[PATCH rtems 2/9] imx: Move imx_iomux to arm/shared
Christian Mauderer
christian.mauderer at embedded-brains.de
Tue Nov 17 11:04:25 UTC 2020
Update #4180
bsps/arm/imx/headers.am | 2 -
bsps/arm/imx/include/bsp.h | 3 +-
bsps/arm/shared/headers.am | 6 +++
.../include/arm/freescale/imx/imx_iomuxreg.h | 0
.../include/arm/freescale/imx/imx_iomuxvar.h | 0
bsps/arm/shared/include/bsp/imx-iomux.h | 49 +++++++++++++++++++
.../{imx/start => shared/pins}/imx_iomux.c | 0
c/src/lib/libbsp/arm/imx/Makefile.am | 2 +-
spec/build/bsps/arm/imx/bspimx.yml | 10 ++--
9 files changed, 63 insertions(+), 9 deletions(-)
create mode 100644 bsps/arm/shared/headers.am
rename bsps/arm/{imx => shared}/include/arm/freescale/imx/imx_iomuxreg.h (100%)
rename bsps/arm/{imx => shared}/include/arm/freescale/imx/imx_iomuxvar.h (100%)
create mode 100644 bsps/arm/shared/include/bsp/imx-iomux.h
rename bsps/arm/{imx/start => shared/pins}/imx_iomux.c (100%)
diff --git a/bsps/arm/imx/headers.am b/bsps/arm/imx/headers.am
index 9863f34300..e7a2418dea 100644
--- a/bsps/arm/imx/headers.am
+++ b/bsps/arm/imx/headers.am
@@ -11,8 +11,6 @@ include_arm_freescale_imx_HEADERS += ../../../../../../bsps/arm/imx/include/arm/
include_arm_freescale_imx_HEADERS += ../../../../../../bsps/arm/imx/include/arm/freescale/imx/imx_ecspireg.h
include_arm_freescale_imx_HEADERS += ../../../../../../bsps/arm/imx/include/arm/freescale/imx/imx_gpcreg.h
include_arm_freescale_imx_HEADERS += ../../../../../../bsps/arm/imx/include/arm/freescale/imx/imx_i2creg.h
-include_arm_freescale_imx_HEADERS += ../../../../../../bsps/arm/imx/include/arm/freescale/imx/imx_iomuxreg.h
-include_arm_freescale_imx_HEADERS += ../../../../../../bsps/arm/imx/include/arm/freescale/imx/imx_iomuxvar.h
include_arm_freescale_imx_HEADERS += ../../../../../../bsps/arm/imx/include/arm/freescale/imx/imx_srcreg.h
include_arm_freescale_imx_HEADERS += ../../../../../../bsps/arm/imx/include/arm/freescale/imx/imx_uartreg.h
include_arm_freescale_imx_HEADERS += ../../../../../../bsps/arm/imx/include/arm/freescale/imx/imx_wdogreg.h
diff --git a/bsps/arm/imx/include/bsp.h b/bsps/arm/imx/include/bsp.h
index 99b7a0d1d7..c7e33985a9 100644
--- a/bsps/arm/imx/include/bsp.h
+++ b/bsps/arm/imx/include/bsp.h
@@ -42,6 +42,7 @@
#include <bsp/default-initial-extension.h>
+#include <bsp/imx-iomux.h>
#ifdef __cplusplus
extern "C" {
@@ -59,8 +60,6 @@ extern uintptr_t imx_gic_dist_base;
void *imx_get_reg_of_node(const void *fdt, int node);
-int imx_iomux_configure_pins(const void *fdt, uint32_t phandle);
rtems_vector_number imx_get_irq_of_node(
const void *fdt,
int node,
diff --git a/bsps/arm/shared/headers.am b/bsps/arm/shared/headers.am
new file mode 100644
index 0000000000..4fd7238f81
--- /dev/null
+++ b/bsps/arm/shared/headers.am
@@ -0,0 +1,6 @@
+## This file was generated by "./boostrap -H".
+include_arm_freescale_imxdir = $(includedir)/arm/freescale/imx
+include_arm_freescale_imx_HEADERS =
+include_arm_freescale_imx_HEADERS += ../../../../../../bsps/arm/shared/include/arm/freescale/imx/imx_iomuxreg.h
+include_arm_freescale_imx_HEADERS += ../../../../../../bsps/arm/shared/include/arm/freescale/imx/imx_iomuxvar.h
diff --git a/bsps/arm/imx/include/arm/freescale/imx/imx_iomuxreg.h b/bsps/arm/shared/include/arm/freescale/imx/imx_iomuxreg.h
similarity index 100%
rename from bsps/arm/imx/include/arm/freescale/imx/imx_iomuxreg.h
rename to bsps/arm/shared/include/arm/freescale/imx/imx_iomuxreg.h
diff --git a/bsps/arm/imx/include/arm/freescale/imx/imx_iomuxvar.h b/bsps/arm/shared/include/arm/freescale/imx/imx_iomuxvar.h
rename from bsps/arm/imx/include/arm/freescale/imx/imx_iomuxvar.h
rename to bsps/arm/shared/include/arm/freescale/imx/imx_iomuxvar.h
diff --git a/bsps/arm/shared/include/bsp/imx-iomux.h b/bsps/arm/shared/include/bsp/imx-iomux.h
index 0000000000..60421807c0
--- /dev/null
+++ b/bsps/arm/shared/include/bsp/imx-iomux.h
@@ -0,0 +1,49 @@
+ * @file
+ * @ingroup RTEMSBSPsARM
+ * @brief Functions for imx iomux.
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifndef LIBBSP_ARM_SHARED_IMX_IOMUX_H
+#define LIBBSP_ARM_SHARED_IMX_IOMUX_H
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+int imx_iomux_configure_pins(const void *fdt, uint32_t phandle);
+#ifdef __cplusplus
+#endif /* LIBBSP_ARM_SHARED_IMX_IOMUX_H */
diff --git a/bsps/arm/imx/start/imx_iomux.c b/bsps/arm/shared/pins/imx_iomux.c
rename from bsps/arm/imx/start/imx_iomux.c
rename to bsps/arm/shared/pins/imx_iomux.c
diff --git a/c/src/lib/libbsp/arm/imx/Makefile.am b/c/src/lib/libbsp/arm/imx/Makefile.am
index ad221f7576..80871a286c 100644
--- a/c/src/lib/libbsp/arm/imx/Makefile.am
+++ b/c/src/lib/libbsp/arm/imx/Makefile.am
@@ -43,7 +43,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-ttb
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/imx/start/bspreset.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/imx/start/bspstart.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/imx/start/ccm.c
-librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/imx/start/imx_iomux.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/pins/imx_iomux.c
if HAS_SMP
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/start/arm-a9mpcore-smp.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/imx/start/bspsmp.c
diff --git a/spec/build/bsps/arm/imx/bspimx.yml b/spec/build/bsps/arm/imx/bspimx.yml
index 48d41890c7..442c631b3a 100644
--- a/spec/build/bsps/arm/imx/bspimx.yml
+++ b/spec/build/bsps/arm/imx/bspimx.yml
@@ -8,7 +8,8 @@ copyrights:
cppflags: []
enabled-by: true
family: imx
-includes: []
+includes:
+ - bsps/arm/shared/include
install:
- destination: ${BSP_INCLUDEDIR}
source:
@@ -20,8 +21,8 @@ install:
- bsps/arm/imx/include/arm/freescale/imx/imx_ecspireg.h
- bsps/arm/imx/include/arm/freescale/imx/imx_gpcreg.h
- bsps/arm/imx/include/arm/freescale/imx/imx_i2creg.h
- - bsps/arm/imx/include/arm/freescale/imx/imx_iomuxreg.h
- - bsps/arm/imx/include/arm/freescale/imx/imx_iomuxvar.h
+ - bsps/arm/shared/include/arm/freescale/imx/imx_iomuxreg.h
+ - bsps/arm/shared/include/arm/freescale/imx/imx_iomuxvar.h
- bsps/arm/imx/include/arm/freescale/imx/imx_srcreg.h
- bsps/arm/imx/include/arm/freescale/imx/imx_uartreg.h
- bsps/arm/imx/include/arm/freescale/imx/imx_wdogreg.h
@@ -29,6 +30,7 @@ install:
source:
- bsps/arm/imx/include/bsp/imx-gpio.h
- bsps/arm/imx/include/bsp/irq.h
+ - bsps/arm/shared/include/bsp/imx-iomux.h
- destination: ${BSP_INCLUDEDIR}/dev/clock
source:
- bsps/include/dev/clock/arm-generic-timer.h
@@ -88,7 +90,7 @@ source:
- bsps/arm/imx/start/bspstart.c
- bsps/arm/imx/start/bspstarthooks.c
- bsps/arm/imx/start/ccm.c
-- bsps/arm/imx/start/imx_iomux.c
+- bsps/arm/shared/pins/imx_iomux.c
- bsps/arm/shared/cache/cache-cp15.c
- bsps/arm/shared/cache/cache-v7ar-disable-data.S
- bsps/shared/dev/clock/arm-generic-timer.c
2.26.2
