[PATCH rtems-tools] bsps/a53_*: Fix typo in qemu options
Gedare Bloom gedare at gwu.edu
Sun Nov 15 17:47:02 UTC 2020
On Sun, Nov 15, 2020 at 8:37 AM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> Hi Kinsey,
> Thanks for reviewing the patch...
> On Sun, Nov 15, 2020 at 9:51 AM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
>> Odd, "gic_version" works just fine in the version of qemu-system-aarch64 in the Debian package repos which is what I've been testing against. As you've provided in the patch, the official option name is "gic-version" and that also works. Just out of curiosity, does this cause Qemu to fail for you?
> Qemu 5.0 crashes with:
> qemu-system-aarch64: Property '.gic_version' not found
>> Either way, this change looks good to me.
> Thanks, I'll push.
Yes, the change looks good. Go ahead.
> Best regards,
> Vijay
>> Kinsey
>> -----Original Message-----
>> From: devel <devel-bounces at rtems.org> On Behalf Of Vijay Kumar Banerjee
>> Sent: Saturday, November 14, 2020 14:51
>> To: devel at rtems.org
>> Subject: [PATCH rtems-tools] bsps/a53_*: Fix typo in qemu options
>>  tester/rtems/testing/bsps/a53_ilp32_qemu.ini | 2 +-  tester/rtems/testing/bsps/a53_lp64_qemu.ini  | 2 +-
>>  2 files changed, 2 insertions(+), 2 deletions(-)
>> diff --git a/tester/rtems/testing/bsps/a53_ilp32_qemu.ini b/tester/rtems/testing/bsps/a53_ilp32_qemu.ini
>> index 6dfc883..3beba06 100644
>> --- a/tester/rtems/testing/bsps/a53_ilp32_qemu.ini
>> +++ b/tester/rtems/testing/bsps/a53_ilp32_qemu.ini
>> @@ -35,4 +35,4 @@
>>  bsp           = a53_ilp32_qemu
>>  arch          = aarch64
>>  tester        = %{_rtscripts}/qemu.cfg
>> -bsp_qemu_opts = %{qemu_opts_base} -serial mon:stdio -machine virt,gic_version=3 -cpu cortex-a53 -m 4096
>> +bsp_qemu_opts = %{qemu_opts_base} -serial mon:stdio -machine
>> +virt,gic-version=3 -cpu cortex-a53 -m 4096
>> diff --git a/tester/rtems/testing/bsps/a53_lp64_qemu.ini b/tester/rtems/testing/bsps/a53_lp64_qemu.ini
>> index f29ab13..1b89284 100644
>> --- a/tester/rtems/testing/bsps/a53_lp64_qemu.ini
>> +++ b/tester/rtems/testing/bsps/a53_lp64_qemu.ini
>> @@ -35,4 +35,4 @@
>>  bsp           = a53_lp64_qemu
>>  arch          = aarch64
>> 2.21.1
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
