[PATCH rtems 8/9] bsp/imxrt: Adapt imported files
Christian Mauderer
christian.mauderer at embedded-brains.de
Tue Nov 17 11:04:31 UTC 2020
Update #4180
bsps/arm/imxrt/include/fsl_device_registers.h | 57 ++++++++++---------
bsps/arm/imxrt/include/fsl_flexspi_nor_boot.h | 6 ++
..._nor_config.h => fsl_flexspi_nor_config.h} | 0
bsps/arm/imxrt/include/fsl_lpuart.h | 4 ++
bsps/arm/imxrt/include/fsl_pin_mux.h | 4 ++
.../nxp/boards/evkbimxrt1050/clock_config.c | 12 ++++
.../imxrt/nxp/boards/evkbimxrt1050/pin_mux.c | 6 ++
.../devices/MIMXRT1052/drivers/fsl_lpuart.c | 17 ++++++
8 files changed, 80 insertions(+), 26 deletions(-)
rename bsps/arm/imxrt/include/{evkbimxrt1050_flexspi_nor_config.h => fsl_flexspi_nor_config.h} (100%)
diff --git a/bsps/arm/imxrt/include/fsl_device_registers.h b/bsps/arm/imxrt/include/fsl_device_registers.h
index 54caf43ca6..00c3fc7036 100644
--- a/bsps/arm/imxrt/include/fsl_device_registers.h
+++ b/bsps/arm/imxrt/include/fsl_device_registers.h
@@ -1,36 +1,41 @@
- * Copyright 2014-2016 Freescale Semiconductor, Inc.
- * Copyright 2016-2018 NXP
- * All rights reserved.
+ * @file
- * SPDX-License-Identifier: BSD-3-Clause
+ * @ingroup RTEMSBSPsARMimxrt
+ * @brief Helper file for including registers for SDK drivers.
-#ifndef __FSL_DEVICE_REGISTERS_H__
-#define __FSL_DEVICE_REGISTERS_H__
- * Include the cpu specific register header files.
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
- * The CPU macro should be declared in the project or makefile.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
-#if (defined(CPU_MIMXRT1052CVJ5B) || defined(CPU_MIMXRT1052CVL5B) || defined(CPU_MIMXRT1052DVJ6B) || \
- defined(CPU_MIMXRT1052DVL6B))
-#define MIMXRT1052_SERIES
-/* CMSIS-style register definitions */
-#include "MIMXRT1052.h"
-/* CPU specific feature definitions */
-#include "MIMXRT1052_features.h"
-#else
- #error "No valid CPU defined!"
-#endif
+#ifndef FSL_DEVICE_REGISTERS_H
+#define FSL_DEVICE_REGISTERS_H
-#endif /* __FSL_DEVICE_REGISTERS_H__ */
+#include <chip.h>
- * EOF
+#endif /* FSL_DEVICE_REGISTERS_H */
diff --git a/bsps/arm/imxrt/include/fsl_flexspi_nor_boot.h b/bsps/arm/imxrt/include/fsl_flexspi_nor_boot.h
index 7b256f6670..56995eca55 100644
--- a/bsps/arm/imxrt/include/fsl_flexspi_nor_boot.h
+++ b/bsps/arm/imxrt/include/fsl_flexspi_nor_boot.h
@@ -9,7 +9,9 @@
#define __FLEXSPI_NOR_BOOT_H__
#include <stdint.h>
+#ifndef __rtems__
#include "board.h"
+#endif /* __rtems__ */
/*! @name Driver version */
@@ -85,6 +87,7 @@ typedef struct _ivt_ {
#define FLASH_BASE ((uint32_t)__FLASH_BASE)
#endif
+#ifndef __rtems__
#if defined(XIP_BOOT_HEADER_DCD_ENABLE) && (1 == XIP_BOOT_HEADER_DCD_ENABLE)
#define DCD_ADDRESS dcd_data
#else
@@ -94,6 +97,7 @@ typedef struct _ivt_ {
#define BOOT_DATA_ADDRESS &boot_data
#define CSF_ADDRESS 0
#define IVT_RSVD (uint32_t)(0x00000000)
* Boot Data
@@ -114,11 +118,13 @@ typedef struct _boot_data_ {
#define PLUGIN_FLAG (uint32_t)0
+#ifndef __rtems__
/* External Variables */
const BOOT_DATA_T boot_data;
extern const uint8_t dcd_data[];
#endif
#endif /* __FLEXSPI_NOR_BOOT_H__ */
diff --git a/bsps/arm/imxrt/include/evkbimxrt1050_flexspi_nor_config.h b/bsps/arm/imxrt/include/fsl_flexspi_nor_config.h
similarity index 100%
rename from bsps/arm/imxrt/include/evkbimxrt1050_flexspi_nor_config.h
rename to bsps/arm/imxrt/include/fsl_flexspi_nor_config.h
diff --git a/bsps/arm/imxrt/include/fsl_lpuart.h b/bsps/arm/imxrt/include/fsl_lpuart.h
index 6ec3534c81..fcf203dcf4 100644
--- a/bsps/arm/imxrt/include/fsl_lpuart.h
+++ b/bsps/arm/imxrt/include/fsl_lpuart.h
@@ -315,7 +315,11 @@ static inline void LPUART_SoftwareReset(LPUART_Type *base)
* @retval kStatus_LPUART_BaudrateNotSupport Baudrate is not support in current clock source.
* @retval kStatus_Success LPUART initialize succeed
+#ifndef __rtems__
status_t LPUART_Init(LPUART_Type *base, const lpuart_config_t *config, uint32_t srcClock_Hz);
+#else /* __rtems__ */
+status_t LPUART_Init(LPUART_Type *base, const lpuart_config_t *config, uint32_t srcClock_Hz, bool do_reset);
* @brief Deinitializes a LPUART instance.
diff --git a/bsps/arm/imxrt/include/fsl_pin_mux.h b/bsps/arm/imxrt/include/fsl_pin_mux.h
index cb2ed43025..96e518412b 100644
--- a/bsps/arm/imxrt/include/fsl_pin_mux.h
+++ b/bsps/arm/imxrt/include/fsl_pin_mux.h
@@ -13,6 +13,10 @@
#ifndef _PIN_MUX_H_
#define _PIN_MUX_H_
+#ifdef __rtems__
+#include <bsp/start.h>
* Definitions
diff --git a/bsps/arm/imxrt/nxp/boards/evkbimxrt1050/clock_config.c b/bsps/arm/imxrt/nxp/boards/evkbimxrt1050/clock_config.c
index 2ed6638cbe..c23d5da356 100644
--- a/bsps/arm/imxrt/nxp/boards/evkbimxrt1050/clock_config.c
+++ b/bsps/arm/imxrt/nxp/boards/evkbimxrt1050/clock_config.c
@@ -30,7 +30,11 @@ processor_version: 0.0.0
board: IMXRT1050-EVKB
* BE CAREFUL MODIFYING THIS COMMENT - IT IS YAML SETTINGS FOR TOOLS **********/
+#ifndef __rtems__
#include "clock_config.h"
+#include "fsl_clock_config.h"
#include "fsl_iomuxc.h"
@@ -41,7 +45,11 @@ board: IMXRT1050-EVKB
* Variables
/* System clock frequency. */
+#ifndef __rtems__
extern uint32_t SystemCoreClock;
+uint32_t SystemCoreClock;
************************ BOARD_InitBootClocks function ************************
@@ -216,6 +224,7 @@ void BOARD_BootClockRUN(void)
CLOCK_SetDiv(kCLOCK_Usdhc2Div, 1);
/* Set Usdhc2 clock source. */
CLOCK_SetMux(kCLOCK_Usdhc2Mux, 0);
+#ifndef __rtems__
/* In SDK projects, SDRAM (configured by SEMC) will be initialized in either debug script or dcd.
* With this macro SKIP_SYSCLK_INIT, system pll (selected to be SEMC source clock in SDK projects) will be left
* unchanged.
@@ -242,6 +251,7 @@ void BOARD_BootClockRUN(void)
/* Set Flexspi clock source. */
CLOCK_SetMux(kCLOCK_FlexspiMux, 1);
#endif
/* Disable CSI clock gate. */
CLOCK_DisableClock(kCLOCK_Csi);
/* Set CSI_PODF. */
@@ -353,6 +363,7 @@ void BOARD_BootClockRUN(void)
CLOCK_SetMux(kCLOCK_Pll3SwMux, 0);
/* Init ARM PLL. */
CLOCK_InitArmPll(&armPllConfig_BOARD_BootClockRUN);
+#ifndef __rtems__
* unchanged. Note: If another clock source is selected for SEMC, user may want to avoid changing that clock as
@@ -389,6 +400,7 @@ void BOARD_BootClockRUN(void)
/* Disable Usb1 PLL output for USBPHY1. */
CCM_ANALOG->PLL_USB1 &= ~CCM_ANALOG_PLL_USB1_EN_USB_CLKS_MASK;
#endif
/* DeInit Audio PLL. */
CLOCK_DeinitAudioPll();
/* Bypass Audio PLL. */
diff --git a/bsps/arm/imxrt/nxp/boards/evkbimxrt1050/pin_mux.c b/bsps/arm/imxrt/nxp/boards/evkbimxrt1050/pin_mux.c
index 25ca313926..acb13cfdc2 100644
--- a/bsps/arm/imxrt/nxp/boards/evkbimxrt1050/pin_mux.c
+++ b/bsps/arm/imxrt/nxp/boards/evkbimxrt1050/pin_mux.c
@@ -270,6 +270,9 @@ BOARD_InitDEBUG_UARTPins:
* Description : Configures pin routing and optionally pin electrical features.
* END ****************************************************************************************************************/
+#ifdef __rtems__
+BSP_START_TEXT_SECTION
void BOARD_InitDEBUG_UARTPins(void) {
CLOCK_EnableClock(kCLOCK_Iomuxc); /* iomuxc clock (iomuxc_clk_enable): 0x03u */
@@ -355,6 +358,9 @@ BOARD_InitSDRAMPins:
+#ifdef __rtems__
void BOARD_InitSDRAMPins(void) {
diff --git a/bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_lpuart.c b/bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_lpuart.c
index 379fd8aec0..2f02aabe16 100644
--- a/bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_lpuart.c
+++ b/bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_lpuart.c
@@ -240,7 +240,11 @@ static void LPUART_ReadNonBlocking(LPUART_Type *base, uint8_t *data, size_t leng
* retval kStatus_LPUART_BaudrateNotSupport Baudrate is not support in current clock source.
* retval kStatus_Success LPUART initialize succeed
+#ifndef __rtems__
assert(NULL != config);
assert(0U < config->baudRate_Bps);
@@ -286,6 +290,7 @@ status_t LPUART_Init(LPUART_Type *base, const lpuart_config_t *config, uint32_t
+#ifndef __rtems__
/* Check to see if actual baud rate is within 3% of desired baud rate
* based on the best calculate OSR value */
if (baudDiff > ((config->baudRate_Bps / 100U) * 3U))
@@ -294,6 +299,12 @@ status_t LPUART_Init(LPUART_Type *base, const lpuart_config_t *config, uint32_t
status = kStatus_LPUART_BaudrateNotSupport;
else
+ * Better to have any baudrate then none. With this change, the function can
+ * not fail any more.
#if !(defined(FSL_SDK_DISABLE_DRIVER_CLOCK_CONTROL) && FSL_SDK_DISABLE_DRIVER_CLOCK_CONTROL)
@@ -309,7 +320,13 @@ status_t LPUART_Init(LPUART_Type *base, const lpuart_config_t *config, uint32_t
#if defined(FSL_FEATURE_LPUART_HAS_GLOBAL) && FSL_FEATURE_LPUART_HAS_GLOBAL
/*Reset all internal logic and registers, except the Global Register */
+#ifndef __rtems__
LPUART_SoftwareReset(base);
+ if (do_reset) {
+ LPUART_SoftwareReset(base);
#else
/* Disable LPUART TX RX before setting. */
base->CTRL &= ~(LPUART_CTRL_TE_MASK | LPUART_CTRL_RE_MASK);
2.26.2
