[PATCH 12/20] rtems: Move _Partition_Is_buffer_size_aligned()
Gedare Bloom
gedare at rtems.org
Fri Nov 20 16:15:20 UTC 2020
On Fri, Nov 20, 2020 at 4:16 AM Sebastian Huber
> It is only used by rtems_partition_create(). Fix integer type.
> cpukit/include/rtems/rtems/partimpl.h | 7 -------
> cpukit/rtems/src/partcreate.c | 5 +++++
> 2 files changed, 5 insertions(+), 7 deletions(-)
> diff --git a/cpukit/include/rtems/rtems/partimpl.h b/cpukit/include/rtems/rtems/partimpl.h
> index 0d15d1e991..b9d57ae3c3 100644
> --- a/cpukit/include/rtems/rtems/partimpl.h
> +++ b/cpukit/include/rtems/rtems/partimpl.h
> @@ -34,13 +34,6 @@ extern "C" {
> -RTEMS_INLINE_ROUTINE bool _Partition_Is_buffer_size_aligned(
> - uint32_t buffer_size
> - return (buffer_size % CPU_SIZEOF_POINTER) == 0;
> RTEMS_INLINE_ROUTINE bool _Partition_Is_buffer_area_aligned(
> const void *starting_address
> diff --git a/cpukit/rtems/src/partcreate.c b/cpukit/rtems/src/partcreate.c
> index 9d4c7df283..6673ce2c59 100644
> --- a/cpukit/rtems/src/partcreate.c
> +++ b/cpukit/rtems/src/partcreate.c
> @@ -26,6 +26,11 @@
> #include <rtems/score/sysstate.h>
> #include <rtems/sysinit.h>
> +static bool _Partition_Is_buffer_size_aligned( size_t buffer_size )
Nit: I never saw this before, but this isn't what "aligned" means.
Aligned means you start something at a specific multiple. This is
checking if the buffer_size is a multiple of the pointer size. Anyway,
it is just used here so it's fine, but maybe just a one-line comment
that buffer sizes are required to be a multiple of the pointer size.
> + return ( buffer_size % CPU_SIZEOF_POINTER ) == 0;
> rtems_status_code rtems_partition_create(
> rtems_name name,
> void *starting_address,
> 2.26.2
> devel mailing list
> devel at rtems.org
