[PATCH 2/3] score: Add CONFIGURE_INIT_TASK_STORAGE_SIZE
Tue Nov 24 11:40:12 UTC 2020
On 24/11/20 6:35 pm, Sebastian Huber wrote:
> On 23/11/2020 21:23, Chris Johns wrote:
>> On 23/11/20 7:46 pm, Sebastian Huber wrote:
>>> On 22/11/2020 23:22, Chris Johns wrote:
>>>> On 20/11/20 7:31 pm, Sebastian Huber wrote:
>>>>> In order to better support applications which use the new
>>>>> rtems_task_construct() directive add the
>>>>> CONFIGURE_INIT_TASK_STORAGE_SIZE configuration option.  If this option
>>>>> is specified, then the Classic API initialization task is constructed
>>>>> with rtems_task_construct().
>>>> The name CONFIGURE_INIT_TASK_STORAGE_SIZE does not reflect the role described
>>>> here and is a little ambiguous unless you know the implementation detail.
>>>> CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE ?
>>> I am not sure. The storage size is a property of the task. How this property is
>>> achieved is a detail and may change.
>> Is it a property of a specific instance (Init) of a specific type (construct) of
>> task?
>> You have stated:
>>   "If this option is specified, then the Classic API initialization task
>>    is constructed with rtems_task_construct()."
>> This is how I am reading this sentence. Sure in time the task may not be
>> constructed and that may change but the effect needs to be a "constructed" task
>> or you would need another variables.
>> The key issue is the config option triggers a change in the type of Init task
>> and we should be as clear about that as we can.
> I changed the documentation of CONFIGURE_INIT_TASK_STORAGE_SIZE to not mention
> rtems_task_construct(). This is just an implementation detail.
Does this mean all Init tasks will be statically constructed tasks?
