[PATCH 13/20] rtems: Move _Partition_Is_buffer_area_aligned()
Sebastian Huber
Fri Nov 20 16:24:20 UTC 2020
On 20/11/2020 17:18, Gedare Bloom wrote:
> On Fri, Nov 20, 2020 at 6:34 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> On 20/11/2020 14:31, Joel Sherrill wrote:
>>> Wasn't there Doxygen above it?
>> No.
>>> Needs comments
>> I think a one liner function with a very descriptive name needs no
>> comments if it is placed in a source file:
>> static bool _Partition_Is_buffer_area_aligned( const void
>> *starting_address )
>> return ( ( (uintptr_t) starting_address ) % CPU_SIZEOF_POINTER ) == 0;
> I disagree, this is worth one line to remind that buffers need to be
> aligned to a multiple of the pointer size (and are a multiple of the
> pointer size).
> Just because we can put the code in one line doesn't mean that its
> context is clear.
This function is no longer in a header file. It is in a source file
right next to the code which calls this function. The function name
_Partition_Is_buffer_area_aligned() tells you that the function checks
if the buffer area is aligned. The code
tells you exactly that the address is aligned if and only if it is an integral multiple of the pointer size. Which information is missing which justifies a comment?
embedded brains GmbH
Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 16
Fax: +49-89-18 94 741 - 08
PGP: Public key available on request.
Registernummer: HRB 157899
Unsere Datenschutzerklärung finden Sie hier: https://embedded-brains.de/datenschutzerklaerung/
