[PATCH] rtems: Delete rtems_object_id_api_maximum_class()
Sebastian Huber
Fri Nov 20 18:45:33 UTC 2020
On 20/11/2020 18:56, Joel Sherrill wrote:
> It should be implemented. File a ticket if you don't want to do it now.
> But don't delete it. It should be there for completeness. I would have
> thought there was code that iterated over all the APIs and classes and
> used it. What is being used instead?
This function was added by
commit 6c06288f6452da96fa630f1482aeaaba5d217531
Author: Joel Sherrill <joel.sherrill at OARcorp.com>
Date: Tue Jan 29 21:52:21 2008 +0000
2008-01-29 Joel Sherrill <joel.sherrill at oarcorp.com>
* itron/src/exd_tsk.c, itron/src/task.c,
libmisc/capture/capture.c,
libmisc/monitor/mon-config.c, libmisc/monitor/mon-driver.c,
libmisc/monitor/mon-itask.c, libmisc/monitor/mon-monitor.c,
libmisc/monitor/mon-mpci.c, libmisc/monitor/mon-object.c,
libmisc/monitor/mon-symbols.c, posix/src/cancelrun.c,
posix/src/pthreadexit.c, rtems/Makefile.am,
rtems/preinstall.am,
rtems/include/rtems.h, rtems/include/rtems/rtems/support.h,
rtems/inline/rtems/rtems/tasks.inl, rtems/src/eventmp.c,
rtems/src/msgmp.c, rtems/src/partmp.c, rtems/src/regionmp.c,
rtems/src/rtemsobjectgetname.c, rtems/src/semmp.c,
rtems/src/signalmp.c, rtems/src/taskdelete.c,
rtems/src/taskmp.c,
rtems/src/timerserver.c, score/Makefile.am,
score/include/rtems/score/object.h,
score/inline/rtems/score/object.inl, score/src/Unlimited.txt,
score/src/objectgetnameasstring.c,
score/src/threadqextractwithproxy.c: Add new Object Services
collection. This changed the name of a few previously
public but
undocumented services and added a some new services.
* rtems/include/rtems/rtems/object.h, rtems/src/rtemsbuildid.c,
rtems/src/rtemsbuildname.c,
rtems/src/rtemsobjectapimaximumclass.c,
rtems/src/rtemsobjectapiminimumclass.c,
rtems/src/rtemsobjectgetapiclassname.c,
rtems/src/rtemsobjectgetapiname.c,
rtems/src/rtemsobjectgetclassicname.c,
rtems/src/rtemsobjectgetclassinfo.c,
rtems/src/rtemsobjectidapimaximum.c,
rtems/src/rtemsobjectidapiminimum.c,
rtems/src/rtemsobjectidgetapi.c,
rtems/src/rtemsobjectidgetclass.c,
rtems/src/rtemsobjectidgetindex.c,
rtems/src/rtemsobjectidgetnode.c,
rtems/src/rtemsobjectsetname.c,
score/src/objectapimaximumclass.c, score/src/objectgetinfo.c,
score/src/objectgetinfoid.c, score/src/objectsetname.c: New
files.
* rtems/src/rtemsidtoname.c: Removed.
Nobody noticed that this function is missing in the last twelve years.
What is the differences to:
* @brief Get Highest Valid Class Value
* This method returns the highest valid value Class for the
* specified @a api. Each API supports a different number
* of object classes.
* @param[in] api is the API to obtain the maximum class of
* @retval This method returns the greatet valid value for
* class number for the specified @a api.
int rtems_object_api_maximum_class(
int api
To me the removed function looks like some fragment left over from
development.
> On Fri, Nov 20, 2020 at 11:47 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> This function has no implementation. It is documented in the RTEMS
> Classic API Guide.
> cpukit/include/rtems/rtems/object.h | 17 -----------------
> 1 file changed, 17 deletions(-)
> diff --git a/cpukit/include/rtems/rtems/object.h
> b/cpukit/include/rtems/rtems/object.h
> index 8e8bfbf293..77c13f473f 100644
> --- a/cpukit/include/rtems/rtems/object.h
> +++ b/cpukit/include/rtems/rtems/object.h
> @@ -285,23 +285,6 @@ int rtems_object_api_maximum_class(
> int api
> - * @brief Get Highest Valid Class Value
> - * This method returns the lowest valid value Class for the
> - * specified @a api. Each API supports a different number
> - * of object classes.
> - * @param[in] api is the API to obtain the maximum class of
> - * @retval This method returns the least valid value for
> - * class number for the specified @a api.
> -int rtems_object_id_api_maximum_class(
> - int api
> * @brief Get API Name
> 2.26.2
> devel mailing list
> devel at rtems.org <mailto:devel at rtems.org>
> <http://lists.rtems.org/mailman/listinfo/devel>
embedded brains GmbH
Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 16
Fax: +49-89-18 94 741 - 08
PGP: Public key available on request.
Registernummer: HRB 157899
Unsere Datenschutzerklärung finden Sie hier: https://embedded-brains.de/datenschutzerklaerung/
