[PATCH 2/3] score: Add CONFIGURE_INIT_TASK_STORAGE_SIZE
Tue Nov 24 07:35:55 UTC 2020
On 23/11/2020 21:23, Chris Johns wrote:
> On 23/11/20 7:46 pm, Sebastian Huber wrote:
>> On 22/11/2020 23:22, Chris Johns wrote:
>>> On 20/11/20 7:31 pm, Sebastian Huber wrote:
>>>> In order to better support applications which use the new
>>>> rtems_task_construct() directive add the
>>>> CONFIGURE_INIT_TASK_STORAGE_SIZE configuration option.  If this option
>>>> is specified, then the Classic API initialization task is constructed
>>>> with rtems_task_construct().
>>> The name CONFIGURE_INIT_TASK_STORAGE_SIZE does not reflect the role described
>>> here and is a little ambiguous unless you know the implementation detail.
>>> CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE ?
>> I am not sure. The storage size is a property of the task. How this property is
>> achieved is a detail and may change.
> Is it a property of a specific instance (Init) of a specific type (construct) of
> task?
> You have stated:
>   "If this option is specified, then the Classic API initialization task
>    is constructed with rtems_task_construct()."
> This is how I am reading this sentence. Sure in time the task may not be
> constructed and that may change but the effect needs to be a "constructed" task
> or you would need another variables.
> The key issue is the config option triggers a change in the type of Init task
> and we should be as clear about that as we can.
I changed the documentation of CONFIGURE_INIT_TASK_STORAGE_SIZE to not
mention rtems_task_construct(). This is just an implementation detail.
https://lists.rtems.org/pipermail/devel/2020-November/063457.html
embedded brains GmbH
Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 16
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
Registernummer: HRB 157899
Unsere Datenschutzerklärung finden Sie hier: https://embedded-brains.de/datenschutzerklaerung/
