[PATCH rtems 1/9] Add License file for BSD-3-Clause
Gedare Bloom
gedare at rtems.org
Tue Nov 17 17:34:31 UTC 2020
On Tue, Nov 17, 2020 at 10:32 AM Christian Mauderer <oss at c-mauderer.de> wrote:
> On 17/11/2020 18:29, Gedare Bloom wrote:
> > this is ok, would have preferred it separately ;)
> Hello Gedare,
> yes, sorry. I shouldn't have hidden it in the patch set. I haven't
> checked thoroughly enough before sending. I'll send it as a separate
> patch tomorrow so that everyone is aware of it. Same is true for the i2c
> and spi commands.
OK great, we're on the same page. I think the BSP itself would be
fine. There are a few ARM/shared changes but nothing looks
questionable to me at a glance.
> Best regards
> Christian
> > On Tue, Nov 17, 2020 at 4:05 AM Christian Mauderer
> > <christian.mauderer at embedded-brains.de> wrote:
> >> We have some files with a SPDX identifier for this license. Therefore
> >> the license should be here too.
> >> LICENSE.BSD-3-Clause | 27 +++++++++++++++++++++++++++
> >> 1 file changed, 27 insertions(+)
> >> create mode 100644 LICENSE.BSD-3-Clause
> >> diff --git a/LICENSE.BSD-3-Clause b/LICENSE.BSD-3-Clause
> >> new file mode 100644
> >> index 0000000000..09d01c1ff5
> >> --- /dev/null
> >> +++ b/LICENSE.BSD-3-Clause
> >> @@ -0,0 +1,27 @@
> >> +https://spdx.org/licenses/BSD-3-Clause
> >> +Redistribution and use in source and binary forms, with or without
> >> +modification, are permitted provided that the following conditions are
> >> +met:
> >> + 1. Redistributions of source code must retain the above copyright
> >> + notice, this list of conditions and the following disclaimer.
> >> + 2. Redistributions in binary form must reproduce the above
> >> + copyright notice, this list of conditions and the following
> >> + disclaimer in the documentation and/or other materials provided
> >> + with the distribution.
> >> + 3. Neither the name of the copyright holder nor the names of its
> >> + contributors may be used to endorse or promote products derived
> >> + from this software without specific prior written permission.
> >> +THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> >> +"AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
> >> +LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
> >> +A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
> >> +HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
> >> +SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
> >> +LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
> >> +DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
> >> +THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
> >> +(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
> >> +OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
> >> 2.26.2
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
