[PATCH 13/20] rtems: Move _Partition_Is_buffer_area_aligned()
Fri Nov 20 16:32:46 UTC 2020
On 20/11/2020 17:24, Sebastian Huber wrote:
> On 20/11/2020 17:18, Gedare Bloom wrote:
>> On Fri, Nov 20, 2020 at 6:34 AM Sebastian Huber
>> <sebastian.huber at embedded-brains.de> wrote:
>>> On 20/11/2020 14:31, Joel Sherrill wrote:
>>>> Wasn't there Doxygen above it?
>>> No.
>>>> Needs comments
>>> I think a one liner function with a very descriptive name needs no
>>> comments if it is placed in a source file:
>>> static bool _Partition_Is_buffer_area_aligned( const void
>>> *starting_address )
>>>     return ( ( (uintptr_t) starting_address ) % CPU_SIZEOF_POINTER )
>>> == 0;
>> I disagree, this is worth one line to remind that buffers need to be
>> aligned to a multiple of the pointer size (and are a multiple of the
>> pointer size).
>> Just because we can put the code in one line doesn't mean that its
>> context is clear.
> This function is no longer in a header file. It is in a source file
> right next to the code which calls this function. The function name
> _Partition_Is_buffer_area_aligned() tells you that the function checks
> if the buffer area is aligned. The code
> ( ( (uintptr_t) starting_address ) % CPU_SIZEOF_POINTER ) == 0;
> tells you exactly that the address is aligned if and only if it is an
> integral multiple of the pointer size. Which information is missing
> which justifies a comment?
This function is only used in one place. So, instead of adding a comment
to this function, it makes more sense to remove the function and add a
comment to the calling site.
embedded brains GmbH
Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 16
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
Registernummer: HRB 157899
Unsere Datenschutzerklärung finden Sie hier: https://embedded-brains.de/datenschutzerklaerung/
