[PATCH rtems v3 0/7] Add imxrt BSP
Christian Mauderer christian.mauderer at embedded-brains.de
Fri Nov 20 08:09:45 UTC 2020
Thanks for the reviews. I pushed the patches with changes like discussed.
Best regards
Christian
Am 19.11.20 um 09:51 schrieb Christian Mauderer:
> Hello,
> again an updated version. There haven't been relevant changes beneath
> patch 3 (some follow up ones in 7) so I'm only sending patch 3.
> Changes:
> - renames like suggested by Sebastian
> - the MPU is now disabled, set up and re-enabled
> - every MPU region is only set up once due to that
> - I moved the constants for STM32H7 into a separate file to enable the
>    main advantage of that initialization: Allowing the user to provide
>    a different configuration in his application.
> Best regards
> Christian
embedded brains GmbH
Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
Registernummer: HRB 157899
