[PATCH v2 1/4] Avoid INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL
Sebastian Huber
Tue Nov 24 07:33:55 UTC 2020
Replace a runtime check with a compile time assertion. This makes the
INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL obsolete.
Update #4181.
cpukit/include/rtems/confdefs/inittask.h | 13 ++++++++++
cpukit/include/rtems/score/interr.h | 2 +-
cpukit/rtems/src/taskinitusers.c | 8 +-----
spec/build/testsuites/sptests/grp.yml | 2 --
spec/build/testsuites/sptests/spfatal02.yml | 19 --------------
testsuites/sptests/Makefile.am | 9 -------
testsuites/sptests/configure.ac | 1 -
testsuites/sptests/spfatal02/init.c | 28 ---------------------
testsuites/sptests/spfatal02/spfatal02.doc | 20 ---------------
testsuites/sptests/spfatal02/spfatal02.scn | 3 ---
10 files changed, 15 insertions(+), 90 deletions(-)
delete mode 100644 spec/build/testsuites/sptests/spfatal02.yml
delete mode 100644 testsuites/sptests/spfatal02/init.c
delete mode 100644 testsuites/sptests/spfatal02/spfatal02.doc
delete mode 100644 testsuites/sptests/spfatal02/spfatal02.scn
diff --git a/cpukit/include/rtems/confdefs/inittask.h b/cpukit/include/rtems/confdefs/inittask.h
index a91b9a5917..25453f031d 100644
--- a/cpukit/include/rtems/confdefs/inittask.h
+++ b/cpukit/include/rtems/confdefs/inittask.h
@@ -100,6 +100,19 @@ extern "C" {
#define CONFIGURE_INIT_TASK_ARGUMENTS 0
#endif
+/* Ignore potential warnings from the static assertion below */
+#pragma GCC diagnostic push
+#pragma GCC diagnostic ignored "-Waddress"
+#pragma GCC diagnostic ignored "-Wpragmas"
+#pragma GCC diagnostic ignored "-Wtautological-pointer-compare"
+RTEMS_STATIC_ASSERT(
+ CONFIGURE_INIT_TASK_ENTRY_POINT != NULL,
+ CONFIGURE_INIT_TASK_ENTRY_POINT_MUST_NOT_BE_NULL
+#pragma GCC diagnostic pop
const rtems_initialization_tasks_table _RTEMS_tasks_User_task_table = {
CONFIGURE_INIT_TASK_NAME,
CONFIGURE_INIT_TASK_STACK_SIZE,
diff --git a/cpukit/include/rtems/score/interr.h b/cpukit/include/rtems/score/interr.h
index 4b06199ae9..b1f1061c82 100644
--- a/cpukit/include/rtems/score/interr.h
+++ b/cpukit/include/rtems/score/interr.h
@@ -189,7 +189,7 @@ typedef enum {
INTERNAL_ERROR_NO_MEMORY_FOR_HEAP = 23,
INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR = 24,
INTERNAL_ERROR_RESOURCE_IN_USE = 25,
- INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL = 26,
+ /* INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL = 26, */
/* INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULL = 27, */
INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK = 28,
INTERNAL_ERROR_THREAD_QUEUE_ENQUEUE_STICKY_FROM_BAD_STATE = 29,
diff --git a/cpukit/rtems/src/taskinitusers.c b/cpukit/rtems/src/taskinitusers.c
index 0b23d8bc86..f21c061670 100644
--- a/cpukit/rtems/src/taskinitusers.c
+++ b/cpukit/rtems/src/taskinitusers.c
@@ -29,7 +29,6 @@ void _RTEMS_tasks_Initialize_user_task( void )
rtems_id id;
rtems_status_code return_value;
const rtems_initialization_tasks_table *user_task;
- rtems_task_entry entry_point;
user_task = &_RTEMS_tasks_User_task_table;
return_value = rtems_task_create(
@@ -44,14 +43,9 @@ void _RTEMS_tasks_Initialize_user_task( void )
_Internal_error( INTERNAL_ERROR_RTEMS_INIT_TASK_CREATE_FAILED );
- entry_point = user_task->entry_point;
- if ( entry_point == NULL ) {
- _Internal_error( INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL );
return_value = rtems_task_start(
id,
- entry_point,
+ user_task->entry_point,
user_task->argument
_Assert( rtems_is_status_successful( return_value ) );
diff --git a/spec/build/testsuites/sptests/grp.yml b/spec/build/testsuites/sptests/grp.yml
index 1c865777a7..b1bf85942d 100644
--- a/spec/build/testsuites/sptests/grp.yml
+++ b/spec/build/testsuites/sptests/grp.yml
@@ -218,8 +218,6 @@ links:
uid: spextensions01
- role: build-dependency
uid: spfatal01
-- role: build-dependency
- uid: spfatal02
uid: spfatal03
diff --git a/spec/build/testsuites/sptests/spfatal02.yml b/spec/build/testsuites/sptests/spfatal02.yml
deleted file mode 100644
index 19e329a027..0000000000
--- a/spec/build/testsuites/sptests/spfatal02.yml
+++ /dev/null
@@ -1,19 +0,0 @@
-SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
-build-type: test-program
-cflags: []
-copyrights:
-- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
-cppflags: []
-cxxflags: []
-enabled-by: true
-features: c cprogram
-includes: []
-ldflags: []
-links: []
-source:
-- testsuites/sptests/spfatal02/init.c
-stlib: []
-target: testsuites/sptests/spfatal02.exe
-type: build
-use-after: []
-use-before: []
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index 14788f7fb1..8813d43513 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -904,15 +904,6 @@ spfatal01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_spfatal01) \
$(support_includes)
endif
-if TEST_spfatal02
-sp_tests += spfatal02
-sp_screens += spfatal02/spfatal02.scn
-sp_docs += spfatal02/spfatal02.doc
-spfatal02_SOURCES = spfatal02/init.c
-spfatal02_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_spfatal02) \
- $(support_includes)
-endif
if TEST_spfatal03
sp_tests += spfatal03
sp_screens += spfatal03/spfatal03.scn
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index 099ff0412b..4ca55e6a36 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -137,7 +137,6 @@ RTEMS_TEST_CHECK([speventsystem01])
RTEMS_TEST_CHECK([speventtransient01])
RTEMS_TEST_CHECK([spextensions01])
RTEMS_TEST_CHECK([spfatal01])
-RTEMS_TEST_CHECK([spfatal02])
RTEMS_TEST_CHECK([spfatal03])
RTEMS_TEST_CHECK([spfatal04])
RTEMS_TEST_CHECK([spfatal05])
diff --git a/testsuites/sptests/spfatal02/init.c b/testsuites/sptests/spfatal02/init.c
index 2700b4dd50..0000000000
--- a/testsuites/sptests/spfatal02/init.c
+++ /dev/null
@@ -1,28 +0,0 @@
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include "../spfatal_support/spfatal.h"
- * Classic API Init task create failure
-#define CONFIGURE_INIT_TASK_ENTRY_POINT NULL
-#define FATAL_ERROR_TEST_NAME "2"
-#define FATAL_ERROR_DESCRIPTION "Classic API Init task start failure"
-#define FATAL_ERROR_EXPECTED_SOURCE INTERNAL_ERROR_CORE
-#define FATAL_ERROR_EXPECTED_ERROR \
-static void force_error(void)
- * Case 2: Null entry
- /* we will not run this far */
-#include "../spfatal_support/spfatalimpl.h"
diff --git a/testsuites/sptests/spfatal02/spfatal02.doc b/testsuites/sptests/spfatal02/spfatal02.doc
index 1e62051b52..0000000000
--- a/testsuites/sptests/spfatal02/spfatal02.doc
+++ /dev/null
@@ -1,20 +0,0 @@
-# COPYRIGHT (c) 1989-2009.
-# On-Line Applications Research Corporation (OAR).
-# The license and distribution terms for this file may be
-# found in the file LICENSE in this distribution or at
-# http://www.rtems.org/license/LICENSE.
-This file describes the directives and concepts tested by this test set.
-test set name: spfatal02
-directives:
- rtems_task_start for a user initialization task
-concepts:
-+ Ensure that when rtems_task_start returns an error when creating a Classic
- API user initialization task is properly treated as a fatal error.
diff --git a/testsuites/sptests/spfatal02/spfatal02.scn b/testsuites/sptests/spfatal02/spfatal02.scn
index a6e6d93501..0000000000
--- a/testsuites/sptests/spfatal02/spfatal02.scn
+++ /dev/null
@@ -1,3 +0,0 @@
-*** TEST FATAL 2 ***
-Fatal error (Classic API Init task start failure) hit
-*** END OF TEST FATAL 2 ***
2.26.2
