[PATCH] sapi: Remove obsolete README file
Thu Nov 26 10:29:39 UTC 2020
 cpukit/sapi/include/rtems/README | 129 -------------------------------
 1 file changed, 129 deletions(-)
 delete mode 100644 cpukit/sapi/include/rtems/README
diff --git a/cpukit/sapi/include/rtems/README b/cpukit/sapi/include/rtems/README
deleted file mode 100644
index 1b6dd77619..0000000000
--- a/cpukit/sapi/include/rtems/README
+++ /dev/null
@@ -1,129 +0,0 @@
-Configuring a System Using the Template in confdefs.h
-The file confdefs.h is a Configuration Template file which can be
-used to greatly simplify the creation and maintenance of RTEMS
-Configuration Tables.  The basic concepts are:
-   + confdefs.h provides defaults for all configuration parameters
-   + applications specify only those values they wish to override
-   + confdefs.h can be the only file which knows the precise layout
-     of the RTEMS Configuration Tables.
-The Configuration Template setup is used by all RTEMS tests to
-simplify the maintenance of the tests.
-Here is the section from the system.h file from test tm21 from
-the Timing Test Suite:
-   /* configuration information */
-   #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
-   #define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
-   #define CONFIGURE_MAXIMUM_TASKS              102
-   #define CONFIGURE_MAXIMUM_TIMERS             100
-   #define CONFIGURE_MAXIMUM_SEMAPHORES         100
-   #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES     100
-   #define CONFIGURE_MAXIMUM_PARTITIONS         100
-   #define CONFIGURE_MAXIMUM_REGIONS            100
-   #define CONFIGURE_MAXIMUM_PORTS              100
-   #define CONFIGURE_MAXIMUM_PERIODS            100
-   #define CONFIGURE_TICKS_PER_TIMESLICE        0
-   #include <confdefs.h>
-The above example overrides a number of the configuration parameters.
-It informs the template that it is a member of the Timing Suite,
-requires a console and timer driver, and that it needs 102 tasks,
-100 timers, 100 semaphores, 100 message queues, 100 partitions,
-100 regions, 100 ports, and 100 periods.   By default, the test
-would have gotten no drivers, 10 tasks, and no other RTEMS objects.
-The following shows the configuration tables generated by the
-template by default.
-#include <bsp.h>
-#define NULL_DRIVER_TABLE_ENTRY \
- { NULL, NULL, NULL, NULL, NULL, NULL }
-rtems_driver_address_table Device_drivers[] = {
-#ifdef CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
-  CONSOLE_DRIVER_TABLE_ENTRY,
-#endif
-#ifdef CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
-  CLOCK_DRIVER_TABLE_ENTRY,
-#endif
-#ifdef CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
-  STUB_DRIVER_TABLE_ENTRY,
-#endif
-  NULL_DRIVER_TABLE_ENTRY,
-rtems_initialization_tasks_table Initialization_tasks[] = {
-  { rtems_build_name( 'U', 'I', '1', ' ' ), /* init task name */
-    RTEMS_MINIMUM_STACK_SIZE,               /* init task stack size */
-    1,                                      /* init task priority */
-    RTEMS_DEFAULT_ATTRIBUTES,               /* init task attributes */
-    Init,                                   /* init task entry point */
-    RTEMS_NO_PREEMPT,                       /* init task initial mode */
-    0                                       /* init task argument list */
-#ifdef CONFIGURE_MP_APPLICATION
- *  NODE_NUMBER is assumed to be set on the compile line.
-rtems_multiprocessing_table Multiprocessing_configuration = {
-  NODE_NUMBER,                           /* local node number */
-  2,                                     /* maximum # nodes in system */
-  32,                                    /* maximum # global objects */
-  32,                                    /* maximum # proxies */
-  &MPCI_table                            /* pointer to MPCI config table */
-#endif
- *  CONFIGURE_EXECUTIVE_RAM_SIZE is a rough guess based on the number of
- *  tasks in the system plus enough extra to get a whole 64K extra.
- *  The NULL address for the workspace area is assumed to be assigned
- *  at startup time by the BSP.
-rtems_configuration_table Configuration = {
-  NULL,                      /* executive RAM work area */
-  CONFIGURE_EXECUTIVE_RAM_SIZE, /* executive RAM size */
-  10,                        /* maximum # tasks */
-  0,                         /* maximum # timers */
-  0,                         /* maximum # semaphores */
-  0,                         /* maximum # message queues */
-  0,                         /* maximum # messages */
-  0,                         /* maximum # partitions */
-  0,                         /* maximum # regions */
-  0,                         /* maximum # dp memory areas */
-  0,                         /* maximum # periods */
-  0,                         /* maximum # user extensions */
-  RTEMS_MILLISECONDS_TO_MICROSECONDS(10), /* # us in a tick */
-  50,                        /* # ticks in a timeslice */
-  sizeof (Initialization_tasks) / sizeof(rtems_initialization_tasks_table),
-                             /* number of init tasks */
-  Initialization_tasks,      /* init task(s) table */
-  sizeof (Device_drivers) / sizeof(rtems_driver_address_table),
-                             /* number of device drivers */
-  Device_drivers,            /* pointer to driver address table */
-  NULL,                      /* pointer to initial extensions */
-  &Multiprocessing_configuration
-#else
-  NULL                       /* ptr to MP config table */
-#endif
2.26.2
