[PATCH 12/20] rtems: Move _Partition_Is_buffer_size_aligned()
Fri Nov 20 11:15:18 UTC 2020
It is only used by rtems_partition_create().  Fix integer type.
 cpukit/include/rtems/rtems/partimpl.h | 7 -------
 cpukit/rtems/src/partcreate.c         | 5 +++++
 2 files changed, 5 insertions(+), 7 deletions(-)
diff --git a/cpukit/include/rtems/rtems/partimpl.h b/cpukit/include/rtems/rtems/partimpl.h
index 0d15d1e991..b9d57ae3c3 100644
--- a/cpukit/include/rtems/rtems/partimpl.h
+++ b/cpukit/include/rtems/rtems/partimpl.h
@@ -34,13 +34,6 @@ extern "C" {
-RTEMS_INLINE_ROUTINE bool _Partition_Is_buffer_size_aligned(
-  uint32_t buffer_size
-  return (buffer_size % CPU_SIZEOF_POINTER) == 0;
 RTEMS_INLINE_ROUTINE bool _Partition_Is_buffer_area_aligned(
   const void *starting_address
diff --git a/cpukit/rtems/src/partcreate.c b/cpukit/rtems/src/partcreate.c
index 9d4c7df283..6673ce2c59 100644
--- a/cpukit/rtems/src/partcreate.c
+++ b/cpukit/rtems/src/partcreate.c
@@ -26,6 +26,11 @@
 #include <rtems/score/sysstate.h>
 #include <rtems/sysinit.h>
+static bool _Partition_Is_buffer_size_aligned( size_t buffer_size )
+  return ( buffer_size % CPU_SIZEOF_POINTER ) == 0;
 rtems_status_code rtems_partition_create(
   rtems_name       name,
   void            *starting_address,
2.26.2
