[PATCH rtems v3 3/7] cpu/armv7m: Add table based init for ARMV7M_MPU
Sebastian Huber
Fri Nov 20 06:57:10 UTC 2020
On 19/11/2020 23:19, Gedare Bloom wrote:
>> But there is for example
>> _ARMV7M_NVIC_Is_enabled
>> _ARMV7M_NVIC_Set_enable
>> _ARMV7M_DWT_Enable_CYCCNT
>> ARMV7M_MPU_Access_permissions
>> and some others in the same file. So I would lean towards what Sebastian
>> suggested. Otherwise the new functions wouldn't fit the scheme of the
>> existing ones.
> OK, I don't think those are proper, but consistency is good. You can
> proceed with the MPU_Xxx
The idea was to have support for several hardware modules in this file.
So, from the naming convention point of view _ARMV7M_NVIC and
_ARMV7M_DWT are the modules and not simply _ARMV7M.
embedded brains GmbH
Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 16
Fax: +49-89-18 94 741 - 08
PGP: Public key available on request.
Registernummer: HRB 157899
Unsere Datenschutzerklärung finden Sie hier: https://embedded-brains.de/datenschutzerklaerung/
