[PATCH rtems v2 0/7] Add imxrt BSP
Wed Nov 18 16:15:02 UTC 2020
v2 looks fine to me
On Wed, Nov 18, 2020 at 7:47 AM Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
> Hello,
> this is a second verson for the imxrt BSP. If no one objects, it will be
> the last for this patch set.
> I don't re-send the documentation and libbsd parts. For libbsd it will
> be the same and for documentation it will be the one with changes like
> discussed.
> The BSD-3-clause license and console commands are now on the list for
> review in separate mails.
> The import patch is still the same. It will most likely hit the size
> limit for the mailing list again.
> Changes in this patch set:
> - I replaced the transient event with a semaphore in the SPI driver.
> - The MPU initialization is reworked. Now a user could adapt it by
>   overwriting the variables in his application.
> - I fixed a bug that I introduced in imx.
> Best regards
> Christian
> devel mailing list
> devel at rtems.org
