[PATCH] c-user: Update internal error list
Gedare Bloom
gedare at rtems.org
Thu Nov 19 18:16:12 UTC 2020
ok.
On Thu, Nov 19, 2020 at 12:55 AM Sebastian Huber
> c-user/fatal_error.rst | 37 ++++++++-----------------------------
> 1 file changed, 8 insertions(+), 29 deletions(-)
> diff --git a/c-user/fatal_error.rst b/c-user/fatal_error.rst
> index 2c72deb..81cfa0c 100644
> --- a/c-user/fatal_error.rst
> +++ b/c-user/fatal_error.rst
> @@ -146,15 +146,6 @@ INTERNAL_ERROR_TOO_LITTLE_WORKSPACE (2)
> There is not enough memory for the workspace. This fatal error may occur
> during system initialization. It is an application configuration error.
> -INTERNAL_ERROR_WORKSPACE_ALLOCATION (3)
> - An allocation from the workspace failed. This fatal error may occur during
> - system initialization. It is an application configuration error.
> -INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL (4)
> - The configured interrupt stack size is too small. This fatal error may
> - occur during system initialization. It is an application configuration
> - error.
> INTERNAL_ERROR_THREAD_EXITTED (5)
> A non-POSIX thread entry function returned. This is an API usage error.
> @@ -222,17 +213,6 @@ INTERNAL_ERROR_INVALID_GLOBAL_ID (13)
> find the global object for a specific object identifier. In case this
> happens, then this is probably an operating system bug.
> -INTERNAL_ERROR_BAD_STACK_HOOK (14)
> - The stack allocator hook or stack free hook is NULL. This fatal error may
> - error.
> -INTERNAL_ERROR_UNLIMITED_AND_MAXIMUM_IS_0 (19)
> - An object class is configured to use the unlimited objects option, however,
> - the count of objects for each extension is zero. This fatal error may
> - error.
> INTERNAL_ERROR_NO_MEMORY_FOR_HEAP (23)
> There is not enough memory for the C program heap. This fatal error may
> @@ -372,15 +352,6 @@ INTERNAL_ERROR_POSIX_INIT_THREAD_CREATE_FAILED (33)
> error.
> -INTERNAL_ERROR_LIBIO_USER_ENV_KEY_CREATE_FAILED (34)
> - Creation of the IO library user environment POSIX key failed. This fatal
> - error may occur during system initialization. It is an application
> - configuration error.
> -INTERNAL_ERROR_LIBIO_SEM_CREATE_FAILED (35)
> - Creation of the IO library semaphore failed. This fatal error may occur
> - during system initialization. It is an application configuration error.
> INTERNAL_ERROR_LIBIO_STDOUT_FD_OPEN_FAILED (36)
> Open of the standard output file descriptor failed or resulted in an
> unexpected file descriptor number. This fatal error may occur during
> @@ -405,6 +376,14 @@ INTERNAL_ERROR_NO_MEMORY_FOR_PER_CPU_DATA (40)
> enough memory available to populate the per-CPU data areas, see
> `<rtems/score/percpudata.h> <https://git.rtems.org/rtems/tree/cpukit/include/rtems/score/percpudata.h>`_.
> +INTERNAL_ERROR_TOO_LARGE_TLS_SIZE (41)
> + This fatal error may happen during system initialization. The actual
> + thread-local storage (TLS) size of the application exceeds the configured
> + maximum, see
> + :ref:`CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE <CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE>`.
> + You can get the thread-local storage size of an application using the RTEMS
> + tool ``rtems-execinfo``.
> Operations
> 2.26.2
> devel mailing list
> devel at rtems.org
