[PATCH] libtest: Fix undefined setjmp() behaviour
Mon Nov 23 09:18:33 UTC 2020
Bug was introduced by 78baeb757957fa0807c30e6c4d21ae99c9639e6a.
Update #3199.
 cpukit/include/rtems/test.h |   3 +-
 cpukit/libtest/t-test.c     | 110 +++++++++++++++++++-----------------
 2 files changed, 60 insertions(+), 53 deletions(-)
diff --git a/cpukit/include/rtems/test.h b/cpukit/include/rtems/test.h
index 573f7b93c9..f96a5a6892 100644
--- a/cpukit/include/rtems/test.h
+++ b/cpukit/include/rtems/test.h
@@ -2270,6 +2270,7 @@ typedef enum {
 	T_EVENT_CASE_BEGIN,
 	T_EVENT_CASE_END,
 	T_EVENT_CASE_LATE,
+	T_EVENT_CASE_STOP,
 	T_EVENT_RUN_FINALIZE_EARLY,
 	T_EVENT_RUN_FINALIZE_LATE
 } T_event;
@@ -2306,7 +2307,7 @@ void T_run_all(void);
 void T_run_by_name(const char *);
-bool T_case_begin(const char *, const T_fixture *);
+void T_case_begin(const char *, const T_fixture *);
 void T_case_end(void);
diff --git a/cpukit/libtest/t-test.c b/cpukit/libtest/t-test.c
index ca91d1592f..26521728f4 100644
--- a/cpukit/libtest/t-test.c
+++ b/cpukit/libtest/t-test.c
@@ -67,6 +67,7 @@ typedef struct {
 	atomic_uint planned_steps;
 	atomic_uint steps;
 	atomic_uint failures;
+	bool case_begin_context_valid;
 	jmp_buf case_begin_context;
 	unsigned int fixture_steps;
 	unsigned int overall_cases;
@@ -507,6 +508,37 @@ T_add_failure(T_context *ctx)
 	    memory_order_relaxed);
+static void
+T_actions_forward(const T_config *config, T_event event, const char *name)
+	const T_action *actions;
+	size_t n;
+	size_t i;
+	actions = config->actions;
+	n = config->action_count;
+	for (i = 0; i < n; ++i) {
+		(*actions[i])(event, name);
+static void
+T_actions_backward(const T_config *config, T_event event,
+    const char *name)
+	size_t n;
+	size_t i;
+		(*actions[n - i - 1])(event, name);
 T_NO_RETURN static void
 T_do_stop(T_context *ctx)
@@ -516,17 +548,26 @@ T_do_stop(T_context *ctx)
 	while (node != NULL) {
 		const T_fixture *fixture;
+		void *node_context;
 		fixture = node->fixture;
+		node_context = node->context;
+		node = node->next;
 		if (fixture != NULL && fixture->stop != NULL) {
-			(*fixture->stop)(node->context);
+			(*fixture->stop)(node_context);
-		node = node->next;
-	longjmp(ctx->case_begin_context, 1);
+	if (T_do_is_runner(ctx) && ctx->case_begin_context_valid) {
+		longjmp(ctx->case_begin_context, 1);
+	} else {
+		T_actions_backward(ctx->config, T_EVENT_CASE_STOP,
+		    T_case_name());
+#ifdef __GNUC__
+		__builtin_unreachable();
+#endif
 T_NO_RETURN void
@@ -878,37 +919,6 @@ T_call_destructors(const T_context *ctx)
 #endif
-static void
-T_actions_forward(const T_config *config, T_event event, const char *name)
-	const T_action *actions;
-	size_t n;
-	size_t i;
-	actions = config->actions;
-	n = config->action_count;
-	for (i = 0; i < n; ++i) {
-		(*actions[i])(event, name);
-static void
-T_actions_backward(const T_config *config, T_event event,
-    const char *name)
-	size_t n;
-	size_t i;
-		(*actions[n - i - 1])(event, name);
 static T_context *
 T_do_run_initialize(const T_config *config)
@@ -948,7 +958,7 @@ T_do_run_initialize(const T_config *config)
 	return ctx;
-static bool
+static void
 T_do_case_begin(T_context *ctx, const T_case_context *tc)
 	const T_config *config;
@@ -969,23 +979,16 @@ T_do_case_begin(T_context *ctx, const T_case_context *tc)
 	T_actions_forward(config, T_EVENT_CASE_EARLY, tc->name);
 	T_do_log(ctx, T_NORMAL, "B:%s\n", tc->name);
 	ctx->case_begin_time = (*config->now)();
+	T_actions_forward(config, T_EVENT_CASE_BEGIN, tc->name);
-	if (setjmp(ctx->case_begin_context) == 0) {
-		T_actions_forward(config, T_EVENT_CASE_BEGIN, tc->name);
-		if (fixture != NULL) {
-			ctx->case_fixture.fixture = fixture;
-			ctx->case_fixture.context = fixture->initial_context;
+	if (fixture != NULL) {
+		ctx->case_fixture.fixture = fixture;
+		ctx->case_fixture.context = fixture->initial_context;
-			if (fixture->setup != NULL) {
-				(*fixture->setup)(ctx->case_fixture.context);
+		if (fixture->setup != NULL) {
+			(*fixture->setup)(ctx->case_fixture.context);
-		return true;
-	return false;
 static void
@@ -1041,10 +1044,13 @@ T_do_case_end(T_context *ctx, const T_case_context *tc)
 static void
 T_run_case(T_context *ctx, const T_case_context *tc)
-	if (T_do_case_begin(ctx, tc)) {
+	if (setjmp(ctx->case_begin_context) == 0) {
+		ctx->case_begin_context_valid = true;
+		T_do_case_begin(ctx, tc);
 		(*tc->body)();
+	ctx->case_begin_context_valid = false;
 	T_do_case_end(ctx, tc);
@@ -1145,7 +1151,7 @@ T_run_by_name(const char *name)
 static T_case_context default_case;
-bool
+void
 T_case_begin(const char *name, const T_fixture *fixture)
 	T_case_context *tc;
@@ -1153,7 +1159,7 @@ T_case_begin(const char *name, const T_fixture *fixture)
 	tc = &default_case;
 	tc->name = name;
 	tc->fixture = fixture;
-	return T_do_case_begin(&T_instance, tc);
+	T_do_case_begin(&T_instance, tc);
 void
2.26.2
