RSB error in MSYS2 MinGW
jameszxj
jameszxj at gmail.com
Sat Nov 21 07:10:06 UTC 2020
Hi,
I built arm compiler with "../source-builder/sb-set-builder --dry-run --with-download 6/rtems-arm", and got the errors:
config: tools/rtems-gdb-head.cfg
error: shell macro failed: sh -c "/mingw64/bin/python2-config --ldflags | awk 'BEGIN{FS=\" \"}/python/{for(i=1;i<NF;++i)if(match($i,\".*lpython.*\")) print \"lib\"substr($i,3)\"*\";}'": 1: awk: cmd. line:1: BEGIN{FS=" "}/python/{for(i=1;i<NF;++i)if(match(,".*lpython.*")) print "lib"substr(,3)"*";}
awk: cmd. line:1: ^ syntax error
awk: cmd. line:1: ^ 1 is invalid as number of arguments for match
close failed in file object destructor:
sys.excepthook is missing
lost sys.stderr
Build FAILED
Build Set: Time 0:00:33.478714
Build FAILED
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201121/4185142f/attachment.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201121/4185142f/attachment.obj>
