[PATCH] rtems: Delete rtems_object_id_api_maximum_class()
Fri Nov 20 17:56:02 UTC 2020
It should be implemented. File a ticket if you don't want to do it now.
But don't delete it. It should be there for completeness. I would have
thought there was code that iterated over all the APIs and classes and used
it. What is being used instead?
On Fri, Nov 20, 2020 at 11:47 AM Sebastian Huber <
> This function has no implementation.  It is documented in the RTEMS
> Classic API Guide.
>  cpukit/include/rtems/rtems/object.h | 17 -----------------
>  1 file changed, 17 deletions(-)
> diff --git a/cpukit/include/rtems/rtems/object.h
> b/cpukit/include/rtems/rtems/object.h
> index 8e8bfbf293..77c13f473f 100644
> --- a/cpukit/include/rtems/rtems/object.h
> +++ b/cpukit/include/rtems/rtems/object.h
> @@ -285,23 +285,6 @@ int rtems_object_api_maximum_class(
>    int api
> - * @brief Get Highest Valid Class Value
> - * This method returns the lowest valid value Class for the
> - * specified @a api. Each API supports a different number
> - * of object classes.
> - * @param[in] api is the API to obtain the maximum class of
> - * @retval This method returns the least valid value for
> - *         class number for the specified @a api.
> -int rtems_object_id_api_maximum_class(
> -  int api
>   * @brief Get API Name
> 2.26.2
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201120/80cdbdc2/attachment.html>
