[PATCH v2 1/4] Avoid INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL
Joel Sherrill
joel at rtems.org
Tue Nov 24 21:19:13 UTC 2020
On Tue, Nov 24, 2020 at 1:34 AM Sebastian Huber <
> Replace a runtime check with a compile time assertion. This makes the
> INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL obsolete.
> Update #4181.
> cpukit/include/rtems/confdefs/inittask.h | 13 ++++++++++
> cpukit/include/rtems/score/interr.h | 2 +-
> cpukit/rtems/src/taskinitusers.c | 8 +-----
> spec/build/testsuites/sptests/grp.yml | 2 --
> spec/build/testsuites/sptests/spfatal02.yml | 19 --------------
> testsuites/sptests/Makefile.am | 9 -------
> testsuites/sptests/configure.ac | 1 -
> testsuites/sptests/spfatal02/init.c | 28 ---------------------
> testsuites/sptests/spfatal02/spfatal02.doc | 20 ---------------
> testsuites/sptests/spfatal02/spfatal02.scn | 3 ---
> 10 files changed, 15 insertions(+), 90 deletions(-)
> delete mode 100644 spec/build/testsuites/sptests/spfatal02.yml
> delete mode 100644 testsuites/sptests/spfatal02/init.c
> delete mode 100644 testsuites/sptests/spfatal02/spfatal02.doc
> delete mode 100644 testsuites/sptests/spfatal02/spfatal02.scn
> diff --git a/cpukit/include/rtems/confdefs/inittask.h
> b/cpukit/include/rtems/confdefs/inittask.h
> index a91b9a5917..25453f031d 100644
> --- a/cpukit/include/rtems/confdefs/inittask.h
> +++ b/cpukit/include/rtems/confdefs/inittask.h
> @@ -100,6 +100,19 @@ extern "C" {
> #define CONFIGURE_INIT_TASK_ARGUMENTS 0
> #endif
> +/* Ignore potential warnings from the static assertion below */
> +#pragma GCC diagnostic push
> +#pragma GCC diagnostic ignored "-Waddress"
> +#pragma GCC diagnostic ignored "-Wpragmas"
> +#pragma GCC diagnostic ignored "-Wtautological-pointer-compare"
This comment applies to every place pragmas are used like this.
If they are just potential, the pragmas are not needed. If this is really
disabling
a specific warning, tell the read what the warning is.
Is this correct code and gcc should not be generating a warning? That
should be associated with a gcc ticket for false warnings.
pragmas are to be used lightly and with documented justification.
I am not sure how this would be captured in coding guidelines but this is
an
exceptional thing to use and thus must come with exceptional comments.
> +RTEMS_STATIC_ASSERT(
> + CONFIGURE_INIT_TASK_ENTRY_POINT != NULL,
> + CONFIGURE_INIT_TASK_ENTRY_POINT_MUST_NOT_BE_NULL
> +#pragma GCC diagnostic pop
> const rtems_initialization_tasks_table _RTEMS_tasks_User_task_table = {
> CONFIGURE_INIT_TASK_NAME,
> CONFIGURE_INIT_TASK_STACK_SIZE,
> diff --git a/cpukit/include/rtems/score/interr.h
> b/cpukit/include/rtems/score/interr.h
> index 4b06199ae9..b1f1061c82 100644
> --- a/cpukit/include/rtems/score/interr.h
> +++ b/cpukit/include/rtems/score/interr.h
> @@ -189,7 +189,7 @@ typedef enum {
> INTERNAL_ERROR_NO_MEMORY_FOR_HEAP = 23,
> INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR = 24,
> INTERNAL_ERROR_RESOURCE_IN_USE = 25,
> - INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL = 26,
> + /* INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL = 26, */
> /* INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULL = 27, */
> INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK = 28,
> INTERNAL_ERROR_THREAD_QUEUE_ENQUEUE_STICKY_FROM_BAD_STATE = 29,
> diff --git a/cpukit/rtems/src/taskinitusers.c
> b/cpukit/rtems/src/taskinitusers.c
> index 0b23d8bc86..f21c061670 100644
> --- a/cpukit/rtems/src/taskinitusers.c
> +++ b/cpukit/rtems/src/taskinitusers.c
> @@ -29,7 +29,6 @@ void _RTEMS_tasks_Initialize_user_task( void )
> rtems_id id;
> rtems_status_code return_value;
> const rtems_initialization_tasks_table *user_task;
> - rtems_task_entry entry_point;
> user_task = &_RTEMS_tasks_User_task_table;
> return_value = rtems_task_create(
> @@ -44,14 +43,9 @@ void _RTEMS_tasks_Initialize_user_task( void )
> _Internal_error( INTERNAL_ERROR_RTEMS_INIT_TASK_CREATE_FAILED );
> - entry_point = user_task->entry_point;
> - if ( entry_point == NULL ) {
> - _Internal_error( INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL );
> return_value = rtems_task_start(
> id,
> - entry_point,
> + user_task->entry_point,
> user_task->argument
> _Assert( rtems_is_status_successful( return_value ) );
> diff --git a/spec/build/testsuites/sptests/grp.yml
> b/spec/build/testsuites/sptests/grp.yml
> index 1c865777a7..b1bf85942d 100644
> --- a/spec/build/testsuites/sptests/grp.yml
> +++ b/spec/build/testsuites/sptests/grp.yml
> @@ -218,8 +218,6 @@ links:
> uid: spextensions01
> - role: build-dependency
> uid: spfatal01
> -- role: build-dependency
> - uid: spfatal02
> uid: spfatal03
> diff --git a/spec/build/testsuites/sptests/spfatal02.yml
> b/spec/build/testsuites/sptests/spfatal02.yml
> deleted file mode 100644
> index 19e329a027..0000000000
> --- a/spec/build/testsuites/sptests/spfatal02.yml
> +++ /dev/null
> @@ -1,19 +0,0 @@
> -SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> -build-type: test-program
> -cflags: []
> -copyrights:
> -- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
> -cppflags: []
> -cxxflags: []
> -enabled-by: true
> -features: c cprogram
> -includes: []
> -ldflags: []
> -links: []
> -source:
> -- testsuites/sptests/spfatal02/init.c
> -stlib: []
> -target: testsuites/sptests/spfatal02.exe
> -type: build
> -use-after: []
> -use-before: []
> diff --git a/testsuites/sptests/Makefile.am
> b/testsuites/sptests/Makefile.am
> index 14788f7fb1..8813d43513 100644
> --- a/testsuites/sptests/Makefile.am
> +++ b/testsuites/sptests/Makefile.am
> @@ -904,15 +904,6 @@ spfatal01_CPPFLAGS = $(AM_CPPFLAGS)
> $(TEST_FLAGS_spfatal01) \
> $(support_includes)
> endif
> -if TEST_spfatal02
> -sp_tests += spfatal02
> -sp_screens += spfatal02/spfatal02.scn
> -sp_docs += spfatal02/spfatal02.doc
> -spfatal02_SOURCES = spfatal02/init.c
> -spfatal02_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_spfatal02) \
> - $(support_includes)
> -endif
> if TEST_spfatal03
> sp_tests += spfatal03
> sp_screens += spfatal03/spfatal03.scn
> diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/
> configure.ac
> index 099ff0412b..4ca55e6a36 100644
> --- a/testsuites/sptests/configure.ac
> +++ b/testsuites/sptests/configure.ac
> @@ -137,7 +137,6 @@ RTEMS_TEST_CHECK([speventsystem01])
> RTEMS_TEST_CHECK([speventtransient01])
> RTEMS_TEST_CHECK([spextensions01])
> RTEMS_TEST_CHECK([spfatal01])
> -RTEMS_TEST_CHECK([spfatal02])
> RTEMS_TEST_CHECK([spfatal03])
> RTEMS_TEST_CHECK([spfatal04])
> RTEMS_TEST_CHECK([spfatal05])
> diff --git a/testsuites/sptests/spfatal02/init.c
> b/testsuites/sptests/spfatal02/init.c
> index 2700b4dd50..0000000000
> --- a/testsuites/sptests/spfatal02/init.c
> +++ /dev/null
> @@ -1,28 +0,0 @@
> -#ifdef HAVE_CONFIG_H
> -#include "config.h"
> -#endif
> -#include "../spfatal_support/spfatal.h"
> - * Classic API Init task create failure
> -#define CONFIGURE_INIT_TASK_ENTRY_POINT NULL
> -#define FATAL_ERROR_TEST_NAME "2"
> -#define FATAL_ERROR_DESCRIPTION "Classic API Init task start
> failure"
> -#define FATAL_ERROR_EXPECTED_SOURCE INTERNAL_ERROR_CORE
> -#define FATAL_ERROR_EXPECTED_ERROR \
> -static void force_error(void)
> - * Case 2: Null entry
> - /* we will not run this far */
> -#include "../spfatal_support/spfatalimpl.h"
> diff --git a/testsuites/sptests/spfatal02/spfatal02.doc
> b/testsuites/sptests/spfatal02/spfatal02.doc
> index 1e62051b52..0000000000
> --- a/testsuites/sptests/spfatal02/spfatal02.doc
> +++ /dev/null
> @@ -1,20 +0,0 @@
> -# COPYRIGHT (c) 1989-2009.
> -# On-Line Applications Research Corporation (OAR).
> -# The license and distribution terms for this file may be
> -# found in the file LICENSE in this distribution or at
> -# http://www.rtems.org/license/LICENSE.
> -This file describes the directives and concepts tested by this test set.
> -test set name: spfatal02
> -directives:
> - rtems_task_start for a user initialization task
> -concepts:
> -+ Ensure that when rtems_task_start returns an error when creating a
> Classic
> - API user initialization task is properly treated as a fatal error.
> diff --git a/testsuites/sptests/spfatal02/spfatal02.scn
> b/testsuites/sptests/spfatal02/spfatal02.scn
> index a6e6d93501..0000000000
> --- a/testsuites/sptests/spfatal02/spfatal02.scn
> +++ /dev/null
> @@ -1,3 +0,0 @@
> -*** TEST FATAL 2 ***
> -Fatal error (Classic API Init task start failure) hit
> -*** END OF TEST FATAL 2 ***
> 2.26.2
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201124/9e43034a/attachment-0001.html>
