[PATCH rtems v2 7/7] bsp/imxrt: Add new BSP
Christian Mauderer christian.mauderer at embedded-brains.de
Wed Nov 18 14:45:19 UTC 2020
Update #4180
 bsps/arm/imxrt/console/console.c              |  490 +++++++
 bsps/arm/imxrt/dts/imxrt1050-evkb.c           |  800 +++++++++++
 bsps/arm/imxrt/dts/imxrt1050-evkb.dts         |  410 ++++++
 bsps/arm/imxrt/i2c/imxrt-lpi2c.c              |  489 +++++++
 bsps/arm/imxrt/include/bsp.h                  |   93 ++
 bsps/arm/imxrt/include/bsp/flash-headers.h    |   63 +
 bsps/arm/imxrt/include/bsp/irq.h              |   54 +
 bsps/arm/imxrt/include/chip.h                 |    2 +
 .../imxrt/include/imxrt/imxrt1050-pinfunc.h   | 1236 +++++++++++++++++
 bsps/arm/imxrt/include/imxrt/memory.h         |   83 ++
 bsps/arm/imxrt/include/imxrt/start.h          |   54 +
 bsps/arm/imxrt/include/tm27.h                 |    1 +
 bsps/arm/imxrt/spi/imxrt-lpspi.c              |  533 +++++++
 bsps/arm/imxrt/start/bspstart.c               |  141 ++
 bsps/arm/imxrt/start/bspstarthooks.c          |   53 +
 bsps/arm/imxrt/start/flash-boot-data.c        |   37 +
 bsps/arm/imxrt/start/flash-config.c           |   60 +
 bsps/arm/imxrt/start/flash-dcd.c              |   38 +-
 bsps/arm/imxrt/start/flash-ivt.c              |   39 +
 bsps/arm/imxrt/start/imxrt-ffec-init.c        |   86 ++
 bsps/arm/imxrt/start/linkcmds.flexspi         |   35 +
 bsps/arm/imxrt/start/linkcmds.sdram           |   23 +
 bsps/arm/imxrt/start/mpu-config.c             |   75 +
 bsps/arm/shared/pins/imx_iomux.c              |    5 +
 bsps/include/bsp/fatal.h                      |   17 +-
 spec/build/bsps/arm/imxrt/abi.yml             |   20 +
 spec/build/bsps/arm/imxrt/bspimxrt.yml        |  250 ++++
 spec/build/bsps/arm/imxrt/linkcmds.yml        |   11 +
 spec/build/bsps/arm/imxrt/linkcmdsmemory.yml  |   67 +
 spec/build/bsps/arm/imxrt/optlinkcmds.yml     |   16 +
 .../build/bsps/arm/imxrt/optmemflashcfgsz.yml |   19 +
 .../build/bsps/arm/imxrt/optmemflashivtsz.yml |   18 +
 spec/build/bsps/arm/imxrt/optmemflexspisz.yml |   17 +
 spec/build/bsps/arm/imxrt/optmemnullsz.yml    |   17 +
 spec/build/bsps/arm/imxrt/optmemsdrambase.yml |   16 +
 .../bsps/arm/imxrt/optmemsdramnocachesz.yml   |   16 +
 spec/build/bsps/arm/imxrt/optmemsdramsz.yml   |   16 +
 37 files changed, 5364 insertions(+), 36 deletions(-)
 create mode 100644 bsps/arm/imxrt/console/console.c
 create mode 100644 bsps/arm/imxrt/dts/imxrt1050-evkb.c
 create mode 100644 bsps/arm/imxrt/dts/imxrt1050-evkb.dts
 create mode 100644 bsps/arm/imxrt/i2c/imxrt-lpi2c.c
 create mode 100644 bsps/arm/imxrt/include/bsp.h
 create mode 100644 bsps/arm/imxrt/include/bsp/flash-headers.h
 create mode 100644 bsps/arm/imxrt/include/bsp/irq.h
 create mode 100644 bsps/arm/imxrt/include/chip.h
 create mode 100644 bsps/arm/imxrt/include/imxrt/imxrt1050-pinfunc.h
 create mode 100644 bsps/arm/imxrt/include/imxrt/memory.h
 create mode 100644 bsps/arm/imxrt/include/imxrt/start.h
 create mode 100644 bsps/arm/imxrt/include/tm27.h
 create mode 100644 bsps/arm/imxrt/spi/imxrt-lpspi.c
 create mode 100644 bsps/arm/imxrt/start/bspstart.c
 create mode 100644 bsps/arm/imxrt/start/bspstarthooks.c
 create mode 100644 bsps/arm/imxrt/start/flash-boot-data.c
 create mode 100644 bsps/arm/imxrt/start/flash-config.c
 create mode 100644 bsps/arm/imxrt/start/flash-ivt.c
 create mode 100644 bsps/arm/imxrt/start/imxrt-ffec-init.c
 create mode 100644 bsps/arm/imxrt/start/linkcmds.flexspi
 create mode 100644 bsps/arm/imxrt/start/linkcmds.sdram
 create mode 100644 bsps/arm/imxrt/start/mpu-config.c
 create mode 100644 spec/build/bsps/arm/imxrt/abi.yml
 create mode 100644 spec/build/bsps/arm/imxrt/bspimxrt.yml
 create mode 100644 spec/build/bsps/arm/imxrt/linkcmds.yml
 create mode 100644 spec/build/bsps/arm/imxrt/linkcmdsmemory.yml
 create mode 100644 spec/build/bsps/arm/imxrt/optlinkcmds.yml
 create mode 100644 spec/build/bsps/arm/imxrt/optmemflashcfgsz.yml
 create mode 100644 spec/build/bsps/arm/imxrt/optmemflashivtsz.yml
 create mode 100644 spec/build/bsps/arm/imxrt/optmemflexspisz.yml
 create mode 100644 spec/build/bsps/arm/imxrt/optmemnullsz.yml
 create mode 100644 spec/build/bsps/arm/imxrt/optmemsdrambase.yml
 create mode 100644 spec/build/bsps/arm/imxrt/optmemsdramnocachesz.yml
 create mode 100644 spec/build/bsps/arm/imxrt/optmemsdramsz.yml
diff --git a/bsps/arm/imxrt/console/console.c b/bsps/arm/imxrt/console/console.c
new file mode 100644
index 0000000000..05320f2c4c
--- /dev/null
+++ b/bsps/arm/imxrt/console/console.c
@@ -0,0 +1,490 @@
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+#include <bsp.h>
+#include <bsp/fdt.h>
+#include <bsp/fatal.h>
+#include <bsp/irq.h>
+#include <rtems/bspIo.h>
+#include <rtems/console.h>
+#include <rtems/termiostypes.h>
+#include <inttypes.h>
+#include <libfdt.h>
+#include <stdio.h>
+#include <chip.h>
+#include <fsl_lpuart.h>
+#define LPUART_MAX_INSTANCES 8
+#define LPUART_DATA_RT (LPUART_DATA_R0T0_MASK | LPUART_DATA_R1T1_MASK | \
+                        LPUART_DATA_R2T2_MASK | LPUART_DATA_R3T3_MASK | \
+                        LPUART_DATA_R4T4_MASK | LPUART_DATA_R5T5_MASK | \
+                        LPUART_DATA_R6T6_MASK | LPUART_DATA_R7T7_MASK | \
+                        LPUART_DATA_R8T8_MASK | LPUART_DATA_R9T9_MASK)
+typedef struct {
+  rtems_termios_device_context base;
+  volatile LPUART_Type *regs;
+  rtems_vector_number irq;
+  const char *path;
+  uint32_t src_clock_hz;
+  lpuart_config_t config;
+} imxrt_lpuart_context;
+/* Static memory for the console UART because it might is initialized early. */
+static imxrt_lpuart_context imxrt_lpuart_console_instance;
+static imxrt_lpuart_context *imxrt_lpuart_console;
+static void imxrt_output_char(char c);
+static int imxrt_poll_char(void);
+static imxrt_lpuart_context *imxrt_lpuart_get_context(
+  rtems_termios_device_context *base
+  return RTEMS_CONTAINER_OF(base, imxrt_lpuart_context, base);
+static void imxrt_lpuart_write_polled(
+    rtems_termios_device_context *base,
+    char c
+  imxrt_lpuart_context *ctx = imxrt_lpuart_get_context(base);
+  volatile LPUART_Type *regs = ctx->regs;
+  rtems_interrupt_level isr_cookie;
+  uint32_t ctrl;
+  rtems_interrupt_disable(isr_cookie);
+  ctrl = ctx->regs->CTRL;
+  ctx->regs->CTRL = ctrl & ~LPUART_CTRL_TIE_MASK;
+  rtems_interrupt_enable(isr_cookie);
+  while ((regs->STAT & LPUART_STAT_TDRE_MASK) == 0) {
+    /* Wait */
+  regs->DATA = c;
+  if ((ctrl & LPUART_CTRL_TIE_MASK) != 0) {
+    ctx->regs->CTRL |= LPUART_CTRL_TIE_MASK;
+static int imxrt_lpuart_read_polled(rtems_termios_device_context *base)
+  uint32_t data;
+  data = regs->DATA;
+  if ( data & (LPUART_DATA_PARITYE_MASK | LPUART_DATA_FRETSC_MASK |
+      LPUART_DATA_RXEMPT_MASK) ) {
+    return -1;
+  } else {
+    return data & LPUART_DATA_RT;
+static bool imxrt_lpuart_set_attributes(
+  const struct termios *term
+  switch (term->c_cflag & CSIZE) {
+    case CS7:
+      ctx->config.dataBitsCount = kLPUART_SevenDataBits;
+      break;
+    case CS8:
+      ctx->config.dataBitsCount = kLPUART_EightDataBits;
+      break;
+    default:
+      return false;
+      break;
+  ctx->config.baudRate_Bps = rtems_termios_baud_to_number(term->c_ospeed);
+  if ((term->c_cflag & CSTOPB) != 0) {
+    ctx->config.stopBitCount = kLPUART_TwoStopBit;
+  } else {
+    ctx->config.stopBitCount = kLPUART_OneStopBit;
+  if ((term->c_cflag & PARENB) != 0) {
+    if ((term->c_cflag & PARODD) != 0) {
+      ctx->config.parityMode = kLPUART_ParityOdd;
+    } else {
+      ctx->config.parityMode = kLPUART_ParityEven;
+  } else {
+    ctx->config.parityMode = kLPUART_ParityDisabled;
+  if ((term->c_cflag & CREAD) != 0) {
+    ctx->config.enableRx = true;
+  } else {
+    ctx->config.enableRx = false;
+  if ((term->c_cflag & CCTS_OFLOW) != 0) {
+    ctx->config.enableTxCTS = true;
+  } else {
+    ctx->config.enableTxCTS = false;
+  if ((term->c_cflag & CRTS_IFLOW) != 0) {
+    ctx->config.enableRxRTS = true;
+  } else {
+    ctx->config.enableRxRTS = false;
+  (void) LPUART_Init((LPUART_Type *)ctx->regs, &ctx->config,
+      ctx->src_clock_hz, false);
+  return true;
+static uint32_t imxrt_lpuart_get_src_freq(void)
+  uint32_t freq;
+  uint32_t mux;
+  uint32_t divider;
+  mux = CLOCK_GetMux(kCLOCK_UartMux);
+  divider = 1;
+  switch (mux) {
+  case 0: /* pll3_sw_clk */
+    freq = CLOCK_GetFreq(kCLOCK_Usb1PllClk);
+    divider = 6;
+    break;
+  case 1: /* OSC */
+    freq = CLOCK_GetFreq(kCLOCK_OscClk);
+    break;
+  default:
+    freq = 0;
+  divider *= CLOCK_GetDiv(kCLOCK_UartDiv) + 1U;
+  freq /= divider;
+  return freq;
+static void imxrt_lpuart_init_hardware(imxrt_lpuart_context *ctx)
+      ctx->src_clock_hz, true);
+#ifdef BSP_CONSOLE_USE_INTERRUPTS
+static void imxrt_lpuart_interrupt(void *arg)
+  rtems_termios_tty *tty = arg;
+  rtems_termios_device_context *base = rtems_termios_get_device_context(tty);
+  uint32_t stat;
+  uint32_t data;
+  stat = ctx->regs->STAT;
+  if ((stat & LPUART_STAT_RDRF_MASK) != 0) {
+    do {
+      char c;
+      data = ctx->regs->DATA;
+      if ((data & (LPUART_DATA_PARITYE_MASK | LPUART_DATA_FRETSC_MASK |
+          LPUART_DATA_RXEMPT_MASK)) == 0) {
+        c = data & LPUART_DATA_RT;
+        rtems_termios_enqueue_raw_characters(tty, &c, 1);
+    } while ((data & LPUART_DATA_RXEMPT_MASK) == 0);
+  if ((ctx->regs->CTRL & LPUART_CTRL_TIE_MASK) != 0
+      && (stat & LPUART_STAT_TDRE_MASK) != 0) {
+    /* Note: This will call imxrt_lpuart_write */
+    rtems_termios_dequeue_characters(tty, 1);
+#endif
+static bool imxrt_lpuart_first_open(
+  rtems_termios_tty *tty,
+  struct termios *term,
+  rtems_libio_open_close_args_t *args
+  rtems_status_code sc;
+#endif
+  rtems_termios_set_initial_baud(tty, BSP_CONSOLE_BAUD);
+  sc = rtems_interrupt_handler_install(
+    ctx->irq,
+    "LPUART",
+    RTEMS_INTERRUPT_SHARED,
+    imxrt_lpuart_interrupt,
+    tty
+  if (sc != RTEMS_SUCCESSFUL) {
+    return false;
+#endif
+  imxrt_lpuart_init_hardware(ctx);
+  ctx->regs->CTRL |= LPUART_CTRL_RIE_MASK;
+#endif
+  imxrt_lpuart_set_attributes(base, term);
+  return true;
+static void imxrt_lpuart_last_close(
+  LPUART_Deinit((LPUART_Type *)ctx->regs);
+  (void) rtems_interrupt_handler_remove(
+    ctx->irq,
+    tty
+#endif
+static void imxrt_lpuart_write(
+  const char *buf,
+  size_t len
+  if (len > 0) {
+    ctx->regs->DATA = (uint8_t) buf[0];
+  } else {
+    ctx->regs->CTRL &= ~LPUART_CTRL_TIE_MASK;
+#else
+  size_t i;
+  for (i = 0; i < len; ++i) {
+    imxrt_lpuart_write_polled(base, buf[i]);
+#endif
+static const rtems_termios_device_handler imxrt_lpuart_handler = {
+  .first_open = imxrt_lpuart_first_open,
+  .last_close = imxrt_lpuart_last_close,
+  .write = imxrt_lpuart_write,
+  .set_attributes = imxrt_lpuart_set_attributes,
+  .mode = TERMIOS_IRQ_DRIVEN,
+#else
+  .poll_read = imxrt_lpuart_read_polled,
+  .mode = TERMIOS_POLLED,
+#endif
+static int imxrt_lpuart_get_stdout_node(const void *fdt)
+  int node;
+  const char *console;
+  node = fdt_path_offset(fdt, "/chosen");
+  if (node < 0) {
+    bsp_fatal(IMXRT_FATAL_NO_CONSOLE);
+  console = fdt_getprop(fdt, node, "stdout-path", NULL);
+  if (console == NULL) {
+  node = fdt_path_offset(fdt, console);
+  if (node < 0) {
+  return node;
+static void imxrt_lpuart_init_context_from_fdt(
+  imxrt_lpuart_context *ctx,
+  const void *fdt,
+  int node
+  memset(&ctx->base, 0, sizeof(ctx->base));
+  ctx->regs = imx_get_reg_of_node(fdt, node);
+  if (ctx->regs == NULL) {
+    bsp_fatal(IMXRT_FATAL_LPUART_INVALID_FDT);
+  ctx->irq = imx_get_irq_of_node(fdt, node, 0);
+  if (ctx->irq == BSP_INTERRUPT_VECTOR_INVALID) {
+  ctx->path = fdt_getprop(fdt, node, "rtems,path", NULL);
+  if (ctx->path == NULL) {
+    bsp_fatal(IMXRT_FATAL_LPI2C_INVALID_FDT);
+  ctx->src_clock_hz = imxrt_lpuart_get_src_freq();
+  LPUART_GetDefaultConfig(&ctx->config);
+  ctx->config.enableTx = true;
+  rtems_termios_device_context_initialize(&ctx->base, "LPUART");
+static void imxrt_lpuart_console_probe_early(void)
+  int node;
+  const void *fdt;
+  imxrt_lpuart_console = NULL;
+  fdt = bsp_fdt_get();
+  node = imxrt_lpuart_get_stdout_node(fdt);
+  imxrt_lpuart_init_context_from_fdt(&imxrt_lpuart_console_instance, fdt, node);
+    (LPUART_Type *)imxrt_lpuart_console_instance.regs,
+    &imxrt_lpuart_console_instance.config,
+    imxrt_lpuart_console_instance.src_clock_hz,
+    true
+  imxrt_lpuart_console = &imxrt_lpuart_console_instance;
+  BSP_output_char = imxrt_output_char;
+  BSP_poll_char = imxrt_poll_char;
+rtems_status_code console_initialize(
+  rtems_device_major_number major,
+  rtems_device_minor_number minor,
+  void *arg
+  const void *fdt;
+  int stdout_node;
+  int node;
+  stdout_node = imxrt_lpuart_get_stdout_node(fdt);
+  node = -1;
+  rtems_termios_initialize();
+  do {
+    node = fdt_node_offset_by_compatible(fdt, node, "nxp,imxrt-lpuart");
+    if (node >= 0 && imxrt_fdt_node_is_enabled(fdt, node)) {
+      imxrt_lpuart_context *ctx;
+      if (node != stdout_node) {
+        ctx = calloc(1, sizeof(imxrt_lpuart_context));
+        if (ctx == NULL) {
+          bsp_fatal(IMXRT_FATAL_LPUART_ALLOC_FAILED);
+        imxrt_lpuart_init_context_from_fdt(ctx, fdt, node);
+      } else {
+        ctx = imxrt_lpuart_console;
+          imxrt_lpuart_console_probe_early();
+      sc = rtems_termios_device_install(
+        ctx->path,
+        &imxrt_lpuart_handler,
+        NULL,
+        &ctx->base
+        bsp_fatal(IMXRT_FATAL_LPUART_INSTALL_FAILED);
+      if (node == stdout_node) {
+        link(ctx->path, CONSOLE_DEVICE_NAME);
+  } while (node >= 0);
+  return RTEMS_SUCCESSFUL;
+  if (imxrt_lpuart_console != NULL) {
+    imxrt_lpuart_write_polled(&imxrt_lpuart_console->base, c);
+  return imxrt_lpuart_read_polled(&imxrt_lpuart_console->base);
+static void imxrt_output_char_init(char c)
+  imxrt_output_char(c);
+BSP_output_char_function_type BSP_output_char = imxrt_output_char_init;
+BSP_polling_getchar_function_type BSP_poll_char = NULL;
diff --git a/bsps/arm/imxrt/dts/imxrt1050-evkb.c b/bsps/arm/imxrt/dts/imxrt1050-evkb.c
index 0000000000..b97337b264
--- /dev/null
+++ b/bsps/arm/imxrt/dts/imxrt1050-evkb.c
@@ -0,0 +1,800 @@
+ *  Declarations for C structure representing binary file imxrt_dtb
+ *  WARNING: Automatically generated -- do not edit!
+#include <sys/types.h>
+const unsigned char imxrt_dtb[] = {
+  0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x24, 0xeb, 0x00, 0x00, 0x00, 0x38,
+  0x00, 0x00, 0x1e, 0xc8, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x11,
+  0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x23,
+  0x00, 0x00, 0x1e, 0x90, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x01,
+  0x00, 0x00, 0x00, 0x01, 0x63, 0x68, 0x6f, 0x73, 0x65, 0x6e, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x25, 0x00, 0x00, 0x00, 0x1b,
+  0x2f, 0x73, 0x6f, 0x63, 0x2f, 0x61, 0x69, 0x70, 0x73, 0x2d, 0x62, 0x75,
+  0x73, 0x40, 0x34, 0x30, 0x31, 0x30, 0x30, 0x30, 0x30, 0x30, 0x2f, 0x75,
+  0x61, 0x72, 0x74, 0x40, 0x34, 0x30, 0x31, 0x38, 0x34, 0x30, 0x30, 0x30,
+  0x00, 0x00, 0x00, 0x27, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x01, 0x61, 0x6c, 0x69, 0x61, 0x73, 0x65, 0x73, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x25, 0x00, 0x00, 0x00, 0x2f,
+  0x73, 0x40, 0x34, 0x30, 0x31, 0x30, 0x30, 0x30, 0x30, 0x30, 0x2f, 0x67,
+  0x70, 0x69, 0x6f, 0x40, 0x34, 0x30, 0x31, 0x62, 0x38, 0x30, 0x30, 0x30,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x25,
+  0x00, 0x00, 0x00, 0x35, 0x2f, 0x73, 0x6f, 0x63, 0x2f, 0x61, 0x69, 0x70,
+  0x73, 0x2d, 0x62, 0x75, 0x73, 0x40, 0x34, 0x30, 0x31, 0x30, 0x30, 0x30,
+  0x30, 0x30, 0x2f, 0x67, 0x70, 0x69, 0x6f, 0x40, 0x34, 0x30, 0x31, 0x62,
+  0x63, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x25, 0x00, 0x00, 0x00, 0x3b, 0x2f, 0x73, 0x6f, 0x63,
+  0x2f, 0x61, 0x69, 0x70, 0x73, 0x2d, 0x62, 0x75, 0x73, 0x40, 0x34, 0x30,
+  0x31, 0x30, 0x30, 0x30, 0x30, 0x30, 0x2f, 0x67, 0x70, 0x69, 0x6f, 0x40,
+  0x34, 0x30, 0x31, 0x63, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x25, 0x00, 0x00, 0x00, 0x41,
+  0x70, 0x69, 0x6f, 0x40, 0x34, 0x30, 0x31, 0x63, 0x34, 0x30, 0x30, 0x30,
+  0x00, 0x00, 0x00, 0x47, 0x2f, 0x73, 0x6f, 0x63, 0x2f, 0x61, 0x69, 0x70,
+  0x73, 0x2d, 0x62, 0x75, 0x73, 0x40, 0x34, 0x30, 0x30, 0x30, 0x30, 0x30,
+  0x30, 0x30, 0x2f, 0x67, 0x70, 0x69, 0x6f, 0x40, 0x34, 0x30, 0x30, 0x63,
+  0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x01, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70,
+  0x74, 0x2d, 0x63, 0x6f, 0x6e, 0x74, 0x72, 0x6f, 0x6c, 0x6c, 0x65, 0x72,
+  0x40, 0x65, 0x30, 0x30, 0x30, 0x65, 0x31, 0x30, 0x30, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x4d,
+  0x61, 0x72, 0x6d, 0x2c, 0x61, 0x72, 0x6d, 0x76, 0x37, 0x6d, 0x2d, 0x6e,
+  0x76, 0x69, 0x63, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x58, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x6d, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x7e, 0xe0, 0x00, 0xe1, 0x00,
+  0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x27, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x01, 0x74, 0x69, 0x6d, 0x65, 0x72, 0x40, 0x65, 0x30,
+  0x30, 0x30, 0x65, 0x30, 0x31, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x13, 0x00, 0x00, 0x00, 0x4d, 0x61, 0x72, 0x6d, 0x2c,
+  0x61, 0x72, 0x6d, 0x76, 0x37, 0x6d, 0x2d, 0x73, 0x79, 0x73, 0x74, 0x69,
+  0x63, 0x6b, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
+  0x00, 0x00, 0x00, 0x7e, 0xe0, 0x00, 0xe0, 0x10, 0x00, 0x00, 0x00, 0x10,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x82,
+  0x64, 0x69, 0x73, 0x61, 0x62, 0x6c, 0x65, 0x64, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x27,
+  0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+  0x73, 0x6f, 0x63, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0b,
+  0x00, 0x00, 0x00, 0x4d, 0x73, 0x69, 0x6d, 0x70, 0x6c, 0x65, 0x2d, 0x62,
+  0x75, 0x73, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x89,
+  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x9a, 0x00, 0x00, 0x00, 0x01, 0x61, 0x69, 0x70, 0x73,
+  0x2d, 0x62, 0x75, 0x73, 0x40, 0x34, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30,
+  0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x18,
+  0x00, 0x00, 0x00, 0x4d, 0x66, 0x73, 0x6c, 0x2c, 0x61, 0x69, 0x70, 0x73,
+  0x2d, 0x62, 0x75, 0x73, 0x00, 0x73, 0x69, 0x6d, 0x70, 0x6c, 0x65, 0x2d,
+  0x62, 0x75, 0x73, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x7e,
+  0x40, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x9a, 0x00, 0x00, 0x00, 0x01,
+  0x67, 0x70, 0x69, 0x6f, 0x40, 0x34, 0x30, 0x30, 0x63, 0x30, 0x30, 0x30,
+  0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x2e,
+  0x00, 0x00, 0x00, 0x4d, 0x66, 0x73, 0x6c, 0x2c, 0x69, 0x6d, 0x78, 0x72,
+  0x74, 0x2d, 0x67, 0x70, 0x69, 0x6f, 0x00, 0x66, 0x73, 0x6c, 0x2c, 0x69,
+  0x6d, 0x78, 0x36, 0x75, 0x6c, 0x2d, 0x67, 0x70, 0x69, 0x6f, 0x00, 0x66,
+  0x73, 0x6c, 0x2c, 0x69, 0x6d, 0x78, 0x33, 0x35, 0x2d, 0x67, 0x70, 0x69,
+  0x6f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
+  0x00, 0x00, 0x00, 0x7e, 0x40, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0xa1,
+  0x00, 0x00, 0x00, 0x58, 0x00, 0x00, 0x00, 0x59, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xac, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xbc, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x58,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x6d,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x27, 0x00, 0x00, 0x00, 0x0a, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x61, 0x69, 0x70, 0x73,
+  0x2d, 0x62, 0x75, 0x73, 0x40, 0x34, 0x30, 0x31, 0x30, 0x30, 0x30, 0x30,
+  0x40, 0x10, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x67, 0x70, 0x69, 0x6f, 0x40, 0x34, 0x30, 0x31, 0x63, 0x34, 0x30, 0x30,
+  0x00, 0x00, 0x00, 0x7e, 0x40, 0x1c, 0x40, 0x00, 0x00, 0x00, 0x40, 0x00,
+  0x00, 0x00, 0x00, 0x56, 0x00, 0x00, 0x00, 0x57, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x27, 0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x01, 0x67, 0x70, 0x69, 0x6f, 0x40, 0x34, 0x30, 0x31,
+  0x63, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x2e, 0x00, 0x00, 0x00, 0x4d, 0x66, 0x73, 0x6c, 0x2c,
+  0x69, 0x6d, 0x78, 0x72, 0x74, 0x2d, 0x67, 0x70, 0x69, 0x6f, 0x00, 0x66,
+  0x73, 0x6c, 0x2c, 0x69, 0x6d, 0x78, 0x36, 0x75, 0x6c, 0x2d, 0x67, 0x70,
+  0x69, 0x6f, 0x00, 0x66, 0x73, 0x6c, 0x2c, 0x69, 0x6d, 0x78, 0x33, 0x35,
+  0x2d, 0x67, 0x70, 0x69, 0x6f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x7e, 0x40, 0x1c, 0x00, 0x00,
+  0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
+  0x00, 0x00, 0x00, 0xa1, 0x00, 0x00, 0x00, 0x54, 0x00, 0x00, 0x00, 0x55,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xac,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xbc,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x6d, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x27, 0x00, 0x00, 0x00, 0x0c,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x67, 0x70, 0x69, 0x6f,
+  0x40, 0x34, 0x30, 0x31, 0x62, 0x63, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x2e, 0x00, 0x00, 0x00, 0x4d,
+  0x66, 0x73, 0x6c, 0x2c, 0x69, 0x6d, 0x78, 0x72, 0x74, 0x2d, 0x67, 0x70,
+  0x69, 0x6f, 0x00, 0x66, 0x73, 0x6c, 0x2c, 0x69, 0x6d, 0x78, 0x36, 0x75,
+  0x6c, 0x2d, 0x67, 0x70, 0x69, 0x6f, 0x00, 0x66, 0x73, 0x6c, 0x2c, 0x69,
+  0x6d, 0x78, 0x33, 0x35, 0x2d, 0x67, 0x70, 0x69, 0x6f, 0x00, 0x00, 0x00,
+  0x40, 0x1b, 0xc0, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0xa1, 0x00, 0x00, 0x00, 0x52,
+  0x00, 0x00, 0x00, 0x53, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0xac, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0xbc, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x58, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x6d, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x0d, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+  0x67, 0x70, 0x69, 0x6f, 0x40, 0x34, 0x30, 0x31, 0x62, 0x38, 0x30, 0x30,
+  0x00, 0x00, 0x00, 0x7e, 0x40, 0x1b, 0x80, 0x00, 0x00, 0x00, 0x40, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0xa1,
+  0x00, 0x00, 0x00, 0x50, 0x00, 0x00, 0x00, 0x51, 0x00, 0x00, 0x00, 0x48,
+  0x00, 0x00, 0x00, 0x49, 0x00, 0x00, 0x00, 0x4a, 0x00, 0x00, 0x00, 0x4b,
+  0x00, 0x00, 0x00, 0x4c, 0x00, 0x00, 0x00, 0x4d, 0x00, 0x00, 0x00, 0x4e,
+  0x00, 0x00, 0x00, 0x4f, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+  0x75, 0x61, 0x72, 0x74, 0x40, 0x34, 0x30, 0x31, 0x38, 0x34, 0x30, 0x30,
+  0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x11,
+  0x00, 0x00, 0x00, 0x4d, 0x6e, 0x78, 0x70, 0x2c, 0x69, 0x6d, 0x78, 0x72,
+  0x74, 0x2d, 0x6c, 0x70, 0x75, 0x61, 0x72, 0x74, 0x00, 0x00, 0x00, 0x00,
+  0x40, 0x18, 0x40, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xa1, 0x00, 0x00, 0x00, 0x14,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x82,
+  0x6f, 0x6b, 0x61, 0x79, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x00, 0xc8, 0x2f, 0x64, 0x65, 0x76,
+  0x2f, 0x74, 0x74, 0x79, 0x53, 0x31, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xd3, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+  0x75, 0x61, 0x72, 0x74, 0x40, 0x34, 0x30, 0x31, 0x38, 0x38, 0x30, 0x30,
+  0x40, 0x18, 0x80, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xa1, 0x00, 0x00, 0x00, 0x15,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x00, 0xc8,
+  0x2f, 0x64, 0x65, 0x76, 0x2f, 0x74, 0x74, 0x79, 0x53, 0x32, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+  0x75, 0x61, 0x72, 0x74, 0x40, 0x34, 0x30, 0x31, 0x38, 0x63, 0x30, 0x30,
+  0x40, 0x18, 0xc0, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xa1, 0x00, 0x00, 0x00, 0x16,
+  0x2f, 0x74, 0x74, 0x79, 0x53, 0x33, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xd3, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+  0x75, 0x61, 0x72, 0x74, 0x40, 0x34, 0x30, 0x31, 0x39, 0x30, 0x30, 0x30,
+  0x40, 0x19, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xa1, 0x00, 0x00, 0x00, 0x17,
+  0x2f, 0x64, 0x65, 0x76, 0x2f, 0x74, 0x74, 0x79, 0x53, 0x34, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x11, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+  0x75, 0x61, 0x72, 0x74, 0x40, 0x34, 0x30, 0x31, 0x39, 0x34, 0x30, 0x30,
+  0x40, 0x19, 0x40, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xa1, 0x00, 0x00, 0x00, 0x18,
+  0x2f, 0x64, 0x65, 0x76, 0x2f, 0x74, 0x74, 0x79, 0x53, 0x35, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x12, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+  0x75, 0x61, 0x72, 0x74, 0x40, 0x34, 0x30, 0x31, 0x39, 0x38, 0x30, 0x30,
+  0x40, 0x19, 0x80, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xa1, 0x00, 0x00, 0x00, 0x19,
+  0x2f, 0x64, 0x65, 0x76, 0x2f, 0x74, 0x74, 0x79, 0x53, 0x36, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x13, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+  0x75, 0x61, 0x72, 0x74, 0x40, 0x34, 0x30, 0x31, 0x39, 0x63, 0x30, 0x30,
+  0x40, 0x19, 0xc0, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xa1, 0x00, 0x00, 0x00, 0x1a,
+  0x2f, 0x64, 0x65, 0x76, 0x2f, 0x74, 0x74, 0x79, 0x53, 0x37, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x14, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+  0x75, 0x61, 0x72, 0x74, 0x40, 0x34, 0x30, 0x31, 0x61, 0x30, 0x30, 0x30,
+  0x40, 0x1a, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xa1, 0x00, 0x00, 0x00, 0x1b,
+  0x2f, 0x64, 0x65, 0x76, 0x2f, 0x74, 0x74, 0x79, 0x53, 0x38, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x15, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+  0x70, 0x69, 0x6e, 0x63, 0x74, 0x72, 0x6c, 0x40, 0x34, 0x30, 0x31, 0x66,
+  0x38, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x15, 0x00, 0x00, 0x00, 0x4d, 0x6e, 0x78, 0x70, 0x2c,
+  0x69, 0x6d, 0x78, 0x72, 0x74, 0x31, 0x30, 0x35, 0x30, 0x2d, 0x69, 0x6f,
+  0x6d, 0x75, 0x78, 0x63, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x7e, 0x40, 0x1f, 0x80, 0x00,
+  0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x27, 0x00, 0x00, 0x00, 0x16, 0x00, 0x00, 0x00, 0x01,
+  0x6c, 0x70, 0x75, 0x61, 0x72, 0x74, 0x31, 0x67, 0x72, 0x70, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0xdd,
+  0x00, 0x00, 0x00, 0xec, 0x00, 0x00, 0x02, 0xdc, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08,
+  0x00, 0x00, 0x00, 0xf0, 0x00, 0x00, 0x02, 0xe0, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x30, 0x00,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+  0x6c, 0x70, 0x75, 0x61, 0x72, 0x74, 0x33, 0x67, 0x72, 0x70, 0x00, 0x00,
+  0x00, 0x00, 0x01, 0x14, 0x00, 0x00, 0x03, 0x04, 0x00, 0x00, 0x05, 0x3c,
+  0x00, 0x00, 0x01, 0x18, 0x00, 0x00, 0x03, 0x08, 0x00, 0x00, 0x05, 0x38,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+  0x6c, 0x70, 0x73, 0x70, 0x69, 0x31, 0x67, 0x72, 0x70, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x60, 0x00, 0x00, 0x00, 0xdd,
+  0x00, 0x00, 0x01, 0xc0, 0x00, 0x00, 0x03, 0xb0, 0x00, 0x00, 0x04, 0xec,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08,
+  0x00, 0x00, 0x01, 0xc4, 0x00, 0x00, 0x03, 0xb4, 0x00, 0x00, 0x04, 0xf8,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x08,
+  0x00, 0x00, 0x01, 0xc8, 0x00, 0x00, 0x03, 0xb8, 0x00, 0x00, 0x04, 0xf4,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x01, 0x00, 0x01, 0xb0, 0x00,
+  0x00, 0x00, 0x01, 0xbc, 0x00, 0x00, 0x03, 0xac, 0x00, 0x00, 0x04, 0xf0,
+  0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+  0x6c, 0x70, 0x69, 0x32, 0x63, 0x31, 0x67, 0x72, 0x70, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0xfc, 0x00, 0x00, 0x02, 0xec, 0x00, 0x00, 0x04, 0xcc,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x01, 0x40, 0x00, 0xf8, 0x30,
+  0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x02, 0xf0, 0x00, 0x00, 0x04, 0xd0,
+  0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+  0x66, 0x65, 0x63, 0x31, 0x67, 0x72, 0x70, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x01, 0x20, 0x00, 0x00, 0x00, 0xdd, 0x00, 0x00, 0x00, 0xb8,
+  0x00, 0x00, 0x02, 0xa8, 0x00, 0x00, 0x04, 0x30, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0xb8, 0x29, 0x00, 0x00, 0x00, 0xb4,
+  0x00, 0x00, 0x02, 0xa4, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xb0, 0xe9, 0x00, 0x00, 0x01, 0x8c,
+  0x00, 0x00, 0x03, 0x7c, 0x00, 0x00, 0x04, 0x34, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0xb0, 0xe9, 0x00, 0x00, 0x01, 0x90,
+  0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x04, 0x38, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0xb0, 0xe9, 0x00, 0x00, 0x01, 0x94,
+  0x00, 0x00, 0x03, 0x84, 0x00, 0x00, 0x04, 0x3c, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0xb0, 0xe9, 0x00, 0x00, 0x01, 0x98,
+  0x00, 0x00, 0x03, 0x88, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xb0, 0xe9, 0x00, 0x00, 0x01, 0x9c,
+  0x00, 0x00, 0x03, 0x8c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xb0, 0xe9, 0x00, 0x00, 0x01, 0xa0,
+  0x00, 0x00, 0x03, 0x90, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xb0, 0xe9, 0x00, 0x00, 0x01, 0xa4,
+  0x00, 0x00, 0x03, 0x94, 0x00, 0x00, 0x04, 0x2c, 0x00, 0x00, 0x00, 0x06,
+  0x00, 0x00, 0x00, 0x01, 0x40, 0x00, 0x00, 0x31, 0x00, 0x00, 0x01, 0xa8,
+  0x00, 0x00, 0x03, 0x98, 0x00, 0x00, 0x04, 0x40, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0xb0, 0xe9, 0x00, 0x00, 0x00, 0xe0,
+  0x00, 0x00, 0x02, 0xd0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x10, 0x00, 0x00, 0x00, 0xe4,
+  0x00, 0x00, 0x02, 0xd4, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xb0, 0xa9, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x27, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x01, 0x61, 0x69, 0x70, 0x73, 0x2d, 0x62, 0x75, 0x73,
+  0x40, 0x34, 0x30, 0x32, 0x30, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x4d,
+  0x66, 0x73, 0x6c, 0x2c, 0x61, 0x69, 0x70, 0x73, 0x2d, 0x62, 0x75, 0x73,
+  0x00, 0x73, 0x69, 0x6d, 0x70, 0x6c, 0x65, 0x2d, 0x62, 0x75, 0x73, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x7e, 0x40, 0x20, 0x00, 0x00,
+  0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x9a, 0x00, 0x00, 0x00, 0x01, 0x65, 0x74, 0x68, 0x65,
+  0x72, 0x6e, 0x65, 0x74, 0x40, 0x34, 0x30, 0x32, 0x64, 0x38, 0x30, 0x30,
+  0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x1d,
+  0x74, 0x2d, 0x66, 0x65, 0x63, 0x00, 0x66, 0x73, 0x6c, 0x2c, 0x69, 0x6d,
+  0x78, 0x36, 0x75, 0x6c, 0x2d, 0x66, 0x65, 0x63, 0x00, 0x00, 0x00, 0x00,
+  0x40, 0x2d, 0x80, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0xe6, 0x69, 0x6e, 0x74, 0x30,
+  0x00, 0x70, 0x70, 0x73, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0xa1, 0x00, 0x00, 0x00, 0x72,
+  0x00, 0x00, 0x00, 0x73, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0xf6, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0x08, 0x00, 0x00, 0x00, 0x01,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x01, 0x1a,
+  0x72, 0x6d, 0x69, 0x69, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x82, 0x6f, 0x6b, 0x61, 0x79,
+  0x00, 0x00, 0x00, 0xd3, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x01, 0x23, 0x00, 0x00, 0x00, 0x05,
+  0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x01, 0x33, 0x00, 0x00, 0x00, 0x05,
+  0x00, 0x00, 0x00, 0x0a, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x27, 0x00, 0x00, 0x00, 0x17,
+  0x61, 0x69, 0x70, 0x73, 0x2d, 0x62, 0x75, 0x73, 0x40, 0x34, 0x30, 0x33,
+  0x30, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x4d, 0x66, 0x73, 0x6c, 0x2c,
+  0x61, 0x69, 0x70, 0x73, 0x2d, 0x62, 0x75, 0x73, 0x00, 0x73, 0x69, 0x6d,
+  0x70, 0x6c, 0x65, 0x2d, 0x62, 0x75, 0x73, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x0f,
+  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
+  0x00, 0x00, 0x00, 0x7e, 0x40, 0x30, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x9a,
+  0x00, 0x00, 0x00, 0x01, 0x6c, 0x70, 0x73, 0x70, 0x69, 0x40, 0x34, 0x30,
+  0x33, 0x39, 0x34, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10,
+  0x74, 0x2d, 0x6c, 0x70, 0x73, 0x70, 0x69, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x7e, 0x40, 0x39, 0x40, 0x00,
+  0x00, 0x00, 0x00, 0xa1, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0a,
+  0x00, 0x00, 0x00, 0xc8, 0x2f, 0x64, 0x65, 0x76, 0x2f, 0x73, 0x70, 0x69,
+  0x31, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0xd3, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x27, 0x00, 0x00, 0x00, 0x18,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x6c, 0x70, 0x73, 0x70,
+  0x69, 0x40, 0x34, 0x30, 0x33, 0x39, 0x38, 0x30, 0x30, 0x30, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x4d, 0x6e, 0x78, 0x70, 0x2c,
+  0x69, 0x6d, 0x78, 0x72, 0x74, 0x2d, 0x6c, 0x70, 0x73, 0x70, 0x69, 0x00,
+  0x40, 0x39, 0x80, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xa1, 0x00, 0x00, 0x00, 0x21,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0a, 0x00, 0x00, 0x00, 0xc8,
+  0x2f, 0x64, 0x65, 0x76, 0x2f, 0x73, 0x70, 0x69, 0x32, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x19, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+  0x6c, 0x70, 0x73, 0x70, 0x69, 0x40, 0x34, 0x30, 0x33, 0x39, 0x63, 0x30,
+  0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x00,
+  0x6e, 0x78, 0x70, 0x2c, 0x69, 0x6d, 0x78, 0x72, 0x74, 0x2d, 0x6c, 0x70,
+  0x73, 0x70, 0x69, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
+  0x00, 0x00, 0x00, 0x7e, 0x40, 0x39, 0xc0, 0x00, 0x00, 0x00, 0x40, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xa1,
+  0x00, 0x00, 0x00, 0x22, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x09,
+  0x00, 0x00, 0x00, 0x82, 0x64, 0x69, 0x73, 0x61, 0x62, 0x6c, 0x65, 0x64,
+  0x33, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x27, 0x00, 0x00, 0x00, 0x1a, 0x00, 0x00, 0x00, 0x02,
+  0x33, 0x61, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x7e, 0x40, 0x3a, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0xa1, 0x00, 0x00, 0x00, 0x23, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x82, 0x64, 0x69, 0x73, 0x61,
+  0x62, 0x6c, 0x65, 0x64, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x0a, 0x00, 0x00, 0x00, 0xc8, 0x2f, 0x64, 0x65, 0x76,
+  0x2f, 0x73, 0x70, 0x69, 0x34, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x27, 0x00, 0x00, 0x00, 0x1b,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x6c, 0x70, 0x69, 0x32,
+  0x63, 0x40, 0x34, 0x30, 0x33, 0x66, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00,
+  0x69, 0x6d, 0x78, 0x72, 0x74, 0x2d, 0x6c, 0x70, 0x69, 0x32, 0x63, 0x00,
+  0x40, 0x3f, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xa1, 0x00, 0x00, 0x00, 0x1c,
+  0x2f, 0x69, 0x32, 0x63, 0x31, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xd3, 0x00, 0x00, 0x00, 0x07,
+  0x00, 0x00, 0x00, 0x1c, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+  0x6c, 0x70, 0x69, 0x32, 0x63, 0x40, 0x34, 0x30, 0x33, 0x66, 0x34, 0x30,
+  0x69, 0x32, 0x63, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
+  0x00, 0x00, 0x00, 0x7e, 0x40, 0x3f, 0x40, 0x00, 0x00, 0x00, 0x40, 0x00,
+  0x00, 0x00, 0x00, 0x1d, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x09,
+  0x00, 0x00, 0x00, 0xc8, 0x2f, 0x64, 0x65, 0x76, 0x2f, 0x69, 0x32, 0x63,
+  0x32, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x00, 0x27, 0x00, 0x00, 0x00, 0x1d, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x01, 0x6c, 0x70, 0x69, 0x32, 0x63, 0x40, 0x34, 0x30,
+  0x33, 0x66, 0x38, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x74, 0x2d, 0x6c, 0x70, 0x69, 0x32, 0x63, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x7e, 0x40, 0x3f, 0x80, 0x00,
+  0x00, 0x00, 0x00, 0xa1, 0x00, 0x00, 0x00, 0x1e, 0x00, 0x00, 0x00, 0x03,
+  0x2f, 0x69, 0x32, 0x63, 0x33, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x27, 0x00, 0x00, 0x00, 0x1e,
+  0x63, 0x40, 0x34, 0x30, 0x33, 0x66, 0x63, 0x30, 0x30, 0x30, 0x00, 0x00,
+  0x40, 0x3f, 0xc0, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xa1, 0x00, 0x00, 0x00, 0x1f,
+  0x2f, 0x64, 0x65, 0x76, 0x2f, 0x69, 0x32, 0x63, 0x34, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x1f, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x5f, 0x5f, 0x73, 0x79,
+  0x6d, 0x62, 0x6f, 0x6c, 0x73, 0x5f, 0x5f, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x01, 0x4d, 0x2f, 0x63, 0x68, 0x6f,
+  0x73, 0x65, 0x6e, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x1f,
+  0x00, 0x00, 0x01, 0x54, 0x2f, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75,
+  0x70, 0x74, 0x2d, 0x63, 0x6f, 0x6e, 0x74, 0x72, 0x6f, 0x6c, 0x6c, 0x65,
+  0x72, 0x40, 0x65, 0x30, 0x30, 0x30, 0x65, 0x31, 0x30, 0x30, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x01, 0x59,
+  0x2f, 0x74, 0x69, 0x6d, 0x65, 0x72, 0x40, 0x65, 0x30, 0x30, 0x30, 0x65,
+  0x30, 0x31, 0x30, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x25,
+  0x00, 0x00, 0x01, 0x61, 0x2f, 0x73, 0x6f, 0x63, 0x2f, 0x61, 0x69, 0x70,
+  0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x25, 0x00, 0x00, 0x00, 0x47, 0x2f, 0x73, 0x6f, 0x63,
+  0x34, 0x30, 0x31, 0x63, 0x34, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00,
+  0x70, 0x69, 0x6f, 0x40, 0x34, 0x30, 0x31, 0x63, 0x30, 0x30, 0x30, 0x30,
+  0x00, 0x00, 0x00, 0x3b, 0x2f, 0x73, 0x6f, 0x63, 0x2f, 0x61, 0x69, 0x70,
+  0x00, 0x00, 0x00, 0x25, 0x00, 0x00, 0x00, 0x35, 0x2f, 0x73, 0x6f, 0x63,
+  0x34, 0x30, 0x31, 0x62, 0x38, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x25, 0x00, 0x00, 0x01, 0x67,
+  0x00, 0x00, 0x01, 0x6f, 0x2f, 0x73, 0x6f, 0x63, 0x2f, 0x61, 0x69, 0x70,
+  0x30, 0x30, 0x2f, 0x75, 0x61, 0x72, 0x74, 0x40, 0x34, 0x30, 0x31, 0x38,
+  0x00, 0x00, 0x00, 0x25, 0x00, 0x00, 0x01, 0x77, 0x2f, 0x73, 0x6f, 0x63,
+  0x31, 0x30, 0x30, 0x30, 0x30, 0x30, 0x2f, 0x75, 0x61, 0x72, 0x74, 0x40,
+  0x34, 0x30, 0x31, 0x38, 0x63, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x25, 0x00, 0x00, 0x01, 0x7f,
+  0x61, 0x72, 0x74, 0x40, 0x34, 0x30, 0x31, 0x39, 0x30, 0x30, 0x30, 0x30,
+  0x00, 0x00, 0x01, 0x87, 0x2f, 0x73, 0x6f, 0x63, 0x2f, 0x61, 0x69, 0x70,
+  0x30, 0x30, 0x2f, 0x75, 0x61, 0x72, 0x74, 0x40, 0x34, 0x30, 0x31, 0x39,
+  0x34, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x25, 0x00, 0x00, 0x01, 0x8f, 0x2f, 0x73, 0x6f, 0x63,
+  0x34, 0x30, 0x31, 0x39, 0x38, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x25, 0x00, 0x00, 0x01, 0x97,
+  0x61, 0x72, 0x74, 0x40, 0x34, 0x30, 0x31, 0x39, 0x63, 0x30, 0x30, 0x30,
+  0x00, 0x00, 0x01, 0x9f, 0x2f, 0x73, 0x6f, 0x63, 0x2f, 0x61, 0x69, 0x70,
+  0x30, 0x30, 0x2f, 0x75, 0x61, 0x72, 0x74, 0x40, 0x34, 0x30, 0x31, 0x61,
+  0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x01, 0xa7, 0x2f, 0x73, 0x6f, 0x63,
+  0x31, 0x30, 0x30, 0x30, 0x30, 0x30, 0x2f, 0x70, 0x69, 0x6e, 0x63, 0x74,
+  0x72, 0x6c, 0x40, 0x34, 0x30, 0x31, 0x66, 0x38, 0x30, 0x30, 0x30, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x33, 0x00, 0x00, 0x01, 0xae,
+  0x73, 0x40, 0x34, 0x30, 0x31, 0x30, 0x30, 0x30, 0x30, 0x30, 0x2f, 0x70,
+  0x69, 0x6e, 0x63, 0x74, 0x72, 0x6c, 0x40, 0x34, 0x30, 0x31, 0x66, 0x38,
+  0x30, 0x30, 0x30, 0x2f, 0x6c, 0x70, 0x75, 0x61, 0x72, 0x74, 0x31, 0x67,
+  0x72, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x33,
+  0x00, 0x00, 0x01, 0xbe, 0x2f, 0x73, 0x6f, 0x63, 0x2f, 0x61, 0x69, 0x70,
+  0x30, 0x30, 0x2f, 0x70, 0x69, 0x6e, 0x63, 0x74, 0x72, 0x6c, 0x40, 0x34,
+  0x30, 0x31, 0x66, 0x38, 0x30, 0x30, 0x30, 0x2f, 0x6c, 0x70, 0x75, 0x61,
+  0x72, 0x74, 0x33, 0x67, 0x72, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x32, 0x00, 0x00, 0x01, 0xce, 0x2f, 0x73, 0x6f, 0x63,
+  0x72, 0x6c, 0x40, 0x34, 0x30, 0x31, 0x66, 0x38, 0x30, 0x30, 0x30, 0x2f,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x32, 0x00, 0x00, 0x01, 0xdd,
+  0x30, 0x30, 0x30, 0x2f, 0x6c, 0x70, 0x69, 0x32, 0x63, 0x31, 0x67, 0x72,
+  0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x30,
+  0x00, 0x00, 0x01, 0xec, 0x2f, 0x73, 0x6f, 0x63, 0x2f, 0x61, 0x69, 0x70,
+  0x30, 0x31, 0x66, 0x38, 0x30, 0x30, 0x30, 0x2f, 0x66, 0x65, 0x63, 0x31,
+  0x67, 0x72, 0x70, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x29,
+  0x00, 0x00, 0x01, 0xf4, 0x2f, 0x73, 0x6f, 0x63, 0x2f, 0x61, 0x69, 0x70,
+  0x73, 0x2d, 0x62, 0x75, 0x73, 0x40, 0x34, 0x30, 0x32, 0x30, 0x30, 0x30,
+  0x30, 0x30, 0x2f, 0x65, 0x74, 0x68, 0x65, 0x72, 0x6e, 0x65, 0x74, 0x40,
+  0x34, 0x30, 0x32, 0x64, 0x38, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x26, 0x00, 0x00, 0x01, 0xd6,
+  0x73, 0x40, 0x34, 0x30, 0x33, 0x30, 0x30, 0x30, 0x30, 0x30, 0x2f, 0x6c,
+  0x70, 0x73, 0x70, 0x69, 0x40, 0x34, 0x30, 0x33, 0x39, 0x34, 0x30, 0x30,
+  0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x26,
+  0x00, 0x00, 0x01, 0xf9, 0x2f, 0x73, 0x6f, 0x63, 0x2f, 0x61, 0x69, 0x70,
+  0x73, 0x2d, 0x62, 0x75, 0x73, 0x40, 0x34, 0x30, 0x33, 0x30, 0x30, 0x30,
+  0x30, 0x30, 0x2f, 0x6c, 0x70, 0x73, 0x70, 0x69, 0x40, 0x34, 0x30, 0x33,
+  0x39, 0x38, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x26, 0x00, 0x00, 0x02, 0x00, 0x2f, 0x73, 0x6f, 0x63,
+  0x33, 0x30, 0x30, 0x30, 0x30, 0x30, 0x2f, 0x6c, 0x70, 0x73, 0x70, 0x69,
+  0x40, 0x34, 0x30, 0x33, 0x39, 0x63, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x26, 0x00, 0x00, 0x02, 0x07,
+  0x70, 0x73, 0x70, 0x69, 0x40, 0x34, 0x30, 0x33, 0x61, 0x30, 0x30, 0x30,
+  0x00, 0x00, 0x01, 0xe5, 0x2f, 0x73, 0x6f, 0x63, 0x2f, 0x61, 0x69, 0x70,
+  0x30, 0x30, 0x2f, 0x6c, 0x70, 0x69, 0x32, 0x63, 0x40, 0x34, 0x30, 0x33,
+  0x66, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x26, 0x00, 0x00, 0x02, 0x0e, 0x2f, 0x73, 0x6f, 0x63,
+  0x33, 0x30, 0x30, 0x30, 0x30, 0x30, 0x2f, 0x6c, 0x70, 0x69, 0x32, 0x63,
+  0x40, 0x34, 0x30, 0x33, 0x66, 0x34, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x26, 0x00, 0x00, 0x02, 0x15,
+  0x70, 0x69, 0x32, 0x63, 0x40, 0x34, 0x30, 0x33, 0x66, 0x38, 0x30, 0x30,
+  0x00, 0x00, 0x02, 0x1c, 0x2f, 0x73, 0x6f, 0x63, 0x2f, 0x61, 0x69, 0x70,
+  0x66, 0x63, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x09, 0x23, 0x61, 0x64, 0x64,
+  0x72, 0x65, 0x73, 0x73, 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x23,
+  0x73, 0x69, 0x7a, 0x65, 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x73,
+  0x74, 0x64, 0x6f, 0x75, 0x74, 0x2d, 0x70, 0x61, 0x74, 0x68, 0x00, 0x70,
+  0x68, 0x61, 0x6e, 0x64, 0x6c, 0x65, 0x00, 0x67, 0x70, 0x69, 0x6f, 0x30,
+  0x00, 0x67, 0x70, 0x69, 0x6f, 0x31, 0x00, 0x67, 0x70, 0x69, 0x6f, 0x32,
+  0x00, 0x67, 0x70, 0x69, 0x6f, 0x33, 0x00, 0x67, 0x70, 0x69, 0x6f, 0x34,
+  0x00, 0x63, 0x6f, 0x6d, 0x70, 0x61, 0x74, 0x69, 0x62, 0x6c, 0x65, 0x00,
+  0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d, 0x63, 0x6f,
+  0x6e, 0x74, 0x72, 0x6f, 0x6c, 0x6c, 0x65, 0x72, 0x00, 0x23, 0x69, 0x6e,
+  0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d, 0x63, 0x65, 0x6c, 0x6c,
+  0x73, 0x00, 0x72, 0x65, 0x67, 0x00, 0x73, 0x74, 0x61, 0x74, 0x75, 0x73,
+  0x00, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d, 0x70,
+  0x61, 0x72, 0x65, 0x6e, 0x74, 0x00, 0x72, 0x61, 0x6e, 0x67, 0x65, 0x73,
+  0x00, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x73, 0x00,
+  0x67, 0x70, 0x69, 0x6f, 0x2d, 0x63, 0x6f, 0x6e, 0x74, 0x72, 0x6f, 0x6c,
+  0x6c, 0x65, 0x72, 0x00, 0x23, 0x67, 0x70, 0x69, 0x6f, 0x2d, 0x63, 0x65,
+  0x6c, 0x6c, 0x73, 0x00, 0x72, 0x74, 0x65, 0x6d, 0x73, 0x2c, 0x70, 0x61,
+  0x74, 0x68, 0x00, 0x70, 0x69, 0x6e, 0x63, 0x74, 0x72, 0x6c, 0x2d, 0x30,
+  0x00, 0x66, 0x73, 0x6c, 0x2c, 0x70, 0x69, 0x6e, 0x73, 0x00, 0x69, 0x6e,
+  0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d, 0x6e, 0x61, 0x6d, 0x65,
+  0x73, 0x00, 0x66, 0x73, 0x6c, 0x2c, 0x6e, 0x75, 0x6d, 0x2d, 0x74, 0x78,
+  0x2d, 0x71, 0x75, 0x65, 0x75, 0x65, 0x73, 0x00, 0x66, 0x73, 0x6c, 0x2c,
+  0x6e, 0x75, 0x6d, 0x2d, 0x72, 0x78, 0x2d, 0x71, 0x75, 0x65, 0x75, 0x65,
+  0x73, 0x00, 0x70, 0x68, 0x79, 0x2d, 0x6d, 0x6f, 0x64, 0x65, 0x00, 0x70,
+  0x68, 0x79, 0x2d, 0x72, 0x65, 0x73, 0x65, 0x74, 0x2d, 0x67, 0x70, 0x69,
+  0x6f, 0x73, 0x00, 0x72, 0x74, 0x65, 0x6d, 0x73, 0x2c, 0x70, 0x68, 0x79,
+  0x2d, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d, 0x67,
+  0x70, 0x69, 0x6f, 0x73, 0x00, 0x63, 0x68, 0x6f, 0x73, 0x65, 0x6e, 0x00,
+  0x6e, 0x76, 0x69, 0x63, 0x00, 0x73, 0x79, 0x73, 0x74, 0x69, 0x63, 0x6b,
+  0x00, 0x67, 0x70, 0x69, 0x6f, 0x35, 0x00, 0x6c, 0x70, 0x75, 0x61, 0x72,
+  0x74, 0x31, 0x00, 0x6c, 0x70, 0x75, 0x61, 0x72, 0x74, 0x32, 0x00, 0x6c,
+  0x70, 0x75, 0x61, 0x72, 0x74, 0x33, 0x00, 0x6c, 0x70, 0x75, 0x61, 0x72,
+  0x74, 0x34, 0x00, 0x6c, 0x70, 0x75, 0x61, 0x72, 0x74, 0x35, 0x00, 0x6c,
+  0x70, 0x75, 0x61, 0x72, 0x74, 0x36, 0x00, 0x6c, 0x70, 0x75, 0x61, 0x72,
+  0x74, 0x37, 0x00, 0x6c, 0x70, 0x75, 0x61, 0x72, 0x74, 0x38, 0x00, 0x69,
+  0x6f, 0x6d, 0x75, 0x78, 0x63, 0x00, 0x70, 0x69, 0x6e, 0x63, 0x74, 0x72,
+  0x6c, 0x5f, 0x6c, 0x70, 0x75, 0x61, 0x72, 0x74, 0x31, 0x00, 0x70, 0x69,
+  0x6e, 0x63, 0x74, 0x72, 0x6c, 0x5f, 0x6c, 0x70, 0x75, 0x61, 0x72, 0x74,
+  0x33, 0x00, 0x70, 0x69, 0x6e, 0x63, 0x74, 0x72, 0x6c, 0x5f, 0x6c, 0x70,
+  0x73, 0x70, 0x69, 0x31, 0x00, 0x70, 0x69, 0x6e, 0x63, 0x74, 0x72, 0x6c,
+  0x5f, 0x6c, 0x70, 0x69, 0x32, 0x63, 0x31, 0x00, 0x70, 0x69, 0x6e, 0x63,
+  0x74, 0x72, 0x6c, 0x5f, 0x66, 0x65, 0x63, 0x31, 0x00, 0x6c, 0x70, 0x73,
+  0x70, 0x69, 0x32, 0x00, 0x6c, 0x70, 0x73, 0x70, 0x69, 0x33, 0x00, 0x6c,
+  0x70, 0x73, 0x70, 0x69, 0x34, 0x00, 0x6c, 0x70, 0x69, 0x32, 0x63, 0x32,
+  0x00, 0x6c, 0x70, 0x69, 0x32, 0x63, 0x33, 0x00, 0x6c, 0x70, 0x69, 0x32,
+  0x63, 0x34, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
+const size_t imxrt_dtb_size = sizeof(imxrt_dtb);
diff --git a/bsps/arm/imxrt/dts/imxrt1050-evkb.dts b/bsps/arm/imxrt/dts/imxrt1050-evkb.dts
index 0000000000..968ca1dbdc
--- /dev/null
+++ b/bsps/arm/imxrt/dts/imxrt1050-evkb.dts
@@ -0,0 +1,410 @@
+ * are met:
+ * FIXME: Compilation should be automated.
+ * Compile this file with the following commands:
+ *     export BSP_DIR="${RTEMS_SRC_DIR}/bsps/arm/imxrt/"
+ *     arm-rtems6-cpp -P -x assembler-with-cpp -I "${BSP_DIR}/include/" -include "${BSP_DIR}/dts/imxrt1050-evkb.dts" /dev/null | \
+ *         dtc -@ -O dtb -o "${BSP_DIR}/dts/imxrt1050-evkb.dtb" -b 0 -p 1024
+ *     rtems-bin2c -C -N imxrt_dtb "${BSP_DIR}/dts/imxrt1050-evkb.dtb" "${BSP_DIR}/dts/imxrt1050-evkb.c"
+#include <imxrt/imxrt1050-pinfunc.h>
+/dts-v1/;
+	#address-cells = <1>;
+	#size-cells = <1>;
+	chosen: chosen {};
+	aliases {
+		gpio0 = &gpio1;
+		gpio1 = &gpio2;
+		gpio2 = &gpio3;
+		gpio3 = &gpio4;
+		gpio4 = &gpio5;
+	nvic: interrupt-controller at e000e100  {
+		compatible = "arm,armv7m-nvic";
+		interrupt-controller;
+		#interrupt-cells = <1>;
+		reg = <0xe000e100 0xc00>;
+	systick: timer at e000e010 {
+		compatible = "arm,armv7m-systick";
+		reg = <0xe000e010 0x10>;
+		status = "disabled";
+	soc {
+		compatible = "simple-bus";
+		interrupt-parent = <&nvic>;
+		ranges;
+		aips-bus at 40000000 {
+			compatible = "fsl,aips-bus", "simple-bus";
+			reg = <0x40000000 0x00100000>;
+			ranges;
+			gpio5: gpio at 400c0000 {
+				compatible = "fsl,imxrt-gpio",
+				    "fsl,imx6ul-gpio", "fsl,imx35-gpio";
+				reg = <0x400c0000 0x4000>;
+				interrupts = <88>, <89>;
+				gpio-controller;
+				#gpio-cells = <2>;
+				#interrupt-cells = <2>;
+		aips-bus at 40100000 {
+			reg = <0x40100000 0x00100000>;
+			ranges;
+			gpio4: gpio at 401c4000 {
+				reg = <0x401c4000 0x4000>;
+				interrupts = <86>, <87>;
+				gpio-controller;
+			gpio3: gpio at 401c0000 {
+				reg = <0x401c0000 0x4000>;
+				interrupts = <84>, <85>;
+				gpio-controller;
+			gpio2: gpio at 401bc000 {
+				reg = <0x401bc000 0x4000>;
+				interrupts = <82>, <83>;
+				gpio-controller;
+			gpio1: gpio at 401b8000 {
+				reg = <0x401b8000 0x4000>;
+				interrupts = <80>, <81>, <72>, <73>, <74>,
+				    <75>, <76>, <77>, <78>, <79>;
+				gpio-controller;
+			lpuart1: uart at 40184000 {
+				compatible = "nxp,imxrt-lpuart";
+				reg = <0x40184000 0x4000>;
+				interrupts = <20>;
+				rtems,path = "/dev/ttyS1";
+			lpuart2: uart at 40188000 {
+				reg = <0x40188000 0x4000>;
+				interrupts = <21>;
+				rtems,path = "/dev/ttyS2";
+			lpuart3: uart at 4018c000 {
+				reg = <0x4018c000 0x4000>;
+				interrupts = <22>;
+				rtems,path = "/dev/ttyS3";
+			lpuart4: uart at 40190000 {
+				reg = <0x40190000 0x4000>;
+				interrupts = <23>;
+				rtems,path = "/dev/ttyS4";
+			lpuart5: uart at 40194000 {
+				reg = <0x40194000 0x4000>;
+				interrupts = <24>;
+				rtems,path = "/dev/ttyS5";
+			lpuart6: uart at 40198000 {
+				reg = <0x40198000 0x4000>;
+				interrupts = <25>;
+				rtems,path = "/dev/ttyS6";
+			lpuart7: uart at 4019c000 {
+				reg = <0x4019c000 0x4000>;
+				interrupts = <26>;
+				rtems,path = "/dev/ttyS7";
+			lpuart8: uart at 401a0000 {
+				reg = <0x401a0000 0x4000>;
+				interrupts = <27>;
+				rtems,path = "/dev/ttyS8";
+			iomuxc: pinctrl at 401f8000 {
+				compatible = "nxp,imxrt1050-iomuxc";
+				reg = <0x401f8000 0x4000>;
+		aips-bus at 40200000 {
+			reg = <0x40200000 0x00100000>;
+			ranges;
+			fec1: ethernet at 402d8000 {
+				compatible = "fsl,imxrt-fec", "fsl,imx6ul-fec";
+				reg = <0x402d8000 0x4000>;
+				interrupt-names = "int0", "pps";
+				interrupts = <114>, <115>;
+				fsl,num-tx-queues = <1>;
+				fsl,num-rx-queues = <1>;
+				phy-mode = "rmii";
+		aips-bus at 40300000 {
+			reg = <0x40300000 0x00100000>;
+			ranges;
+			lpspi1: lpspi at 40394000 {
+				#size-cells = <0>;
+				compatible = "nxp,imxrt-lpspi";
+				reg = <0x40394000 0x4000>;
+				interrupts = <32>;
+				rtems,path = "/dev/spi1";
+			lpspi2: lpspi at 40398000 {
+				reg = <0x40398000 0x4000>;
+				interrupts = <33>;
+				rtems,path = "/dev/spi2";
+			lpspi3: lpspi at 4039c000 {
+				reg = <0x4039c000 0x4000>;
+				interrupts = <34>;
+				rtems,path = "/dev/spi3";
+			lpspi4: lpspi at 403a0000 {
+				reg = <0x403a0000 0x4000>;
+				interrupts = <35>;
+				rtems,path = "/dev/spi4";
+			lpi2c1: lpi2c at 403f0000 {
+				compatible = "nxp,imxrt-lpi2c";
+				reg = <0x403f0000 0x4000>;
+				interrupts = <28>;
+				rtems,path = "/dev/i2c1";
+			lpi2c2: lpi2c at 403f4000 {
+				reg = <0x403f4000 0x4000>;
+				interrupts = <29>;
+				rtems,path = "/dev/i2c2";
+			lpi2c3: lpi2c at 403f8000 {
+				reg = <0x403f8000 0x4000>;
+				interrupts = <30>;
+				rtems,path = "/dev/i2c3";
+			lpi2c4: lpi2c at 403fc000 {
+				reg = <0x403fc000 0x4000>;
+				interrupts = <31>;
+				rtems,path = "/dev/i2c4";
+&lpuart1 {
+	pinctrl-0 = <&pinctrl_lpuart1>;
+	status = "okay";
+&chosen {
+	stdout-path = &lpuart1;
+&lpuart3 {
+	pinctrl-0 = <&pinctrl_lpuart3>;
+	status = "okay";
+&lpspi1 {
+	pinctrl-0 = <&pinctrl_lpspi1>;
+	status = "okay";
+&lpi2c1 {
+	pinctrl-0 = <&pinctrl_lpi2c1>;
+	status = "okay";
+&lpi2c1 {
+	status = "okay";
+&fec1 {
+	pinctrl-0 = <&pinctrl_fec1>;
+	phy-reset-gpios = <&gpio1 9 1>;
+	rtems,phy-interrupt-gpios = <&gpio1 10 1>;
+	status = "okay";
+&iomuxc {
+	pinctrl_lpuart1: lpuart1grp {
+		fsl,pins = <
+			IMXRT_PAD_GPIO_AD_B0_12__LPUART1_TX	0x8
+			IMXRT_PAD_GPIO_AD_B0_13__LPUART1_RX	0x13000
+	pinctrl_lpuart3: lpuart3grp {
+		fsl,pins = <
+			IMXRT_PAD_GPIO_AD_B1_06__LPUART3_TX	0x8
+			IMXRT_PAD_GPIO_AD_B1_07__LPUART3_RX	0x13000
+	pinctrl_lpspi1: lpspi1grp {
+		fsl,pins = <
+			IMXRT_PAD_GPIO_SD_B0_01__LPSPI1_PCS0	0x8
+			IMXRT_PAD_GPIO_SD_B0_02__LPSPI1_SDO	0x8
+			IMXRT_PAD_GPIO_SD_B0_03__LPSPI1_SDI	0x1b000
+			IMXRT_PAD_GPIO_SD_B0_00__LPSPI1_SCK	0x8
+	pinctrl_lpi2c1: lpi2c1grp {
+		fsl,pins = <
+			IMXRT_PAD_GPIO_AD_B1_00__LPI2C1_SCL	0x4000f830
+			IMXRT_PAD_GPIO_AD_B1_01__LPI2C1_SDA	0x4000f830
+	pinctrl_fec1: fec1grp {
+		fsl,pins = <
+			IMXRT_PAD_GPIO_EMC_41__ENET_enet_mdio		0xb829
+			IMXRT_PAD_GPIO_EMC_40__ENET_enet_mdc		0xb0e9
+			IMXRT_PAD_GPIO_B1_04__ENET_enet_rx_data0	0xb0e9
+			IMXRT_PAD_GPIO_B1_05__ENET_enet_rx_data1	0xb0e9
+			IMXRT_PAD_GPIO_B1_06__ENET_enet_rx_en		0xb0e9
+			IMXRT_PAD_GPIO_B1_07__ENET_enet_tx_data0	0xb0e9
+			IMXRT_PAD_GPIO_B1_08__ENET_enet_tx_data1	0xb0e9
+			IMXRT_PAD_GPIO_B1_09__ENET_enet_tx_en		0xb0e9
+			IMXRT_PAD_GPIO_B1_10__ENET_enet_ref_clk		0x40000031
+			IMXRT_PAD_GPIO_B1_11__ENET_enet_rx_er		0xb0e9
+			/* ENET_RST */
+			IMXRT_PAD_GPIO_AD_B0_09__GPIO1_gpio_io09	0x810
+			/* ENET_INT */
+			IMXRT_PAD_GPIO_AD_B0_10__GPIO1_gpio_io10	0xb0a9
diff --git a/bsps/arm/imxrt/i2c/imxrt-lpi2c.c b/bsps/arm/imxrt/i2c/imxrt-lpi2c.c
index 0000000000..783c6e18e6
--- /dev/null
+++ b/bsps/arm/imxrt/i2c/imxrt-lpi2c.c
@@ -0,0 +1,489 @@
+ * are met:
+#include <bsp.h>
+#include <chip.h>
+#include <dev/i2c/i2c.h>
+#include <fsl_clock.h>
+#include <fsl_lpi2c.h>
+#define LPI2C_MTDR_CMD_transmit                           LPI2C_MTDR_CMD(0)
+#define LPI2C_MTDR_CMD_receive                            LPI2C_MTDR_CMD(1)
+#define LPI2C_MTDR_CMD_stop                               LPI2C_MTDR_CMD(2)
+#define LPI2C_MTDR_CMD_receive_and_discard                LPI2C_MTDR_CMD(3)
+#define LPI2C_MTDR_CMD_start_and_transmit                 LPI2C_MTDR_CMD(4)
+#define LPI2C_MTDR_CMD_start_and_transmit_NACK            LPI2C_MTDR_CMD(5)
+#define LPI2C_MTDR_CMD_start_and_transmit_highspeed       LPI2C_MTDR_CMD(6)
+#define LPI2C_MTDR_CMD_start_and_transmit_highspeed_NACK  LPI2C_MTDR_CMD(7)
+#define LPI2C_INT_ERRORS_SERIOUS ( \
+  LPI2C_MSR_FEF_MASK | LPI2C_MSR_ALF_MASK | LPI2C_MSR_PLTF_MASK )
+#define LPI2C_INT_ERROR_NO_ACK (LPI2C_MSR_NDF_MASK)
+#define LPI2C_INT_ERRORS (LPI2C_INT_ERRORS_SERIOUS | LPI2C_INT_ERROR_NO_ACK)
+#define LPI2C_INT_ADDRESSED (LPI2C_INT_ERRORS | LPI2C_MSR_TDF_MASK)
+#define LPI2C_INT_STOP_SENT (LPI2C_INT_ERRORS | LPI2C_MSR_SDF_MASK)
+#define LPI2C_INT_RECEIVED (LPI2C_INT_ERRORS | LPI2C_MSR_RDF_MASK)
+#define LPI2C_INT_TRANSMITTED (LPI2C_INT_ERRORS | LPI2C_MSR_TDF_MASK)
+struct imxrt_lpi2c_bus {
+  i2c_bus base;
+  volatile LPI2C_Type *regs;
+  clock_ip_name_t clock_ip;
+  unsigned long clock;
+  rtems_binary_semaphore sem;
+  int eno;
+  uint32_t msg_todo;
+  const i2c_msg *msg;
+  /* Everything that is necessary for the current message */
+  uint32_t chunk_todo;
+  uint16_t buf_todo;
+  uint8_t *buf;
+  bool stop;
+  bool read;
+static void imxrt_lpi2c_sw_reset(volatile LPI2C_Type *regs)
+  regs->MCR = LPI2C_MCR_RST_MASK | LPI2C_MCR_RRF_MASK | LPI2C_MCR_RTF_MASK;
+  regs->SCR = LPI2C_SCR_RST_MASK | LPI2C_SCR_RRF_MASK | LPI2C_SCR_RTF_MASK;
+  regs->MCR = 0;
+  regs->SCR = 0;
+static int imxrt_lpi2c_set_clock(i2c_bus *base, unsigned long clock)
+  struct imxrt_lpi2c_bus *bus;
+  bus = (struct imxrt_lpi2c_bus *) base;
+  regs = bus->regs;
+  bus->clock = clock;
+   * Maybe there is a more efficient way than used by that function. But
+   * changing clock doesn't happen often. So it should be OK for now.
+  LPI2C_MasterSetBaudRate((LPI2C_Type *)regs, bus->src_clock_hz, clock);
+  return 0;
+static void imxrt_lpi2c_do_reinit(
+  struct imxrt_lpi2c_bus *bus,
+  regs->MIER = 0;
+  imxrt_lpi2c_sw_reset(regs);
+  regs->MCFGR2 = LPI2C_MCFGR2_FILTSDA(0) | LPI2C_MCFGR2_FILTSCL(0) |
+    LPI2C_MCFGR2_BUSIDLE(0);
+  regs->MCFGR3 = LPI2C_MCFGR3_PINLOW(0);
+  regs->MFCR = LPI2C_MFCR_RXWATER(0) | LPI2C_MFCR_TXWATER(1);
+  imxrt_lpi2c_set_clock(&bus->base, bus->clock);
+static void imxrt_lpi2c_done(
+  regs->MIER = 0;
+  regs->MCR &= ~LPI2C_MCR_MEN_MASK;
+  rtems_binary_semaphore_post(&bus->sem);
+static void imxrt_lpi2c_next_msg(
+static void imxrt_lpi2c_transmit_next(
+  if (bus->chunk_todo == 0) {
+    /* Check whether a stop has to be send */
+    if (bus->stop) {
+      regs->MTDR = LPI2C_MTDR_CMD_stop;
+      bus->stop = false;
+      regs->MIER = LPI2C_INT_STOP_SENT;
+    } else {
+      imxrt_lpi2c_next_msg(bus, regs);
+  } else {
+    if (bus->read) {
+      uint16_t to_read;
+      to_read = MIN(bus->chunk_todo, 256);
+      bus->chunk_todo -= to_read;
+      regs->MTDR = LPI2C_MTDR_CMD_receive | (to_read - 1);
+      regs->MIER = LPI2C_INT_RECEIVED;
+    } else {
+      regs->MTDR = LPI2C_MTDR_CMD_transmit | *bus->buf;
+      ++bus->buf;
+      --bus->buf_todo;
+      --bus->chunk_todo;
+      regs->MIER = LPI2C_INT_TRANSMITTED;
+  if (bus->msg_todo == 0) {
+    imxrt_lpi2c_done(bus, regs);
+  } else {
+    int flags;
+    bool start;
+    uint16_t addr;
+    msg = bus->msg;
+    flags = msg->flags;
+    addr = msg->addr;
+    start = (flags & I2C_M_NOSTART) == 0;
+    bus->read = (flags & I2C_M_RD) != 0;
+    bus->chunk_todo = msg->len;
+    bus->buf_todo = msg->len;
+    bus->buf = msg->buf;
+    bus->stop = (flags & I2C_M_STOP) != 0 || bus->msg_todo <= 1;
+    ++bus->msg;
+    --bus->msg_todo;
+    if (start) {
+      uint32_t mtdr;
+      mtdr = LPI2C_MTDR_CMD_start_and_transmit;
+      mtdr |= addr << 1;
+      if (bus->read) {
+        mtdr |= 1;
+      regs->MTDR = mtdr;
+      regs->MIER = LPI2C_INT_ADDRESSED;
+    } else {
+      imxrt_lpi2c_transmit_next(bus, regs);
+static void imxrt_lpi2c_interrupt(void *arg)
+  uint32_t msr;
+  bus = arg;
+  regs = bus->regs;
+  msr = regs->MSR;
+  regs->MSR = msr;
+  if ((msr & LPI2C_INT_ERROR_NO_ACK) != 0) {
+    /* Just end the transmission */
+    bus->eno = EIO;
+  } else if ((msr & LPI2C_INT_ERRORS_SERIOUS) != 0) {
+    /* Some worse error occurred. Reset hardware. */
+    bus->eno = EIO;
+    imxrt_lpi2c_do_reinit(bus, regs);
+  } else {
+    uint32_t mrdr;
+    while (((mrdr = regs->MRDR) & LPI2C_MRDR_RXEMPTY_MASK) == 0) {
+      if (bus->read && bus->buf_todo > 0) {
+        *bus->buf = (mrdr & LPI2C_MRDR_DATA_MASK) >> LPI2C_MRDR_DATA_SHIFT;
+        ++bus->buf;
+        --bus->buf_todo;
+    if (
+      ((msr & LPI2C_MSR_TDF_MASK) != 0) &&
+      (!bus->read || bus->chunk_todo > 0 || bus->buf_todo == 0)
+static int imxrt_lpi2c_wait_for_not_busy(volatile LPI2C_Type *regs)
+  rtems_interval timeout;
+  bool before;
+  if ((regs->MSR & LPI2C_MSR_BBF_MASK) == 0) {
+    return 0;
+  timeout = rtems_clock_tick_later_usec(5000);
+  do {
+    before = rtems_clock_tick_before(timeout);
+      return 0;
+  } while (before);
+  return ETIMEDOUT;
+static void imxrt_lpi2c_first_msg(
+  if ((regs->MCR & LPI2C_MCR_MEN_MASK) == 0) {
+    regs->MCR |= LPI2C_MCR_MEN_MASK;
+static int imxrt_lpi2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t n)
+  int supported_flags;
+  int eno;
+  uint16_t i;
+  regs = bus->regs;
+  supported_flags = I2C_M_RD | I2C_M_STOP;
+  for (i = 0; i < n; ++i) {
+    if ((msgs[i].flags & ~supported_flags) != 0) {
+      return -EINVAL;
+    supported_flags |= I2C_M_NOSTART;
+  eno = imxrt_lpi2c_wait_for_not_busy(regs);
+  if (eno != 0) {
+    return -eno;
+  bus->msg_todo = n;
+  bus->msg = &msgs[0];
+  bus->eno = 0;
+  imxrt_lpi2c_first_msg(bus, regs);
+  eno = rtems_binary_semaphore_wait_timed_ticks(&bus->sem, bus->base.timeout);
+  if (eno != 0) {
+    /* Timeout */
+    rtems_binary_semaphore_try_wait(&bus->sem);
+    return -eno;
+  return -bus->eno;
+static void imxrt_lpi2c_destroy(i2c_bus *base)
+  regs = bus->regs;
+  CLOCK_DisableClock(bus->clock_ip);
+  rtems_interrupt_handler_remove(bus->irq, imxrt_lpi2c_interrupt, bus);
+  i2c_bus_destroy_and_free(&bus->base);
+static int imxrt_lpi2c_hw_init(struct imxrt_lpi2c_bus *bus)
+  regs = bus->regs;
+  CLOCK_EnableClock(bus->clock_ip);
+  bus->clock = I2C_BUS_CLOCK_DEFAULT;
+    bus->irq,
+    "LPI2C",
+    RTEMS_INTERRUPT_UNIQUE,
+    imxrt_lpi2c_interrupt,
+    bus
+    return EAGAIN;
+  return 0;
+static uint32_t imxrt_lpi2c_get_src_freq(void)
+  uint32_t freq;
+  uint32_t mux;
+  uint32_t divider;
+  mux = CLOCK_GetMux(kCLOCK_Lpi2cMux);
+  divider = 1;
+  switch (mux) {
+    divider = 8;
+    break;
+  case 1: /* OSC */
+    break;
+  default:
+    freq = 0;
+  divider *= CLOCK_GetDiv(kCLOCK_Lpi2cDiv) + 1;
+  freq /= divider;
+  return freq;
+static clock_ip_name_t imxrt_lpi2c_clock_ip(volatile LPI2C_Type *regs)
+  LPI2C_Type *const base_addresses[] = LPI2C_BASE_PTRS;
+  static const clock_ip_name_t lpi2c_clocks[] = LPI2C_CLOCKS;
+  size_t i;
+  for (i = 0; i < RTEMS_ARRAY_SIZE(base_addresses); ++i) {
+    if (base_addresses[i] == regs) {
+      return lpi2c_clocks[i];
+  return kCLOCK_IpInvalid;
+void imxrt_lpi2c_init(void)
+  const void *fdt;
+  int node;
+  node = -1;
+  do {
+    node = fdt_node_offset_by_compatible(fdt, node, "nxp,imxrt-lpi2c");
+      int eno;
+      const char *bus_path;
+      bus = (struct imxrt_lpi2c_bus*) i2c_bus_alloc_and_init(sizeof(*bus));
+      if (bus == NULL) {
+        bsp_fatal(IMXRT_FATAL_LPI2C_ALLOC_FAILED);
+      rtems_binary_semaphore_init(&bus->sem, "LPI2C");
+      bus->regs = imx_get_reg_of_node(fdt, node);
+      if (bus->regs == NULL) {
+        (*bus->base.destroy)(&bus->base);
+      bus->irq = imx_get_irq_of_node(fdt, node, 0);
+      if (bus->irq == BSP_INTERRUPT_VECTOR_INVALID) {
+      bus_path = fdt_getprop(fdt, node, "rtems,path", NULL);
+      if (bus_path == NULL) {
+      bus->clock_ip = imxrt_lpi2c_clock_ip(bus->regs);
+      bus->src_clock_hz = imxrt_lpi2c_get_src_freq();
+      eno = imxrt_lpi2c_hw_init(bus);
+      if (eno != 0) {
+        bsp_fatal(IMXRT_FATAL_LPI2C_HW_INIT_FAILED);
+      bus->base.transfer = imxrt_lpi2c_transfer;
+      bus->base.set_clock = imxrt_lpi2c_set_clock;
+      bus->base.destroy = imxrt_lpi2c_destroy;
+       * Need at least three FIFO bytes:
+       * 1. One to two data to transmit or receive.
+       *    Two is necessary for long receives without NACK.
+       * 2. A stop condition.
+      if ((1 << ((bus->regs->PARAM & LPI2C_PARAM_MTXFIFO_MASK) >>
+          LPI2C_PARAM_MTXFIFO_SHIFT)) < 3) {
+        bsp_fatal(IMXRT_FATAL_LPI2C_UNSUPPORTED_HARDWARE);
+      eno = i2c_bus_register(&bus->base, bus_path);
+      if (eno != 0) {
+        bsp_fatal(IMXRT_FATAL_LPI2C_REGISTER_FAILED);
diff --git a/bsps/arm/imxrt/include/bsp.h b/bsps/arm/imxrt/include/bsp.h
new file mode 100644
index 0000000000..f93c28aee0
--- /dev/null
+++ b/bsps/arm/imxrt/include/bsp.h
@@ -0,0 +1,93 @@
+ * @file
+ * @ingroup RTEMSBSPsARMimxrt
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+#ifndef LIBBSP_ARM_IMXRT_BSP_H
+#define LIBBSP_ARM_IMXRT_BSP_H
+ * @defgroup RTEMSBSPsARMimxrt NXP i.MXRT
+ * @brief NXP i.MXRT Board Support Package.
+#include <bspopts.h>
+#include <rtems.h>
+#include <bsp/default-initial-extension.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+#define BSP_FEATURE_IRQ_EXTENSION
+#define BSP_FDT_IS_SUPPORTED
+extern const unsigned char imxrt_dtb[];
+extern const size_t imxrt_dtb_size;
+void *imx_get_reg_of_node(const void *fdt, int node);
+rtems_vector_number imx_get_irq_of_node(
+  const void *fdt,
+  int node,
+  size_t index
+bool imxrt_fdt_node_is_enabled(const void *fdt, int node);
+ * About 50% between `basepri` in arm_interrupt_disable and the maximum for this
+ * chip.
+#define BSP_ARMV7M_IRQ_PRIORITY_DEFAULT (13 << 4)
+#define BSP_ARMV7M_SYSTICK_PRIORITY (14 << 4)
+#define BSP_ARMV7M_SYSTICK_FREQUENCY imxrt_systick_frequency()
+uint32_t imxrt_systick_frequency(void);
+void imxrt_lpspi_init(void);
+void imxrt_lpi2c_init(void);
+void imxrt_ffec_init(void);
+#ifdef __cplusplus
+#endif /* LIBBSP_ARM_IMXRT_BSP_H */
diff --git a/bsps/arm/imxrt/include/bsp/flash-headers.h b/bsps/arm/imxrt/include/bsp/flash-headers.h
index 0000000000..6575b1c21b
--- /dev/null
+++ b/bsps/arm/imxrt/include/bsp/flash-headers.h
@@ -0,0 +1,63 @@
+ * @file
+ * @brief Header structures that are used by i.MXRT1050 for booting from flash.
+ * are met:
+#ifndef LIBBSP_ARM_IMXRT_FLASH_HEADERS_H
+#define LIBBSP_ARM_IMXRT_FLASH_HEADERS_H
+#include <stdint.h>
+#include <fsl_flexspi_nor_config.h>
+#include <fsl_flexspi_nor_boot.h>
+#ifdef __cplusplus
+extern "C" {
+__attribute__((section(".boot_hdr.dcd_data")))
+extern const uint8_t imxrt_dcd_data[];
+__attribute__((section(".boot_hdr.ivt")))
+extern const ivt imxrt_image_vector_table;
+__attribute__((section(".boot_hdr.boot_data")))
+extern const BOOT_DATA_T imxrt_boot_data;
+__attribute__((section(".boot_hdr.conf")))
+extern const flexspi_nor_config_t imxrt_flexspi_config;
+#ifdef __cplusplus
+#endif /* LIBBSP_ARM_IMXRT_FLASH_HEADERS_H */
diff --git a/bsps/arm/imxrt/include/bsp/irq.h b/bsps/arm/imxrt/include/bsp/irq.h
index 0000000000..eed54f8648
--- /dev/null
+++ b/bsps/arm/imxrt/include/bsp/irq.h
@@ -0,0 +1,54 @@
+ * @file
+ * are met:
+#ifndef LIBBSP_ARM_IMXRT_IRQ_H
+#define LIBBSP_ARM_IMXRT_IRQ_H
+#ifndef ASM
+  #include <rtems/irq.h>
+  #include <rtems/irq-extension.h>
+#endif /* ASM */
+#ifdef __cplusplus
+extern "C" {
+#define BSP_INTERRUPT_VECTOR_MIN 0
+#define BSP_INTERRUPT_VECTOR_MAX 159
+#define BSP_INTERRUPT_VECTOR_INVALID (UINT32_MAX)
+#ifdef __cplusplus
+#endif /* LIBBSP_ARM_IMXRT_IRQ_H */
diff --git a/bsps/arm/imxrt/include/chip.h b/bsps/arm/imxrt/include/chip.h
index 0000000000..9ea618edd1
--- /dev/null
+++ b/bsps/arm/imxrt/include/chip.h
@@ -0,0 +1,2 @@
+#include "MIMXRT1052.h"
+#include "MIMXRT1052_features.h"
diff --git a/bsps/arm/imxrt/include/imxrt/imxrt1050-pinfunc.h b/bsps/arm/imxrt/include/imxrt/imxrt1050-pinfunc.h
index 0000000000..16ebfae5b3
--- /dev/null
+++ b/bsps/arm/imxrt/include/imxrt/imxrt1050-pinfunc.h
@@ -0,0 +1,1236 @@
+ * @file
+ * @brief Pin function definitions for i.MXRT1050
+ * are met:
+#ifndef LIBBSP_ARM_IMXRT_IMXRT1050_PINFUNC_H
+#define LIBBSP_ARM_IMXRT_IMXRT1050_PINFUNC_H
+#ifdef __cplusplus
+extern "C" {
+/* GPIO_AD_B0_00 */
+#define IMXRT_PAD_GPIO_AD_B0_00__PWM2_A3                   0x00bc 0x02ac 0x0474 0 2
+#define IMXRT_PAD_GPIO_AD_B0_00__XBARA1_OUT14              0x00bc 0x02ac 0x0644 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_14 to 0x1 */
+#define IMXRT_PAD_GPIO_AD_B0_00__XBARA1_IN14               0x00bc 0x02ac 0x0644 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_14 to 0 */
+#define IMXRT_PAD_GPIO_AD_B0_00__XTALOSC24M_REF_CLK_32K    0x00bc 0x02ac 0x0000 2 0
+#define IMXRT_PAD_GPIO_AD_B0_00__USB2_usb_otg2_id          0x00bc 0x02ac 0x03f8 3 0
+#define IMXRT_PAD_GPIO_AD_B0_00__LPI2C1_SCLS               0x00bc 0x02ac 0x0000 4 0
+#define IMXRT_PAD_GPIO_AD_B0_00__GPIO1_gpio_io00           0x00bc 0x02ac 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B0_00__USDHC1_usdhc_reset_b      0x00bc 0x02ac 0x0000 6 0
+#define IMXRT_PAD_GPIO_AD_B0_00__LPSPI3_SCK                0x00bc 0x02ac 0x0510 7 0
+#define IMXRT_PAD_GPIO_AD_B0_00__CMP1_IN4                  0x00bc 0x02ac 0x0000 5 0
+/* GPIO_AD_B0_01 */
+#define IMXRT_PAD_GPIO_AD_B0_01__PWM2_B3                   0x00c0 0x02b0 0x0484 0 2
+#define IMXRT_PAD_GPIO_AD_B0_01__XBARA1_OUT15              0x00c0 0x02b0 0x0648 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_15 to 0x1 */
+#define IMXRT_PAD_GPIO_AD_B0_01__XBARA1_IN15               0x00c0 0x02b0 0x0648 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_15 to 0 */
+#define IMXRT_PAD_GPIO_AD_B0_01__XTALOSC24M_REF_CLK_24M    0x00c0 0x02b0 0x0000 2 0
+#define IMXRT_PAD_GPIO_AD_B0_01__USB1_usb_otg1_id          0x00c0 0x02b0 0x03f4 3 0
+#define IMXRT_PAD_GPIO_AD_B0_01__LPI2C1_SDAS               0x00c0 0x02b0 0x0000 4 0
+#define IMXRT_PAD_GPIO_AD_B0_01__GPIO1_gpio_io01           0x00c0 0x02b0 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B0_01__EWM_EWM_OUT_B             0x00c0 0x02b0 0x0000 6 0
+#define IMXRT_PAD_GPIO_AD_B0_01__LPSPI3_SDO                0x00c0 0x02b0 0x0518 7 0
+#define IMXRT_PAD_GPIO_AD_B0_01__CMP2_IN4                  0x00c0 0x02b0 0x0000 5 0
+/* GPIO_AD_B0_02 */
+#define IMXRT_PAD_GPIO_AD_B0_02__CAN2_TX                   0x00c4 0x02b4 0x0000 0 0
+#define IMXRT_PAD_GPIO_AD_B0_02__XBARA1_OUT16              0x00c4 0x02b4 0x064c 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_16 to 0x1 */
+#define IMXRT_PAD_GPIO_AD_B0_02__XBARA1_IN16               0x00c4 0x02b4 0x064c 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_16 to 0 */
+#define IMXRT_PAD_GPIO_AD_B0_02__LPUART6_TX                0x00c4 0x02b4 0x0554 2 1
+#define IMXRT_PAD_GPIO_AD_B0_02__USB1_usb_otg1_pwr         0x00c4 0x02b4 0x0000 3 0
+#define IMXRT_PAD_GPIO_AD_B0_02__PWM1_X0                   0x00c4 0x02b4 0x0000 4 0
+#define IMXRT_PAD_GPIO_AD_B0_02__GPIO1_gpio_io02           0x00c4 0x02b4 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B0_02__LPI2C1_HREQ               0x00c4 0x02b4 0x0000 6 0
+#define IMXRT_PAD_GPIO_AD_B0_02__LPSPI3_SDI                0x00c4 0x02b4 0x0514 7 0
+#define IMXRT_PAD_GPIO_AD_B0_02__CMP3_IN4                  0x00c4 0x02b4 0x0000 5 0
+/* GPIO_AD_B0_03 */
+#define IMXRT_PAD_GPIO_AD_B0_03__CAN2_RX                   0x00c8 0x02b8 0x0450 0 1
+#define IMXRT_PAD_GPIO_AD_B0_03__XBARA1_OUT17              0x00c8 0x02b8 0x062c 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_17 to 0x1 */
+#define IMXRT_PAD_GPIO_AD_B0_03__XBARA1_IN17               0x00c8 0x02b8 0x062c 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_17 to 0 */
+#define IMXRT_PAD_GPIO_AD_B0_03__LPUART6_RX                0x00c8 0x02b8 0x0550 2 1
+#define IMXRT_PAD_GPIO_AD_B0_03__USB1_usb_otg1_oc          0x00c8 0x02b8 0x05d0 3 0
+#define IMXRT_PAD_GPIO_AD_B0_03__PWM1_X1                   0x00c8 0x02b8 0x0000 4 0
+#define IMXRT_PAD_GPIO_AD_B0_03__GPIO1_gpio_io03           0x00c8 0x02b8 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B0_03__XTALOSC24M_REF_CLK_24M    0x00c8 0x02b8 0x0000 6 0
+#define IMXRT_PAD_GPIO_AD_B0_03__LPSPI3_PCS0               0x00c8 0x02b8 0x050c 7 0
+#define IMXRT_PAD_GPIO_AD_B0_03__CMP4_IN4                  0x00c8 0x02b8 0x0000 5 0
+/* GPIO_AD_B0_04 */
+#define IMXRT_PAD_GPIO_AD_B0_04__SRC_BOOT_MODE0            0x00cc 0x02bc 0x0000 0 0
+#define IMXRT_PAD_GPIO_AD_B0_04__MQS_RIGHT                 0x00cc 0x02bc 0x0000 1 0
+#define IMXRT_PAD_GPIO_AD_B0_04__ENET_enet_tx_data3        0x00cc 0x02bc 0x0000 2 0
+#define IMXRT_PAD_GPIO_AD_B0_04__SAI2_sai_tx_sync          0x00cc 0x02bc 0x05c4 3 1
+#define IMXRT_PAD_GPIO_AD_B0_04__CSI_csi_data09            0x00cc 0x02bc 0x041c 4 1
+#define IMXRT_PAD_GPIO_AD_B0_04__GPIO1_gpio_io04           0x00cc 0x02bc 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B0_04__PIT_TRIGGER0              0x00cc 0x02bc 0x0000 6 0
+#define IMXRT_PAD_GPIO_AD_B0_04__LPSPI3_PCS1               0x00cc 0x02bc 0x0000 7 0
+/* GPIO_AD_B0_05 */
+#define IMXRT_PAD_GPIO_AD_B0_05__SRC_BOOT_MODE1            0x00d0 0x02c0 0x0000 0 0
+#define IMXRT_PAD_GPIO_AD_B0_05__MQS_LEFT                  0x00d0 0x02c0 0x0000 1 0
+#define IMXRT_PAD_GPIO_AD_B0_05__ENET_enet_tx_data2        0x00d0 0x02c0 0x0000 2 0
+#define IMXRT_PAD_GPIO_AD_B0_05__SAI2_sai_tx_bclk          0x00d0 0x02c0 0x05c0 3 1
+#define IMXRT_PAD_GPIO_AD_B0_05__CSI_csi_data08            0x00d0 0x02c0 0x0418 4 1
+#define IMXRT_PAD_GPIO_AD_B0_05__GPIO1_gpio_io05           0x00d0 0x02c0 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B0_05__XBARA1_OUT17              0x00d0 0x02c0 0x062c 6 2 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_17 to 0x1 */
+#define IMXRT_PAD_GPIO_AD_B0_05__XBARA1_IN17               0x00d0 0x02c0 0x062c 6 2 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_17 to 0 */
+#define IMXRT_PAD_GPIO_AD_B0_05__LPSPI3_PCS2               0x00d0 0x02c0 0x0000 7 0
+/* GPIO_AD_B0_06 */
+#define IMXRT_PAD_GPIO_AD_B0_06__JTAG_TMS                  0x00d4 0x02c4 0x0000 0 0
+#define IMXRT_PAD_GPIO_AD_B0_06__GPT2_gpt_compare1         0x00d4 0x02c4 0x0000 1 0
+#define IMXRT_PAD_GPIO_AD_B0_06__ENET_enet_rx_clk          0x00d4 0x02c4 0x0000 2 0
+#define IMXRT_PAD_GPIO_AD_B0_06__SAI2_sai_rx_bclk          0x00d4 0x02c4 0x05b4 3 1
+#define IMXRT_PAD_GPIO_AD_B0_06__CSI_csi_data07            0x00d4 0x02c4 0x0414 4 1
+#define IMXRT_PAD_GPIO_AD_B0_06__GPIO1_gpio_io06           0x00d4 0x02c4 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B0_06__XBARA1_OUT18              0x00d4 0x02c4 0x0630 6 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_18 to 0x1 */
+#define IMXRT_PAD_GPIO_AD_B0_06__XBARA1_IN18               0x00d4 0x02c4 0x0630 6 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_18 to 0 */
+#define IMXRT_PAD_GPIO_AD_B0_06__LPSPI3_PCS3               0x00d4 0x02c4 0x0000 7 0
+/* GPIO_AD_B0_07 */
+#define IMXRT_PAD_GPIO_AD_B0_07__JTAG_TCK                  0x00d8 0x02c8 0x0000 0 0
+#define IMXRT_PAD_GPIO_AD_B0_07__GPT2_gpt_compare2         0x00d8 0x02c8 0x0000 1 0
+#define IMXRT_PAD_GPIO_AD_B0_07__ENET_enet_tx_er           0x00d8 0x02c8 0x0000 2 0
+#define IMXRT_PAD_GPIO_AD_B0_07__SAI2_sai_rx_sync          0x00d8 0x02c8 0x05bc 3 1
+#define IMXRT_PAD_GPIO_AD_B0_07__CSI_csi_data06            0x00d8 0x02c8 0x0410 4 1
+#define IMXRT_PAD_GPIO_AD_B0_07__GPIO1_gpio_io07           0x00d8 0x02c8 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B0_07__XBARA1_OUT19              0x00d8 0x02c8 0x0654 6 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_19 to 0x1 */
+#define IMXRT_PAD_GPIO_AD_B0_07__XBARA1_IN19               0x00d8 0x02c8 0x0654 6 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_19 to 0 */
+#define IMXRT_PAD_GPIO_AD_B0_07__ENET_1588_EVENT3_OUT      0x00d8 0x02c8 0x0000 7 0
+/* GPIO_AD_B0_08 */
+#define IMXRT_PAD_GPIO_AD_B0_08__JTAG_MOD                  0x00dc 0x02cc 0x0000 0 0
+#define IMXRT_PAD_GPIO_AD_B0_08__GPT2_gpt_compare3         0x00dc 0x02cc 0x0000 1 0
+#define IMXRT_PAD_GPIO_AD_B0_08__ENET_enet_rx_data3        0x00dc 0x02cc 0x0000 2 0
+#define IMXRT_PAD_GPIO_AD_B0_08__SAI2_sai_rx_data          0x00dc 0x02cc 0x05b8 3 1
+#define IMXRT_PAD_GPIO_AD_B0_08__CSI_csi_data05            0x00dc 0x02cc 0x040c 4 1
+#define IMXRT_PAD_GPIO_AD_B0_08__GPIO1_gpio_io08           0x00dc 0x02cc 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B0_08__XBARA1_IN20               0x00dc 0x02cc 0x0634 6 1
+#define IMXRT_PAD_GPIO_AD_B0_08__ENET_1588_EVENT3_IN       0x00dc 0x02cc 0x0000 7 0
+/* GPIO_AD_B0_09 */
+#define IMXRT_PAD_GPIO_AD_B0_09__JTAG_TDI                  0x00e0 0x02d0 0x0000 0 0
+#define IMXRT_PAD_GPIO_AD_B0_09__PWM2_A3                   0x00e0 0x02d0 0x0474 1 3
+#define IMXRT_PAD_GPIO_AD_B0_09__ENET_enet_rx_data2        0x00e0 0x02d0 0x0000 2 0
+#define IMXRT_PAD_GPIO_AD_B0_09__SAI2_sai_tx_data          0x00e0 0x02d0 0x0000 3 0
+#define IMXRT_PAD_GPIO_AD_B0_09__CSI_csi_data04            0x00e0 0x02d0 0x0408 4 1
+#define IMXRT_PAD_GPIO_AD_B0_09__GPIO1_gpio_io09           0x00e0 0x02d0 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B0_09__XBARA1_IN21               0x00e0 0x02d0 0x0658 6 1
+#define IMXRT_PAD_GPIO_AD_B0_09__GPT2_gpt_clk              0x00e0 0x02d0 0x0000 7 0
+/* GPIO_AD_B0_10 */
+#define IMXRT_PAD_GPIO_AD_B0_10__JTAG_TDO                  0x00e4 0x02d4 0x0000 0 0
+#define IMXRT_PAD_GPIO_AD_B0_10__PWM1_A3                   0x00e4 0x02d4 0x0454 1 3
+#define IMXRT_PAD_GPIO_AD_B0_10__ENET_enet_crs             0x00e4 0x02d4 0x0000 2 0
+#define IMXRT_PAD_GPIO_AD_B0_10__SAI2_sai_mclk             0x00e4 0x02d4 0x05b0 3 1
+#define IMXRT_PAD_GPIO_AD_B0_10__CSI_csi_data03            0x00e4 0x02d4 0x0404 4 1
+#define IMXRT_PAD_GPIO_AD_B0_10__GPIO1_gpio_io10           0x00e4 0x02d4 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B0_10__XBARA1_IN22               0x00e4 0x02d4 0x0638 6 1
+#define IMXRT_PAD_GPIO_AD_B0_10__ENET_1588_EVENT0_OUT      0x00e4 0x02d4 0x0000 7 0
+/* GPIO_AD_B0_11 */
+#define IMXRT_PAD_GPIO_AD_B0_11__JTAG_TRSTB                0x00e8 0x02d8 0x0000 0 0
+#define IMXRT_PAD_GPIO_AD_B0_11__PWM1_B3                   0x00e8 0x02d8 0x0464 1 3
+#define IMXRT_PAD_GPIO_AD_B0_11__ENET_enet_col             0x00e8 0x02d8 0x0000 2 0
+#define IMXRT_PAD_GPIO_AD_B0_11__WDOG1_wdog_b              0x00e8 0x02d8 0x0000 3 0
+#define IMXRT_PAD_GPIO_AD_B0_11__CSI_csi_data02            0x00e8 0x02d8 0x0400 4 1
+#define IMXRT_PAD_GPIO_AD_B0_11__GPIO1_gpio_io11           0x00e8 0x02d8 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B0_11__XBARA1_IN23               0x00e8 0x02d8 0x063c 6 1
+#define IMXRT_PAD_GPIO_AD_B0_11__ENET_1588_EVENT0_IN       0x00e8 0x02d8 0x0444 7 1
+/* GPIO_AD_B0_12 */
+#define IMXRT_PAD_GPIO_AD_B0_12__LPI2C4_SCL                0x00ec 0x02dc 0x04e4 0 1
+#define IMXRT_PAD_GPIO_AD_B0_12__CCM_PMIC_RDY              0x00ec 0x02dc 0x03fc 1 1
+#define IMXRT_PAD_GPIO_AD_B0_12__LPUART1_TX                0x00ec 0x02dc 0x0000 2 0
+#define IMXRT_PAD_GPIO_AD_B0_12__WDOG2_wdog_b              0x00ec 0x02dc 0x0000 3 0
+#define IMXRT_PAD_GPIO_AD_B0_12__PWM1_X2                   0x00ec 0x02dc 0x0000 4 0
+#define IMXRT_PAD_GPIO_AD_B0_12__GPIO1_gpio_io12           0x00ec 0x02dc 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B0_12__ENET_1588_EVENT1_OUT      0x00ec 0x02dc 0x0000 6 0
+#define IMXRT_PAD_GPIO_AD_B0_12__ARM_arm_nmi               0x00ec 0x02dc 0x0568 7 0
+#define IMXRT_PAD_GPIO_AD_B0_12__ADC1_IN1                  0x00ec 0x02dc 0x0000 5 0
+/* GPIO_AD_B0_13 */
+#define IMXRT_PAD_GPIO_AD_B0_13__LPI2C4_SDA                0x00f0 0x02e0 0x04e8 0 1
+#define IMXRT_PAD_GPIO_AD_B0_13__GPT1_gpt_clk              0x00f0 0x02e0 0x0000 1 0
+#define IMXRT_PAD_GPIO_AD_B0_13__LPUART1_RX                0x00f0 0x02e0 0x0000 2 0
+#define IMXRT_PAD_GPIO_AD_B0_13__EWM_EWM_OUT_B             0x00f0 0x02e0 0x0000 3 0
+#define IMXRT_PAD_GPIO_AD_B0_13__PWM1_X3                   0x00f0 0x02e0 0x0000 4 0
+#define IMXRT_PAD_GPIO_AD_B0_13__GPIO1_gpio_io13           0x00f0 0x02e0 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B0_13__ENET_1588_EVENT1_IN       0x00f0 0x02e0 0x0000 6 0
+#define IMXRT_PAD_GPIO_AD_B0_13__XTALOSC24M_REF_CLK_24M    0x00f0 0x02e0 0x0000 7 0
+#define IMXRT_PAD_GPIO_AD_B0_13__ADC1_IN2                  0x00f0 0x02e0 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B0_13__CMP1_IN2                  0x00f0 0x02e0 0x0000 5 0
+/* GPIO_AD_B0_14 */
+#define IMXRT_PAD_GPIO_AD_B0_14__USB2_usb_otg2_oc          0x00f4 0x02e4 0x05cc 0 0
+#define IMXRT_PAD_GPIO_AD_B0_14__XBARA1_IN24               0x00f4 0x02e4 0x0640 1 1
+#define IMXRT_PAD_GPIO_AD_B0_14__LPUART1_CTS_B             0x00f4 0x02e4 0x0000 2 0
+#define IMXRT_PAD_GPIO_AD_B0_14__ENET_1588_EVENT0_OUT      0x00f4 0x02e4 0x0000 3 0
+#define IMXRT_PAD_GPIO_AD_B0_14__CSI_csi_vsync             0x00f4 0x02e4 0x0428 4 0
+#define IMXRT_PAD_GPIO_AD_B0_14__GPIO1_gpio_io14           0x00f4 0x02e4 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B0_14__CAN2_TX                   0x00f4 0x02e4 0x0000 6 0
+#define IMXRT_PAD_GPIO_AD_B0_14__ADC1_IN3                  0x00f4 0x02e4 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B0_14__CMP2_IN2                  0x00f4 0x02e4 0x0000 5 0
+/* GPIO_AD_B0_15 */
+#define IMXRT_PAD_GPIO_AD_B0_15__USB2_usb_otg2_pwr         0x00f8 0x02e8 0x0000 0 0
+#define IMXRT_PAD_GPIO_AD_B0_15__XBARA1_IN25               0x00f8 0x02e8 0x0650 1 0
+#define IMXRT_PAD_GPIO_AD_B0_15__LPUART1_RTS_B             0x00f8 0x02e8 0x0000 2 0
+#define IMXRT_PAD_GPIO_AD_B0_15__ENET_1588_EVENT0_IN       0x00f8 0x02e8 0x0444 3 0
+#define IMXRT_PAD_GPIO_AD_B0_15__CSI_csi_hsync             0x00f8 0x02e8 0x0420 4 0
+#define IMXRT_PAD_GPIO_AD_B0_15__GPIO1_gpio_io15           0x00f8 0x02e8 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B0_15__CAN2_RX                   0x00f8 0x02e8 0x0450 6 2
+#define IMXRT_PAD_GPIO_AD_B0_15__WDOG1_wdog_rst_b_deb      0x00f8 0x02e8 0x0000 7 0
+#define IMXRT_PAD_GPIO_AD_B0_15__ADC1_IN4                  0x00f8 0x02e8 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B0_15__CMP3_IN2                  0x00f8 0x02e8 0x0000 5 0
+/* GPIO_AD_B1_00 */
+#define IMXRT_PAD_GPIO_AD_B1_00__USB2_usb_otg2_id          0x00fc 0x02ec 0x03f8 0 1
+#define IMXRT_PAD_GPIO_AD_B1_00__TMR3_TIMER0               0x00fc 0x02ec 0x057c 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM0_INPUT_SEL to 0 */
+#define IMXRT_PAD_GPIO_AD_B1_00__LPUART2_CTS_B             0x00fc 0x02ec 0x0000 2 0
+#define IMXRT_PAD_GPIO_AD_B1_00__LPI2C1_SCL                0x00fc 0x02ec 0x04cc 3 1
+#define IMXRT_PAD_GPIO_AD_B1_00__WDOG1_wdog_b              0x00fc 0x02ec 0x0000 4 0
+#define IMXRT_PAD_GPIO_AD_B1_00__GPIO1_gpio_io16           0x00fc 0x02ec 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_00__USDHC1_usdhc_wp           0x00fc 0x02ec 0x05d8 6 2
+#define IMXRT_PAD_GPIO_AD_B1_00__KPP_kpp_row7              0x00fc 0x02ec 0x0000 7 0
+#define IMXRT_PAD_GPIO_AD_B1_00__ADC1_IN5                  0x00fc 0x02ec 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_00__ADC2_IN5                  0x00fc 0x02ec 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_00__CMP4_IN2                  0x00fc 0x02ec 0x0000 5 0
+/* GPIO_AD_B1_01 */
+#define IMXRT_PAD_GPIO_AD_B1_01__USB1_usb_otg1_pwr         0x0100 0x02f0 0x0000 0 0
+#define IMXRT_PAD_GPIO_AD_B1_01__TMR3_TIMER1               0x0100 0x02f0 0x0580 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM1_INPUT_SEL to 0 */
+#define IMXRT_PAD_GPIO_AD_B1_01__LPUART2_RTS_B             0x0100 0x02f0 0x0000 2 0
+#define IMXRT_PAD_GPIO_AD_B1_01__LPI2C1_SDA                0x0100 0x02f0 0x04d0 3 1
+#define IMXRT_PAD_GPIO_AD_B1_01__CCM_PMIC_RDY              0x0100 0x02f0 0x03fc 4 2
+#define IMXRT_PAD_GPIO_AD_B1_01__GPIO1_gpio_io17           0x0100 0x02f0 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_01__USDHC1_usdhc_vselect      0x0100 0x02f0 0x0000 6 0
+#define IMXRT_PAD_GPIO_AD_B1_01__KPP_kpp_col7              0x0100 0x02f0 0x0000 7 0
+#define IMXRT_PAD_GPIO_AD_B1_01__ADC1_IN6                  0x0100 0x02f0 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_01__ADC2_IN6                  0x0100 0x02f0 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_01__CMP1_IN0                  0x0100 0x02f0 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_01__CMP2_IN0                  0x0100 0x02f0 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_01__CMP3_IN0                  0x0100 0x02f0 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_01__CMP4_IN0                  0x0100 0x02f0 0x0000 5 0
+/* GPIO_AD_B1_02 */
+#define IMXRT_PAD_GPIO_AD_B1_02__USB1_usb_otg1_id          0x0104 0x02f4 0x03f4 0 1
+#define IMXRT_PAD_GPIO_AD_B1_02__TMR3_TIMER2               0x0104 0x02f4 0x0584 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM2_INPUT_SEL to 0 */
+#define IMXRT_PAD_GPIO_AD_B1_02__LPUART2_TX                0x0104 0x02f4 0x0530 2 1
+#define IMXRT_PAD_GPIO_AD_B1_02__SPDIF_spdif_out           0x0104 0x02f4 0x0000 3 0
+#define IMXRT_PAD_GPIO_AD_B1_02__ENET_1588_EVENT2_OUT      0x0104 0x02f4 0x0000 4 0
+#define IMXRT_PAD_GPIO_AD_B1_02__GPIO1_gpio_io18           0x0104 0x02f4 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_02__USDHC1_usdhc_cd_b         0x0104 0x02f4 0x05d4 6 1
+#define IMXRT_PAD_GPIO_AD_B1_02__KPP_kpp_row6              0x0104 0x02f4 0x0000 7 0
+#define IMXRT_PAD_GPIO_AD_B1_02__ADC1_IN7                  0x0104 0x02f4 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_02__ADC2_IN7                  0x0104 0x02f4 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_02__CMP1_IN3                  0x0104 0x02f4 0x0000 5 0
+/* GPIO_AD_B1_03 */
+#define IMXRT_PAD_GPIO_AD_B1_03__USB1_usb_otg1_oc          0x0108 0x02f8 0x05d0 0 1
+#define IMXRT_PAD_GPIO_AD_B1_03__TMR3_TIMER3               0x0108 0x02f8 0x0588 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM3_INPUT_SEL to 0 */
+#define IMXRT_PAD_GPIO_AD_B1_03__LPUART2_RX                0x0108 0x02f8 0x052c 2 1
+#define IMXRT_PAD_GPIO_AD_B1_03__SPDIF_spdif_in            0x0108 0x02f8 0x05c8 3 0
+#define IMXRT_PAD_GPIO_AD_B1_03__ENET_1588_EVENT2_IN       0x0108 0x02f8 0x0000 4 0
+#define IMXRT_PAD_GPIO_AD_B1_03__GPIO1_gpio_io19           0x0108 0x02f8 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_03__USDHC2_usdhc_cd_b         0x0108 0x02f8 0x05e0 6 0
+#define IMXRT_PAD_GPIO_AD_B1_03__KPP_kpp_col6              0x0108 0x02f8 0x0000 7 0
+#define IMXRT_PAD_GPIO_AD_B1_03__ADC1_IN8                  0x0108 0x02f8 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_03__ADC2_IN8                  0x0108 0x02f8 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_03__CMP2_IN3                  0x0108 0x02f8 0x0000 5 0
+/* GPIO_AD_B1_04 */
+#define IMXRT_PAD_GPIO_AD_B1_04__FLEXSPI_FLEXSPI_B_DATA3   0x010c 0x02fc 0x04c4 0 1
+#define IMXRT_PAD_GPIO_AD_B1_04__ENET_enet_mdc             0x010c 0x02fc 0x0000 1 0
+#define IMXRT_PAD_GPIO_AD_B1_04__LPUART3_CTS_B             0x010c 0x02fc 0x0534 2 1
+#define IMXRT_PAD_GPIO_AD_B1_04__SPDIF_spdif_sr_clk        0x010c 0x02fc 0x0000 3 0
+#define IMXRT_PAD_GPIO_AD_B1_04__CSI_csi_pixclk            0x010c 0x02fc 0x0424 4 0
+#define IMXRT_PAD_GPIO_AD_B1_04__GPIO1_gpio_io20           0x010c 0x02fc 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_04__USDHC2_usdhc_data0        0x010c 0x02fc 0x05e8 6 1
+#define IMXRT_PAD_GPIO_AD_B1_04__KPP_kpp_row5              0x010c 0x02fc 0x0000 7 0
+#define IMXRT_PAD_GPIO_AD_B1_04__ADC1_IN9                  0x010c 0x02fc 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_04__ADC2_IN9                  0x010c 0x02fc 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_04__CMP3_IN3                  0x010c 0x02fc 0x0000 5 0
+/* GPIO_AD_B1_05 */
+#define IMXRT_PAD_GPIO_AD_B1_05__FLEXSPI_FLEXSPI_B_DATA2   0x0110 0x0300 0x04c0 0 1
+#define IMXRT_PAD_GPIO_AD_B1_05__ENET_enet_mdio            0x0110 0x0300 0x0430 1 0
+#define IMXRT_PAD_GPIO_AD_B1_05__LPUART3_RTS_B             0x0110 0x0300 0x0000 2 0
+#define IMXRT_PAD_GPIO_AD_B1_05__SPDIF_spdif_out           0x0110 0x0300 0x0000 3 0
+#define IMXRT_PAD_GPIO_AD_B1_05__CSI_csi_mclk              0x0110 0x0300 0x0000 4 0
+#define IMXRT_PAD_GPIO_AD_B1_05__GPIO1_gpio_io21           0x0110 0x0300 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_05__USDHC2_usdhc_data1        0x0110 0x0300 0x05ec 6 1
+#define IMXRT_PAD_GPIO_AD_B1_05__KPP_kpp_col5              0x0110 0x0300 0x0000 7 0
+#define IMXRT_PAD_GPIO_AD_B1_05__ADC1_IN10                 0x0110 0x0300 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_05__ADC2_IN10                 0x0110 0x0300 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_05__CMP4_IN3                  0x0110 0x0300 0x0000 5 0
+/* GPIO_AD_B1_06 */
+#define IMXRT_PAD_GPIO_AD_B1_06__FLEXSPI_FLEXSPI_B_DATA1   0x0114 0x0304 0x04bc 0 1
+#define IMXRT_PAD_GPIO_AD_B1_06__LPI2C3_SDA                0x0114 0x0304 0x04e0 1 2
+#define IMXRT_PAD_GPIO_AD_B1_06__LPUART3_TX                0x0114 0x0304 0x053c 2 0
+#define IMXRT_PAD_GPIO_AD_B1_06__SPDIF_spdif_lock          0x0114 0x0304 0x0000 3 0
+#define IMXRT_PAD_GPIO_AD_B1_06__CSI_csi_vsync             0x0114 0x0304 0x0428 4 1
+#define IMXRT_PAD_GPIO_AD_B1_06__GPIO1_gpio_io22           0x0114 0x0304 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_06__USDHC2_usdhc_data2        0x0114 0x0304 0x05f0 6 1
+#define IMXRT_PAD_GPIO_AD_B1_06__KPP_kpp_row4              0x0114 0x0304 0x0000 7 0
+#define IMXRT_PAD_GPIO_AD_B1_06__ADC1_IN11                 0x0114 0x0304 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_06__ADC2_IN11                 0x0114 0x0304 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_06__CMP1_IN1                  0x0114 0x0304 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_06__CMP2_IN1                  0x0114 0x0304 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_06__CMP3_IN1                  0x0114 0x0304 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_06__CMP4_IN1                  0x0114 0x0304 0x0000 5 0
+/* GPIO_AD_B1_07 */
+#define IMXRT_PAD_GPIO_AD_B1_07__FLEXSPI_FLEXSPI_B_DATA0   0x0118 0x0308 0x04b8 0 1
+#define IMXRT_PAD_GPIO_AD_B1_07__LPI2C3_SCL                0x0118 0x0308 0x04dc 1 2
+#define IMXRT_PAD_GPIO_AD_B1_07__LPUART3_RX                0x0118 0x0308 0x0538 2 0
+#define IMXRT_PAD_GPIO_AD_B1_07__SPDIF_spdif_ext_clk       0x0118 0x0308 0x0000 3 0
+#define IMXRT_PAD_GPIO_AD_B1_07__CSI_csi_hsync             0x0118 0x0308 0x0420 4 1
+#define IMXRT_PAD_GPIO_AD_B1_07__GPIO1_gpio_io23           0x0118 0x0308 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_07__USDHC2_usdhc_data3        0x0118 0x0308 0x05f4 6 1
+#define IMXRT_PAD_GPIO_AD_B1_07__KPP_kpp_col4              0x0118 0x0308 0x0000 7 0
+#define IMXRT_PAD_GPIO_AD_B1_07__ADC1_IN12                 0x0118 0x0308 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_07__ADC2_IN12                 0x0118 0x0308 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_07__CMP1_IN5                  0x0118 0x0308 0x0000 5 0
+/* GPIO_AD_B1_08 */
+#define IMXRT_PAD_GPIO_AD_B1_08__FLEXSPI_FLEXSPI_A_SS1_B   0x011c 0x030c 0x0000 0 0
+#define IMXRT_PAD_GPIO_AD_B1_08__PWM4_A0                   0x011c 0x030c 0x0494 1 1
+#define IMXRT_PAD_GPIO_AD_B1_08__CAN1_TX                   0x011c 0x030c 0x0000 2 0
+#define IMXRT_PAD_GPIO_AD_B1_08__CCM_PMIC_RDY              0x011c 0x030c 0x03fc 3 3
+#define IMXRT_PAD_GPIO_AD_B1_08__CSI_csi_data09            0x011c 0x030c 0x041c 4 0
+#define IMXRT_PAD_GPIO_AD_B1_08__GPIO1_gpio_io24           0x011c 0x030c 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_08__USDHC2_usdhc_cmd          0x011c 0x030c 0x05e4 6 1
+#define IMXRT_PAD_GPIO_AD_B1_08__KPP_kpp_row3              0x011c 0x030c 0x0000 7 0
+#define IMXRT_PAD_GPIO_AD_B1_08__ADC1_IN13                 0x011c 0x030c 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_08__ADC2_IN13                 0x011c 0x030c 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_08__CMP2_IN5                  0x011c 0x030c 0x0000 5 0
+/* GPIO_AD_B1_09 */
+#define IMXRT_PAD_GPIO_AD_B1_09__FLEXSPI_FLEXSPI_A_DQS     0x0120 0x0310 0x04a4 0 1
+#define IMXRT_PAD_GPIO_AD_B1_09__PWM4_A1                   0x0120 0x0310 0x0498 1 1
+#define IMXRT_PAD_GPIO_AD_B1_09__CAN1_RX                   0x0120 0x0310 0x044c 2 2
+#define IMXRT_PAD_GPIO_AD_B1_09__SAI1_sai_mclk             0x0120 0x0310 0x058c 3 1
+#define IMXRT_PAD_GPIO_AD_B1_09__CSI_csi_data08            0x0120 0x0310 0x0418 4 0
+#define IMXRT_PAD_GPIO_AD_B1_09__GPIO1_gpio_io25           0x0120 0x0310 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_09__USDHC2_usdhc_clk          0x0120 0x0310 0x05dc 6 1
+#define IMXRT_PAD_GPIO_AD_B1_09__KPP_kpp_col3              0x0120 0x0310 0x0000 7 0
+#define IMXRT_PAD_GPIO_AD_B1_09__ADC1_IN14                 0x0120 0x0310 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_09__ADC2_IN14                 0x0120 0x0310 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_09__CMP3_IN5                  0x0120 0x0310 0x0000 5 0
+/* GPIO_AD_B1_10 */
+#define IMXRT_PAD_GPIO_AD_B1_10__FLEXSPI_FLEXSPI_A_DATA3   0x0124 0x0314 0x04b4 0 1
+#define IMXRT_PAD_GPIO_AD_B1_10__WDOG1_wdog_b              0x0124 0x0314 0x0000 1 0
+#define IMXRT_PAD_GPIO_AD_B1_10__LPUART8_TX                0x0124 0x0314 0x0564 2 1
+#define IMXRT_PAD_GPIO_AD_B1_10__SAI1_sai_rx_sync          0x0124 0x0314 0x05a4 3 1
+#define IMXRT_PAD_GPIO_AD_B1_10__CSI_csi_data07            0x0124 0x0314 0x0414 4 0
+#define IMXRT_PAD_GPIO_AD_B1_10__GPIO1_gpio_io26           0x0124 0x0314 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_10__USDHC2_usdhc_wp           0x0124 0x0314 0x0608 6 1
+#define IMXRT_PAD_GPIO_AD_B1_10__KPP_kpp_row2              0x0124 0x0314 0x0000 7 0
+#define IMXRT_PAD_GPIO_AD_B1_10__ADC1_IN15                 0x0124 0x0314 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_10__ADC2_IN15                 0x0124 0x0314 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_10__CMP4_IN5                  0x0124 0x0314 0x0000 5 0
+/* GPIO_AD_B1_11 */
+#define IMXRT_PAD_GPIO_AD_B1_11__FLEXSPI_FLEXSPI_A_DATA2   0x0128 0x0318 0x04b0 0 1
+#define IMXRT_PAD_GPIO_AD_B1_11__EWM_EWM_OUT_B             0x0128 0x0318 0x0000 1 0
+#define IMXRT_PAD_GPIO_AD_B1_11__LPUART8_RX                0x0128 0x0318 0x0560 2 1
+#define IMXRT_PAD_GPIO_AD_B1_11__SAI1_sai_rx_bclk          0x0128 0x0318 0x0590 3 1
+#define IMXRT_PAD_GPIO_AD_B1_11__CSI_csi_data06            0x0128 0x0318 0x0410 4 0
+#define IMXRT_PAD_GPIO_AD_B1_11__GPIO1_gpio_io27           0x0128 0x0318 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_11__USDHC2_usdhc_reset_b      0x0128 0x0318 0x0000 6 0
+#define IMXRT_PAD_GPIO_AD_B1_11__KPP_kpp_col2              0x0128 0x0318 0x0000 7 0
+#define IMXRT_PAD_GPIO_AD_B1_11__ADC1_IN0                  0x0128 0x0318 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_11__ADC2_IN0                  0x0128 0x0318 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_11__CMP1_IN6                  0x0128 0x0318 0x0000 5 0
+/* GPIO_AD_B1_12 */
+#define IMXRT_PAD_GPIO_AD_B1_12__FLEXSPI_FLEXSPI_A_DATA1   0x012c 0x031c 0x04ac 0 1
+#define IMXRT_PAD_GPIO_AD_B1_12__CMP1_OUT                  0x012c 0x031c 0x0000 1 0
+#define IMXRT_PAD_GPIO_AD_B1_12__LPSPI3_PCS0               0x012c 0x031c 0x050c 2 1
+#define IMXRT_PAD_GPIO_AD_B1_12__SAI1_sai_rx_data0         0x012c 0x031c 0x0594 3 1
+#define IMXRT_PAD_GPIO_AD_B1_12__CSI_csi_data05            0x012c 0x031c 0x040c 4 0
+#define IMXRT_PAD_GPIO_AD_B1_12__GPIO1_gpio_io28           0x012c 0x031c 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_12__USDHC2_usdhc_data4        0x012c 0x031c 0x05f8 6 1
+#define IMXRT_PAD_GPIO_AD_B1_12__KPP_kpp_row1              0x012c 0x031c 0x0000 7 0
+#define IMXRT_PAD_GPIO_AD_B1_12__ADC2_IN1                  0x012c 0x031c 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_12__CMP2_IN6                  0x012c 0x031c 0x0000 5 0
+/* GPIO_AD_B1_13 */
+#define IMXRT_PAD_GPIO_AD_B1_13__FLEXSPI_FLEXSPI_A_DATA0   0x0130 0x0320 0x04a8 0 1
+#define IMXRT_PAD_GPIO_AD_B1_13__CMP2_OUT                  0x0130 0x0320 0x0000 1 0
+#define IMXRT_PAD_GPIO_AD_B1_13__LPSPI3_SDI                0x0130 0x0320 0x0514 2 1
+#define IMXRT_PAD_GPIO_AD_B1_13__SAI1_sai_tx_data0         0x0130 0x0320 0x0000 3 0
+#define IMXRT_PAD_GPIO_AD_B1_13__CSI_csi_data04            0x0130 0x0320 0x0408 4 0
+#define IMXRT_PAD_GPIO_AD_B1_13__GPIO1_gpio_io29           0x0130 0x0320 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_13__USDHC2_usdhc_data5        0x0130 0x0320 0x05fc 6 1
+#define IMXRT_PAD_GPIO_AD_B1_13__KPP_kpp_col1              0x0130 0x0320 0x0000 7 0
+#define IMXRT_PAD_GPIO_AD_B1_13__ADC2_IN2                  0x0130 0x0320 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_13__CMP3_IN6                  0x0130 0x0320 0x0000 5 0
+/* GPIO_AD_B1_14 */
+#define IMXRT_PAD_GPIO_AD_B1_14__FLEXSPI_FLEXSPI_A_SCLK    0x0134 0x0324 0x04c8 0 1
+#define IMXRT_PAD_GPIO_AD_B1_14__CMP3_OUT                  0x0134 0x0324 0x0000 1 0
+#define IMXRT_PAD_GPIO_AD_B1_14__LPSPI3_SDO                0x0134 0x0324 0x0518 2 1
+#define IMXRT_PAD_GPIO_AD_B1_14__SAI1_sai_tx_bclk          0x0134 0x0324 0x05a8 3 1
+#define IMXRT_PAD_GPIO_AD_B1_14__CSI_csi_data03            0x0134 0x0324 0x0404 4 0
+#define IMXRT_PAD_GPIO_AD_B1_14__GPIO1_gpio_io30           0x0134 0x0324 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_14__USDHC2_usdhc_data6        0x0134 0x0324 0x0600 6 1
+#define IMXRT_PAD_GPIO_AD_B1_14__KPP_kpp_row0              0x0134 0x0324 0x0000 7 0
+#define IMXRT_PAD_GPIO_AD_B1_14__ADC2_IN3                  0x0134 0x0324 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_14__CMP4_IN6                  0x0134 0x0324 0x0000 5 0
+/* GPIO_AD_B1_15 */
+#define IMXRT_PAD_GPIO_AD_B1_15__FLEXSPI_FLEXSPI_A_SS0_B   0x0138 0x0328 0x0000 0 0
+#define IMXRT_PAD_GPIO_AD_B1_15__CMP4_OUT                  0x0138 0x0328 0x0000 1 0
+#define IMXRT_PAD_GPIO_AD_B1_15__LPSPI3_SCK                0x0138 0x0328 0x0000 2 0
+#define IMXRT_PAD_GPIO_AD_B1_15__SAI1_sai_tx_sync          0x0138 0x0328 0x05ac 3 1
+#define IMXRT_PAD_GPIO_AD_B1_15__CSI_csi_data02            0x0138 0x0328 0x0400 4 0
+#define IMXRT_PAD_GPIO_AD_B1_15__GPIO1_gpio_io31           0x0138 0x0328 0x0000 5 0
+#define IMXRT_PAD_GPIO_AD_B1_15__USDHC2_usdhc_data7        0x0138 0x0328 0x0604 6 1
+#define IMXRT_PAD_GPIO_AD_B1_15__KPP_kpp_col0              0x0138 0x0328 0x0000 7 0
+#define IMXRT_PAD_GPIO_AD_B1_15__ADC2_IN4                  0x0138 0x0328 0x0000 5 0
+/* GPIO_B0_00 */
+#define IMXRT_PAD_GPIO_B0_00__LCDIF_lcdif_clk              0x013c 0x032c 0x0000 0 0
+#define IMXRT_PAD_GPIO_B0_00__TMR1_TIMER0                  0x013c 0x032c 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER1_TRM0_INPUT_SEL to 0 */
+#define IMXRT_PAD_GPIO_B0_00__MQS_RIGHT                    0x013c 0x032c 0x0000 2 0
+#define IMXRT_PAD_GPIO_B0_00__LPSPI4_PCS0                  0x013c 0x032c 0x051c 3 0
+#define IMXRT_PAD_GPIO_B0_00__FLEXIO2_IO00                 0x013c 0x032c 0x0000 4 0
+#define IMXRT_PAD_GPIO_B0_00__GPIO2_gpio_io00              0x013c 0x032c 0x0000 5 0
+#define IMXRT_PAD_GPIO_B0_00__SEMC_CSX1                    0x013c 0x032c 0x0000 6 0
+/* GPIO_B0_01 */
+#define IMXRT_PAD_GPIO_B0_01__LCDIF_lcdif_enable           0x0140 0x0330 0x0000 0 0
+#define IMXRT_PAD_GPIO_B0_01__TMR1_TIMER1                  0x0140 0x0330 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER1_TRM1_INPUT_SEL to 0 */
+#define IMXRT_PAD_GPIO_B0_01__MQS_LEFT                     0x0140 0x0330 0x0000 2 0
+#define IMXRT_PAD_GPIO_B0_01__LPSPI4_SDI                   0x0140 0x0330 0x0524 3 0
+#define IMXRT_PAD_GPIO_B0_01__FLEXIO2_IO01                 0x0140 0x0330 0x0000 4 0
+#define IMXRT_PAD_GPIO_B0_01__GPIO2_gpio_io01              0x0140 0x0330 0x0000 5 0
+#define IMXRT_PAD_GPIO_B0_01__SEMC_CSX2                    0x0140 0x0330 0x0000 6 0
+/* GPIO_B0_02 */
+#define IMXRT_PAD_GPIO_B0_02__LCDIF_lcdif_hsync            0x0144 0x0334 0x0000 0 0
+#define IMXRT_PAD_GPIO_B0_02__TMR1_TIMER2                  0x0144 0x0334 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER1_TRM2_INPUT_SEL to 0 */
+#define IMXRT_PAD_GPIO_B0_02__CAN1_TX                      0x0144 0x0334 0x0000 2 0
+#define IMXRT_PAD_GPIO_B0_02__LPSPI4_SDO                   0x0144 0x0334 0x0528 3 0
+#define IMXRT_PAD_GPIO_B0_02__FLEXIO2_IO02                 0x0144 0x0334 0x0000 4 0
+#define IMXRT_PAD_GPIO_B0_02__GPIO2_gpio_io02              0x0144 0x0334 0x0000 5 0
+#define IMXRT_PAD_GPIO_B0_02__SEMC_CSX3                    0x0144 0x0334 0x0000 6 0
+/* GPIO_B0_03 */
+#define IMXRT_PAD_GPIO_B0_03__LCDIF_lcdif_vsync            0x0148 0x0338 0x0000 0 0
+#define IMXRT_PAD_GPIO_B0_03__TMR2_TIMER0                  0x0148 0x0338 0x056c 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER2_TRM0_INPUT_SEL to 0 */
+#define IMXRT_PAD_GPIO_B0_03__CAN1_RX                      0x0148 0x0338 0x044c 2 3
+#define IMXRT_PAD_GPIO_B0_03__LPSPI4_SCK                   0x0148 0x0338 0x0520 3 0
+#define IMXRT_PAD_GPIO_B0_03__FLEXIO2_IO03                 0x0148 0x0338 0x0000 4 0
+#define IMXRT_PAD_GPIO_B0_03__GPIO2_gpio_io03              0x0148 0x0338 0x0000 5 0
+#define IMXRT_PAD_GPIO_B0_03__WDOG2_wdog_rst_b_deb         0x0148 0x0338 0x0000 6 0
+/* GPIO_B0_04 */
+#define IMXRT_PAD_GPIO_B0_04__LCDIF_lcdif_data00           0x014c 0x033c 0x0000 0 0
+#define IMXRT_PAD_GPIO_B0_04__TMR2_TIMER1                  0x014c 0x033c 0x0570 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER2_TRM1_INPUT_SEL to 0 */
+#define IMXRT_PAD_GPIO_B0_04__LPI2C2_SCL                   0x014c 0x033c 0x04d4 2 1
+#define IMXRT_PAD_GPIO_B0_04__ARM_TRACE0                   0x014c 0x033c 0x0000 3 0
+#define IMXRT_PAD_GPIO_B0_04__FLEXIO2_IO04                 0x014c 0x033c 0x0000 4 0
+#define IMXRT_PAD_GPIO_B0_04__GPIO2_gpio_io04              0x014c 0x033c 0x0000 5 0
+#define IMXRT_PAD_GPIO_B0_04__SRC_BOOT_CFG0                0x014c 0x033c 0x0000 6 0
+/* GPIO_B0_05 */
+#define IMXRT_PAD_GPIO_B0_05__LCDIF_lcdif_data01           0x0150 0x0340 0x0000 0 0
+#define IMXRT_PAD_GPIO_B0_05__TMR2_TIMER2                  0x0150 0x0340 0x0574 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER2_TRM2_INPUT_SEL to 0 */
+#define IMXRT_PAD_GPIO_B0_05__LPI2C2_SDA                   0x0150 0x0340 0x04d8 2 1
+#define IMXRT_PAD_GPIO_B0_05__ARM_TRACE1                   0x0150 0x0340 0x0000 3 0
+#define IMXRT_PAD_GPIO_B0_05__FLEXIO2_IO05                 0x0150 0x0340 0x0000 4 0
+#define IMXRT_PAD_GPIO_B0_05__GPIO2_gpio_io05              0x0150 0x0340 0x0000 5 0
+#define IMXRT_PAD_GPIO_B0_05__SRC_BOOT_CFG1                0x0150 0x0340 0x0000 6 0
+/* GPIO_B0_06 */
+#define IMXRT_PAD_GPIO_B0_06__LCDIF_lcdif_data02           0x0154 0x0344 0x0000 0 0
+#define IMXRT_PAD_GPIO_B0_06__TMR3_TIMER0                  0x0154 0x0344 0x057c 1 2 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM0_INPUT_SEL to 0 */
+#define IMXRT_PAD_GPIO_B0_06__PWM2_A0                      0x0154 0x0344 0x0478 2 1
+#define IMXRT_PAD_GPIO_B0_06__ARM_TRACE2                   0x0154 0x0344 0x0000 3 0
+#define IMXRT_PAD_GPIO_B0_06__FLEXIO2_IO06                 0x0154 0x0344 0x0000 4 0
+#define IMXRT_PAD_GPIO_B0_06__GPIO2_gpio_io06              0x0154 0x0344 0x0000 5 0
+#define IMXRT_PAD_GPIO_B0_06__SRC_BOOT_CFG2                0x0154 0x0344 0x0000 6 0
+/* GPIO_B0_07 */
+#define IMXRT_PAD_GPIO_B0_07__LCDIF_lcdif_data03           0x0158 0x0348 0x0000 0 0
+#define IMXRT_PAD_GPIO_B0_07__TMR3_TIMER1                  0x0158 0x0348 0x0580 1 2 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM1_INPUT_SEL to 0 */
+#define IMXRT_PAD_GPIO_B0_07__PWM2_B0                      0x0158 0x0348 0x0488 2 1
+#define IMXRT_PAD_GPIO_B0_07__ARM_TRACE3                   0x0158 0x0348 0x0000 3 0
+#define IMXRT_PAD_GPIO_B0_07__FLEXIO2_IO07                 0x0158 0x0348 0x0000 4 0
+#define IMXRT_PAD_GPIO_B0_07__GPIO2_gpio_io07              0x0158 0x0348 0x0000 5 0
+#define IMXRT_PAD_GPIO_B0_07__SRC_BOOT_CFG3                0x0158 0x0348 0x0000 6 0
+/* GPIO_B0_08 */
+#define IMXRT_PAD_GPIO_B0_08__LCDIF_lcdif_data04           0x015c 0x034c 0x0000 0 0
+#define IMXRT_PAD_GPIO_B0_08__TMR3_TIMER2                  0x015c 0x034c 0x0584 1 2 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM2_INPUT_SEL to 0 */
+#define IMXRT_PAD_GPIO_B0_08__PWM2_A1                      0x015c 0x034c 0x047c 2 1
+#define IMXRT_PAD_GPIO_B0_08__LPUART3_TX                   0x015c 0x034c 0x053c 3 2
+#define IMXRT_PAD_GPIO_B0_08__FLEXIO2_IO08                 0x015c 0x034c 0x0000 4 0
+#define IMXRT_PAD_GPIO_B0_08__GPIO2_gpio_io08              0x015c 0x034c 0x0000 5 0
+#define IMXRT_PAD_GPIO_B0_08__SRC_BOOT_CFG4                0x015c 0x034c 0x0000 6 0
+/* GPIO_B0_09 */
+#define IMXRT_PAD_GPIO_B0_09__LCDIF_lcdif_data05           0x0160 0x0350 0x0000 0 0
+#define IMXRT_PAD_GPIO_B0_09__TMR4_TIMER0                  0x0160 0x0350 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER4_TRM0_INPUT_SEL to 0 */
+#define IMXRT_PAD_GPIO_B0_09__PWM2_B1                      0x0160 0x0350 0x048c 2 1
+#define IMXRT_PAD_GPIO_B0_09__LPUART3_RX                   0x0160 0x0350 0x0538 3 2
+#define IMXRT_PAD_GPIO_B0_09__FLEXIO2_IO09                 0x0160 0x0350 0x0000 4 0
+#define IMXRT_PAD_GPIO_B0_09__GPIO2_gpio_io09              0x0160 0x0350 0x0000 5 0
+#define IMXRT_PAD_GPIO_B0_09__SRC_BOOT_CFG5                0x0160 0x0350 0x0000 6 0
+/* GPIO_B0_10 */
+#define IMXRT_PAD_GPIO_B0_10__LCDIF_lcdif_data06           0x0164 0x0354 0x0000 0 0
+#define IMXRT_PAD_GPIO_B0_10__TMR4_TIMER1                  0x0164 0x0354 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER4_TRM1_INPUT_SEL to 0 */
+#define IMXRT_PAD_GPIO_B0_10__PWM2_A2                      0x0164 0x0354 0x0480 2 1
+#define IMXRT_PAD_GPIO_B0_10__SAI1_sai_tx_data3            0x0164 0x0354 0x0598 3 1
+#define IMXRT_PAD_GPIO_B0_10__FLEXIO2_IO10                 0x0164 0x0354 0x0000 4 0
+#define IMXRT_PAD_GPIO_B0_10__GPIO2_gpio_io10              0x0164 0x0354 0x0000 5 0
+#define IMXRT_PAD_GPIO_B0_10__SRC_BOOT_CFG6                0x0164 0x0354 0x0000 6 0
+/* GPIO_B0_11 */
+#define IMXRT_PAD_GPIO_B0_11__LCDIF_lcdif_data07           0x0168 0x0358 0x0000 0 0
+#define IMXRT_PAD_GPIO_B0_11__TMR4_TIMER2                  0x0168 0x0358 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER4_TRM2_INPUT_SEL to 0 */
+#define IMXRT_PAD_GPIO_B0_11__PWM2_B2                      0x0168 0x0358 0x0490 2 1
+#define IMXRT_PAD_GPIO_B0_11__SAI1_sai_tx_data2            0x0168 0x0358 0x059c 3 1
+#define IMXRT_PAD_GPIO_B0_11__FLEXIO2_IO11                 0x0168 0x0358 0x0000 4 0
+#define IMXRT_PAD_GPIO_B0_11__GPIO2_gpio_io11              0x0168 0x0358 0x0000 5 0
+#define IMXRT_PAD_GPIO_B0_11__SRC_BOOT_CFG7                0x0168 0x0358 0x0000 6 0
+/* GPIO_B0_12 */
+#define IMXRT_PAD_GPIO_B0_12__LCDIF_lcdif_data08           0x016c 0x035c 0x0000 0 0
+#define IMXRT_PAD_GPIO_B0_12__XBARA1_OUT10                 0x016c 0x035c 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_10 to 0x1 */
+#define IMXRT_PAD_GPIO_B0_12__XBARA1_IN10                  0x016c 0x035c 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_10 to 0 */
+#define IMXRT_PAD_GPIO_B0_12__ARM_arm_trace_clk            0x016c 0x035c 0x0000 2 0
+#define IMXRT_PAD_GPIO_B0_12__SAI1_sai_tx_data1            0x016c 0x035c 0x05a0 3 1
+#define IMXRT_PAD_GPIO_B0_12__FLEXIO2_IO12                 0x016c 0x035c 0x0000 4 0
+#define IMXRT_PAD_GPIO_B0_12__GPIO2_gpio_io12              0x016c 0x035c 0x0000 5 0
+#define IMXRT_PAD_GPIO_B0_12__SRC_BOOT_CFG8                0x016c 0x035c 0x0000 6 0
+/* GPIO_B0_13 */
+#define IMXRT_PAD_GPIO_B0_13__LCDIF_lcdif_data09           0x0170 0x0360 0x0000 0 0
+#define IMXRT_PAD_GPIO_B0_13__XBARA1_OUT11                 0x0170 0x0360 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_11 to 0x1 */
+#define IMXRT_PAD_GPIO_B0_13__XBARA1_IN11                  0x0170 0x0360 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_11 to 0 */
+#define IMXRT_PAD_GPIO_B0_13__ARM_arm_trace_swo            0x0170 0x0360 0x0000 2 0
+#define IMXRT_PAD_GPIO_B0_13__SAI1_sai_mclk                0x0170 0x0360 0x058c 3 2
+#define IMXRT_PAD_GPIO_B0_13__FLEXIO2_IO13                 0x0170 0x0360 0x0000 4 0
+#define IMXRT_PAD_GPIO_B0_13__GPIO2_gpio_io13              0x0170 0x0360 0x0000 5 0
+#define IMXRT_PAD_GPIO_B0_13__SRC_BOOT_CFG9                0x0170 0x0360 0x0000 6 0
+/* GPIO_B0_14 */
+#define IMXRT_PAD_GPIO_B0_14__LCDIF_lcdif_data10           0x0174 0x0364 0x0000 0 0
+#define IMXRT_PAD_GPIO_B0_14__XBARA1_OUT12                 0x0174 0x0364 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_12 to 0x1 */
+#define IMXRT_PAD_GPIO_B0_14__XBARA1_IN12                  0x0174 0x0364 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_12 to 0 */
+#define IMXRT_PAD_GPIO_B0_14__ARM_arm_cm7_txev             0x0174 0x0364 0x0000 2 0
+#define IMXRT_PAD_GPIO_B0_14__SAI1_sai_rx_sync             0x0174 0x0364 0x05a4 3 2
+#define IMXRT_PAD_GPIO_B0_14__FLEXIO2_IO14                 0x0174 0x0364 0x0000 4 0
+#define IMXRT_PAD_GPIO_B0_14__GPIO2_gpio_io14              0x0174 0x0364 0x0000 5 0
+#define IMXRT_PAD_GPIO_B0_14__SRC_BOOT_CFG10               0x0174 0x0364 0x0000 6 0
+/* GPIO_B0_15 */
+#define IMXRT_PAD_GPIO_B0_15__LCDIF_lcdif_data11           0x0178 0x0368 0x0000 0 0
+#define IMXRT_PAD_GPIO_B0_15__XBARA1_OUT13                 0x0178 0x0368 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_13 to 0x1 */
+#define IMXRT_PAD_GPIO_B0_15__XBARA1_IN13                  0x0178 0x0368 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_13 to 0 */
+#define IMXRT_PAD_GPIO_B0_15__ARM_arm_cm7_rxev             0x0178 0x0368 0x0000 2 0
+#define IMXRT_PAD_GPIO_B0_15__SAI1_sai_rx_bclk             0x0178 0x0368 0x0590 3 2
+#define IMXRT_PAD_GPIO_B0_15__FLEXIO2_IO15                 0x0178 0x0368 0x0000 4 0
+#define IMXRT_PAD_GPIO_B0_15__GPIO2_gpio_io15              0x0178 0x0368 0x0000 5 0
+#define IMXRT_PAD_GPIO_B0_15__SRC_BOOT_CFG11               0x0178 0x0368 0x0000 6 0
+/* GPIO_B1_00 */
+#define IMXRT_PAD_GPIO_B1_00__LCDIF_lcdif_data12           0x017c 0x036c 0x0000 0 0
+#define IMXRT_PAD_GPIO_B1_00__XBARA1_OUT14                 0x017c 0x036c 0x0644 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_14 to 0x1 */
+#define IMXRT_PAD_GPIO_B1_00__XBARA1_IN14                  0x017c 0x036c 0x0644 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_14 to 0 */
+#define IMXRT_PAD_GPIO_B1_00__LPUART4_TX                   0x017c 0x036c 0x0544 2 2
+#define IMXRT_PAD_GPIO_B1_00__SAI1_sai_rx_data0            0x017c 0x036c 0x0594 3 2
+#define IMXRT_PAD_GPIO_B1_00__FLEXIO2_IO16                 0x017c 0x036c 0x0000 4 0
+#define IMXRT_PAD_GPIO_B1_00__GPIO2_gpio_io16              0x017c 0x036c 0x0000 5 0
+#define IMXRT_PAD_GPIO_B1_00__PWM1_A3                      0x017c 0x036c 0x0454 6 4
+/* GPIO_B1_01 */
+#define IMXRT_PAD_GPIO_B1_01__LCDIF_lcdif_data13           0x0180 0x0370 0x0000 0 0
+#define IMXRT_PAD_GPIO_B1_01__XBARA1_OUT15                 0x0180 0x0370 0x0648 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_15 to 0x1 */
+#define IMXRT_PAD_GPIO_B1_01__XBARA1_IN15                  0x0180 0x0370 0x0648 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_15 to 0 */
+#define IMXRT_PAD_GPIO_B1_01__LPUART4_RX                   0x0180 0x0370 0x0540 2 2
+#define IMXRT_PAD_GPIO_B1_01__SAI1_sai_tx_data0            0x0180 0x0370 0x0000 3 0
+#define IMXRT_PAD_GPIO_B1_01__FLEXIO2_IO17                 0x0180 0x0370 0x0000 4 0
+#define IMXRT_PAD_GPIO_B1_01__GPIO2_gpio_io17              0x0180 0x0370 0x0000 5 0
+#define IMXRT_PAD_GPIO_B1_01__PWM1_B3                      0x0180 0x0370 0x0464 6 4
+/* GPIO_B1_02 */
+#define IMXRT_PAD_GPIO_B1_02__LCDIF_lcdif_data14           0x0184 0x0374 0x0000 0 0
+#define IMXRT_PAD_GPIO_B1_02__XBARA1_OUT16                 0x0184 0x0374 0x064c 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_16 to 0x1 */
+#define IMXRT_PAD_GPIO_B1_02__XBARA1_IN16                  0x0184 0x0374 0x064c 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_16 to 0 */
+#define IMXRT_PAD_GPIO_B1_02__LPSPI4_PCS2                  0x0184 0x0374 0x0000 2 0
+#define IMXRT_PAD_GPIO_B1_02__SAI1_sai_tx_bclk             0x0184 0x0374 0x05a8 3 2
+#define IMXRT_PAD_GPIO_B1_02__FLEXIO2_IO18                 0x0184 0x0374 0x0000 4 0
+#define IMXRT_PAD_GPIO_B1_02__GPIO2_gpio_io18              0x0184 0x0374 0x0000 5 0
+#define IMXRT_PAD_GPIO_B1_02__PWM2_A3                      0x0184 0x0374 0x0474 6 4
+/* GPIO_B1_03 */
+#define IMXRT_PAD_GPIO_B1_03__LCDIF_lcdif_data15           0x0188 0x0378 0x0000 0 0
+#define IMXRT_PAD_GPIO_B1_03__XBARA1_OUT17                 0x0188 0x0378 0x062c 1 3 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_17 to 0x1 */
+#define IMXRT_PAD_GPIO_B1_03__XBARA1_IN17                  0x0188 0x0378 0x062c 1 3 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_17 to 0 */
+#define IMXRT_PAD_GPIO_B1_03__LPSPI4_PCS1                  0x0188 0x0378 0x0000 2 0
+#define IMXRT_PAD_GPIO_B1_03__SAI1_sai_tx_sync             0x0188 0x0378 0x05ac 3 2
+#define IMXRT_PAD_GPIO_B1_03__FLEXIO2_IO19                 0x0188 0x0378 0x0000 4 0
+#define IMXRT_PAD_GPIO_B1_03__GPIO2_gpio_io19              0x0188 0x0378 0x0000 5 0
+#define IMXRT_PAD_GPIO_B1_03__PWM2_B3                      0x0188 0x0378 0x0484 6 3
+/* GPIO_B1_04 */
+#define IMXRT_PAD_GPIO_B1_04__LCDIF_lcdif_data16           0x018c 0x037c 0x0000 0 0
+#define IMXRT_PAD_GPIO_B1_04__LPSPI4_PCS0                  0x018c 0x037c 0x051c 1 1
+#define IMXRT_PAD_GPIO_B1_04__CSI_csi_data15               0x018c 0x037c 0x0000 2 0
+#define IMXRT_PAD_GPIO_B1_04__ENET_enet_rx_data0           0x018c 0x037c 0x0434 3 1
+#define IMXRT_PAD_GPIO_B1_04__FLEXIO2_IO20                 0x018c 0x037c 0x0000 4 0
+#define IMXRT_PAD_GPIO_B1_04__GPIO2_gpio_io20              0x018c 0x037c 0x0000 5 0
+/* GPIO_B1_05 */
+#define IMXRT_PAD_GPIO_B1_05__LCDIF_lcdif_data17           0x0190 0x0380 0x0000 0 0
+#define IMXRT_PAD_GPIO_B1_05__LPSPI4_SDI                   0x0190 0x0380 0x0524 1 1
+#define IMXRT_PAD_GPIO_B1_05__CSI_csi_data14               0x0190 0x0380 0x0000 2 0
+#define IMXRT_PAD_GPIO_B1_05__ENET_enet_rx_data1           0x0190 0x0380 0x0438 3 1
+#define IMXRT_PAD_GPIO_B1_05__FLEXIO2_IO21                 0x0190 0x0380 0x0000 4 0
+#define IMXRT_PAD_GPIO_B1_05__GPIO2_gpio_io21              0x0190 0x0380 0x0000 5 0
+/* GPIO_B1_06 */
+#define IMXRT_PAD_GPIO_B1_06__LCDIF_lcdif_data18           0x0194 0x0384 0x0000 0 0
+#define IMXRT_PAD_GPIO_B1_06__LPSPI4_SDO                   0x0194 0x0384 0x0528 1 1
+#define IMXRT_PAD_GPIO_B1_06__CSI_csi_data13               0x0194 0x0384 0x0000 2 0
+#define IMXRT_PAD_GPIO_B1_06__ENET_enet_rx_en              0x0194 0x0384 0x043c 3 1
+#define IMXRT_PAD_GPIO_B1_06__FLEXIO2_IO22                 0x0194 0x0384 0x0000 4 0
+#define IMXRT_PAD_GPIO_B1_06__GPIO2_gpio_io22              0x0194 0x0384 0x0000 5 0
+/* GPIO_B1_07 */
+#define IMXRT_PAD_GPIO_B1_07__LCDIF_lcdif_data19           0x0198 0x0388 0x0000 0 0
+#define IMXRT_PAD_GPIO_B1_07__LPSPI4_SCK                   0x0198 0x0388 0x0520 1 1
+#define IMXRT_PAD_GPIO_B1_07__CSI_csi_data12               0x0198 0x0388 0x0000 2 0
+#define IMXRT_PAD_GPIO_B1_07__ENET_enet_tx_data0           0x0198 0x0388 0x0000 3 0
+#define IMXRT_PAD_GPIO_B1_07__FLEXIO2_IO23                 0x0198 0x0388 0x0000 4 0
+#define IMXRT_PAD_GPIO_B1_07__GPIO2_gpio_io23              0x0198 0x0388 0x0000 5 0
+/* GPIO_B1_08 */
+#define IMXRT_PAD_GPIO_B1_08__LCDIF_lcdif_data20           0x019c 0x038c 0x0000 0 0
+#define IMXRT_PAD_GPIO_B1_08__TMR1_TIMER3                  0x019c 0x038c 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER1_TRM3_INPUT_SEL to 0 */
+#define IMXRT_PAD_GPIO_B1_08__CSI_csi_data11               0x019c 0x038c 0x0000 2 0
+#define IMXRT_PAD_GPIO_B1_08__ENET_enet_tx_data1           0x019c 0x038c 0x0000 3 0
+#define IMXRT_PAD_GPIO_B1_08__FLEXIO2_IO24                 0x019c 0x038c 0x0000 4 0
+#define IMXRT_PAD_GPIO_B1_08__GPIO2_gpio_io24              0x019c 0x038c 0x0000 5 0
+#define IMXRT_PAD_GPIO_B1_08__CAN2_TX                      0x019c 0x038c 0x0000 6 0
+/* GPIO_B1_09 */
+#define IMXRT_PAD_GPIO_B1_09__LCDIF_lcdif_data21           0x01a0 0x0390 0x0000 0 0
+#define IMXRT_PAD_GPIO_B1_09__TMR2_TIMER3                  0x01a0 0x0390 0x0578 1 1 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER2_TRM3_INPUT_SEL to 0 */
+#define IMXRT_PAD_GPIO_B1_09__CSI_csi_data10               0x01a0 0x0390 0x0000 2 0
+#define IMXRT_PAD_GPIO_B1_09__ENET_enet_tx_en              0x01a0 0x0390 0x0000 3 0
+#define IMXRT_PAD_GPIO_B1_09__FLEXIO2_IO25                 0x01a0 0x0390 0x0000 4 0
+#define IMXRT_PAD_GPIO_B1_09__GPIO2_gpio_io25              0x01a0 0x0390 0x0000 5 0
+#define IMXRT_PAD_GPIO_B1_09__CAN2_RX                      0x01a0 0x0390 0x0450 6 3
+/* GPIO_B1_10 */
+#define IMXRT_PAD_GPIO_B1_10__LCDIF_lcdif_data22           0x01a4 0x0394 0x0000 0 0
+#define IMXRT_PAD_GPIO_B1_10__TMR3_TIMER3                  0x01a4 0x0394 0x0588 1 2 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM3_INPUT_SEL to 0 */
+#define IMXRT_PAD_GPIO_B1_10__CSI_csi_data00               0x01a4 0x0394 0x0000 2 0
+#define IMXRT_PAD_GPIO_B1_10__ENET_enet_tx_clk             0x01a4 0x0394 0x0448 3 1
+#define IMXRT_PAD_GPIO_B1_10__FLEXIO2_IO26                 0x01a4 0x0394 0x0000 4 0
+#define IMXRT_PAD_GPIO_B1_10__GPIO2_gpio_io26              0x01a4 0x0394 0x0000 5 0
+#define IMXRT_PAD_GPIO_B1_10__ENET_enet_ref_clk            0x01a4 0x0394 0x042c 6 1
+/* GPIO_B1_11 */
+#define IMXRT_PAD_GPIO_B1_11__LCDIF_lcdif_data23           0x01a8 0x0398 0x0000 0 0
+#define IMXRT_PAD_GPIO_B1_11__TMR4_TIMER3                  0x01a8 0x0398 0x0000 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER4_TRM3_INPUT_SEL to 0 */
+#define IMXRT_PAD_GPIO_B1_11__CSI_csi_data01               0x01a8 0x0398 0x0000 2 0
+#define IMXRT_PAD_GPIO_B1_11__ENET_enet_rx_er              0x01a8 0x0398 0x0440 3 1
+#define IMXRT_PAD_GPIO_B1_11__FLEXIO2_IO27                 0x01a8 0x0398 0x0000 4 0
+#define IMXRT_PAD_GPIO_B1_11__GPIO2_gpio_io27              0x01a8 0x0398 0x0000 5 0
+#define IMXRT_PAD_GPIO_B1_11__LPSPI4_PCS3                  0x01a8 0x0398 0x0000 6 0
+/* GPIO_B1_12 */
+#define IMXRT_PAD_GPIO_B1_12__LPUART5_TX                   0x01ac 0x039c 0x054c 1 1
+#define IMXRT_PAD_GPIO_B1_12__CSI_csi_pixclk               0x01ac 0x039c 0x0424 2 1
+#define IMXRT_PAD_GPIO_B1_12__ENET_1588_EVENT0_IN          0x01ac 0x039c 0x0444 3 2
+#define IMXRT_PAD_GPIO_B1_12__FLEXIO2_IO28                 0x01ac 0x039c 0x0000 4 0
+#define IMXRT_PAD_GPIO_B1_12__GPIO2_gpio_io28              0x01ac 0x039c 0x0000 5 0
+#define IMXRT_PAD_GPIO_B1_12__USDHC1_usdhc_cd_b            0x01ac 0x039c 0x05d4 6 2
+/* GPIO_B1_13 */
+#define IMXRT_PAD_GPIO_B1_13__WDOG1_wdog_b                 0x01b0 0x03a0 0x0000 0 0
+#define IMXRT_PAD_GPIO_B1_13__LPUART5_RX                   0x01b0 0x03a0 0x0548 1 1
+#define IMXRT_PAD_GPIO_B1_13__CSI_csi_vsync                0x01b0 0x03a0 0x0428 2 2
+#define IMXRT_PAD_GPIO_B1_13__ENET_1588_EVENT0_OUT         0x01b0 0x03a0 0x0000 3 0
+#define IMXRT_PAD_GPIO_B1_13__FLEXIO2_IO29                 0x01b0 0x03a0 0x0000 4 0
+#define IMXRT_PAD_GPIO_B1_13__GPIO2_gpio_io29              0x01b0 0x03a0 0x0000 5 0
+#define IMXRT_PAD_GPIO_B1_13__USDHC1_usdhc_wp              0x01b0 0x03a0 0x05d8 6 3
+/* GPIO_B1_14 */
+#define IMXRT_PAD_GPIO_B1_14__ENET_enet_mdc                0x01b4 0x03a4 0x0000 0 0
+#define IMXRT_PAD_GPIO_B1_14__PWM4_A2                      0x01b4 0x03a4 0x049c 1 1
+#define IMXRT_PAD_GPIO_B1_14__CSI_csi_hsync                0x01b4 0x03a4 0x0420 2 2
+#define IMXRT_PAD_GPIO_B1_14__XBARA1_IN02                  0x01b4 0x03a4 0x060c 3 1
+#define IMXRT_PAD_GPIO_B1_14__FLEXIO2_IO30                 0x01b4 0x03a4 0x0000 4 0
+#define IMXRT_PAD_GPIO_B1_14__GPIO2_gpio_io30              0x01b4 0x03a4 0x0000 5 0
+#define IMXRT_PAD_GPIO_B1_14__USDHC1_usdhc_vselect         0x01b4 0x03a4 0x0000 6 0
+/* GPIO_B1_15 */
+#define IMXRT_PAD_GPIO_B1_15__ENET_enet_mdio               0x01b8 0x03a8 0x0430 0 2
+#define IMXRT_PAD_GPIO_B1_15__PWM4_A3                      0x01b8 0x03a8 0x04a0 1 1
+#define IMXRT_PAD_GPIO_B1_15__CSI_csi_mclk                 0x01b8 0x03a8 0x0000 2 0
+#define IMXRT_PAD_GPIO_B1_15__XBARA1_IN03                  0x01b8 0x03a8 0x0610 3 1
+#define IMXRT_PAD_GPIO_B1_15__FLEXIO2_IO31                 0x01b8 0x03a8 0x0000 4 0
+#define IMXRT_PAD_GPIO_B1_15__GPIO2_gpio_io31              0x01b8 0x03a8 0x0000 5 0
+#define IMXRT_PAD_GPIO_B1_15__USDHC1_usdhc_reset_b         0x01b8 0x03a8 0x0000 6 0
+/* GPIO_EMC_00 */
+#define IMXRT_PAD_GPIO_EMC_00__SEMC_DATA00                 0x0014 0x0204 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_00__PWM4_A0                     0x0014 0x0204 0x0494 1 0
+#define IMXRT_PAD_GPIO_EMC_00__LPSPI2_SCK                  0x0014 0x0204 0x0500 2 1
+#define IMXRT_PAD_GPIO_EMC_00__XBARA1_IN02                 0x0014 0x0204 0x060c 3 0
+#define IMXRT_PAD_GPIO_EMC_00__FLEXIO1_IO00                0x0014 0x0204 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_00__GPIO4_gpio_io00             0x0014 0x0204 0x0000 5 0
+/* GPIO_EMC_01 */
+#define IMXRT_PAD_GPIO_EMC_01__SEMC_DATA01                 0x0018 0x0208 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_01__PWM4_B0                     0x0018 0x0208 0x0000 1 0
+#define IMXRT_PAD_GPIO_EMC_01__LPSPI2_PCS0                 0x0018 0x0208 0x04fc 2 1
+#define IMXRT_PAD_GPIO_EMC_01__XBARA1_IN03                 0x0018 0x0208 0x0610 3 0
+#define IMXRT_PAD_GPIO_EMC_01__FLEXIO1_IO01                0x0018 0x0208 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_01__GPIO4_gpio_io01             0x0018 0x0208 0x0000 5 0
+/* GPIO_EMC_02 */
+#define IMXRT_PAD_GPIO_EMC_02__SEMC_DATA02                 0x001c 0x020c 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_02__PWM4_A1                     0x001c 0x020c 0x0498 1 0
+#define IMXRT_PAD_GPIO_EMC_02__LPSPI2_SDO                  0x001c 0x020c 0x0508 2 1
+#define IMXRT_PAD_GPIO_EMC_02__XBARA1_OUT04                0x001c 0x020c 0x0614 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_4 to 0x1 */
+#define IMXRT_PAD_GPIO_EMC_02__XBARA1_IN04                 0x001c 0x020c 0x0614 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_4 to 0 */
+#define IMXRT_PAD_GPIO_EMC_02__FLEXIO1_IO02                0x001c 0x020c 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_02__GPIO4_gpio_io02             0x001c 0x020c 0x0000 5 0
+/* GPIO_EMC_03 */
+#define IMXRT_PAD_GPIO_EMC_03__SEMC_DATA03                 0x0020 0x0210 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_03__PWM4_B1                     0x0020 0x0210 0x0000 1 0
+#define IMXRT_PAD_GPIO_EMC_03__LPSPI2_SDI                  0x0020 0x0210 0x0504 2 1
+#define IMXRT_PAD_GPIO_EMC_03__XBARA1_OUT05                0x0020 0x0210 0x0618 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_5 to 0x1 */
+#define IMXRT_PAD_GPIO_EMC_03__XBARA1_IN05                 0x0020 0x0210 0x0618 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_5 to 0 */
+#define IMXRT_PAD_GPIO_EMC_03__FLEXIO1_IO03                0x0020 0x0210 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_03__GPIO4_gpio_io03             0x0020 0x0210 0x0000 5 0
+/* GPIO_EMC_04 */
+#define IMXRT_PAD_GPIO_EMC_04__SEMC_DATA04                 0x0024 0x0214 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_04__PWM4_A2                     0x0024 0x0214 0x049c 1 0
+#define IMXRT_PAD_GPIO_EMC_04__SAI2_sai_tx_data            0x0024 0x0214 0x0000 2 0
+#define IMXRT_PAD_GPIO_EMC_04__XBARA1_OUT06                0x0024 0x0214 0x061c 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_6 to 0x1 */
+#define IMXRT_PAD_GPIO_EMC_04__XBARA1_IN06                 0x0024 0x0214 0x061c 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_6 to 0 */
+#define IMXRT_PAD_GPIO_EMC_04__FLEXIO1_IO04                0x0024 0x0214 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_04__GPIO4_gpio_io04             0x0024 0x0214 0x0000 5 0
+/* GPIO_EMC_05 */
+#define IMXRT_PAD_GPIO_EMC_05__SEMC_DATA05                 0x0028 0x0218 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_05__PWM4_B2                     0x0028 0x0218 0x0000 1 0
+#define IMXRT_PAD_GPIO_EMC_05__SAI2_sai_tx_sync            0x0028 0x0218 0x05c4 2 0
+#define IMXRT_PAD_GPIO_EMC_05__XBARA1_OUT07                0x0028 0x0218 0x0620 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_7 to 0x1 */
+#define IMXRT_PAD_GPIO_EMC_05__XBARA1_IN07                 0x0028 0x0218 0x0620 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_7 to 0 */
+#define IMXRT_PAD_GPIO_EMC_05__FLEXIO1_IO05                0x0028 0x0218 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_05__GPIO4_gpio_io05             0x0028 0x0218 0x0000 5 0
+/* GPIO_EMC_06 */
+#define IMXRT_PAD_GPIO_EMC_06__SEMC_DATA06                 0x002c 0x021c 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_06__PWM2_A0                     0x002c 0x021c 0x0478 1 0
+#define IMXRT_PAD_GPIO_EMC_06__SAI2_sai_tx_bclk            0x002c 0x021c 0x05c0 2 0
+#define IMXRT_PAD_GPIO_EMC_06__XBARA1_OUT08                0x002c 0x021c 0x0624 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_8 to 0x1 */
+#define IMXRT_PAD_GPIO_EMC_06__XBARA1_IN08                 0x002c 0x021c 0x0624 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_8 to 0 */
+#define IMXRT_PAD_GPIO_EMC_06__FLEXIO1_IO06                0x002c 0x021c 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_06__GPIO4_gpio_io06             0x002c 0x021c 0x0000 5 0
+/* GPIO_EMC_07 */
+#define IMXRT_PAD_GPIO_EMC_07__SEMC_DATA07                 0x0030 0x0220 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_07__PWM2_B0                     0x0030 0x0220 0x0488 1 0
+#define IMXRT_PAD_GPIO_EMC_07__SAI2_sai_mclk               0x0030 0x0220 0x05b0 2 0
+#define IMXRT_PAD_GPIO_EMC_07__XBARA1_OUT09                0x0030 0x0220 0x0628 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_9 to 0x1 */
+#define IMXRT_PAD_GPIO_EMC_07__XBARA1_IN09                 0x0030 0x0220 0x0628 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_9 to 0 */
+#define IMXRT_PAD_GPIO_EMC_07__FLEXIO1_IO07                0x0030 0x0220 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_07__GPIO4_gpio_io07             0x0030 0x0220 0x0000 5 0
+/* GPIO_EMC_08 */
+#define IMXRT_PAD_GPIO_EMC_08__SEMC_DM0                    0x0034 0x0224 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_08__PWM2_A1                     0x0034 0x0224 0x047c 1 0
+#define IMXRT_PAD_GPIO_EMC_08__SAI2_sai_rx_data            0x0034 0x0224 0x05b8 2 0
+#define IMXRT_PAD_GPIO_EMC_08__XBARA1_OUT17                0x0034 0x0224 0x062c 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_17 to 0x1 */
+#define IMXRT_PAD_GPIO_EMC_08__XBARA1_IN17                 0x0034 0x0224 0x062c 3 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_17 to 0 */
+#define IMXRT_PAD_GPIO_EMC_08__FLEXIO1_IO08                0x0034 0x0224 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_08__GPIO4_gpio_io08             0x0034 0x0224 0x0000 5 0
+/* GPIO_EMC_09 */
+#define IMXRT_PAD_GPIO_EMC_09__SEMC_ADDR00                 0x0038 0x0228 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_09__PWM2_B1                     0x0038 0x0228 0x048c 1 0
+#define IMXRT_PAD_GPIO_EMC_09__SAI2_sai_rx_sync            0x0038 0x0228 0x05bc 2 0
+#define IMXRT_PAD_GPIO_EMC_09__CAN2_TX                     0x0038 0x0228 0x0000 3 0
+#define IMXRT_PAD_GPIO_EMC_09__FLEXIO1_IO09                0x0038 0x0228 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_09__GPIO4_gpio_io09             0x0038 0x0228 0x0000 5 0
+/* GPIO_EMC_10 */
+#define IMXRT_PAD_GPIO_EMC_10__SEMC_ADDR01                 0x003c 0x022c 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_10__PWM2_A2                     0x003c 0x022c 0x0480 1 0
+#define IMXRT_PAD_GPIO_EMC_10__SAI2_sai_rx_bclk            0x003c 0x022c 0x05b4 2 0
+#define IMXRT_PAD_GPIO_EMC_10__CAN2_RX                     0x003c 0x022c 0x0450 3 0
+#define IMXRT_PAD_GPIO_EMC_10__FLEXIO1_IO10                0x003c 0x022c 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_10__GPIO4_gpio_io10             0x003c 0x022c 0x0000 5 0
+/* GPIO_EMC_11 */
+#define IMXRT_PAD_GPIO_EMC_11__SEMC_ADDR02                 0x0040 0x0230 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_11__PWM2_B2                     0x0040 0x0230 0x0490 1 0
+#define IMXRT_PAD_GPIO_EMC_11__LPI2C4_SDA                  0x0040 0x0230 0x04e8 2 0
+#define IMXRT_PAD_GPIO_EMC_11__USDHC2_usdhc_reset_b        0x0040 0x0230 0x0000 3 0
+#define IMXRT_PAD_GPIO_EMC_11__FLEXIO1_IO11                0x0040 0x0230 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_11__GPIO4_gpio_io11             0x0040 0x0230 0x0000 5 0
+/* GPIO_EMC_12 */
+#define IMXRT_PAD_GPIO_EMC_12__SEMC_ADDR03                 0x0044 0x0234 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_12__XBARA1_IN24                 0x0044 0x0234 0x0640 1 0
+#define IMXRT_PAD_GPIO_EMC_12__LPI2C4_SCL                  0x0044 0x0234 0x04e4 2 0
+#define IMXRT_PAD_GPIO_EMC_12__USDHC1_usdhc_wp             0x0044 0x0234 0x05d8 3 0
+#define IMXRT_PAD_GPIO_EMC_12__PWM1_A3                     0x0044 0x0234 0x0454 4 1
+#define IMXRT_PAD_GPIO_EMC_12__GPIO4_gpio_io12             0x0044 0x0234 0x0000 5 0
+/* GPIO_EMC_13 */
+#define IMXRT_PAD_GPIO_EMC_13__SEMC_ADDR04                 0x0048 0x0238 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_13__XBARA1_IN25                 0x0048 0x0238 0x0650 1 1
+#define IMXRT_PAD_GPIO_EMC_13__LPUART3_TX                  0x0048 0x0238 0x053c 2 1
+#define IMXRT_PAD_GPIO_EMC_13__MQS_RIGHT                   0x0048 0x0238 0x0000 3 0
+#define IMXRT_PAD_GPIO_EMC_13__PWM1_B3                     0x0048 0x0238 0x0464 4 1
+#define IMXRT_PAD_GPIO_EMC_13__GPIO4_gpio_io13             0x0048 0x0238 0x0000 5 0
+/* GPIO_EMC_14 */
+#define IMXRT_PAD_GPIO_EMC_14__SEMC_ADDR05                 0x004c 0x023c 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_14__XBARA1_OUT19                0x004c 0x023c 0x0654 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_19 to 0x1 */
+#define IMXRT_PAD_GPIO_EMC_14__XBARA1_IN19                 0x004c 0x023c 0x0654 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_19 to 0 */
+#define IMXRT_PAD_GPIO_EMC_14__LPUART3_RX                  0x004c 0x023c 0x0538 2 1
+#define IMXRT_PAD_GPIO_EMC_14__MQS_LEFT                    0x004c 0x023c 0x0000 3 0
+#define IMXRT_PAD_GPIO_EMC_14__LPSPI2_PCS1                 0x004c 0x023c 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_14__GPIO4_gpio_io14             0x004c 0x023c 0x0000 5 0
+/* GPIO_EMC_15 */
+#define IMXRT_PAD_GPIO_EMC_15__SEMC_ADDR06                 0x0050 0x0240 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_15__XBARA1_IN20                 0x0050 0x0240 0x0634 1 0
+#define IMXRT_PAD_GPIO_EMC_15__LPUART3_CTS_B               0x0050 0x0240 0x0534 2 0
+#define IMXRT_PAD_GPIO_EMC_15__SPDIF_spdif_out             0x0050 0x0240 0x0000 3 0
+#define IMXRT_PAD_GPIO_EMC_15__TMR3_TIMER0                 0x0050 0x0240 0x057c 4 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM0_INPUT_SEL to 0 */
+#define IMXRT_PAD_GPIO_EMC_15__GPIO4_gpio_io15             0x0050 0x0240 0x0000 5 0
+/* GPIO_EMC_16 */
+#define IMXRT_PAD_GPIO_EMC_16__SEMC_ADDR07                 0x0054 0x0244 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_16__XBARA1_IN21                 0x0054 0x0244 0x0658 1 0
+#define IMXRT_PAD_GPIO_EMC_16__LPUART3_RTS_B               0x0054 0x0244 0x0000 2 0
+#define IMXRT_PAD_GPIO_EMC_16__SPDIF_spdif_in              0x0054 0x0244 0x05c8 3 1
+#define IMXRT_PAD_GPIO_EMC_16__TMR3_TIMER1                 0x0054 0x0244 0x0580 4 1 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM1_INPUT_SEL to 0 */
+#define IMXRT_PAD_GPIO_EMC_16__GPIO4_gpio_io16             0x0054 0x0244 0x0000 5 0
+/* GPIO_EMC_17 */
+#define IMXRT_PAD_GPIO_EMC_17__SEMC_ADDR08                 0x0058 0x0248 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_17__PWM4_A3                     0x0058 0x0248 0x04a0 1 0
+#define IMXRT_PAD_GPIO_EMC_17__LPUART4_CTS_B               0x0058 0x0248 0x0000 2 0
+#define IMXRT_PAD_GPIO_EMC_17__CAN1_TX                     0x0058 0x0248 0x0000 3 0
+#define IMXRT_PAD_GPIO_EMC_17__TMR3_TIMER2                 0x0058 0x0248 0x0584 4 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM2_INPUT_SEL to 0 */
+#define IMXRT_PAD_GPIO_EMC_17__GPIO4_gpio_io17             0x0058 0x0248 0x0000 5 0
+/* GPIO_EMC_18 */
+#define IMXRT_PAD_GPIO_EMC_18__SEMC_ADDR09                 0x005c 0x024c 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_18__PWM4_B3                     0x005c 0x024c 0x0000 1 0
+#define IMXRT_PAD_GPIO_EMC_18__LPUART4_RTS_B               0x005c 0x024c 0x0000 2 0
+#define IMXRT_PAD_GPIO_EMC_18__CAN1_RX                     0x005c 0x024c 0x044c 3 1
+#define IMXRT_PAD_GPIO_EMC_18__TMR3_TIMER3                 0x005c 0x024c 0x0588 4 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER3_TRM3_INPUT_SEL to 0 */
+#define IMXRT_PAD_GPIO_EMC_18__GPIO4_gpio_io18             0x005c 0x024c 0x0000 5 0
+#define IMXRT_PAD_GPIO_EMC_18__SNVS_snvs_vio_5_ctl         0x005c 0x024c 0x0000 6 0
+/* GPIO_EMC_19 */
+#define IMXRT_PAD_GPIO_EMC_19__SEMC_ADDR11                 0x0060 0x0250 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_19__PWM2_A3                     0x0060 0x0250 0x0474 1 1
+#define IMXRT_PAD_GPIO_EMC_19__LPUART4_TX                  0x0060 0x0250 0x0544 2 1
+#define IMXRT_PAD_GPIO_EMC_19__ENET_enet_rx_data1          0x0060 0x0250 0x0438 3 0
+#define IMXRT_PAD_GPIO_EMC_19__TMR2_TIMER0                 0x0060 0x0250 0x056c 4 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER2_TRM0_INPUT_SEL to 0 */
+#define IMXRT_PAD_GPIO_EMC_19__GPIO4_gpio_io19             0x0060 0x0250 0x0000 5 0
+#define IMXRT_PAD_GPIO_EMC_19__SNVS_snvs_vio_5_b           0x0060 0x0250 0x0000 6 0
+/* GPIO_EMC_20 */
+#define IMXRT_PAD_GPIO_EMC_20__SEMC_ADDR12                 0x0064 0x0254 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_20__PWM2_B3                     0x0064 0x0254 0x0484 1 1
+#define IMXRT_PAD_GPIO_EMC_20__LPUART4_RX                  0x0064 0x0254 0x0540 2 1
+#define IMXRT_PAD_GPIO_EMC_20__ENET_enet_rx_data0          0x0064 0x0254 0x0434 3 0
+#define IMXRT_PAD_GPIO_EMC_20__TMR2_TIMER1                 0x0064 0x0254 0x0570 4 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER2_TRM1_INPUT_SEL to 0 */
+#define IMXRT_PAD_GPIO_EMC_20__GPIO4_gpio_io20             0x0064 0x0254 0x0000 5 0
+/* GPIO_EMC_21 */
+#define IMXRT_PAD_GPIO_EMC_21__SEMC_BA0                    0x0068 0x0258 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_21__PWM3_A3                     0x0068 0x0258 0x0000 1 0
+#define IMXRT_PAD_GPIO_EMC_21__LPI2C3_SDA                  0x0068 0x0258 0x04e0 2 0
+#define IMXRT_PAD_GPIO_EMC_21__ENET_enet_tx_data1          0x0068 0x0258 0x0000 3 0
+#define IMXRT_PAD_GPIO_EMC_21__TMR2_TIMER2                 0x0068 0x0258 0x0574 4 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER2_TRM2_INPUT_SEL to 0 */
+#define IMXRT_PAD_GPIO_EMC_21__GPIO4_gpio_io21             0x0068 0x0258 0x0000 5 0
+/* GPIO_EMC_22 */
+#define IMXRT_PAD_GPIO_EMC_22__SEMC_BA1                    0x006c 0x025c 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_22__PWM3_B3                     0x006c 0x025c 0x0000 1 0
+#define IMXRT_PAD_GPIO_EMC_22__LPI2C3_SCL                  0x006c 0x025c 0x04dc 2 0
+#define IMXRT_PAD_GPIO_EMC_22__ENET_enet_tx_data0          0x006c 0x025c 0x0000 3 0
+#define IMXRT_PAD_GPIO_EMC_22__TMR2_TIMER3                 0x006c 0x025c 0x0578 4 0 /* Maybe you want to set IOMUXC_GPR_GPR6 QTIMER2_TRM3_INPUT_SEL to 0 */
+#define IMXRT_PAD_GPIO_EMC_22__GPIO4_gpio_io22             0x006c 0x025c 0x0000 5 0
+/* GPIO_EMC_23 */
+#define IMXRT_PAD_GPIO_EMC_23__SEMC_ADDR10                 0x0070 0x0260 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_23__PWM1_A0                     0x0070 0x0260 0x0458 1 0
+#define IMXRT_PAD_GPIO_EMC_23__LPUART5_TX                  0x0070 0x0260 0x054c 2 0
+#define IMXRT_PAD_GPIO_EMC_23__ENET_enet_rx_en             0x0070 0x0260 0x043c 3 0
+#define IMXRT_PAD_GPIO_EMC_23__GPT1_gpt_capture2           0x0070 0x0260 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_23__GPIO4_gpio_io23             0x0070 0x0260 0x0000 5 0
+/* GPIO_EMC_24 */
+#define IMXRT_PAD_GPIO_EMC_24__SEMC_semc_cas               0x0074 0x0264 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_24__PWM1_B0                     0x0074 0x0264 0x0468 1 0
+#define IMXRT_PAD_GPIO_EMC_24__LPUART5_RX                  0x0074 0x0264 0x0548 2 0
+#define IMXRT_PAD_GPIO_EMC_24__ENET_enet_tx_en             0x0074 0x0264 0x0000 3 0
+#define IMXRT_PAD_GPIO_EMC_24__GPT1_gpt_capture1           0x0074 0x0264 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_24__GPIO4_gpio_io24             0x0074 0x0264 0x0000 5 0
+/* GPIO_EMC_25 */
+#define IMXRT_PAD_GPIO_EMC_25__SEMC_semc_ras               0x0078 0x0268 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_25__PWM1_A1                     0x0078 0x0268 0x045c 1 0
+#define IMXRT_PAD_GPIO_EMC_25__LPUART6_TX                  0x0078 0x0268 0x0554 2 0
+#define IMXRT_PAD_GPIO_EMC_25__ENET_enet_tx_clk            0x0078 0x0268 0x0448 3 0
+#define IMXRT_PAD_GPIO_EMC_25__ENET_enet_ref_clk           0x0078 0x0268 0x042c 4 0
+#define IMXRT_PAD_GPIO_EMC_25__GPIO4_gpio_io25             0x0078 0x0268 0x0000 5 0
+/* GPIO_EMC_26 */
+#define IMXRT_PAD_GPIO_EMC_26__SEMC_semc_clk               0x007c 0x026c 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_26__PWM1_B1                     0x007c 0x026c 0x046c 1 0
+#define IMXRT_PAD_GPIO_EMC_26__LPUART6_RX                  0x007c 0x026c 0x0550 2 0
+#define IMXRT_PAD_GPIO_EMC_26__ENET_enet_rx_er             0x007c 0x026c 0x0440 3 0
+#define IMXRT_PAD_GPIO_EMC_26__FLEXIO1_IO12                0x007c 0x026c 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_26__GPIO4_gpio_io26             0x007c 0x026c 0x0000 5 0
+/* GPIO_EMC_27 */
+#define IMXRT_PAD_GPIO_EMC_27__SEMC_semc_cke               0x0080 0x0270 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_27__PWM1_A2                     0x0080 0x0270 0x0460 1 0
+#define IMXRT_PAD_GPIO_EMC_27__LPUART5_RTS_B               0x0080 0x0270 0x0000 2 0
+#define IMXRT_PAD_GPIO_EMC_27__LPSPI1_SCK                  0x0080 0x0270 0x04f0 3 0
+#define IMXRT_PAD_GPIO_EMC_27__FLEXIO1_IO13                0x0080 0x0270 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_27__GPIO4_gpio_io27             0x0080 0x0270 0x0000 5 0
+/* GPIO_EMC_28 */
+#define IMXRT_PAD_GPIO_EMC_28__SEMC_semc_we                0x0084 0x0274 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_28__PWM1_B2                     0x0084 0x0274 0x0470 1 0
+#define IMXRT_PAD_GPIO_EMC_28__LPUART5_CTS_B               0x0084 0x0274 0x0000 2 0
+#define IMXRT_PAD_GPIO_EMC_28__LPSPI1_SDO                  0x0084 0x0274 0x04f8 3 0
+#define IMXRT_PAD_GPIO_EMC_28__FLEXIO1_IO14                0x0084 0x0274 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_28__GPIO4_gpio_io28             0x0084 0x0274 0x0000 5 0
+/* GPIO_EMC_29 */
+#define IMXRT_PAD_GPIO_EMC_29__SEMC_CS0                    0x0088 0x0278 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_29__PWM3_A0                     0x0088 0x0278 0x0000 1 0
+#define IMXRT_PAD_GPIO_EMC_29__LPUART6_RTS_B               0x0088 0x0278 0x0000 2 0
+#define IMXRT_PAD_GPIO_EMC_29__LPSPI1_SDI                  0x0088 0x0278 0x04f4 3 0
+#define IMXRT_PAD_GPIO_EMC_29__FLEXIO1_IO15                0x0088 0x0278 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_29__GPIO4_gpio_io29             0x0088 0x0278 0x0000 5 0
+/* GPIO_EMC_30 */
+#define IMXRT_PAD_GPIO_EMC_30__SEMC_DATA08                 0x008c 0x027c 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_30__PWM3_B0                     0x008c 0x027c 0x0000 1 0
+#define IMXRT_PAD_GPIO_EMC_30__LPUART6_CTS_B               0x008c 0x027c 0x0000 2 0
+#define IMXRT_PAD_GPIO_EMC_30__LPSPI1_PCS0                 0x008c 0x027c 0x04ec 3 1
+#define IMXRT_PAD_GPIO_EMC_30__CSI_csi_data23              0x008c 0x027c 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_30__GPIO4_gpio_io30             0x008c 0x027c 0x0000 5 0
+/* GPIO_EMC_31 */
+#define IMXRT_PAD_GPIO_EMC_31__SEMC_DATA09                 0x0090 0x0280 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_31__PWM3_A1                     0x0090 0x0280 0x0000 1 0
+#define IMXRT_PAD_GPIO_EMC_31__LPUART7_TX                  0x0090 0x0280 0x055c 2 1
+#define IMXRT_PAD_GPIO_EMC_31__LPSPI1_PCS1                 0x0090 0x0280 0x0000 3 0
+#define IMXRT_PAD_GPIO_EMC_31__CSI_csi_data22              0x0090 0x0280 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_31__GPIO4_gpio_io31             0x0090 0x0280 0x0000 5 0
+/* GPIO_EMC_32 */
+#define IMXRT_PAD_GPIO_EMC_32__SEMC_DATA10                 0x0094 0x0284 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_32__PWM3_B1                     0x0094 0x0284 0x0000 1 0
+#define IMXRT_PAD_GPIO_EMC_32__LPUART7_RX                  0x0094 0x0284 0x0558 2 1
+#define IMXRT_PAD_GPIO_EMC_32__CCM_PMIC_RDY                0x0094 0x0284 0x03fc 3 4
+#define IMXRT_PAD_GPIO_EMC_32__CSI_csi_data21              0x0094 0x0284 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_32__GPIO3_gpio_io18             0x0094 0x0284 0x0000 5 0
+/* GPIO_EMC_33 */
+#define IMXRT_PAD_GPIO_EMC_33__SEMC_DATA11                 0x0098 0x0288 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_33__PWM3_A2                     0x0098 0x0288 0x0000 1 0
+#define IMXRT_PAD_GPIO_EMC_33__USDHC1_usdhc_reset_b        0x0098 0x0288 0x0000 2 0
+#define IMXRT_PAD_GPIO_EMC_33__SAI3_sai_rx_data            0x0098 0x0288 0x0000 3 0
+#define IMXRT_PAD_GPIO_EMC_33__CSI_csi_data20              0x0098 0x0288 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_33__GPIO3_gpio_io19             0x0098 0x0288 0x0000 5 0
+/* GPIO_EMC_34 */
+#define IMXRT_PAD_GPIO_EMC_34__SEMC_DATA12                 0x009c 0x028c 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_34__PWM3_B2                     0x009c 0x028c 0x0000 1 0
+#define IMXRT_PAD_GPIO_EMC_34__USDHC1_usdhc_vselect        0x009c 0x028c 0x0000 2 0
+#define IMXRT_PAD_GPIO_EMC_34__SAI3_sai_rx_sync            0x009c 0x028c 0x0000 3 0
+#define IMXRT_PAD_GPIO_EMC_34__CSI_csi_data19              0x009c 0x028c 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_34__GPIO3_gpio_io20             0x009c 0x028c 0x0000 5 0
+/* GPIO_EMC_35 */
+#define IMXRT_PAD_GPIO_EMC_35__SEMC_DATA13                 0x00a0 0x0290 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_35__XBARA1_OUT18                0x00a0 0x0290 0x0630 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_18 to 0x1 */
+#define IMXRT_PAD_GPIO_EMC_35__XBARA1_IN18                 0x00a0 0x0290 0x0630 1 0 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_18 to 0 */
+#define IMXRT_PAD_GPIO_EMC_35__GPT1_gpt_compare1           0x00a0 0x0290 0x0000 2 0
+#define IMXRT_PAD_GPIO_EMC_35__SAI3_sai_rx_bclk            0x00a0 0x0290 0x0000 3 0
+#define IMXRT_PAD_GPIO_EMC_35__CSI_csi_data18              0x00a0 0x0290 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_35__GPIO3_gpio_io21             0x00a0 0x0290 0x0000 5 0
+#define IMXRT_PAD_GPIO_EMC_35__USDHC1_usdhc_cd_b           0x00a0 0x0290 0x05d4 6 0
+/* GPIO_EMC_36 */
+#define IMXRT_PAD_GPIO_EMC_36__SEMC_DATA14                 0x00a4 0x0294 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_36__XBARA1_IN22                 0x00a4 0x0294 0x0638 1 0
+#define IMXRT_PAD_GPIO_EMC_36__GPT1_gpt_compare2           0x00a4 0x0294 0x0000 2 0
+#define IMXRT_PAD_GPIO_EMC_36__SAI3_sai_tx_data            0x00a4 0x0294 0x0000 3 0
+#define IMXRT_PAD_GPIO_EMC_36__CSI_csi_data17              0x00a4 0x0294 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_36__GPIO3_gpio_io22             0x00a4 0x0294 0x0000 5 0
+#define IMXRT_PAD_GPIO_EMC_36__USDHC1_usdhc_wp             0x00a4 0x0294 0x05d8 6 1
+/* GPIO_EMC_37 */
+#define IMXRT_PAD_GPIO_EMC_37__SEMC_DATA15                 0x00a8 0x0298 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_37__XBARA1_IN23                 0x00a8 0x0298 0x063c 1 0
+#define IMXRT_PAD_GPIO_EMC_37__GPT1_gpt_compare3           0x00a8 0x0298 0x0000 2 0
+#define IMXRT_PAD_GPIO_EMC_37__SAI3_sai_mclk               0x00a8 0x0298 0x0000 3 0
+#define IMXRT_PAD_GPIO_EMC_37__CSI_csi_data16              0x00a8 0x0298 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_37__GPIO3_gpio_io23             0x00a8 0x0298 0x0000 5 0
+#define IMXRT_PAD_GPIO_EMC_37__USDHC2_usdhc_wp             0x00a8 0x0298 0x0608 6 0
+/* GPIO_EMC_38 */
+#define IMXRT_PAD_GPIO_EMC_38__SEMC_DM1                    0x00ac 0x029c 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_38__PWM1_A3                     0x00ac 0x029c 0x0454 1 2
+#define IMXRT_PAD_GPIO_EMC_38__LPUART8_TX                  0x00ac 0x029c 0x0564 2 2
+#define IMXRT_PAD_GPIO_EMC_38__SAI3_sai_tx_bclk            0x00ac 0x029c 0x0000 3 0
+#define IMXRT_PAD_GPIO_EMC_38__CSI_csi_field               0x00ac 0x029c 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_38__GPIO3_gpio_io24             0x00ac 0x029c 0x0000 5 0
+#define IMXRT_PAD_GPIO_EMC_38__USDHC2_usdhc_vselect        0x00ac 0x029c 0x0000 6 0
+/* GPIO_EMC_39 */
+#define IMXRT_PAD_GPIO_EMC_39__SEMC_semc_dqs               0x00b0 0x02a0 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_39__PWM1_B3                     0x00b0 0x02a0 0x0464 1 2
+#define IMXRT_PAD_GPIO_EMC_39__LPUART8_RX                  0x00b0 0x02a0 0x0560 2 2
+#define IMXRT_PAD_GPIO_EMC_39__SAI3_sai_tx_sync            0x00b0 0x02a0 0x0000 3 0
+#define IMXRT_PAD_GPIO_EMC_39__WDOG1_wdog_b                0x00b0 0x02a0 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_39__GPIO3_gpio_io25             0x00b0 0x02a0 0x0000 5 0
+#define IMXRT_PAD_GPIO_EMC_39__USDHC2_usdhc_cd_b           0x00b0 0x02a0 0x05e0 6 1
+/* GPIO_EMC_40 */
+#define IMXRT_PAD_GPIO_EMC_40__SEMC_semc_rdy               0x00b4 0x02a4 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_40__GPT2_gpt_capture2           0x00b4 0x02a4 0x0000 1 0
+#define IMXRT_PAD_GPIO_EMC_40__LPSPI1_PCS2                 0x00b4 0x02a4 0x0000 2 0
+#define IMXRT_PAD_GPIO_EMC_40__USB2_usb_otg2_oc            0x00b4 0x02a4 0x05cc 3 1
+#define IMXRT_PAD_GPIO_EMC_40__ENET_enet_mdc               0x00b4 0x02a4 0x0000 4 0
+#define IMXRT_PAD_GPIO_EMC_40__GPIO3_gpio_io26             0x00b4 0x02a4 0x0000 5 0
+#define IMXRT_PAD_GPIO_EMC_40__USDHC2_usdhc_reset_b        0x00b4 0x02a4 0x0000 6 0
+/* GPIO_EMC_41 */
+#define IMXRT_PAD_GPIO_EMC_41__SEMC_CSX0                   0x00b8 0x02a8 0x0000 0 0
+#define IMXRT_PAD_GPIO_EMC_41__GPT2_gpt_capture1           0x00b8 0x02a8 0x0000 1 0
+#define IMXRT_PAD_GPIO_EMC_41__LPSPI1_PCS3                 0x00b8 0x02a8 0x0000 2 0
+#define IMXRT_PAD_GPIO_EMC_41__USB2_usb_otg2_pwr           0x00b8 0x02a8 0x0000 3 0
+#define IMXRT_PAD_GPIO_EMC_41__ENET_enet_mdio              0x00b8 0x02a8 0x0430 4 1
+#define IMXRT_PAD_GPIO_EMC_41__GPIO3_gpio_io27             0x00b8 0x02a8 0x0000 5 0
+#define IMXRT_PAD_GPIO_EMC_41__USDHC1_usdhc_vselect        0x00b8 0x02a8 0x0000 6 0
+/* GPIO_SD_B0_00 */
+#define IMXRT_PAD_GPIO_SD_B0_00__USDHC1_usdhc_cmd          0x01bc 0x03ac 0x0000 0 0
+#define IMXRT_PAD_GPIO_SD_B0_00__PWM1_A0                   0x01bc 0x03ac 0x0458 1 1
+#define IMXRT_PAD_GPIO_SD_B0_00__LPI2C3_SCL                0x01bc 0x03ac 0x04dc 2 1
+#define IMXRT_PAD_GPIO_SD_B0_00__XBARA1_OUT04              0x01bc 0x03ac 0x0614 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_4 to 0x1 */
+#define IMXRT_PAD_GPIO_SD_B0_00__XBARA1_IN04               0x01bc 0x03ac 0x0614 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_4 to 0 */
+#define IMXRT_PAD_GPIO_SD_B0_00__LPSPI1_SCK                0x01bc 0x03ac 0x04f0 4 1
+#define IMXRT_PAD_GPIO_SD_B0_00__GPIO3_gpio_io12           0x01bc 0x03ac 0x0000 5 0
+#define IMXRT_PAD_GPIO_SD_B0_00__FLEXSPI_FLEXSPI_A_SS1_B   0x01bc 0x03ac 0x0000 6 0
+/* GPIO_SD_B0_01 */
+#define IMXRT_PAD_GPIO_SD_B0_01__USDHC1_usdhc_clk          0x01c0 0x03b0 0x0000 0 0
+#define IMXRT_PAD_GPIO_SD_B0_01__PWM1_B0                   0x01c0 0x03b0 0x0468 1 1
+#define IMXRT_PAD_GPIO_SD_B0_01__LPI2C3_SDA                0x01c0 0x03b0 0x04e0 2 1
+#define IMXRT_PAD_GPIO_SD_B0_01__XBARA1_OUT05              0x01c0 0x03b0 0x0618 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_5 to 0x1 */
+#define IMXRT_PAD_GPIO_SD_B0_01__XBARA1_IN05               0x01c0 0x03b0 0x0618 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_5 to 0 */
+#define IMXRT_PAD_GPIO_SD_B0_01__LPSPI1_PCS0               0x01c0 0x03b0 0x04ec 4 0
+#define IMXRT_PAD_GPIO_SD_B0_01__GPIO3_gpio_io13           0x01c0 0x03b0 0x0000 5 0
+#define IMXRT_PAD_GPIO_SD_B0_01__FLEXSPI_FLEXSPI_B_SS1_B   0x01c0 0x03b0 0x0000 6 0
+/* GPIO_SD_B0_02 */
+#define IMXRT_PAD_GPIO_SD_B0_02__USDHC1_usdhc_data0        0x01c4 0x03b4 0x0000 0 0
+#define IMXRT_PAD_GPIO_SD_B0_02__PWM1_A1                   0x01c4 0x03b4 0x045c 1 1
+#define IMXRT_PAD_GPIO_SD_B0_02__LPUART8_CTS_B             0x01c4 0x03b4 0x0000 2 0
+#define IMXRT_PAD_GPIO_SD_B0_02__XBARA1_OUT06              0x01c4 0x03b4 0x061c 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_6 to 0x1 */
+#define IMXRT_PAD_GPIO_SD_B0_02__XBARA1_IN06               0x01c4 0x03b4 0x061c 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_6 to 0 */
+#define IMXRT_PAD_GPIO_SD_B0_02__LPSPI1_SDO                0x01c4 0x03b4 0x04f8 4 1
+#define IMXRT_PAD_GPIO_SD_B0_02__GPIO3_gpio_io14           0x01c4 0x03b4 0x0000 5 0
+/* GPIO_SD_B0_03 */
+#define IMXRT_PAD_GPIO_SD_B0_03__USDHC1_usdhc_data1        0x01c8 0x03b8 0x0000 0 0
+#define IMXRT_PAD_GPIO_SD_B0_03__PWM1_B1                   0x01c8 0x03b8 0x046c 1 1
+#define IMXRT_PAD_GPIO_SD_B0_03__LPUART8_RTS_B             0x01c8 0x03b8 0x0000 2 0
+#define IMXRT_PAD_GPIO_SD_B0_03__XBARA1_OUT07              0x01c8 0x03b8 0x0620 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_7 to 0x1 */
+#define IMXRT_PAD_GPIO_SD_B0_03__XBARA1_IN07               0x01c8 0x03b8 0x0620 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_7 to 0 */
+#define IMXRT_PAD_GPIO_SD_B0_03__LPSPI1_SDI                0x01c8 0x03b8 0x04f4 4 1
+#define IMXRT_PAD_GPIO_SD_B0_03__GPIO3_gpio_io15           0x01c8 0x03b8 0x0000 5 0
+/* GPIO_SD_B0_04 */
+#define IMXRT_PAD_GPIO_SD_B0_04__USDHC1_usdhc_data2        0x01cc 0x03bc 0x0000 0 0
+#define IMXRT_PAD_GPIO_SD_B0_04__PWM1_A2                   0x01cc 0x03bc 0x0460 1 1
+#define IMXRT_PAD_GPIO_SD_B0_04__LPUART8_TX                0x01cc 0x03bc 0x0564 2 0
+#define IMXRT_PAD_GPIO_SD_B0_04__XBARA1_OUT08              0x01cc 0x03bc 0x0624 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_8 to 0x1 */
+#define IMXRT_PAD_GPIO_SD_B0_04__XBARA1_IN08               0x01cc 0x03bc 0x0624 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_8 to 0 */
+#define IMXRT_PAD_GPIO_SD_B0_04__FLEXSPI_FLEXSPI_B_SS0_B   0x01cc 0x03bc 0x0000 4 0
+#define IMXRT_PAD_GPIO_SD_B0_04__GPIO3_gpio_io16           0x01cc 0x03bc 0x0000 5 0
+#define IMXRT_PAD_GPIO_SD_B0_04__CCM_CLKO1                 0x01cc 0x03bc 0x0000 6 0
+/* GPIO_SD_B0_05 */
+#define IMXRT_PAD_GPIO_SD_B0_05__USDHC1_usdhc_data3        0x01d0 0x03c0 0x0000 0 0
+#define IMXRT_PAD_GPIO_SD_B0_05__PWM1_B2                   0x01d0 0x03c0 0x0470 1 1
+#define IMXRT_PAD_GPIO_SD_B0_05__LPUART8_RX                0x01d0 0x03c0 0x0560 2 0
+#define IMXRT_PAD_GPIO_SD_B0_05__XBARA1_OUT09              0x01d0 0x03c0 0x0628 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_9 to 0x1 */
+#define IMXRT_PAD_GPIO_SD_B0_05__XBARA1_IN09               0x01d0 0x03c0 0x0628 3 1 /* Maybe you want to set IOMUXC_GPR_GPR6 IOMUXC_XBAR_DIR_SEL_9 to 0 */
+#define IMXRT_PAD_GPIO_SD_B0_05__FLEXSPI_FLEXSPI_B_DQS     0x01d0 0x03c0 0x0000 4 0
+#define IMXRT_PAD_GPIO_SD_B0_05__GPIO3_gpio_io17           0x01d0 0x03c0 0x0000 5 0
+#define IMXRT_PAD_GPIO_SD_B0_05__CCM_CLKO2                 0x01d0 0x03c0 0x0000 6 0
+/* GPIO_SD_B1_00 */
+#define IMXRT_PAD_GPIO_SD_B1_00__USDHC2_usdhc_data3        0x01d4 0x03c4 0x05f4 0 0
+#define IMXRT_PAD_GPIO_SD_B1_00__FLEXSPI_FLEXSPI_B_DATA3   0x01d4 0x03c4 0x04c4 1 0
+#define IMXRT_PAD_GPIO_SD_B1_00__PWM1_A3                   0x01d4 0x03c4 0x0454 2 0
+#define IMXRT_PAD_GPIO_SD_B1_00__SAI1_sai_tx_data3         0x01d4 0x03c4 0x0598 3 0
+#define IMXRT_PAD_GPIO_SD_B1_00__LPUART4_TX                0x01d4 0x03c4 0x0544 4 0
+#define IMXRT_PAD_GPIO_SD_B1_00__GPIO3_gpio_io00           0x01d4 0x03c4 0x0000 5 0
+/* GPIO_SD_B1_01 */
+#define IMXRT_PAD_GPIO_SD_B1_01__USDHC2_usdhc_data2        0x01d8 0x03c8 0x05f0 0 0
+#define IMXRT_PAD_GPIO_SD_B1_01__FLEXSPI_FLEXSPI_B_DATA2   0x01d8 0x03c8 0x04c0 1 0
+#define IMXRT_PAD_GPIO_SD_B1_01__PWM1_B3                   0x01d8 0x03c8 0x0464 2 0
+#define IMXRT_PAD_GPIO_SD_B1_01__SAI1_sai_tx_data2         0x01d8 0x03c8 0x059c 3 0
+#define IMXRT_PAD_GPIO_SD_B1_01__LPUART4_RX                0x01d8 0x03c8 0x0540 4 0
+#define IMXRT_PAD_GPIO_SD_B1_01__GPIO3_gpio_io01           0x01d8 0x03c8 0x0000 5 0
+/* GPIO_SD_B1_02 */
+#define IMXRT_PAD_GPIO_SD_B1_02__USDHC2_usdhc_data1        0x01dc 0x03cc 0x05ec 0 0
+#define IMXRT_PAD_GPIO_SD_B1_02__FLEXSPI_FLEXSPI_B_DATA1   0x01dc 0x03cc 0x04bc 1 0
+#define IMXRT_PAD_GPIO_SD_B1_02__PWM2_A3                   0x01dc 0x03cc 0x0474 2 0
+#define IMXRT_PAD_GPIO_SD_B1_02__SAI1_sai_tx_data1         0x01dc 0x03cc 0x05a0 3 0
+#define IMXRT_PAD_GPIO_SD_B1_02__CAN1_TX                   0x01dc 0x03cc 0x0000 4 0
+#define IMXRT_PAD_GPIO_SD_B1_02__GPIO3_gpio_io02           0x01dc 0x03cc 0x0000 5 0
+#define IMXRT_PAD_GPIO_SD_B1_02__CCM_WAIT                  0x01dc 0x03cc 0x0000 6 0
+/* GPIO_SD_B1_03 */
+#define IMXRT_PAD_GPIO_SD_B1_03__USDHC2_usdhc_data0        0x01e0 0x03d0 0x05e8 0 0
+#define IMXRT_PAD_GPIO_SD_B1_03__FLEXSPI_FLEXSPI_B_DATA0   0x01e0 0x03d0 0x04b8 1 0
+#define IMXRT_PAD_GPIO_SD_B1_03__PWM2_B3                   0x01e0 0x03d0 0x0484 2 0
+#define IMXRT_PAD_GPIO_SD_B1_03__SAI1_sai_mclk             0x01e0 0x03d0 0x058c 3 0
+#define IMXRT_PAD_GPIO_SD_B1_03__CAN1_RX                   0x01e0 0x03d0 0x044c 4 0
+#define IMXRT_PAD_GPIO_SD_B1_03__GPIO3_gpio_io03           0x01e0 0x03d0 0x0000 5 0
+#define IMXRT_PAD_GPIO_SD_B1_03__CCM_PMIC_RDY              0x01e0 0x03d0 0x03fc 6 0
+/* GPIO_SD_B1_04 */
+#define IMXRT_PAD_GPIO_SD_B1_04__USDHC2_usdhc_clk          0x01e4 0x03d4 0x05dc 0 0
+#define IMXRT_PAD_GPIO_SD_B1_04__FLEXSPI_FLEXSPI_B_SCLK    0x01e4 0x03d4 0x0000 1 0
+#define IMXRT_PAD_GPIO_SD_B1_04__LPI2C1_SCL                0x01e4 0x03d4 0x04cc 2 0
+#define IMXRT_PAD_GPIO_SD_B1_04__SAI1_sai_rx_sync          0x01e4 0x03d4 0x05a4 3 0
+#define IMXRT_PAD_GPIO_SD_B1_04__FLEXSPI_FLEXSPI_A_SS1_B   0x01e4 0x03d4 0x0000 4 0
+#define IMXRT_PAD_GPIO_SD_B1_04__GPIO3_gpio_io04           0x01e4 0x03d4 0x0000 5 0
+#define IMXRT_PAD_GPIO_SD_B1_04__CCM_STOP                  0x01e4 0x03d4 0x0000 6 0
+/* GPIO_SD_B1_05 */
+#define IMXRT_PAD_GPIO_SD_B1_05__USDHC2_usdhc_cmd          0x01e8 0x03d8 0x05e4 0 0
+#define IMXRT_PAD_GPIO_SD_B1_05__FLEXSPI_FLEXSPI_A_DQS     0x01e8 0x03d8 0x04a4 1 0
+#define IMXRT_PAD_GPIO_SD_B1_05__LPI2C1_SDA                0x01e8 0x03d8 0x04d0 2 0
+#define IMXRT_PAD_GPIO_SD_B1_05__SAI1_sai_rx_bclk          0x01e8 0x03d8 0x0590 3 0
+#define IMXRT_PAD_GPIO_SD_B1_05__FLEXSPI_FLEXSPI_B_SS0_B   0x01e8 0x03d8 0x0000 4 0
+#define IMXRT_PAD_GPIO_SD_B1_05__GPIO3_gpio_io05           0x01e8 0x03d8 0x0000 5 0
+/* GPIO_SD_B1_06 */
+#define IMXRT_PAD_GPIO_SD_B1_06__USDHC2_usdhc_reset_b      0x01ec 0x03dc 0x0000 0 0
+#define IMXRT_PAD_GPIO_SD_B1_06__FLEXSPI_FLEXSPI_A_SS0_B   0x01ec 0x03dc 0x0000 1 0
+#define IMXRT_PAD_GPIO_SD_B1_06__LPUART7_CTS_B             0x01ec 0x03dc 0x0000 2 0
+#define IMXRT_PAD_GPIO_SD_B1_06__SAI1_sai_rx_data0         0x01ec 0x03dc 0x0594 3 0
+#define IMXRT_PAD_GPIO_SD_B1_06__LPSPI2_PCS0               0x01ec 0x03dc 0x04fc 4 0
+#define IMXRT_PAD_GPIO_SD_B1_06__GPIO3_gpio_io06           0x01ec 0x03dc 0x0000 5 0
+/* GPIO_SD_B1_07 */
+#define IMXRT_PAD_GPIO_SD_B1_07__SEMC_CSX1                 0x01f0 0x03e0 0x0000 0 0
+#define IMXRT_PAD_GPIO_SD_B1_07__FLEXSPI_FLEXSPI_A_SCLK    0x01f0 0x03e0 0x04c8 1 0
+#define IMXRT_PAD_GPIO_SD_B1_07__LPUART7_RTS_B             0x01f0 0x03e0 0x0000 2 0
+#define IMXRT_PAD_GPIO_SD_B1_07__SAI1_sai_tx_data0         0x01f0 0x03e0 0x0000 3 0
+#define IMXRT_PAD_GPIO_SD_B1_07__LPSPI2_SCK                0x01f0 0x03e0 0x0500 4 0
+#define IMXRT_PAD_GPIO_SD_B1_07__GPIO3_gpio_io07           0x01f0 0x03e0 0x0000 5 0
+/* GPIO_SD_B1_08 */
+#define IMXRT_PAD_GPIO_SD_B1_08__USDHC2_usdhc_data4        0x01f4 0x03e4 0x05f8 0 0
+#define IMXRT_PAD_GPIO_SD_B1_08__FLEXSPI_FLEXSPI_A_DATA0   0x01f4 0x03e4 0x04a8 1 0
+#define IMXRT_PAD_GPIO_SD_B1_08__LPUART7_TX                0x01f4 0x03e4 0x055c 2 0
+#define IMXRT_PAD_GPIO_SD_B1_08__SAI1_sai_tx_bclk          0x01f4 0x03e4 0x05a8 3 0
+#define IMXRT_PAD_GPIO_SD_B1_08__LPSPI2_SDO                0x01f4 0x03e4 0x0508 4 0
+#define IMXRT_PAD_GPIO_SD_B1_08__GPIO3_gpio_io08           0x01f4 0x03e4 0x0000 5 0
+#define IMXRT_PAD_GPIO_SD_B1_08__SEMC_CSX2                 0x01f4 0x03e4 0x0000 6 0
+/* GPIO_SD_B1_09 */
+#define IMXRT_PAD_GPIO_SD_B1_09__USDHC2_usdhc_data5        0x01f8 0x03e8 0x05fc 0 0
+#define IMXRT_PAD_GPIO_SD_B1_09__FLEXSPI_FLEXSPI_A_DATA1   0x01f8 0x03e8 0x04ac 1 0
+#define IMXRT_PAD_GPIO_SD_B1_09__LPUART7_RX                0x01f8 0x03e8 0x0558 2 0
+#define IMXRT_PAD_GPIO_SD_B1_09__SAI1_sai_tx_sync          0x01f8 0x03e8 0x05ac 3 0
+#define IMXRT_PAD_GPIO_SD_B1_09__LPSPI2_SDI                0x01f8 0x03e8 0x0504 4 0
+#define IMXRT_PAD_GPIO_SD_B1_09__GPIO3_gpio_io09           0x01f8 0x03e8 0x0000 5 0
+/* GPIO_SD_B1_10 */
+#define IMXRT_PAD_GPIO_SD_B1_10__USDHC2_usdhc_data6        0x01fc 0x03ec 0x0600 0 0
+#define IMXRT_PAD_GPIO_SD_B1_10__FLEXSPI_FLEXSPI_A_DATA2   0x01fc 0x03ec 0x04b0 1 0
+#define IMXRT_PAD_GPIO_SD_B1_10__LPUART2_RX                0x01fc 0x03ec 0x052c 2 0
+#define IMXRT_PAD_GPIO_SD_B1_10__LPI2C2_SDA                0x01fc 0x03ec 0x04d8 3 0
+#define IMXRT_PAD_GPIO_SD_B1_10__LPSPI2_PCS2               0x01fc 0x03ec 0x0000 4 0
+#define IMXRT_PAD_GPIO_SD_B1_10__GPIO3_gpio_io10           0x01fc 0x03ec 0x0000 5 0
+/* GPIO_SD_B1_11 */
+#define IMXRT_PAD_GPIO_SD_B1_11__USDHC2_usdhc_data7        0x0200 0x03f0 0x0604 0 0
+#define IMXRT_PAD_GPIO_SD_B1_11__FLEXSPI_FLEXSPI_A_DATA3   0x0200 0x03f0 0x04b4 1 0
+#define IMXRT_PAD_GPIO_SD_B1_11__LPUART2_TX                0x0200 0x03f0 0x0530 2 0
+#define IMXRT_PAD_GPIO_SD_B1_11__LPI2C2_SCL                0x0200 0x03f0 0x04d4 3 0
+#define IMXRT_PAD_GPIO_SD_B1_11__LPSPI2_PCS3               0x0200 0x03f0 0x0000 4 0
+#define IMXRT_PAD_GPIO_SD_B1_11__GPIO3_gpio_io11           0x0200 0x03f0 0x0000 5 0
+#ifdef __cplusplus
+#endif /* __cplusplus */
+#endif /* LIBBSP_ARM_IMXRT_IMXRT1050_PINFUNC_H */
diff --git a/bsps/arm/imxrt/include/imxrt/memory.h b/bsps/arm/imxrt/include/imxrt/memory.h
new file mode 100644
index 0000000000..5a6b457aa6
--- /dev/null
+++ b/bsps/arm/imxrt/include/imxrt/memory.h
@@ -0,0 +1,83 @@
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * ARE DISCLAIMED. IN NO EVENT SMEMORYL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+#ifndef LIBBSP_ARM_IMXRT_IMXRT_MEMORY_H
+#define LIBBSP_ARM_IMXRT_IMXRT_MEMORY_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+extern char imxrt_memory_null_begin[];
+extern char imxrt_memory_null_end[];
+extern char imxrt_memory_null_size[];
+extern char imxrt_memory_itcm_begin[];
+extern char imxrt_memory_itcm_end[];
+extern char imxrt_memory_itcm_size[];
+extern char imxrt_memory_dtcm_begin[];
+extern char imxrt_memory_dtcm_end[];
+extern char imxrt_memory_dtcm_size[];
+extern char imxrt_memory_ocram_begin[];
+extern char imxrt_memory_ocram_end[];
+extern char imxrt_memory_ocram_size[];
+extern char imxrt_memory_peripheral_begin[];
+extern char imxrt_memory_peripheral_end[];
+extern char imxrt_memory_peripheral_size[];
+extern char imxrt_memory_flexspi_config_begin[];
+extern char imxrt_memory_flexspi_config_end[];
+extern char imxrt_memory_flexspi_config_size[];
+extern char imxrt_memory_flexspi_ivt_begin[];
+extern char imxrt_memory_flexspi_ivt_end[];
+extern char imxrt_memory_flexspi_ivt_size[];
+extern char imxrt_memory_flexspi_begin[];
+extern char imxrt_memory_flexspi_end[];
+extern char imxrt_memory_flexspi_size[];
+extern char imxrt_memory_flexspi_fifo_begin[];
+extern char imxrt_memory_flexspi_fifo_end[];
+extern char imxrt_memory_flexspi_fifo_size[];
+extern char imxrt_memory_sdram_begin[];
+extern char imxrt_memory_sdram_end[];
+extern char imxrt_memory_sdram_size[];
+extern char imxrt_memory_sdram_nocache_begin[];
+extern char imxrt_memory_sdram_nocache_end[];
+extern char imxrt_memory_sdram_nocache_size[];
+#ifdef __cplusplus
+#endif
+#endif /* LIBBSP_ARM_IMXRT_IMXRT_MEMORY_H */
diff --git a/bsps/arm/imxrt/include/imxrt/start.h b/bsps/arm/imxrt/include/imxrt/start.h
index 0000000000..a7016c83ee
--- /dev/null
+++ b/bsps/arm/imxrt/include/imxrt/start.h
@@ -0,0 +1,54 @@
+ * @file
+ * @ingroup RTEMSBSPsARMimxrt
+ * @brief Special start configurations.
+ * are met:
+#ifndef LIBBSP_ARM_IMXRT_IMXRT_START_H
+#define LIBBSP_ARM_IMXRT_IMXRT_START_H
+#include <bsp/start.h>
+#include <rtems/score/armv7m.h>
+#ifdef __cplusplus
+extern "C" {
+extern BSP_START_DATA_SECTION const ARMV7M_MPU_Region_Config
+  imxrt_start_config_mpu_region[];
+extern BSP_START_DATA_SECTION const size_t imxrt_start_config_mpu_region_count;
+#ifdef __cplusplus
+#endif /* LIBBSP_ARM_IMXRT_IMXRT_START_H */
diff --git a/bsps/arm/imxrt/include/tm27.h b/bsps/arm/imxrt/include/tm27.h
index 0000000000..0dfa7bf628
--- /dev/null
+++ b/bsps/arm/imxrt/include/tm27.h
@@ -0,0 +1 @@
+#include <rtems/tm27-default.h>
diff --git a/bsps/arm/imxrt/spi/imxrt-lpspi.c b/bsps/arm/imxrt/spi/imxrt-lpspi.c
index 0000000000..6da3ffdecf
--- /dev/null
+++ b/bsps/arm/imxrt/spi/imxrt-lpspi.c
@@ -0,0 +1,533 @@
+ * are met:
+#include <bsp.h>
+#include <bsp/fatal.h>
+#include <bsp/fdt.h>
+#include <bsp/irq.h>
+#include <chip.h>
+#include <dev/spi/spi.h>
+#include <fsl_clock.h>
+#include <libfdt.h>
+struct imxrt_lpspi_bus {
+  spi_bus base;
+  volatile LPSPI_Type *regs;
+  rtems_vector_number irq;
+  uint32_t src_clock_hz;
+  clock_ip_name_t clock_ip;
+  uint32_t msg_todo;
+  const spi_ioc_transfer *msg;
+  rtems_binary_semaphore sem;
+  uint32_t tcr;
+  size_t remaining_rx_size;
+  uint8_t *rx_buf;
+  size_t remaining_tx_size;
+  const uint8_t *tx_buf;
+  uint32_t fifo_size;
+static const uint32_t word_size = 8;
+static unsigned div_round_up(unsigned divident, unsigned divisor)
+  return (divident + divisor - 1) / divisor;
+static void imxrt_lpspi_find_clockdivs(
+  struct imxrt_lpspi_bus *bus,
+  uint32_t max_baud_hz,
+  unsigned *sckdiv,
+  unsigned *prescale
+  const unsigned max_sckdif = LPSPI_CCR_SCKDIV_MASK >> LPSPI_CCR_SCKDIV_SHIFT;
+  const unsigned max_prescale =
+      LPSPI_TCR_PRESCALE_MASK >> LPSPI_TCR_PRESCALE_SHIFT;
+  unsigned best_baud_hz;
+  int best_sckdif;
+  int best_prescale;
+  int check_baud_hz;
+  int check_sckdif;
+  int check_prescale;
+  /* Start with slowest possible */
+  best_sckdif = max_sckdif;
+  best_prescale = max_prescale;
+  best_baud_hz = div_round_up(bus->src_clock_hz,
+      (1 << best_prescale) * (best_sckdif + 2));
+  for (check_prescale = 0;
+      check_prescale <= max_prescale && best_baud_hz < max_baud_hz;
+      ++check_prescale) {
+    check_sckdif = div_round_up(bus->src_clock_hz,
+        (1 << check_prescale) * max_baud_hz) - 2;
+    if (check_sckdif > max_sckdif) {
+      check_sckdif = max_sckdif;
+    check_baud_hz = div_round_up(bus->src_clock_hz,
+        (1 << check_prescale) * (check_sckdif + 2));
+    if (check_baud_hz <= max_baud_hz && check_baud_hz > best_baud_hz) {
+      best_baud_hz = check_baud_hz;
+      best_sckdif = check_sckdif;
+      best_prescale = check_prescale;
+  *sckdiv = best_sckdif;
+  *prescale = best_prescale;
+static void imxrt_lpspi_config(
+  volatile LPSPI_Type *regs,
+  uint32_t ccr_orig;
+  uint32_t ccr;
+  uint32_t tcr;
+  unsigned sckdiv;
+  unsigned prescale;
+  ccr_orig = ccr = regs->CCR;
+  tcr = 0;
+  imxrt_lpspi_find_clockdivs(bus, msg->speed_hz, &sckdiv, &prescale);
+  /* Currently just force half a clock after and before chip select. */
+  ccr = LPSPI_CCR_SCKDIV(sckdiv) | LPSPI_CCR_SCKPCS(sckdiv) |
+      LPSPI_CCR_PCSSCK(sckdiv) | LPSPI_CCR_DBT(sckdiv);
+  tcr |= LPSPI_TCR_PRESCALE(prescale);
+  if ((msg->mode & SPI_CPOL) != 0) {
+    tcr |= LPSPI_TCR_CPOL_MASK;
+  if ((msg->mode & SPI_CPHA) != 0) {
+    tcr |= LPSPI_TCR_CPHA_MASK;
+  if (msg->mode & SPI_LSB_FIRST) {
+    tcr |= LPSPI_TCR_LSBF_MASK;
+  tcr |= LPSPI_TCR_PCS(msg->cs);
+  if (!msg->cs_change) {
+    tcr |= LPSPI_TCR_CONT_MASK;
+  tcr |= LPSPI_TCR_FRAMESZ(word_size-1);
+  if (ccr_orig != ccr) {
+    regs->CR &= ~LPSPI_CR_MEN_MASK;
+    regs->CCR = ccr;
+    regs->CR |= LPSPI_CR_MEN_MASK;
+  /* No CONTC on first write. Otherwise upper 8 bits are not written. */
+  regs->TCR = tcr;
+  regs->TCR = tcr | LPSPI_TCR_CONTC_MASK | LPSPI_TCR_CONT_MASK;
+static inline bool imxrt_lpspi_rx_fifo_not_empty(
+  return ((regs->RSR & LPSPI_RSR_RXEMPTY_MASK) == 0);
+static inline bool imxrt_lpspi_tx_fifo_not_full(
+   * We might add two things to the FIFO: A TCR and data. Therefore leave one
+   * extra space.
+  return ((regs->FSR & LPSPI_FSR_TXCOUNT_MASK) >> LPSPI_FSR_TXCOUNT_SHIFT) <
+      bus->fifo_size - 2;
+static void imxrt_lpspi_fill_tx_fifo(
+  while(imxrt_lpspi_tx_fifo_not_full(bus, regs)
+      && bus->remaining_tx_size > 0) {
+    if (bus->remaining_tx_size == 1) {
+      regs->TCR &= ~(LPSPI_TCR_CONT_MASK);
+    if (bus->tx_buf != NULL) {
+      regs->TDR = bus->tx_buf[0];
+      ++bus->tx_buf;
+    } else {
+      regs->TDR = 0;
+    --bus->remaining_tx_size;
+static void imxrt_lpspi_next_msg(
+  if (bus->msg_todo > 0) {
+    msg = bus->msg;
+    imxrt_lpspi_config(bus, regs, msg);
+    bus->remaining_tx_size = msg->len;
+    bus->remaining_rx_size = msg->len;
+    bus->rx_buf = msg->rx_buf;
+    bus->tx_buf = msg->tx_buf;
+    imxrt_lpspi_fill_tx_fifo(bus, regs);
+    regs->IER = LPSPI_IER_TDIE_MASK;
+  } else {
+    regs->IER = 0;
+    rtems_binary_semaphore_post(&bus->sem);
+static void imxrt_lpspi_pull_data_from_rx_fifo(
+  while (imxrt_lpspi_rx_fifo_not_empty(regs) && bus->remaining_rx_size > 0) {
+    uint32_t data;
+    data = regs->RDR;
+    if (bus->rx_buf != NULL) {
+      *bus->rx_buf = data;
+      ++bus->rx_buf;
+    --bus->remaining_rx_size;
+static void imxrt_lpspi_interrupt(void *arg)
+  struct imxrt_lpspi_bus *bus;
+  bus = arg;
+  regs = bus->regs;
+  imxrt_lpspi_pull_data_from_rx_fifo(bus, regs);
+  if (bus->remaining_tx_size == 0) {
+    if (bus->remaining_rx_size > 0) {
+      regs->IER = LPSPI_IER_RDIE_MASK;
+    } else {
+      --bus->msg_todo;
+      ++bus->msg;
+      imxrt_lpspi_next_msg(bus, regs);
+static inline int imxrt_lpspi_settings_ok(
+  if (msg->cs_change == 0) {
+     * This one most likely would need a bigger workaround if it is necessary.
+     * See "i.MX RT1050 Processor Reference Manual Rev. 4" Chapter 47.3.2.2
+     * "Receive FIFO and Data Match":
+     * "During a continuous transfer, if the transmit FIFO is empty, then the
+     * receive data is only written to the receive FIFO after the transmit FIFO
+     * is written or after the Transmit Command Register (TCR) is written to end
+     * the frame."
+     * It might is possible to extend the driver so that it can work with an
+     * empty read buffer.
+    return -EINVAL;
+  /* most of this is currently just not implemented */
+  if (msg->cs > 3 ||
+      msg->speed_hz > bus->base.max_speed_hz ||
+      msg->delay_usecs != 0 ||
+      (msg->mode & ~(SPI_CPHA | SPI_CPOL | SPI_LSB_FIRST)) != 0 ||
+      msg->bits_per_word != word_size) {
+    return -EINVAL;
+  return 0;
+static int imxrt_lpspi_check_messages(
+  const spi_ioc_transfer *msg,
+  uint32_t size
+  while(size > 0) {
+    int rv;
+    rv = imxrt_lpspi_settings_ok(bus, msg);
+    if (rv != 0) {
+      return rv;
+    ++msg;
+    --size;
+  return 0;
+static int imxrt_lpspi_transfer(
+  spi_bus *base,
+  const spi_ioc_transfer *msgs,
+  uint32_t n
+  int rv;
+  bus = (struct imxrt_lpspi_bus *) base;
+  rv = imxrt_lpspi_check_messages(bus, msgs, n);
+  if (rv == 0) {
+    bus->msg_todo = n;
+    bus->msg = &msgs[0];
+    imxrt_lpspi_next_msg(bus, bus->regs);
+    rtems_binary_semaphore_wait(&bus->sem);
+  return rv;
+static void imxrt_lpspi_sw_reset(volatile LPSPI_Type *regs)
+  regs->CR = LPSPI_CR_RST_MASK | LPSPI_CR_RRF_MASK | LPSPI_CR_RTF_MASK;
+  regs->CR = 0;
+static void imxrt_lpspi_destroy(spi_bus *base)
+  regs = bus->regs;
+  imxrt_lpspi_sw_reset(regs);
+  CLOCK_DisableClock(bus->clock_ip);
+  rtems_interrupt_handler_remove(bus->irq, imxrt_lpspi_interrupt, bus);
+  spi_bus_destroy_and_free(&bus->base);
+static int imxrt_lpspi_hw_init(struct imxrt_lpspi_bus *bus)
+  rtems_status_code sc;
+  regs = bus->regs;
+  CLOCK_EnableClock(bus->clock_ip);
+  regs->CFGR1 |= LPSPI_CFGR1_MASTER_MASK;
+  regs->FCR = LPSPI_FCR_TXWATER(0) | LPSPI_FCR_RXWATER(0);
+  bus->fifo_size = 1 << ((regs->PARAM & LPSPI_PARAM_TXFIFO_MASK) >>
+      LPSPI_PARAM_TXFIFO_SHIFT);
+  sc = rtems_interrupt_handler_install(
+    bus->irq,
+    "LPSPI",
+    RTEMS_INTERRUPT_UNIQUE,
+    imxrt_lpspi_interrupt,
+    bus
+  if (sc != RTEMS_SUCCESSFUL) {
+    return EAGAIN;
+  return 0;
+static int imxrt_lpspi_setup(spi_bus *base)
+  int rv;
+  spi_ioc_transfer msg = {
+    .cs_change = base->cs_change,
+    .cs = base->cs,
+    .bits_per_word = base->bits_per_word,
+    .mode = base->mode,
+    .speed_hz = base->speed_hz,
+    .delay_usecs = base->delay_usecs,
+    .rx_buf = NULL,
+    .tx_buf = NULL,
+  rv = imxrt_lpspi_settings_ok(bus, &msg);
+   * Nothing to do besides checking.
+   * Every transfer will later overwrite the settings anyway.
+  return rv;
+static uint32_t imxrt_lpspi_get_src_freq(void)
+  uint32_t freq;
+  uint32_t mux;
+  uint32_t divider;
+  mux = CLOCK_GetMux(kCLOCK_LpspiMux);
+  switch (mux) {
+  case 0: /* PLL3 PFD1 */
+    freq = CLOCK_GetFreq(kCLOCK_Usb1PllPfd1Clk);
+    break;
+  case 1: /* PLL3 PFD0 */
+    freq = CLOCK_GetFreq(kCLOCK_Usb1PllPfd0Clk);
+    break;
+  case 2: /* PLL2 */
+    freq = CLOCK_GetFreq(kCLOCK_SysPllClk);
+    break;
+  case 3: /* PLL2 PFD2 */
+    freq = CLOCK_GetFreq(kCLOCK_SysPllPfd2Clk);
+    break;
+  default:
+    freq = 0;
+  divider = CLOCK_GetDiv(kCLOCK_LpspiDiv) + 1;
+  freq /= divider;
+  return freq;
+static clock_ip_name_t imxrt_lpspi_clock_ip(volatile LPSPI_Type *regs)
+  LPSPI_Type *const base_addresses[] = LPSPI_BASE_PTRS;
+  static const clock_ip_name_t lpspi_clocks[] = LPSPI_CLOCKS;
+  size_t i;
+  for (i = 0; i < RTEMS_ARRAY_SIZE(base_addresses); ++i) {
+    if (base_addresses[i] == regs) {
+      return lpspi_clocks[i];
+  return kCLOCK_IpInvalid;
+void imxrt_lpspi_init(void)
+  const void *fdt;
+  int node;
+  fdt = bsp_fdt_get();
+  node = -1;
+  do {
+    node = fdt_node_offset_by_compatible(fdt, node, "nxp,imxrt-lpspi");
+    if (node >= 0 && imxrt_fdt_node_is_enabled(fdt, node)) {
+      int eno;
+      const char *bus_path;
+      bus = (struct imxrt_lpspi_bus*) spi_bus_alloc_and_init(sizeof(*bus));
+      if (bus == NULL) {
+        bsp_fatal(IMXRT_FATAL_LPSPI_ALLOC_FAILED);
+      rtems_binary_semaphore_init(&bus->sem, "LPSPI");
+      bus->regs = imx_get_reg_of_node(fdt, node);
+      if (bus->regs == NULL) {
+        bsp_fatal(IMXRT_FATAL_LPSPI_INVALID_FDT);
+      bus->irq = imx_get_irq_of_node(fdt, node, 0);
+      if (bus->irq == BSP_INTERRUPT_VECTOR_INVALID) {
+      bus_path = fdt_getprop(fdt, node, "rtems,path", NULL);
+      if (bus_path == NULL) {
+      bus->clock_ip = imxrt_lpspi_clock_ip(bus->regs);
+      bus->src_clock_hz = imxrt_lpspi_get_src_freq();
+      /* Absolut maximum is 30MHz according to electrical characteristics */
+      bus->base.max_speed_hz = MIN(bus->src_clock_hz / 2, 30000000);
+      bus->base.delay_usecs = 0;
+      eno = imxrt_lpspi_hw_init(bus);
+      if (eno != 0) {
+        bsp_fatal(IMXRT_FATAL_LPSPI_HW_INIT_FAILED);
+      bus->base.transfer = imxrt_lpspi_transfer;
+      bus->base.destroy = imxrt_lpspi_destroy;
+      bus->base.setup = imxrt_lpspi_setup;
+      eno = spi_bus_register(&bus->base, bus_path);
+      if (eno != 0) {
+        bsp_fatal(IMXRT_FATAL_LPSPI_REGISTER_FAILED);
+  } while (node >= 0);
diff --git a/bsps/arm/imxrt/start/bspstart.c b/bsps/arm/imxrt/start/bspstart.c
index 0000000000..884f0aaf92
--- /dev/null
+++ b/bsps/arm/imxrt/start/bspstart.c
@@ -0,0 +1,141 @@
+ * are met:
+#include <rtems/sysinit.h>
+#include <bsp.h>
+#include <bsp/bootcard.h>
+#include <bsp/imx-iomux.h>
+#include <bsp/irq-generic.h>
+#include <bsp/linker-symbols.h>
+#include <bsp/flash-headers.h>
+uint32_t imxrt_systick_frequency(void)
+  return CLOCK_GetCpuClkFreq();
+static void imxrt_disable_wait_mode(void)
+   * Prevent processor from entering WAIT or SLEEP mode when a WFI is executed.
+   * This would switch off the normal interrupt controller and activate an
+   * alternative one. See "i.MX RT1050 Reference Manual, Rev. 4, 12/2019"
+   * chapter 14.6.3.2.1 "Entering WAIT mode".
+   * FIXME: For saving energy it would be a better solution to support the
+   * alternative interrupt controller. But that makes a bit of work necessary on
+   * every WFI.
+  CLOCK_SetMode(kCLOCK_ModeRun);
+void bsp_start(void)
+  imxrt_disable_wait_mode();
+  bsp_interrupt_initialize();
+  rtems_cache_coherent_add_area(
+    bsp_section_nocacheheap_begin,
+    (uintptr_t) bsp_section_nocacheheap_size
+const void *bsp_fdt_get(void)
+  return imxrt_dtb;
+bool imxrt_fdt_node_is_enabled(const void *fdt, int node)
+  int len;
+  const uint32_t *val;
+  val = fdt_getprop(fdt, node, "status", &len);
+  if (val != NULL &&
+      (strcmp((char*)val, "ok") == 0 || strcmp((char*)val, "okay") == 0)) {
+    return true;
+  return false;
+void *imx_get_reg_of_node(const void *fdt, int node)
+  int len;
+  val = fdt_getprop(fdt, node, "reg", &len);
+  if (val == NULL || len < 4) {
+    return NULL;
+  return (void *) fdt32_to_cpu(val[0]);
+rtems_vector_number imx_get_irq_of_node(
+  const void *fdt,
+  int node,
+  size_t index
+  int len;
+  val = fdt_getprop(fdt, node, "interrupts", &len);
+  if (val == NULL || len < (int) ((index) * 4)) {
+    return BSP_INTERRUPT_VECTOR_INVALID;
+  return fdt32_to_cpu(val[index]);
+uint32_t bsp_fdt_map_intr(const uint32_t *intr, size_t icells)
+  return intr[0];
+/* Make sure to pull in the flash headers */
+__attribute__((used)) static const void *hdr_dcd = &imxrt_dcd_data;
+__attribute__((used)) static const void *hdr_ivt = &imxrt_image_vector_table;
+__attribute__((used)) static const void *hdr_btd = &imxrt_boot_data;
+__attribute__((used)) static const void *hdr_fsc = &imxrt_flexspi_config;
+/* pull in some drivers */
+__attribute__((used)) static const void *drv_iomux = &imx_iomux_configure_pins;
+RTEMS_SYSINIT_ITEM(imxrt_lpspi_init, RTEMS_SYSINIT_DEVICE_DRIVERS,
+    RTEMS_SYSINIT_ORDER_MIDDLE);
+RTEMS_SYSINIT_ITEM(imxrt_lpi2c_init, RTEMS_SYSINIT_DEVICE_DRIVERS,
+RTEMS_SYSINIT_ITEM(imxrt_ffec_init, RTEMS_SYSINIT_DEVICE_DRIVERS,
diff --git a/bsps/arm/imxrt/start/bspstarthooks.c b/bsps/arm/imxrt/start/bspstarthooks.c
index 0000000000..269a8c2e69
--- /dev/null
+++ b/bsps/arm/imxrt/start/bspstarthooks.c
@@ -0,0 +1,53 @@
+ * Copyright (c) 2013, 2018 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <info at embedded-brains.de>
+#include <bsp.h>
+#include <imxrt/start.h>
+#include <chip.h>
+#include <fsl_pin_mux.h>
+#include <fsl_clock_config.h>
+BSP_START_TEXT_SECTION void bsp_start_hook_0(void)
+  /* FIXME: Initializing SDRAM is currently done by DCD. It would be more user
+   * friendly if that would be done here with a readable structure. */
+  if ((SCB->CCR & SCB_CCR_IC_Msk) == 0) {
+    SCB_EnableICache();
+  if ((SCB->CCR & SCB_CCR_DC_Msk) == 0) {
+    SCB_EnableDCache();
+  _ARMV7M_MPU_setup_from_config_and_enable(
+    imxrt_start_config_mpu_region, imxrt_start_config_mpu_region_count
+BSP_START_TEXT_SECTION void bsp_start_hook_1(void)
+  bsp_start_copy_sections_compact();
+  SCB_CleanDCache();
+  SCB_InvalidateICache();
+  bsp_start_clear_bss();
+  BOARD_BootClockRUN();
+  BOARD_InitDEBUG_UARTPins();
+  /* Reduce frequency for I2C */
+  CLOCK_SetDiv(kCLOCK_Lpi2cDiv, 5);
diff --git a/bsps/arm/imxrt/start/flash-boot-data.c b/bsps/arm/imxrt/start/flash-boot-data.c
index 0000000000..cf0430af72
--- /dev/null
+++ b/bsps/arm/imxrt/start/flash-boot-data.c
@@ -0,0 +1,37 @@
+ * are met:
+#include <imxrt/memory.h>
+#include <bspopts.h>
+const BOOT_DATA_T imxrt_boot_data = {
+  .start = (uint32_t) imxrt_memory_flexspi_config_begin,
+  .size = IMXRT_MEMORY_FLEXSPI_FLASH_SIZE,
+  .plugin = PLUGIN_FLAG,
+  .placeholder = 0xFFFFFFFF,
diff --git a/bsps/arm/imxrt/start/flash-config.c b/bsps/arm/imxrt/start/flash-config.c
index 0000000000..07324f1330
--- /dev/null
+++ b/bsps/arm/imxrt/start/flash-config.c
@@ -0,0 +1,60 @@
+ * are met:
+const flexspi_nor_config_t imxrt_flexspi_config = {
+  .memConfig = {
+    .tag = FLEXSPI_CFG_BLK_TAG,
+    .version = FLEXSPI_CFG_BLK_VERSION,
+    .readSampleClkSrc = kFlexSPIReadSampleClk_ExternalInputFromDqsPad,
+    .csHoldTime = 3u,
+    .csSetupTime = 3u,
+    .columnAddressWidth = 3u,
+    .controllerMiscOption = (1 << kFlexSpiMiscOffset_DdrModeEnable) |
+                            (1 << kFlexSpiMiscOffset_WordAddressableEnable) |
+                            (1 << kFlexSpiMiscOffset_SafeConfigFreqEnable) |
+                            (1 << kFlexSpiMiscOffset_DiffClkEnable),
+    .deviceType = kFlexSpiDeviceType_SerialRAM,
+    .sflashPadType = kSerialFlash_8Pads,
+    .serialClkFreq = kFlexSpiSerialClk_133MHz,
+    .sflashA1Size = IMXRT_MEMORY_FLEXSPI_FLASH_SIZE,
+    .dataValidTime = {16u, 16u},
+    .lookupTable = {
+      FLEXSPI_LUT_SEQ(CMD_DDR, FLEXSPI_8PAD, 0xA0, RADDR_DDR, FLEXSPI_8PAD, 0x18),
+      FLEXSPI_LUT_SEQ(CADDR_DDR, FLEXSPI_8PAD, 0x10, DUMMY_DDR, FLEXSPI_8PAD, 0x06),
+      FLEXSPI_LUT_SEQ(READ_DDR, FLEXSPI_8PAD, 0x04, STOP, FLEXSPI_1PAD, 0x0),
+    .lutCustomSeq = {{0,0},{0,0},{0,0},{0,0},{0,0},{0,0},
+                     {0,0},{0,0},{0,0},{0,0},{0,0},{0,0}},
+  .pageSize = 0x200,
+  .sectorSize = 0x40000,
+  .blockSize = 0x40000,
+  .isUniformBlockSize = 1,
diff --git a/bsps/arm/imxrt/start/flash-dcd.c b/bsps/arm/imxrt/start/flash-dcd.c
index 6dced830b9..a53e5bda39 100644
--- a/bsps/arm/imxrt/start/flash-dcd.c
+++ b/bsps/arm/imxrt/start/flash-dcd.c
@@ -5,38 +5,11 @@
  * SPDX-License-Identifier: BSD-3-Clause
- * This file was generated by the MCUXpresso Config Tools. Any manual edits made to this file
- * will be overwritten if the respective MCUXpresso Config Tools is used to update this file.
+#include <stdint.h>
-#include "dcd.h"
-/* Component ID definition, used by tools. */
-#ifndef FSL_COMPONENT_ID
-#define FSL_COMPONENT_ID "platform.drivers.xip_board"
-#endif
-#if defined(XIP_BOOT_HEADER_ENABLE) && (XIP_BOOT_HEADER_ENABLE == 1)
-#if defined(XIP_BOOT_HEADER_DCD_ENABLE) && (XIP_BOOT_HEADER_DCD_ENABLE == 1)
-#if defined(__CC_ARM) || defined(__ARMCC_VERSION) || defined(__GNUC__)
 __attribute__((section(".boot_hdr.dcd_data")))
-#elif defined(__ICCARM__)
-#pragma location = ".boot_hdr.dcd_data"
-#endif
-/* TEXT BELOW IS USED AS SETTING FOR TOOLS *************************************
-!!GlobalInfo
-product: DCDx V2.0
-processor: MIMXRT1052xxxxB
-package_id: MIMXRT1052DVL6B
-mcu_data: ksdk2_0
-processor_version: 0.0.0
-board: IMXRT1050-EVKB
-output_format: c_array
- * BE CAREFUL MODIFYING THIS COMMENT - IT IS YAML SETTINGS FOR TOOLS **********/
-/* COMMENTS BELOW ARE USED AS SETTINGS FOR DCD DATA */
-const uint8_t dcd_data[] = {
+const uint8_t imxrt_dcd_data[] = {
 	/* HEADER */
 	/* Tag */
 	0xD2,
@@ -308,8 +281,3 @@ const uint8_t dcd_data[] = {
 	0xCC, 0x00, 0x0C, 0x04, 0x40, 0x2F, 0x00, 0x4C, 0x50, 0x21, 0x0A, 0x09
 /* BE CAREFUL MODIFYING THIS SETTINGS - IT IS YAML SETTINGS FOR TOOLS */
-#else
-const uint8_t dcd_data[] = {0x00};
-#endif /* XIP_BOOT_HEADER_DCD_ENABLE */
-#endif /* XIP_BOOT_HEADER_ENABLE */
diff --git a/bsps/arm/imxrt/start/flash-ivt.c b/bsps/arm/imxrt/start/flash-ivt.c
index 0000000000..fd396d5e1a
--- /dev/null
+++ b/bsps/arm/imxrt/start/flash-ivt.c
@@ -0,0 +1,39 @@
+ * are met:
+void _start(void);
+const ivt imxrt_image_vector_table = {
+  .hdr = IVT_HEADER,
+  .entry = (uint32_t) _start - 1, /* remove thumb mode flag! */
+  .dcd = (uint32_t) &imxrt_dcd_data,
+  .boot_data = (uint32_t) &imxrt_boot_data,
+  .self = (uint32_t) &imxrt_image_vector_table,
diff --git a/bsps/arm/imxrt/start/imxrt-ffec-init.c b/bsps/arm/imxrt/start/imxrt-ffec-init.c
index 0000000000..4b71944c00
--- /dev/null
+++ b/bsps/arm/imxrt/start/imxrt-ffec-init.c
@@ -0,0 +1,86 @@
+ * are met:
+#include <bsp.h>
+#include <bsp/imx-gpio.h>
+#include <chip.h>
+#include <rtems/counter.h>
+void imxrt_ffec_init(void)
+  volatile IOMUXC_GPR_Type *iomuxc_gpr = IOMUXC_GPR;
+  const void *fdt;
+  int node;
+  const clock_enet_pll_config_t config = {
+    .enableClkOutput = true,
+    .enableClkOutput25M = false,
+    .loopDivider = 1
+  CLOCK_InitEnetPll(&config);
+  iomuxc_gpr->GPR1 |= IOMUXC_GPR_GPR1_ENET1_TX_CLK_DIR_MASK;
+  node = fdt_node_offset_by_compatible(fdt, -1, "fsl,imxrt-fec");
+  if (node >= 0) {
+    struct imx_gpio_pin reset;
+    struct imx_gpio_pin interrupt;
+    sc = imx_gpio_init_from_fdt_property(
+        &reset, node, "phy-reset-gpios",
+        IMX_GPIO_MODE_OUTPUT, 0);
+    if (sc == RTEMS_SUCCESSFUL) {
+          &interrupt, node, "rtems,phy-interrupt-gpios",
+          IMX_GPIO_MODE_INPUT, 0);
+      imx_gpio_set_output(&reset, 0);
+        /* Force interrupt GPIO to high. Otherwise we
+         * get NAND_TREE mode of the PHY. */
+        interrupt.mode = IMX_GPIO_MODE_OUTPUT;
+        imx_gpio_init(&interrupt);
+        imx_gpio_set_output(&interrupt, 1);
+      rtems_counter_delay_nanoseconds(100000);
+      imx_gpio_set_output(&reset, 1);
+      rtems_counter_delay_nanoseconds(5);
+        interrupt.mode = IMX_GPIO_MODE_INPUT;
diff --git a/bsps/arm/imxrt/start/linkcmds.flexspi b/bsps/arm/imxrt/start/linkcmds.flexspi
index 0000000000..4196bb33e5
--- /dev/null
+++ b/bsps/arm/imxrt/start/linkcmds.flexspi
@@ -0,0 +1,35 @@
+INCLUDE linkcmds.memory
+REGION_ALIAS ("REGION_START", FLEXSPI);
+REGION_ALIAS ("REGION_VECTOR", FLEXSPI);
+REGION_ALIAS ("REGION_TEXT", FLEXSPI);
+REGION_ALIAS ("REGION_TEXT_LOAD", FLEXSPI);
+REGION_ALIAS ("REGION_RODATA", FLEXSPI);
+REGION_ALIAS ("REGION_RODATA_LOAD", FLEXSPI);
+REGION_ALIAS ("REGION_DATA", SDRAM);
+REGION_ALIAS ("REGION_DATA_LOAD", FLEXSPI);
+REGION_ALIAS ("REGION_FAST_TEXT", FLEXSPI);
+REGION_ALIAS ("REGION_FAST_TEXT_LOAD", FLEXSPI);
+REGION_ALIAS ("REGION_FAST_DATA", SDRAM);
+REGION_ALIAS ("REGION_FAST_DATA_LOAD", FLEXSPI);
+REGION_ALIAS ("REGION_BSS", SDRAM);
+REGION_ALIAS ("REGION_WORK", SDRAM);
+REGION_ALIAS ("REGION_STACK", SDRAM);
+REGION_ALIAS ("REGION_NOCACHE", SDRAM_NOCACHE);
+REGION_ALIAS ("REGION_NOCACHE_LOAD", FLEXSPI);
+bsp_vector_table_in_start_section = 1;
+SECTIONS {
+  . = imxrt_memory_flexspi_begin;
+  .flash_config : ALIGN_WITH_INPUT {
+    KEEP(*(.boot_hdr.conf))
+  } > FLEXSPI_CONFIG AT > FLEXSPI_CONFIG
+  .flash_ivt : ALIGN_WITH_INPUT {
+    KEEP(*(.boot_hdr.ivt))
+    KEEP(*(.boot_hdr.boot_data))
+    KEEP(*(.boot_hdr.dcd_data))
+  } > FLEXSPI_IVT AT > FLEXSPI_IVT
+INCLUDE linkcmds.armv7m
diff --git a/bsps/arm/imxrt/start/linkcmds.sdram b/bsps/arm/imxrt/start/linkcmds.sdram
index 0000000000..87d1dffa53
--- /dev/null
+++ b/bsps/arm/imxrt/start/linkcmds.sdram
@@ -0,0 +1,23 @@
+REGION_ALIAS ("REGION_START", SDRAM);
+REGION_ALIAS ("REGION_VECTOR", SDRAM);
+REGION_ALIAS ("REGION_TEXT", SDRAM);
+REGION_ALIAS ("REGION_TEXT_LOAD", SDRAM);
+REGION_ALIAS ("REGION_RODATA", SDRAM);
+REGION_ALIAS ("REGION_RODATA_LOAD", SDRAM);
+REGION_ALIAS ("REGION_DATA_LOAD", SDRAM);
+REGION_ALIAS ("REGION_FAST_TEXT", SDRAM);
+REGION_ALIAS ("REGION_FAST_TEXT_LOAD", SDRAM);
+REGION_ALIAS ("REGION_FAST_DATA_LOAD", SDRAM);
+REGION_ALIAS ("REGION_NOCACHE_LOAD", SDRAM);
diff --git a/bsps/arm/imxrt/start/mpu-config.c b/bsps/arm/imxrt/start/mpu-config.c
index 0000000000..97f5b70764
--- /dev/null
+++ b/bsps/arm/imxrt/start/mpu-config.c
@@ -0,0 +1,75 @@
+ * are met:
+BSP_START_DATA_SECTION const ARMV7M_MPU_Region_Config
+  imxrt_start_config_mpu_region [] = {
+      .begin = imxrt_memory_sdram_begin,
+      .end = imxrt_memory_sdram_end,
+      .flags = ARMV7M_MPU_RASR_AP(0x3)
+        | ARMV7M_MPU_RASR_TEX(0x1) | ARMV7M_MPU_RASR_C | ARMV7M_MPU_RASR_B
+        | ARMV7M_MPU_RASR_ENABLE,
+      .begin = imxrt_memory_ocram_begin,
+      .end = imxrt_memory_ocram_end,
+      .begin = imxrt_memory_flexspi_config_begin,
+      .end = imxrt_memory_flexspi_end,
+      .begin = imxrt_memory_sdram_nocache_begin,
+      .end = imxrt_memory_sdram_nocache_end,
+        | ARMV7M_MPU_RASR_TEX(0x2)
+      .begin = imxrt_memory_peripheral_begin,
+      .end = imxrt_memory_peripheral_end,
+      .flags = ARMV7M_MPU_RASR_XN
+        | ARMV7M_MPU_RASR_AP(0x3)
+      .begin = imxrt_memory_null_begin,
+      .end = imxrt_memory_null_end,
+        | ARMV7M_MPU_RASR_AP(0x0)
+BSP_START_DATA_SECTION const size_t imxrt_start_config_mpu_region_count =
+  RTEMS_ARRAY_SIZE(imxrt_start_config_mpu_region);
diff --git a/bsps/arm/shared/pins/imx_iomux.c b/bsps/arm/shared/pins/imx_iomux.c
index d97e35deef..1ff4186360 100644
--- a/bsps/arm/shared/pins/imx_iomux.c
+++ b/bsps/arm/shared/pins/imx_iomux.c
@@ -72,6 +72,7 @@
 #else /* __rtems__ */
 #include <bsp.h>
 #include <libfdt.h>
@@ -163,6 +164,10 @@ imx_iomux_init(void)
 		    "fsl,imx6ul-iomuxc");
+	if (node < 0) {
+		    "nxp,imxrt1050-iomuxc");
 	sc = iomux_sc;
 	sc->regs = imx_get_reg_of_node(fdt, node);
diff --git a/bsps/include/bsp/fatal.h b/bsps/include/bsp/fatal.h
index a66073ae3d..ec5902755e 100644
--- a/bsps/include/bsp/fatal.h
+++ b/bsps/include/bsp/fatal.h
@@ -157,7 +157,22 @@ typedef enum {
   RISCV_FATAL_NO_TLCLOCK_FREQUENCY_IN_DEVICE_TREE,
   /* GRLIB fatal codes */
-  GRLIB_FATAL_CLOCK_NO_IRQMP_TIMESTAMP_SUPPORT = BSP_FATAL_CODE_BLOCK(14)
+  GRLIB_FATAL_CLOCK_NO_IRQMP_TIMESTAMP_SUPPORT = BSP_FATAL_CODE_BLOCK(14),
+  /* i.MXRT fatal codes */
+  IMXRT_FATAL_NO_CONSOLE = BSP_FATAL_CODE_BLOCK(15),
+  IMXRT_FATAL_LPUART_INVALID_FDT,
+  IMXRT_FATAL_LPUART_ALLOC_FAILED,
+  IMXRT_FATAL_LPUART_INSTALL_FAILED,
+  IMXRT_FATAL_LPSPI_INVALID_FDT,
+  IMXRT_FATAL_LPSPI_ALLOC_FAILED,
+  IMXRT_FATAL_LPSPI_HW_INIT_FAILED,
+  IMXRT_FATAL_LPSPI_REGISTER_FAILED,
+  IMXRT_FATAL_LPI2C_INVALID_FDT,
+  IMXRT_FATAL_LPI2C_ALLOC_FAILED,
+  IMXRT_FATAL_LPI2C_HW_INIT_FAILED,
+  IMXRT_FATAL_LPI2C_REGISTER_FAILED,
+  IMXRT_FATAL_LPI2C_UNSUPPORTED_HARDWARE,
 } bsp_fatal_code;
 RTEMS_NO_RETURN static inline void
diff --git a/spec/build/bsps/arm/imxrt/abi.yml b/spec/build/bsps/arm/imxrt/abi.yml
index 0000000000..7a95742c36
--- /dev/null
+++ b/spec/build/bsps/arm/imxrt/abi.yml
@@ -0,0 +1,20 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- get-string: null
+- split: null
+- env-append: null
+build-type: option
+copyrights:
+- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+default:
+- -mthumb
+- -mcpu=cortex-m7
+- -mfpu=fpv5-d16
+- -mfloat-abi=hard
+default-by-variant: []
+description: |
+  ABI flags
+enabled-by: true
+links: []
+name: ABI_FLAGS
+type: build
diff --git a/spec/build/bsps/arm/imxrt/bspimxrt.yml b/spec/build/bsps/arm/imxrt/bspimxrt.yml
index 0000000000..8f71081ebe
--- /dev/null
+++ b/spec/build/bsps/arm/imxrt/bspimxrt.yml
@@ -0,0 +1,250 @@
+arch: arm
+bsp: imxrt1052
+build-type: bsp
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+family: imxrt
+includes:
+  - bsps/arm/shared/include
+install:
+- destination: ${BSP_INCLUDEDIR}
+  source:
+  - bsps/arm/imxrt/include/bsp.h
+  - bsps/arm/imxrt/include/chip.h
+  - bsps/arm/imxrt/include/fsl_adc_etc.h
+  - bsps/arm/imxrt/include/fsl_adc.h
+  - bsps/arm/imxrt/include/fsl_aipstz.h
+  - bsps/arm/imxrt/include/fsl_aoi.h
+  - bsps/arm/imxrt/include/fsl_bee.h
+  - bsps/arm/imxrt/include/fsl_cache.h
+  - bsps/arm/imxrt/include/fsl_clock.h
+  - bsps/arm/imxrt/include/fsl_clock_config.h
+  - bsps/arm/imxrt/include/fsl_cmp.h
+  - bsps/arm/imxrt/include/fsl_common.h
+  - bsps/arm/imxrt/include/fsl_csi.h
+  - bsps/arm/imxrt/include/fsl_dcdc.h
+  - bsps/arm/imxrt/include/fsl_dcp.h
+  - bsps/arm/imxrt/include/fsl_device_registers.h
+  - bsps/arm/imxrt/include/fsl_dmamux.h
+  - bsps/arm/imxrt/include/fsl_edma.h
+  - bsps/arm/imxrt/include/fsl_elcdif.h
+  - bsps/arm/imxrt/include/fsl_enc.h
+  - bsps/arm/imxrt/include/fsl_enet.h
+  - bsps/arm/imxrt/include/fsl_ewm.h
+  - bsps/arm/imxrt/include/fsl_flexcan.h
+  - bsps/arm/imxrt/include/fsl_flexio_camera_edma.h
+  - bsps/arm/imxrt/include/fsl_flexio_camera.h
+  - bsps/arm/imxrt/include/fsl_flexio.h
+  - bsps/arm/imxrt/include/fsl_flexio_i2c_master.h
+  - bsps/arm/imxrt/include/fsl_flexio_i2s_edma.h
+  - bsps/arm/imxrt/include/fsl_flexio_i2s.h
+  - bsps/arm/imxrt/include/fsl_flexio_mculcd_edma.h
+  - bsps/arm/imxrt/include/fsl_flexio_mculcd.h
+  - bsps/arm/imxrt/include/fsl_flexio_spi_edma.h
+  - bsps/arm/imxrt/include/fsl_flexio_spi.h
+  - bsps/arm/imxrt/include/fsl_flexio_uart_edma.h
+  - bsps/arm/imxrt/include/fsl_flexio_uart.h
+  - bsps/arm/imxrt/include/fsl_flexram_allocate.h
+  - bsps/arm/imxrt/include/fsl_flexram.h
+  - bsps/arm/imxrt/include/fsl_flexspi.h
+  - bsps/arm/imxrt/include/fsl_flexspi_nor_boot.h
+  - bsps/arm/imxrt/include/fsl_gpc.h
+  - bsps/arm/imxrt/include/fsl_gpio.h
+  - bsps/arm/imxrt/include/fsl_gpt.h
+  - bsps/arm/imxrt/include/fsl_iomuxc.h
+  - bsps/arm/imxrt/include/fsl_kpp.h
+  - bsps/arm/imxrt/include/fsl_lpi2c_edma.h
+  - bsps/arm/imxrt/include/fsl_lpi2c.h
+  - bsps/arm/imxrt/include/fsl_lpspi_edma.h
+  - bsps/arm/imxrt/include/fsl_lpspi.h
+  - bsps/arm/imxrt/include/fsl_lpuart_edma.h
+  - bsps/arm/imxrt/include/fsl_lpuart.h
+  - bsps/arm/imxrt/include/fsl_ocotp.h
+  - bsps/arm/imxrt/include/fsl_pin_mux.h
+  - bsps/arm/imxrt/include/fsl_pit.h
+  - bsps/arm/imxrt/include/fsl_pmu.h
+  - bsps/arm/imxrt/include/fsl_pwm.h
+  - bsps/arm/imxrt/include/fsl_pxp.h
+  - bsps/arm/imxrt/include/fsl_qtmr.h
+  - bsps/arm/imxrt/include/fsl_rtwdog.h
+  - bsps/arm/imxrt/include/fsl_sai_edma.h
+  - bsps/arm/imxrt/include/fsl_sai.h
+  - bsps/arm/imxrt/include/fsl_semc.h
+  - bsps/arm/imxrt/include/fsl_snvs_hp.h
+  - bsps/arm/imxrt/include/fsl_snvs_lp.h
+  - bsps/arm/imxrt/include/fsl_spdif_edma.h
+  - bsps/arm/imxrt/include/fsl_spdif.h
+  - bsps/arm/imxrt/include/fsl_src.h
+  - bsps/arm/imxrt/include/fsl_tempmon.h
+  - bsps/arm/imxrt/include/fsl_trng.h
+  - bsps/arm/imxrt/include/fsl_tsc.h
+  - bsps/arm/imxrt/include/fsl_usdhc.h
+  - bsps/arm/imxrt/include/fsl_wdog.h
+  - bsps/arm/imxrt/include/fsl_xbara.h
+  - bsps/arm/imxrt/include/fsl_xbarb.h
+  - bsps/arm/imxrt/include/MIMXRT1052_features.h
+  - bsps/arm/imxrt/include/MIMXRT1052.h
+  - bsps/arm/imxrt/include/system_MIMXRT1052.h
+  - bsps/arm/imxrt/include/tm27.h
+- destination: ${BSP_INCLUDEDIR}/arm/freescale/imx
+  source:
+  - bsps/arm/shared/include/arm/freescale/imx/imx_iomuxreg.h
+  - bsps/arm/shared/include/arm/freescale/imx/imx_iomuxvar.h
+- destination: ${BSP_INCLUDEDIR}/bsp
+  source:
+  - bsps/arm/imxrt/include/bsp/flash-headers.h
+  - bsps/arm/imxrt/include/bsp/irq.h
+  - bsps/arm/shared/include/bsp/imx-gpio.h
+  - bsps/arm/shared/include/bsp/imx-iomux.h
+- destination: ${BSP_INCLUDEDIR}/imxrt
+  source:
+  - bsps/arm/imxrt/include/imxrt/imxrt1050-pinfunc.h
+  - bsps/arm/imxrt/include/imxrt/memory.h
+  - bsps/arm/imxrt/include/imxrt/start.h
+- destination: ${BSP_LIBDIR}
+  source:
+  - bsps/arm/imxrt/start/linkcmds.flexspi
+  - bsps/arm/imxrt/start/linkcmds.sdram
+links:
+- role: build-dependency
+  uid: ../grp
+  uid: abi
+  uid: ../../optconsolebaud
+  uid: ../../optconsoleirq
+  uid: optlinkcmds
+  uid: optmemflashcfgsz
+  uid: optmemflashivtsz
+  uid: optmemflexspisz
+  uid: optmemnullsz
+  uid: optmemsdrambase
+  uid: optmemsdramsz
+  uid: optmemsdramnocachesz
+  uid: ../start
+  uid: ../../obj
+  uid: ../../objirq
+  uid: ../../opto2
+  uid: linkcmds
+  uid: linkcmdsmemory
+  uid: ../../bspopts
+source:
+- bsps/arm/imxrt/console/console.c
+- bsps/arm/imxrt/dts/imxrt1050-evkb.c
+- bsps/arm/imxrt/i2c/imxrt-lpi2c.c
+- bsps/arm/imxrt/nxp/boards/evkbimxrt1050/clock_config.c
+- bsps/arm/imxrt/nxp/boards/evkbimxrt1050/pin_mux.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_adc.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_adc_etc.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_aipstz.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_aoi.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_bee.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_cache.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_clock.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_cmp.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_common.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_csi.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_dcdc.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_dcp.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_dmamux.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_edma.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_elcdif.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_enc.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_enet.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_ewm.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_flexcan.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_flexio.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_flexio_camera.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_flexio_camera_edma.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_flexio_i2c_master.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_flexio_i2s.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_flexio_i2s_edma.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_flexio_mculcd.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_flexio_mculcd_edma.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_flexio_spi.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_flexio_spi_edma.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_flexio_uart.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_flexio_uart_edma.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_flexram_allocate.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_flexram.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_flexspi.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_gpc.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_gpio.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_gpt.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_kpp.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_lpi2c.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_lpi2c_edma.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_lpspi.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_lpspi_edma.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_lpuart.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_lpuart_edma.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_ocotp.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_pit.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_pmu.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_pwm.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_pxp.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_qtmr.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_rtwdog.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_sai.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_sai_edma.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_semc.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_snvs_hp.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_snvs_lp.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_spdif.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_spdif_edma.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_src.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_tempmon.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_trng.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_tsc.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_usdhc.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_wdog.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_xbara.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_xbarb.c
+- bsps/arm/imxrt/nxp/devices/MIMXRT1052/xip/fsl_flexspi_nor_boot.c
+- bsps/arm/imxrt/spi/imxrt-lpspi.c
+- bsps/arm/imxrt/start/bspstart.c
+- bsps/arm/imxrt/start/bspstarthooks.c
+- bsps/arm/imxrt/start/flash-boot-data.c
+- bsps/arm/imxrt/start/flash-config.c
+- bsps/arm/imxrt/start/flash-dcd.c
+- bsps/arm/imxrt/start/flash-ivt.c
+- bsps/arm/imxrt/start/imxrt-ffec-init.c
+- bsps/arm/imxrt/start/mpu-config.c
+- bsps/arm/shared/cache/cache-v7m.c
+- bsps/arm/shared/clock/clock-armv7m.c
+- bsps/arm/shared/cpucounter/cpucounter-armv7m.c
+- bsps/arm/shared/irq/irq-armv7m.c
+- bsps/arm/shared/irq/irq-dispatch-armv7m.c
+- bsps/arm/shared/pins/imx-gpio.c
+- bsps/arm/shared/pins/imx_iomux.c
+- bsps/arm/shared/start/bsp-start-memcpy.S
+- bsps/arm/shared/start/bspreset-armv7m.c
+- bsps/shared/dev/btimer/btimer-stub.c
+- bsps/shared/dev/getentropy/getentropy-cpucounter.c
+- bsps/shared/dev/serial/console-termios.c
+- bsps/shared/irq/irq-default-handler.c
+- bsps/shared/start/bspfatal-default.c
+- bsps/shared/start/bspgetworkarea-default.c
+- bsps/shared/start/sbrk.c
+- bsps/shared/start/stackalloc.c
+type: build
diff --git a/spec/build/bsps/arm/imxrt/linkcmds.yml b/spec/build/bsps/arm/imxrt/linkcmds.yml
index 0000000000..3e57b9fd7c
--- /dev/null
+++ b/spec/build/bsps/arm/imxrt/linkcmds.yml
@@ -0,0 +1,11 @@
+build-type: config-file
+content: |
+  INCLUDE ${IMXRT_DEFAULT_LINKCMDS}
+enabled-by: true
+install-path: ${BSP_LIBDIR}
+links: []
+target: linkcmds
+type: build
+copyrights:
diff --git a/spec/build/bsps/arm/imxrt/linkcmdsmemory.yml b/spec/build/bsps/arm/imxrt/linkcmdsmemory.yml
index 0000000000..86dc37c3bd
--- /dev/null
+++ b/spec/build/bsps/arm/imxrt/linkcmdsmemory.yml
@@ -0,0 +1,67 @@
+content: |
+  MEMORY {
+    NULL           : ORIGIN = 0x00000000, LENGTH = ${IMXRT_MEMORY_NULL_SIZE:#010x}
+    ITCM           : ORIGIN = ${IMXRT_MEMORY_NULL_SIZE:#010x}, LENGTH = 512k - ${IMXRT_MEMORY_NULL_SIZE:#010x}
+    DTCM           : ORIGIN = 0x20000000, LENGTH = 512k
+    OCRAM          : ORIGIN = 0x20200000, LENGTH = 512k
+    PERIPHERAL     : ORIGIN = 0x40000000, LENGTH = 0x20000000
+    FLEXSPI_CONFIG : ORIGIN = 0x60000000, LENGTH = ${IMXRT_MEMORY_FLASH_CFG_SIZE:#010x}
+    FLEXSPI_IVT    : ORIGIN = 0x60000000 + ${IMXRT_MEMORY_FLASH_CFG_SIZE:#010x}, LENGTH = ${IMXRT_MEMORY_FLASH_IVT_SIZE:#010x}
+    FLEXSPI        : ORIGIN = 0x60000000 + ${IMXRT_MEMORY_FLASH_CFG_SIZE:#010x} + ${IMXRT_MEMORY_FLASH_IVT_SIZE:#010x}, LENGTH = ${IMXRT_MEMORY_FLEXSPI_FLASH_SIZE:#010x} - ${IMXRT_MEMORY_FLASH_CFG_SIZE:#010x} - ${IMXRT_MEMORY_FLASH_IVT_SIZE:#010x}
+    FLEXSPI_FIFO   : ORIGIN = 0x7F800000, LENGTH = 8M
+    SDRAM          : ORIGIN = ${IMXRT_MEMORY_SDRAM_BASE:#010x}, LENGTH = ${IMXRT_MEMORY_SDRAM_SIZE:#010x} - ${IMXRT_MEMORY_SDRAM_NOCACHE_SIZE:#010x}
+    SDRAM_NOCACHE  : ORIGIN = ${IMXRT_MEMORY_SDRAM_BASE:#010x} + ${IMXRT_MEMORY_SDRAM_SIZE:#010x} - ${IMXRT_MEMORY_SDRAM_NOCACHE_SIZE:#010x}, LENGTH = ${IMXRT_MEMORY_SDRAM_NOCACHE_SIZE:#010x}
+  imxrt_memory_null_begin = ORIGIN (NULL);
+  imxrt_memory_null_end = ORIGIN (NULL) + LENGTH (NULL);
+  imxrt_memory_null_size = LENGTH (NULL);
+  imxrt_memory_itcm_begin = ORIGIN (ITCM);
+  imxrt_memory_itcm_end = ORIGIN (ITCM) + LENGTH (ITCM);
+  imxrt_memory_itcm_size = LENGTH (ITCM);
+  imxrt_memory_dtcm_begin = ORIGIN (DTCM);
+  imxrt_memory_dtcm_end = ORIGIN (DTCM) + LENGTH (DTCM);
+  imxrt_memory_dtcm_size = LENGTH (DTCM);
+  imxrt_memory_ocram_begin = ORIGIN (OCRAM);
+  imxrt_memory_ocram_end = ORIGIN (OCRAM) + LENGTH (OCRAM);
+  imxrt_memory_ocram_size = LENGTH (OCRAM);
+  imxrt_memory_peripheral_begin = ORIGIN (PERIPHERAL);
+  imxrt_memory_peripheral_end = ORIGIN (PERIPHERAL) + LENGTH (PERIPHERAL);
+  imxrt_memory_peripheral_size = LENGTH (PERIPHERAL);
+  imxrt_memory_flexspi_config_begin = ORIGIN (FLEXSPI_CONFIG);
+  imxrt_memory_flexspi_config_end = ORIGIN (FLEXSPI_CONFIG) + LENGTH (FLEXSPI_CONFIG);
+  imxrt_memory_flexspi_config_size = LENGTH (FLEXSPI_CONFIG);
+  imxrt_memory_flexspi_ivt_begin = ORIGIN (FLEXSPI_IVT);
+  imxrt_memory_flexspi_ivt_end = ORIGIN (FLEXSPI_IVT) + LENGTH (FLEXSPI_IVT);
+  imxrt_memory_flexspi_ivt_size = LENGTH (FLEXSPI_IVT);
+  imxrt_memory_flexspi_begin = ORIGIN (FLEXSPI);
+  imxrt_memory_flexspi_end = ORIGIN (FLEXSPI) + LENGTH (FLEXSPI);
+  imxrt_memory_flexspi_size = LENGTH (FLEXSPI);
+  imxrt_memory_flexspi_fifo_begin = ORIGIN (FLEXSPI_FIFO);
+  imxrt_memory_flexspi_fifo_end = ORIGIN (FLEXSPI_FIFO) + LENGTH (FLEXSPI_FIFO);
+  imxrt_memory_flexspi_fifo_size = LENGTH (FLEXSPI_FIFO);
+  imxrt_memory_sdram_begin = ORIGIN (SDRAM);
+  imxrt_memory_sdram_end = ORIGIN (SDRAM) + LENGTH (SDRAM);
+  imxrt_memory_sdram_size = LENGTH (SDRAM);
+  imxrt_memory_sdram_nocache_begin = ORIGIN (SDRAM_NOCACHE);
+  imxrt_memory_sdram_nocache_end = ORIGIN (SDRAM_NOCACHE) + LENGTH (SDRAM_NOCACHE);
+  imxrt_memory_sdram_nocache_size = LENGTH (SDRAM_NOCACHE);
+enabled-by: true
+links: []
+target: linkcmds.memory
+type: build
+copyrights:
diff --git a/spec/build/bsps/arm/imxrt/optlinkcmds.yml b/spec/build/bsps/arm/imxrt/optlinkcmds.yml
index 0000000000..ba20c3838f
--- /dev/null
+++ b/spec/build/bsps/arm/imxrt/optlinkcmds.yml
@@ -0,0 +1,16 @@
+actions:
+- get-string: null
+- env-assign: null
+build-type: option
+default: linkcmds.flexspi
+enabled-by: true
+format: '{}'
+links: []
+name: IMXRT_DEFAULT_LINKCMDS
+description: |
+  The default linker command file.  Must be linkcmds.sdram or linkcmds.flexspi.
+type: build
+copyrights:
diff --git a/spec/build/bsps/arm/imxrt/optmemflashcfgsz.yml b/spec/build/bsps/arm/imxrt/optmemflashcfgsz.yml
index 0000000000..cd65a7a442
--- /dev/null
+++ b/spec/build/bsps/arm/imxrt/optmemflashcfgsz.yml
@@ -0,0 +1,19 @@
+actions:
+- get-integer: null
+- env-assign: null
+build-type: option
+default: 0x1000
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: IMXRT_MEMORY_FLASH_CFG_SIZE
+description: |
+  Size of the flash configuration area at the start of the FlexSPI / SEMC flash
+  in bytes. Either 4 KByte for FlexSPI NOR / SEMC NOR or 1 Kbyte for most other.
+  Take a look at the i.MX RT1050 Processor Reference Manual chapter 9.7 "Program
+  image" for details.
+type: build
+copyrights:
diff --git a/spec/build/bsps/arm/imxrt/optmemflashivtsz.yml b/spec/build/bsps/arm/imxrt/optmemflashivtsz.yml
index 0000000000..d1d9516951
--- /dev/null
+++ b/spec/build/bsps/arm/imxrt/optmemflashivtsz.yml
@@ -0,0 +1,18 @@
+actions:
+- env-assign: null
+build-type: option
+default: 0x1000
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: IMXRT_MEMORY_FLASH_IVT_SIZE
+description: |
+  Size of the image vector table, boot data structure, device configuration data
+  and similar program image header information. Take a look at the i.MX RT1050
+  Processor Reference Manual chapter 9.7 "Program image" for details.
+type: build
+copyrights:
diff --git a/spec/build/bsps/arm/imxrt/optmemflexspisz.yml b/spec/build/bsps/arm/imxrt/optmemflexspisz.yml
index 0000000000..3750c2c683
--- /dev/null
+++ b/spec/build/bsps/arm/imxrt/optmemflexspisz.yml
@@ -0,0 +1,17 @@
+actions:
+- env-assign: null
+- define-unquoted: IMXRT_MEMORY_FLEXSPI_FLASH_SIZE
+build-type: option
+default: 67108864
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: IMXRT_MEMORY_FLEXSPI_FLASH_SIZE
+description: |
+  Size of the FlexSPI Flash area in bytes.
+type: build
+copyrights:
diff --git a/spec/build/bsps/arm/imxrt/optmemnullsz.yml b/spec/build/bsps/arm/imxrt/optmemnullsz.yml
index 0000000000..a298f8192f
--- /dev/null
+++ b/spec/build/bsps/arm/imxrt/optmemnullsz.yml
@@ -0,0 +1,17 @@
+actions:
+- env-assign: null
+build-type: option
+default: 0x400
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: IMXRT_MEMORY_NULL_SIZE
+description: |
+  Size of the NULL pointer protection area in bytes.  This memory area reduces
+  the size of the ITCM available to the application.
+type: build
+copyrights:
diff --git a/spec/build/bsps/arm/imxrt/optmemsdrambase.yml b/spec/build/bsps/arm/imxrt/optmemsdrambase.yml
index 0000000000..567ceab07c
--- /dev/null
+++ b/spec/build/bsps/arm/imxrt/optmemsdrambase.yml
@@ -0,0 +1,16 @@
+actions:
+- env-assign: null
+build-type: option
+default: 0x80000000
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: IMXRT_MEMORY_SDRAM_BASE
+description: |
+  Base address of the SDRAM.
+type: build
+copyrights:
diff --git a/spec/build/bsps/arm/imxrt/optmemsdramnocachesz.yml b/spec/build/bsps/arm/imxrt/optmemsdramnocachesz.yml
index 0000000000..113387d039
--- /dev/null
+++ b/spec/build/bsps/arm/imxrt/optmemsdramnocachesz.yml
@@ -0,0 +1,16 @@
+actions:
+- env-assign: null
+build-type: option
+default: 1048576
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: IMXRT_MEMORY_SDRAM_NOCACHE_SIZE
+description: |
+  Size of the nocache area at the end of the SDRAM in bytes.
+type: build
+copyrights:
diff --git a/spec/build/bsps/arm/imxrt/optmemsdramsz.yml b/spec/build/bsps/arm/imxrt/optmemsdramsz.yml
index 0000000000..315b5271dc
--- /dev/null
+++ b/spec/build/bsps/arm/imxrt/optmemsdramsz.yml
@@ -0,0 +1,16 @@
+actions:
+- env-assign: null
+build-type: option
+default: 33554432
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: IMXRT_MEMORY_SDRAM_SIZE
+description: |
+  Size of the SDRAM in bytes.
+type: build
+copyrights:
2.26.2
