[PATCH 7/8] validation/ts-performance-0: Add test suite
Sebastian Huber
Mon Nov 16 06:48:31 UTC 2020
On 16/11/2020 00:53, Chris Johns wrote:
> On 13/11/20 9:07 pm, Sebastian Huber wrote:
>> Share a default test suite with ts-validation-0.
>> spec/build/testsuites/validation/grp.yml | 2 +
>> .../testsuites/validation/performance-0.yml | 19 ++
>> testsuites/validation/ts-default.h | 237 ++++++++++++++++++
>> testsuites/validation/ts-performance-0.c | 74 ++++++
>> testsuites/validation/ts-validation-0.c | 155 +-----------
>> 5 files changed, 333 insertions(+), 154 deletions(-)
>> create mode 100644 spec/build/testsuites/validation/performance-0.yml
>> create mode 100644 testsuites/validation/ts-default.h
>> create mode 100644 testsuites/validation/ts-performance-0.c
>> diff --git a/spec/build/testsuites/validation/grp.yml b/spec/build/testsuites/validation/grp.yml
>> index 390fb48803..1a903a4198 100644
>> --- a/spec/build/testsuites/validation/grp.yml
>> +++ b/spec/build/testsuites/validation/grp.yml
>> @@ -10,6 +10,8 @@ includes:
>> install: []
>> ldflags: []
>> links:
>> +- role: build-dependency
>> + uid: performance-0
>> uid: validation-0
>> type: build
>> diff --git a/spec/build/testsuites/validation/performance-0.yml b/spec/build/testsuites/validation/performance-0.yml
>> new file mode 100644
>> index 0000000000..ba14066dd3
>> --- /dev/null
>> +++ b/spec/build/testsuites/validation/performance-0.yml
>> @@ -0,0 +1,19 @@
>> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>> +build-type: test-program
>> +cflags: []
>> +copyrights:
>> +- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
>> +cppflags: []
>> +cxxflags: []
>> +enabled-by: true
>> +features: c cprogram
>> +includes: []
>> +ldflags: []
>> +links: []
>> +source:
>> +- testsuites/validation/ts-performance-0.c
>> +stlib: []
>> +target: testsuites/validation/ts-performance-0.exe
>> +type: build
>> +use-after: []
>> +use-before: []
>> diff --git a/testsuites/validation/ts-default.h b/testsuites/validation/ts-default.h
> Who's defaults are these?
This is an implementation of the default validation test suite runner
and application configuration. The goal is to use it for a wide range of
test cases.
>> index 0000000000..0f7db65a8e
>> --- /dev/null
>> +++ b/testsuites/validation/ts-default.h
>> @@ -0,0 +1,237 @@
>> +/* SPDX-License-Identifier: BSD-2-Clause */
>> + * @file
>> + * @brief This header file provides the default validation test suite runner
>> + * and application configuration.
>> +#define CONFIGURE_SCHEDULER_EDF_SMP
>> +#include <rtems/scheduler.h>
>> +RTEMS_SCHEDULER_EDF_SMP(a);
>> +RTEMS_SCHEDULER_EDF_SMP(b);
>> +RTEMS_SCHEDULER_EDF_SMP(c);
>> +#define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
>> + RTEMS_SCHEDULER_TABLE_EDF_SMP(a, rtems_build_name('A', ' ', ' ', ' ')), \
>> + RTEMS_SCHEDULER_TABLE_EDF_SMP(b, rtems_build_name('B', ' ', ' ', ' ')), \
>> + RTEMS_SCHEDULER_TABLE_EDF_SMP(c, rtems_build_name('C', ' ', ' ', ' '))
>> +#define CONFIGURE_SCHEDULER_ASSIGNMENTS \
>> + RTEMS_SCHEDULER_ASSIGN(0, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY), \
>> + RTEMS_SCHEDULER_ASSIGN(1, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
>> + RTEMS_SCHEDULER_ASSIGN(2, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL), \
> These seems specific but I ma not sure.
This configuration provides enough resources to run a wide range of test
cases. For example, the SMP scheduler configuration with three
schedulers can be used to test most of the SMP support of RTEMS.
> Do tests depend on this configuration?
Yes, if the configuration provides the necessary resources, they pass,
otherwise they fail.
> Does the number of cores available effect this or the dependent tests? I assume
> this is included in a number of tests.
If a test needs three processors and a board has only two, then the test
case should fail.
Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 16
Fax: +49-89-18 94 741 - 08
PGP: Public key available on request.
Registernummer: HRB 157899
Unsere Datenschutzerklärung finden Sie hier: https://embedded-brains.de/datenschutzerklaerung/
