[PATCH] rtems: Improve rtems_interrupt_server_create()
Sebastian Huber
Mon Nov 23 15:40:34 UTC 2020
Also start interrupt server tasks on processors which do not have a
scheduler. Applications may dynamically manage processors using
rtems_scheduler_remove_processor() and rtems_scheduler_add_processor().
bsps/shared/irq/irq-server.c | 30 +++++++------
testsuites/smptests/smpirqs01/init.c | 65 +++++++++++++++++++++++++++-
2 files changed, 80 insertions(+), 15 deletions(-)
diff --git a/bsps/shared/irq/irq-server.c b/bsps/shared/irq/irq-server.c
index 19d03dc33f..2c8df4952c 100644
--- a/bsps/shared/irq/irq-server.c
+++ b/bsps/shared/irq/irq-server.c
@@ -506,9 +506,6 @@ static rtems_status_code bsp_interrupt_server_create(
cpu_set_t cpu;
#endif
- rtems_interrupt_lock_initialize(&s->lock, "Interrupt Server");
- rtems_chain_initialize_empty(&s->entries);
sc = rtems_task_create(
rtems_build_name('I', 'R', 'Q', 'S'),
priority,
@@ -518,23 +515,30 @@ static rtems_status_code bsp_interrupt_server_create(
&s->server
if (sc != RTEMS_SUCCESSFUL) {
+ (*s->destroy)(s);
return sc;
+ rtems_interrupt_lock_initialize(&s->lock, "Interrupt Server");
+ rtems_chain_initialize_empty(&s->entries);
#if defined(RTEMS_SMP)
sc = rtems_scheduler_ident_by_processor(cpu_index, &scheduler);
- if (sc != RTEMS_SUCCESSFUL) {
- /* Do not start an interrupt server on a processor without a scheduler */
- return RTEMS_SUCCESSFUL;
- sc = rtems_task_set_scheduler(s->server, scheduler, priority);
- _Assert(sc == RTEMS_SUCCESSFUL);
+ * If a scheduler exists for the processor, then move it to this scheduler
+ * and try to set the affinity to the processor, otherwise keep the scheduler
+ * of the executing thread.
+ if (sc == RTEMS_SUCCESSFUL) {
+ sc = rtems_task_set_scheduler(s->server, scheduler, priority);
+ _Assert(sc == RTEMS_SUCCESSFUL);
- /* Set the task to processor affinity on a best-effort basis */
- CPU_ZERO(&cpu);
- CPU_SET(cpu_index, &cpu);
- (void) rtems_task_set_affinity(s->server, sizeof(cpu), &cpu);
+ /* Set the task to processor affinity on a best-effort basis */
+ CPU_ZERO(&cpu);
+ CPU_SET(cpu_index, &cpu);
+ (void) rtems_task_set_affinity(s->server, sizeof(cpu), &cpu);
#else
(void) cpu_index;
#endif
diff --git a/testsuites/smptests/smpirqs01/init.c b/testsuites/smptests/smpirqs01/init.c
index 4350647ca5..03238227fd 100644
--- a/testsuites/smptests/smpirqs01/init.c
+++ b/testsuites/smptests/smpirqs01/init.c
@@ -64,11 +64,10 @@ static void ensure_server_termination(void)
T_rsc_success(sc);
-T_TEST_CASE(InterruptServerSMPInitializeDestroy)
+T_TEST_CASE(InterruptServerSMPInitializeIncorrectState)
rtems_status_code sc;
uint32_t server_count;
- void *greedy;
T_assert_eq_u32(rtems_scheduler_get_processor_maximum(), 2);
@@ -104,6 +103,14 @@ T_TEST_CASE(InterruptServerSMPInitializeDestroy)
sc = rtems_interrupt_server_delete(1);
T_rsc_success(sc);
ensure_server_termination();
+T_TEST_CASE(InterruptServerSMPInitializeInvalidPriority)
+ rtems_status_code sc;
+ uint32_t server_count;
+ T_assert_eq_u32(rtems_scheduler_get_processor_maximum(), 2);
server_count = 456;
sc = rtems_interrupt_server_initialize(
@@ -134,6 +141,15 @@ T_TEST_CASE(InterruptServerSMPInitializeDestroy)
T_rsc_success(sc);
+T_TEST_CASE(InterruptServerSMPInitializeNoMemory)
+ void *greedy;
greedy = rtems_heap_greedy_allocate(NULL, 0);
@@ -158,6 +174,51 @@ T_TEST_CASE(InterruptServerSMPInitializeDestroy)
T_rsc(sc, RTEMS_INVALID_ID);
+T_TEST_CASE(InterruptServerSMPInitializeNoScheduler)
+ rtems_id scheduler_id;
+ rtems_task_priority prio;
+ scheduler_id = 0;
+ sc = rtems_scheduler_ident_by_processor(1, &scheduler_id);
+ T_rsc_success(sc);
+ T_ne_u32(scheduler_id, 0);
+ sc = rtems_scheduler_remove_processor(scheduler_id, 1);
+ server_count = 456;
+ sc = rtems_interrupt_server_initialize(
+ 123,
+ RTEMS_MINIMUM_STACK_SIZE,
+ RTEMS_DEFAULT_MODES,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ &server_count
+ T_eq_u32(server_count, 2);
+ sc = rtems_interrupt_server_delete(0);
+ sc = rtems_interrupt_server_delete(1);
+ prio = 0;
+ sc = rtems_task_set_priority(RTEMS_SELF, 124, &prio);
+ sc = rtems_task_set_priority(RTEMS_SELF, prio, &prio);
+ sc = rtems_scheduler_add_processor(scheduler_id, 1);
const char rtems_test_name[] = "SMPIRQS 1";
static void Init(rtems_task_argument argument)
2.26.2
