[PATCH rtems 7/9] bsp/imxrt: Fix warnings for imported files
Christian Mauderer
christian.mauderer at embedded-brains.de
Tue Nov 17 11:04:30 UTC 2020
Update #4180
bsps/arm/imxrt/include/fsl_common.h | 295 ++++++++++++++++++
bsps/arm/imxrt/include/fsl_flexspi_nor_boot.h | 2 +
.../imxrt/nxp/boards/evkbimxrt1050/pin_mux.c | 4 +
.../nxp/devices/MIMXRT1052/drivers/fsl_dcp.c | 4 +
.../devices/MIMXRT1052/drivers/fsl_spdif.c | 2 +
5 files changed, 307 insertions(+)
diff --git a/bsps/arm/imxrt/include/fsl_common.h b/bsps/arm/imxrt/include/fsl_common.h
index 358f973b9e..76f943ebba 100644
--- a/bsps/arm/imxrt/include/fsl_common.h
+++ b/bsps/arm/imxrt/include/fsl_common.h
@@ -663,6 +663,301 @@ void DefaultISR(void);
void SDK_DelayAtLeastUs(uint32_t delay_us, uint32_t coreClock_Hz);
+#ifdef __rtems__
+/* Prototypes for IRQHandlers */
+void FLEXIO_CommonIRQHandler(void);
+void FLEXIO_DriverIRQHandler(void);
+void FLEXIO0_DriverIRQHandler(void);
+void FLEXIO1_DriverIRQHandler(void);
+void UART2_FLEXIO_DriverIRQHandler(void);
+void FLEXIO2_DriverIRQHandler(void);
+void FLEXIO3_DriverIRQHandler(void);
+void CAN0_DriverIRQHandler(void);
+void CAN1_DriverIRQHandler(void);
+void CAN2_DriverIRQHandler(void);
+void CAN3_DriverIRQHandler(void);
+void CAN4_DriverIRQHandler(void);
+void DMA_FLEXCAN0_INT_DriverIRQHandler(void);
+void DMA_FLEXCAN1_INT_DriverIRQHandler(void);
+void DMA_FLEXCAN2_INT_DriverIRQHandler(void);
+void ADMA_FLEXCAN0_INT_DriverIRQHandler(void);
+void ADMA_FLEXCAN1_INT_DriverIRQHandler(void);
+void ADMA_FLEXCAN2_INT_DriverIRQHandler(void);
+void USDHC0_DriverIRQHandler(void);
+void USDHC1_DriverIRQHandler(void);
+void USDHC2_DriverIRQHandler(void);
+void LPUART0_LPUART1_RX_DriverIRQHandler(void);
+void LPUART0_LPUART1_TX_DriverIRQHandler(void);
+void LPUART0_LPUART1_DriverIRQHandler(void);
+void LPUART0_TX_DriverIRQHandler(void);
+void LPUART0_RX_DriverIRQHandler(void);
+void LPUART0_DriverIRQHandler(void);
+void LPUART1_TX_DriverIRQHandler(void);
+void LPUART1_RX_DriverIRQHandler(void);
+void LPUART1_DriverIRQHandler(void);
+void LPUART2_TX_DriverIRQHandler(void);
+void LPUART2_RX_DriverIRQHandler(void);
+void LPUART2_DriverIRQHandler(void);
+void LPUART3_TX_DriverIRQHandler(void);
+void LPUART3_RX_DriverIRQHandler(void);
+void LPUART3_DriverIRQHandler(void);
+void LPUART4_TX_DriverIRQHandler(void);
+void LPUART4_RX_DriverIRQHandler(void);
+void LPUART4_DriverIRQHandler(void);
+void LPUART5_TX_DriverIRQHandler(void);
+void LPUART5_RX_DriverIRQHandler(void);
+void LPUART5_DriverIRQHandler(void);
+void LPUART6_TX_DriverIRQHandler(void);
+void LPUART6_RX_DriverIRQHandler(void);
+void LPUART6_DriverIRQHandler(void);
+void LPUART7_TX_DriverIRQHandler(void);
+void LPUART7_RX_DriverIRQHandler(void);
+void LPUART7_DriverIRQHandler(void);
+void LPUART8_TX_DriverIRQHandler(void);
+void LPUART8_RX_DriverIRQHandler(void);
+void LPUART8_DriverIRQHandler(void);
+void M4_0_LPUART_DriverIRQHandler(void);
+void M4_1_LPUART_DriverIRQHandler(void);
+void M4_LPUART_DriverIRQHandler(void);
+void DMA_UART0_INT_DriverIRQHandler(void);
+void DMA_UART1_INT_DriverIRQHandler(void);
+void DMA_UART2_INT_DriverIRQHandler(void);
+void DMA_UART3_INT_DriverIRQHandler(void);
+void DMA_UART4_INT_DriverIRQHandler(void);
+void ADMA_UART0_INT_DriverIRQHandler(void);
+void ADMA_UART1_INT_DriverIRQHandler(void);
+void ADMA_UART2_INT_DriverIRQHandler(void);
+void ADMA_UART3_INT_DriverIRQHandler(void);
+void DMA0_04_DriverIRQHandler(void);
+void DMA0_15_DriverIRQHandler(void);
+void DMA0_26_DriverIRQHandler(void);
+void DMA0_37_DriverIRQHandler(void);
+void DMA1_04_DriverIRQHandler(void);
+void DMA1_15_DriverIRQHandler(void);
+void DMA1_26_DriverIRQHandler(void);
+void DMA1_37_DriverIRQHandler(void);
+void DMA0_08_DriverIRQHandler(void);
+void DMA0_19_DriverIRQHandler(void);
+void DMA0_210_DriverIRQHandler(void);
+void DMA0_311_DriverIRQHandler(void);
+void DMA0_412_DriverIRQHandler(void);
+void DMA0_513_DriverIRQHandler(void);
+void DMA0_614_DriverIRQHandler(void);
+void DMA0_715_DriverIRQHandler(void);
+void DMA1_08_DriverIRQHandler(void);
+void DMA1_19_DriverIRQHandler(void);
+void DMA1_210_DriverIRQHandler(void);
+void DMA1_311_DriverIRQHandler(void);
+void DMA1_412_DriverIRQHandler(void);
+void DMA1_513_DriverIRQHandler(void);
+void DMA1_614_DriverIRQHandler(void);
+void DMA1_715_DriverIRQHandler(void);
+void DMA0_DMA16_DriverIRQHandler(void);
+void DMA1_DMA17_DriverIRQHandler(void);
+void DMA2_DMA18_DriverIRQHandler(void);
+void DMA3_DMA19_DriverIRQHandler(void);
+void DMA4_DMA20_DriverIRQHandler(void);
+void DMA5_DMA21_DriverIRQHandler(void);
+void DMA6_DMA22_DriverIRQHandler(void);
+void DMA7_DMA23_DriverIRQHandler(void);
+void DMA8_DMA24_DriverIRQHandler(void);
+void DMA9_DMA25_DriverIRQHandler(void);
+void DMA10_DMA26_DriverIRQHandler(void);
+void DMA11_DMA27_DriverIRQHandler(void);
+void DMA12_DMA28_DriverIRQHandler(void);
+void DMA13_DMA29_DriverIRQHandler(void);
+void DMA14_DMA30_DriverIRQHandler(void);
+void DMA15_DMA31_DriverIRQHandler(void);
+void DMA0_0_16_DriverIRQHandler(void);
+void DMA0_1_17_DriverIRQHandler(void);
+void DMA0_2_18_DriverIRQHandler(void);
+void DMA0_3_19_DriverIRQHandler(void);
+void DMA0_4_20_DriverIRQHandler(void);
+void DMA0_5_21_DriverIRQHandler(void);
+void DMA0_6_22_DriverIRQHandler(void);
+void DMA0_7_23_DriverIRQHandler(void);
+void DMA0_8_24_DriverIRQHandler(void);
+void DMA0_9_25_DriverIRQHandler(void);
+void DMA0_10_26_DriverIRQHandler(void);
+void DMA0_11_27_DriverIRQHandler(void);
+void DMA0_12_28_DriverIRQHandler(void);
+void DMA0_13_29_DriverIRQHandler(void);
+void DMA0_14_30_DriverIRQHandler(void);
+void DMA0_15_31_DriverIRQHandler(void);
+void DMA1_0_16_DriverIRQHandler(void);
+void DMA1_1_17_DriverIRQHandler(void);
+void DMA1_2_18_DriverIRQHandler(void);
+void DMA1_3_19_DriverIRQHandler(void);
+void DMA1_4_20_DriverIRQHandler(void);
+void DMA1_5_21_DriverIRQHandler(void);
+void DMA1_6_22_DriverIRQHandler(void);
+void DMA1_7_23_DriverIRQHandler(void);
+void DMA1_8_24_DriverIRQHandler(void);
+void DMA1_9_25_DriverIRQHandler(void);
+void DMA1_10_26_DriverIRQHandler(void);
+void DMA1_11_27_DriverIRQHandler(void);
+void DMA1_12_28_DriverIRQHandler(void);
+void DMA1_13_29_DriverIRQHandler(void);
+void DMA1_14_30_DriverIRQHandler(void);
+void DMA1_15_31_DriverIRQHandler(void);
+void DMA0_0_4_DriverIRQHandler(void);
+void DMA0_1_5_DriverIRQHandler(void);
+void DMA0_2_6_DriverIRQHandler(void);
+void DMA0_3_7_DriverIRQHandler(void);
+void DMA0_8_12_DriverIRQHandler(void);
+void DMA0_9_13_DriverIRQHandler(void);
+void DMA0_10_14_DriverIRQHandler(void);
+void DMA0_11_15_DriverIRQHandler(void);
+void DMA0_16_20_DriverIRQHandler(void);
+void DMA0_17_21_DriverIRQHandler(void);
+void DMA0_18_22_DriverIRQHandler(void);
+void DMA0_19_23_DriverIRQHandler(void);
+void DMA0_24_28_DriverIRQHandler(void);
+void DMA0_25_29_DriverIRQHandler(void);
+void DMA0_26_30_DriverIRQHandler(void);
+void DMA0_27_31_DriverIRQHandler(void);
+void DMA0_DriverIRQHandler(void);
+void DMA1_DriverIRQHandler(void);
+void DMA2_DriverIRQHandler(void);
+void DMA3_DriverIRQHandler(void);
+void DMA4_DriverIRQHandler(void);
+void DMA5_DriverIRQHandler(void);
+void DMA6_DriverIRQHandler(void);
+void DMA7_DriverIRQHandler(void);
+void DMA8_DriverIRQHandler(void);
+void DMA9_DriverIRQHandler(void);
+void DMA10_DriverIRQHandler(void);
+void DMA11_DriverIRQHandler(void);
+void DMA12_DriverIRQHandler(void);
+void DMA13_DriverIRQHandler(void);
+void DMA14_DriverIRQHandler(void);
+void DMA15_DriverIRQHandler(void);
+void DMA16_DriverIRQHandler(void);
+void DMA17_DriverIRQHandler(void);
+void DMA18_DriverIRQHandler(void);
+void DMA19_DriverIRQHandler(void);
+void DMA20_DriverIRQHandler(void);
+void DMA21_DriverIRQHandler(void);
+void DMA22_DriverIRQHandler(void);
+void DMA23_DriverIRQHandler(void);
+void DMA24_DriverIRQHandler(void);
+void DMA25_DriverIRQHandler(void);
+void DMA26_DriverIRQHandler(void);
+void DMA27_DriverIRQHandler(void);
+void DMA28_DriverIRQHandler(void);
+void DMA29_DriverIRQHandler(void);
+void DMA30_DriverIRQHandler(void);
+void DMA31_DriverIRQHandler(void);
+void ENET_Transmit_IRQHandler(void);
+void ENET_Receive_IRQHandler(void);
+void ENET_Error_IRQHandler(void);
+void ENET_1588_Timer_IRQHandler(void);
+void ENET_DriverIRQHandler(void);
+void ENET1_DriverIRQHandler(void);
+void ENET2_DriverIRQHandler(void);
+void CONNECTIVITY_ENET0_FRAME0_EVENT_INT_DriverIRQHandler(void);
+void CONNECTIVITY_ENET0_FRAME1_INT_DriverIRQHandler(void);
+void CONNECTIVITY_ENET0_FRAME2_INT_DriverIRQHandler(void);
+void CONNECTIVITY_ENET1_FRAME0_EVENT_INT_DriverIRQHandler(void);
+void CONNECTIVITY_ENET1_FRAME1_INT_DriverIRQHandler(void);
+void CONNECTIVITY_ENET1_FRAME2_INT_DriverIRQHandler(void);
+void ENET_1G_DriverIRQHandler(void);
+void ENET_MAC0_Tx_Rx_Done_0_DriverIRQHandler(void);
+void ENET_MAC0_Tx_Rx_Done_1_DriverIRQHandler(void);
+void ENET_1G_1588_Timer_DriverIRQHandler(void);
+void I2S0_DriverIRQHandler(void);
+void I2S0_Tx_DriverIRQHandler(void);
+void I2S0_Rx_DriverIRQHandler(void);
+void I2S1_DriverIRQHandler(void);
+void I2S1_Tx_DriverIRQHandler(void);
+void I2S1_Rx_DriverIRQHandler(void);
+void I2S2_DriverIRQHandler(void);
+void I2S2_Tx_DriverIRQHandler(void);
+void I2S2_Rx_DriverIRQHandler(void);
+void I2S3_DriverIRQHandler(void);
+void I2S3_Tx_DriverIRQHandler(void);
+void I2S3_Rx_DriverIRQHandler(void);
+void I2S4_DriverIRQHandler(void);
+void I2S4_Tx_DriverIRQHandler(void);
+void I2S4_Rx_DriverIRQHandler(void);
+void I2S56_DriverIRQHandler(void);
+void I2S56_Tx_DriverIRQHandler(void);
+void I2S56_Rx_DriverIRQHandler(void);
+void I2S5_DriverIRQHandler(void);
+void I2S5_Tx_DriverIRQHandler(void);
+void I2S5_Rx_DriverIRQHandler(void);
+void I2S6_DriverIRQHandler(void);
+void I2S6_Tx_DriverIRQHandler(void);
+void I2S6_Rx_DriverIRQHandler(void);
+void AUDIO_SAI0_INT_DriverIRQHandler(void);
+void AUDIO_SAI1_INT_DriverIRQHandler(void);
+void AUDIO_SAI2_INT_DriverIRQHandler(void);
+void AUDIO_SAI3_INT_DriverIRQHandler(void);
+void AUDIO_SAI6_INT_DriverIRQHandler(void);
+void AUDIO_SAI7_INT_DriverIRQHandler(void);
+void ADMA_SAI0_INT_DriverIRQHandler(void);
+void ADMA_SAI1_INT_DriverIRQHandler(void);
+void ADMA_SAI2_INT_DriverIRQHandler(void);
+void ADMA_SAI3_INT_DriverIRQHandler(void);
+void ADMA_SAI4_INT_DriverIRQHandler(void);
+void ADMA_SAI5_INT_DriverIRQHandler(void);
+void SAI0_DriverIRQHandler(void);
+void SAI1_DriverIRQHandler(void);
+void SAI2_DriverIRQHandler(void);
+void SAI3_DriverIRQHandler(void);
+void SAI3_TX_DriverIRQHandler(void);
+void SAI3_RX_DriverIRQHandler(void);
+void SAI4_DriverIRQHandler(void);
+void SAI5_DriverIRQHandler(void);
+void SAI6_DriverIRQHandler(void);
+void FLEXSPI_DriverIRQHandler(void);
+void FLEXSPI0_DriverIRQHandler(void);
+void FLEXSPI1_DriverIRQHandler(void);
+void LSIO_OCTASPI0_INT_DriverIRQHandler(void);
+void LSIO_OCTASPI1_INT_DriverIRQHandler(void);
+void FLEXSPI0_FLEXSPI1_DriverIRQHandler(void);
+void LPSPI0_DriverIRQHandler(void);
+void LPSPI1_DriverIRQHandler(void);
+void LPSPI2_DriverIRQHandler(void);
+void LPSPI3_DriverIRQHandler(void);
+void LPSPI4_DriverIRQHandler(void);
+void LPSPI5_DriverIRQHandler(void);
+void DMA_SPI0_INT_DriverIRQHandler(void);
+void DMA_SPI1_INT_DriverIRQHandler(void);
+void DMA_SPI2_INT_DriverIRQHandler(void);
+void DMA_SPI3_INT_DriverIRQHandler(void);
+void ADMA_SPI0_INT_DriverIRQHandler(void);
+void ADMA_SPI1_INT_DriverIRQHandler(void);
+void ADMA_SPI2_INT_DriverIRQHandler(void);
+void ADMA_SPI3_INT_DriverIRQHandler(void);
+void CSI_DriverIRQHandler(void);
+void CSI0_DriverIRQHandler(void);
+void LPI2C0_DriverIRQHandler(void);
+void LPI2C1_DriverIRQHandler(void);
+void LPI2C2_DriverIRQHandler(void);
+void LPI2C3_DriverIRQHandler(void);
+void LPI2C4_DriverIRQHandler(void);
+void LPI2C5_DriverIRQHandler(void);
+void LPI2C6_DriverIRQHandler(void);
+void M4_0_LPI2C_DriverIRQHandler(void);
+void M4_LPI2C_DriverIRQHandler(void);
+void M4_1_LPI2C_DriverIRQHandler(void);
+void DMA_I2C0_INT_DriverIRQHandler(void);
+void DMA_I2C1_INT_DriverIRQHandler(void);
+void DMA_I2C2_INT_DriverIRQHandler(void);
+void DMA_I2C3_INT_DriverIRQHandler(void);
+void DMA_I2C4_INT_DriverIRQHandler(void);
+void ADMA_I2C0_INT_DriverIRQHandler(void);
+void ADMA_I2C1_INT_DriverIRQHandler(void);
+void ADMA_I2C2_INT_DriverIRQHandler(void);
+void ADMA_I2C3_INT_DriverIRQHandler(void);
+void ADMA_I2C4_INT_DriverIRQHandler(void);
+void SPDIF_DriverIRQHandler(void);
+#endif /* __rtems__ */
#if defined(__cplusplus)
#endif
diff --git a/bsps/arm/imxrt/include/fsl_flexspi_nor_boot.h b/bsps/arm/imxrt/include/fsl_flexspi_nor_boot.h
index 4870dfb4dc..7b256f6670 100644
--- a/bsps/arm/imxrt/include/fsl_flexspi_nor_boot.h
+++ b/bsps/arm/imxrt/include/fsl_flexspi_nor_boot.h
@@ -105,11 +105,13 @@ typedef struct _boot_data_ {
uint32_t placeholder; /* placehoder to make even 0x10 size */
}BOOT_DATA_T;
+#ifndef __rtems__
#if defined(BOARD_FLASH_SIZE)
#define FLASH_SIZE BOARD_FLASH_SIZE
#else
#error "Please define macro BOARD_FLASH_SIZE"
#endif
#define PLUGIN_FLAG (uint32_t)0
/* External Variables */
diff --git a/bsps/arm/imxrt/nxp/boards/evkbimxrt1050/pin_mux.c b/bsps/arm/imxrt/nxp/boards/evkbimxrt1050/pin_mux.c
index 8e3021afcb..25ca313926 100644
--- a/bsps/arm/imxrt/nxp/boards/evkbimxrt1050/pin_mux.c
+++ b/bsps/arm/imxrt/nxp/boards/evkbimxrt1050/pin_mux.c
@@ -217,7 +217,11 @@ pin_labels:
#include "fsl_common.h"
#include "fsl_iomuxc.h"
+#ifndef __rtems__
#include "pin_mux.h"
+#else /* __rtems__ */
+#include "fsl_pin_mux.h"
/* FUNCTION ************************************************************************************************************
diff --git a/bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_dcp.c b/bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_dcp.c
index 4477406a73..fff5e6fe35 100644
--- a/bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_dcp.c
+++ b/bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_dcp.c
@@ -1212,8 +1212,12 @@ status_t DCP_HASH_Init(DCP_Type *base, dcp_handle_t *handle, dcp_hash_ctx_t *ctx
status_t status;
dcp_hash_ctx_internal_t *ctxInternal;
+#ifndef __rtems__
/* compile time check for the correct structure size */
BUILD_ASSURE(sizeof(dcp_hash_ctx_t) >= sizeof(dcp_hash_ctx_internal_t), dcp_hash_ctx_t_size);
+ assert(sizeof(dcp_hash_ctx_t) >= sizeof(dcp_hash_ctx_internal_t));
uint32_t i;
status = dcp_hash_check_input_args(base, ctx, algo);
diff --git a/bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_spdif.c b/bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_spdif.c
index ef06114dd6..e03c28b6a0 100644
--- a/bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_spdif.c
+++ b/bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_spdif.c
@@ -811,6 +811,7 @@ void SPDIF_TransferRxHandleIRQ(SPDIF_Type *base, spdif_handle_t *handle)
+#ifndef __rtems__
#if defined(SPDIF)
@@ -826,3 +827,4 @@ void SPDIF_DriverIRQHandler(void)
SDK_ISR_EXIT_BARRIER;
#endif
2.26.2
