How do I skip over a portion on code while debugging with GDB
Tue Nov 17 19:13:38 UTC 2020
Next is good but setting a breakpoint at the line after the task create
loop
is probably the solution here. Or "next NUMBER" to next a number of times.
Many gdb commands take a number.
Another interesting option is using continue and break conditions. You
could
then continue until the loop counter is 99 or something.
https://sourceware.org/gdb/onlinedocs/gdb/Continuing-and-Stepping.html
On Tue, Nov 17, 2020 at 12:41 PM Gedare Bloom <gedare at rtems.org> wrote:
> Use 'next' to step by instructions in program order ignoring their
> control flow. This also will skip over function calls.
> On Tue, Nov 17, 2020 at 8:54 AM Richi Dubey <richidubey at gmail.com> wrote:
> > Hi,
> > When I am trying to debug the tm24 test suite, there's some line of code
> that repeats the same code that creates a task around 100 times. Is there a
> way I can skip that code while debugging? Please let me know.
> > Thanks,
> > Richi.
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201117/b3c8deab/attachment.html>
