How do I skip over a portion on code while debugging with GDB
Tue Nov 17 18:41:09 UTC 2020
Use 'next' to step by instructions in program order ignoring their
control flow. This also will skip over function calls.
On Tue, Nov 17, 2020 at 8:54 AM Richi Dubey <richidubey at gmail.com> wrote:
> Hi,
> When I am trying to debug the tm24 test suite, there's some line of code that repeats the same code that creates a task around 100 times. Is there a way I can skip that code while debugging? Please let me know.
> Thanks,
> Richi.
> devel mailing list
> devel at rtems.org
