[PATCH rtems-tools] bsps/a53_*: Fix typo in qemu options
Vijay Kumar Banerjee
vijay at rtems.org
Sun Nov 15 18:26:20 UTC 2020
On Sun, Nov 15, 2020 at 11:17 PM Gedare Bloom <gedare at gwu.edu> wrote:
> On Sun, Nov 15, 2020 at 8:37 AM Vijay Kumar Banerjee <vijay at rtems.org>
> wrote:
> > Hi Kinsey,
> > Thanks for reviewing the patch...
> > On Sun, Nov 15, 2020 at 9:51 AM Kinsey Moore <kinsey.moore at oarcorp.com>
> wrote:
> >> Odd, "gic_version" works just fine in the version of
> qemu-system-aarch64 in the Debian package repos which is what I've been
> testing against. As you've provided in the patch, the official option name
> is "gic-version" and that also works. Just out of curiosity, does this
> cause Qemu to fail for you?
> > Qemu 5.0 crashes with:
> > qemu-system-aarch64: Property '.gic_version' not found
> >> Either way, this change looks good to me.
> > Thanks, I'll push.
> Yes, the change looks good. Go ahead.
> Pushed! Thanks.
> > Best regards,
> > Vijay
> >> Kinsey
> >> -----Original Message-----
> >> From: devel <devel-bounces at rtems.org> On Behalf Of Vijay Kumar Banerjee
> >> Sent: Saturday, November 14, 2020 14:51
> >> To: devel at rtems.org
> >> Subject: [PATCH rtems-tools] bsps/a53_*: Fix typo in qemu options
> >> tester/rtems/testing/bsps/a53_ilp32_qemu.ini | 2 +-
> tester/rtems/testing/bsps/a53_lp64_qemu.ini | 2 +-
> >> 2 files changed, 2 insertions(+), 2 deletions(-)
> >> diff --git a/tester/rtems/testing/bsps/a53_ilp32_qemu.ini
> b/tester/rtems/testing/bsps/a53_ilp32_qemu.ini
> >> index 6dfc883..3beba06 100644
> >> --- a/tester/rtems/testing/bsps/a53_ilp32_qemu.ini
> >> +++ b/tester/rtems/testing/bsps/a53_ilp32_qemu.ini
> >> @@ -35,4 +35,4 @@
> >> bsp = a53_ilp32_qemu
> >> arch = aarch64
> >> tester = %{_rtscripts}/qemu.cfg
> >> -bsp_qemu_opts = %{qemu_opts_base} -serial mon:stdio -machine
> virt,gic_version=3 -cpu cortex-a53 -m 4096
> >> +bsp_qemu_opts = %{qemu_opts_base} -serial mon:stdio -machine
> >> +virt,gic-version=3 -cpu cortex-a53 -m 4096
> >> diff --git a/tester/rtems/testing/bsps/a53_lp64_qemu.ini
> b/tester/rtems/testing/bsps/a53_lp64_qemu.ini
> >> index f29ab13..1b89284 100644
> >> --- a/tester/rtems/testing/bsps/a53_lp64_qemu.ini
> >> +++ b/tester/rtems/testing/bsps/a53_lp64_qemu.ini
> >> @@ -35,4 +35,4 @@
> >> bsp = a53_lp64_qemu
> >> arch = aarch64
> >> 2.21.1
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201115/b9415999/attachment.html>
