[PATCH 2/3] score: Add CONFIGURE_INIT_TASK_STORAGE_SIZE
Sebastian Huber
Tue Nov 24 11:45:04 UTC 2020
On 24/11/2020 12:40, Chris Johns wrote:
> On 24/11/20 6:35 pm, Sebastian Huber wrote:
>> On 23/11/2020 21:23, Chris Johns wrote:
>>> On 23/11/20 7:46 pm, Sebastian Huber wrote:
>>>> On 22/11/2020 23:22, Chris Johns wrote:
>>>>> On 20/11/20 7:31 pm, Sebastian Huber wrote:
>>>>>> In order to better support applications which use the new
>>>>>> rtems_task_construct() directive add the
>>>>>> CONFIGURE_INIT_TASK_STORAGE_SIZE configuration option. If this option
>>>>>> is specified, then the Classic API initialization task is constructed
>>>>>> with rtems_task_construct().
>>>>> The name CONFIGURE_INIT_TASK_STORAGE_SIZE does not reflect the role described
>>>>> here and is a little ambiguous unless you know the implementation detail.
>>>>> CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE ?
>>>> I am not sure. The storage size is a property of the task. How this property is
>>>> achieved is a detail and may change.
>>> Is it a property of a specific instance (Init) of a specific type (construct) of
>>> task?
>>> You have stated:
>>> "If this option is specified, then the Classic API initialization task
>>> is constructed with rtems_task_construct()."
>>> This is how I am reading this sentence. Sure in time the task may not be
>>> constructed and that may change but the effect needs to be a "constructed" task
>>> or you would need another variables.
>>> The key issue is the config option triggers a change in the type of Init task
>>> and we should be as clear about that as we can.
>> I changed the documentation of CONFIGURE_INIT_TASK_STORAGE_SIZE to not mention
>> rtems_task_construct(). This is just an implementation detail.
> Does this mean all Init tasks will be statically constructed tasks?
No, if you specify CONFIGURE_INIT_TASK_STACK_SIZE (this is also the
default), then rtems_task_create() is used. If you specify
CONFIGURE_INIT_TASK_STORAGE_SIZE, then rtems_task_construct() is used.
For a user it should be no concern how the system creates the Classic
API initialization task. What matters is that the task has the
configured properties.
embedded brains GmbH
Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 16
Fax: +49-89-18 94 741 - 08
PGP: Public key available on request.
Registernummer: HRB 157899
Unsere Datenschutzerklärung finden Sie hier: https://embedded-brains.de/datenschutzerklaerung/
