[PATCH v2 3/6] rtems: Move _Partition_Is_buffer_size_aligned()
Mon Nov 23 16:01:36 UTC 2020
Thanks
On Mon, Nov 23, 2020 at 3:36 AM Sebastian Huber
> It is only used by rtems_partition_create().  Move code directly into
> the directive which called the inline function.
>  cpukit/include/rtems/rtems/partimpl.h | 7 -------
>  cpukit/rtems/src/partcreate.c         | 7 ++++++-
>  2 files changed, 6 insertions(+), 8 deletions(-)
> diff --git a/cpukit/include/rtems/rtems/partimpl.h b/cpukit/include/rtems/rtems/partimpl.h
> index 0d15d1e991..b9d57ae3c3 100644
> --- a/cpukit/include/rtems/rtems/partimpl.h
> +++ b/cpukit/include/rtems/rtems/partimpl.h
> @@ -34,13 +34,6 @@ extern "C" {
> -RTEMS_INLINE_ROUTINE bool _Partition_Is_buffer_size_aligned(
> -  uint32_t buffer_size
> -  return (buffer_size % CPU_SIZEOF_POINTER) == 0;
>  RTEMS_INLINE_ROUTINE bool _Partition_Is_buffer_area_aligned(
>    const void *starting_address
> diff --git a/cpukit/rtems/src/partcreate.c b/cpukit/rtems/src/partcreate.c
> index 9d4c7df283..1e471d3c0a 100644
> --- a/cpukit/rtems/src/partcreate.c
> +++ b/cpukit/rtems/src/partcreate.c
> @@ -58,8 +58,13 @@ rtems_status_code rtems_partition_create(
>    if ( length < buffer_size )
>      return RTEMS_INVALID_SIZE;
> -  if ( !_Partition_Is_buffer_size_aligned( buffer_size ) )
> +   * Ensure that the buffer size is an integral multiple of the pointer size so
> +   * that each buffer begin meets the chain node alignment.
> +  if ( buffer_size % CPU_SIZEOF_POINTER != 0 ) {
>    if ( buffer_size < sizeof( Chain_Node ) )
> 2.26.2
> devel mailing list
> devel at rtems.org
