[PATCH 2/2] config: Initialize task stack allocator on demand
Sebastian Huber
Thu Nov 19 07:41:39 UTC 2020
Register a custom task stack allocator initialization handler only if
necessary.
cpukit/include/rtems/confdefs/wkspace.h | 19 +++++++++++--------
cpukit/score/src/stackallocatorinit.c | 5 +----
2 files changed, 12 insertions(+), 12 deletions(-)
diff --git a/cpukit/include/rtems/confdefs/wkspace.h b/cpukit/include/rtems/confdefs/wkspace.h
index de555101a1..78d669d790 100644
--- a/cpukit/include/rtems/confdefs/wkspace.h
+++ b/cpukit/include/rtems/confdefs/wkspace.h
@@ -144,10 +144,19 @@ const uintptr_t _Stack_Space_size = _CONFIGURE_STACK_SPACE_SIZE;
#endif
#ifdef CONFIGURE_TASK_STACK_ALLOCATOR_INIT
+ RTEMS_STATIC_ASSERT(
+ CONFIGURE_TASK_STACK_ALLOCATOR_INIT != NULL,
+ CONFIGURE_TASK_STACK_ALLOCATOR_INIT_MUST_NOT_BE_NULL
const Stack_Allocator_initialize _Stack_Allocator_initialize =
CONFIGURE_TASK_STACK_ALLOCATOR_INIT;
- #else
- const Stack_Allocator_initialize _Stack_Allocator_initialize = NULL;
+ RTEMS_SYSINIT_ITEM(
+ _Stack_Allocator_do_initialize,
+ RTEMS_SYSINIT_DIRTY_MEMORY,
+ RTEMS_SYSINIT_ORDER_MIDDLE
#endif
@@ -165,12 +174,6 @@ const uintptr_t _Stack_Space_size = _CONFIGURE_STACK_SPACE_SIZE;
const Stack_Allocator_free _Stack_Allocator_free =
CONFIGURE_TASK_STACK_DEALLOCATOR;
- RTEMS_SYSINIT_ITEM(
- _Stack_Allocator_do_initialize,
- RTEMS_SYSINIT_DIRTY_MEMORY,
- RTEMS_SYSINIT_ORDER_MIDDLE
#elif defined(CONFIGURE_TASK_STACK_ALLOCATOR) \
|| defined(CONFIGURE_TASK_STACK_DEALLOCATOR)
#error "CONFIGURE_TASK_STACK_ALLOCATOR and CONFIGURE_TASK_STACK_DEALLOCATOR must be both defined or both undefined"
diff --git a/cpukit/score/src/stackallocatorinit.c b/cpukit/score/src/stackallocatorinit.c
index 412e3142b3..31e239bd46 100644
--- a/cpukit/score/src/stackallocatorinit.c
+++ b/cpukit/score/src/stackallocatorinit.c
@@ -45,8 +45,5 @@ void _Stack_Allocator_do_initialize( void )
rtems_stack_allocate_init_hook init_hook;
init_hook = rtems_configuration_get_stack_allocate_init_hook();
- if ( init_hook != NULL ) {
- (*init_hook )( rtems_configuration_get_stack_space_size() );
+ ( *init_hook )( rtems_configuration_get_stack_space_size() );
2.26.2
