..3beba06 100644
--- a/tester/rtems/testing/bsps/a53_ilp32_qemu.ini
+++ b/tester/rtems/testing/bsps/a53_ilp32_qemu.ini
@@ -35,4 +35,4 @@
bsp = a53_ilp32_qemu
arch = aarch64
tester = %{_rtscripts}/qemu.cfg
-bsp_qemu_opts = %{qemu_opts_base} -serial mon:stdio -machine virt,gic_version=3 -cpu cortex-a53 -m 4096
+bsp_qemu_opts = %{qemu_opts_base} -serial mon:stdio -machine virt,gic-version=3 -cpu cortex-a53 -m 4096
diff --git a/tester/rtems/testing/bsps/a53_lp64_qemu.ini b/tester/rtems/testing/bsps/a53_lp64_qemu.ini
index f29ab13..1b89284 100644
--- a/tester/rtems/testing/bsps/a53_lp64_qemu.ini
+++ b/tester/rtems/testing/bsps/a53_lp64_qemu.ini
@@ -35,4 +35,4 @@
bsp = a53_lp64_qemu
arch = aarch64
2.21.1
