[PATCH 14/20] rtems: Move _Partition_Initialize()
Sebastian Huber
Fri Nov 20 11:15:20 UTC 2020
It is only used by rtems_partition_create(). Fix integer types.
cpukit/include/rtems/rtems/partimpl.h | 25 -------------------------
cpukit/rtems/src/partcreate.c | 25 +++++++++++++++++++++++++
2 files changed, 25 insertions(+), 25 deletions(-)
diff --git a/cpukit/include/rtems/rtems/partimpl.h b/cpukit/include/rtems/rtems/partimpl.h
index dcffe757c7..ab0bdc76f7 100644
--- a/cpukit/include/rtems/rtems/partimpl.h
+++ b/cpukit/include/rtems/rtems/partimpl.h
@@ -19,7 +19,6 @@
#define _RTEMS_RTEMS_PARTIMPL_H
#include <rtems/rtems/partdata.h>
-#include <rtems/score/chainimpl.h>
#ifdef __cplusplus
@@ -46,30 +45,6 @@ RTEMS_INLINE_ROUTINE Partition_Control *_Partition_Allocate ( void )
return (Partition_Control *) _Objects_Allocate( &_Partition_Information );
-RTEMS_INLINE_ROUTINE void _Partition_Initialize(
- Partition_Control *the_partition,
- void *starting_address,
- uint32_t length,
- uint32_t buffer_size,
- rtems_attribute attribute_set
- the_partition->starting_address = starting_address;
- the_partition->length = length;
- the_partition->buffer_size = buffer_size;
- the_partition->attribute_set = attribute_set;
- the_partition->number_of_used_blocks = 0;
- _Chain_Initialize(
- &the_partition->Memory,
- starting_address,
- length / buffer_size,
- buffer_size
- _ISR_lock_Initialize( &the_partition->Lock, "Partition" );
* @brief Calls _Objects_Get() using the ::_Partition_Information.
diff --git a/cpukit/rtems/src/partcreate.c b/cpukit/rtems/src/partcreate.c
index da791e2360..a6824d5224 100644
--- a/cpukit/rtems/src/partcreate.c
+++ b/cpukit/rtems/src/partcreate.c
@@ -23,6 +23,7 @@
#include <rtems/rtems/partimpl.h>
+#include <rtems/score/chainimpl.h>
#include <rtems/score/sysstate.h>
#include <rtems/sysinit.h>
@@ -36,6 +37,30 @@ static bool _Partition_Is_buffer_area_aligned( const void *starting_address )
return ( ( (uintptr_t) starting_address ) % CPU_SIZEOF_POINTER ) == 0;
+static void _Partition_Initialize(
+ Partition_Control *the_partition,
+ void *starting_address,
+ uintptr_t length,
+ size_t buffer_size,
+ rtems_attribute attribute_set
+ the_partition->starting_address = starting_address;
+ the_partition->length = length;
+ the_partition->buffer_size = buffer_size;
+ the_partition->attribute_set = attribute_set;
+ the_partition->number_of_used_blocks = 0;
+ _Chain_Initialize(
+ &the_partition->Memory,
+ starting_address,
+ length / buffer_size,
+ buffer_size
+ _ISR_lock_Initialize( &the_partition->Lock, "Partition" );
rtems_status_code rtems_partition_create(
rtems_name name,
2.26.2
