[PATCH] c-user: Update internal error list
Sebastian Huber
Thu Nov 19 07:55:34 UTC 2020
c-user/fatal_error.rst | 37 ++++++++-----------------------------
1 file changed, 8 insertions(+), 29 deletions(-)
diff --git a/c-user/fatal_error.rst b/c-user/fatal_error.rst
index 2c72deb..81cfa0c 100644
--- a/c-user/fatal_error.rst
+++ b/c-user/fatal_error.rst
@@ -146,15 +146,6 @@ INTERNAL_ERROR_TOO_LITTLE_WORKSPACE (2)
There is not enough memory for the workspace. This fatal error may occur
during system initialization. It is an application configuration error.
-INTERNAL_ERROR_WORKSPACE_ALLOCATION (3)
- An allocation from the workspace failed. This fatal error may occur during
- system initialization. It is an application configuration error.
-INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL (4)
- The configured interrupt stack size is too small. This fatal error may
- occur during system initialization. It is an application configuration
- error.
INTERNAL_ERROR_THREAD_EXITTED (5)
A non-POSIX thread entry function returned. This is an API usage error.
@@ -222,17 +213,6 @@ INTERNAL_ERROR_INVALID_GLOBAL_ID (13)
find the global object for a specific object identifier. In case this
happens, then this is probably an operating system bug.
-INTERNAL_ERROR_BAD_STACK_HOOK (14)
- The stack allocator hook or stack free hook is NULL. This fatal error may
- error.
-INTERNAL_ERROR_UNLIMITED_AND_MAXIMUM_IS_0 (19)
- An object class is configured to use the unlimited objects option, however,
- the count of objects for each extension is zero. This fatal error may
- error.
INTERNAL_ERROR_NO_MEMORY_FOR_HEAP (23)
There is not enough memory for the C program heap. This fatal error may
@@ -372,15 +352,6 @@ INTERNAL_ERROR_POSIX_INIT_THREAD_CREATE_FAILED (33)
error.
-INTERNAL_ERROR_LIBIO_USER_ENV_KEY_CREATE_FAILED (34)
- Creation of the IO library user environment POSIX key failed. This fatal
- error may occur during system initialization. It is an application
- configuration error.
-INTERNAL_ERROR_LIBIO_SEM_CREATE_FAILED (35)
- Creation of the IO library semaphore failed. This fatal error may occur
- during system initialization. It is an application configuration error.
INTERNAL_ERROR_LIBIO_STDOUT_FD_OPEN_FAILED (36)
Open of the standard output file descriptor failed or resulted in an
unexpected file descriptor number. This fatal error may occur during
@@ -405,6 +376,14 @@ INTERNAL_ERROR_NO_MEMORY_FOR_PER_CPU_DATA (40)
enough memory available to populate the per-CPU data areas, see
`<rtems/score/percpudata.h> <https://git.rtems.org/rtems/tree/cpukit/include/rtems/score/percpudata.h>`_.
+INTERNAL_ERROR_TOO_LARGE_TLS_SIZE (41)
+ This fatal error may happen during system initialization. The actual
+ thread-local storage (TLS) size of the application exceeds the configured
+ maximum, see
+ :ref:`CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE <CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE>`.
+ You can get the thread-local storage size of an application using the RTEMS
+ tool ``rtems-execinfo``.
Operations
2.26.2
