[PATCH] sapi: Remove obsolete README file
Gedare Bloom
gedare at rtems.org
Mon Nov 30 17:51:40 UTC 2020
ok with me.
On Thu, Nov 26, 2020 at 3:29 AM Sebastian Huber <
> cpukit/sapi/include/rtems/README | 129 -------------------------------
> 1 file changed, 129 deletions(-)
> delete mode 100644 cpukit/sapi/include/rtems/README
> diff --git a/cpukit/sapi/include/rtems/README
> b/cpukit/sapi/include/rtems/README
> deleted file mode 100644
> index 1b6dd77619..0000000000
> --- a/cpukit/sapi/include/rtems/README
> +++ /dev/null
> @@ -1,129 +0,0 @@
> -Configuring a System Using the Template in confdefs.h
> -The file confdefs.h is a Configuration Template file which can be
> -used to greatly simplify the creation and maintenance of RTEMS
> -Configuration Tables. The basic concepts are:
> - + confdefs.h provides defaults for all configuration parameters
> - + applications specify only those values they wish to override
> - + confdefs.h can be the only file which knows the precise layout
> - of the RTEMS Configuration Tables.
> -The Configuration Template setup is used by all RTEMS tests to
> -simplify the maintenance of the tests.
> -Here is the section from the system.h file from test tm21 from
> -the Timing Test Suite:
> - /* configuration information */
> - #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> - #define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
> - #define CONFIGURE_MAXIMUM_TASKS 102
> - #define CONFIGURE_MAXIMUM_TIMERS 100
> - #define CONFIGURE_MAXIMUM_SEMAPHORES 100
> - #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 100
> - #define CONFIGURE_MAXIMUM_PARTITIONS 100
> - #define CONFIGURE_MAXIMUM_REGIONS 100
> - #define CONFIGURE_MAXIMUM_PORTS 100
> - #define CONFIGURE_MAXIMUM_PERIODS 100
> - #define CONFIGURE_TICKS_PER_TIMESLICE 0
> - #include <confdefs.h>
> -The above example overrides a number of the configuration parameters.
> -It informs the template that it is a member of the Timing Suite,
> -requires a console and timer driver, and that it needs 102 tasks,
> -100 timers, 100 semaphores, 100 message queues, 100 partitions,
> -100 regions, 100 ports, and 100 periods. By default, the test
> -would have gotten no drivers, 10 tasks, and no other RTEMS objects.
> -The following shows the configuration tables generated by the
> -template by default.
> -#include <bsp.h>
> -#define NULL_DRIVER_TABLE_ENTRY \
> - { NULL, NULL, NULL, NULL, NULL, NULL }
> -rtems_driver_address_table Device_drivers[] = {
> -#ifdef CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> - CONSOLE_DRIVER_TABLE_ENTRY,
> -#endif
> -#ifdef CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> - CLOCK_DRIVER_TABLE_ENTRY,
> -#endif
> -#ifdef CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
> - STUB_DRIVER_TABLE_ENTRY,
> -#endif
> - NULL_DRIVER_TABLE_ENTRY,
> -rtems_initialization_tasks_table Initialization_tasks[] = {
> - { rtems_build_name( 'U', 'I', '1', ' ' ), /* init task name */
> - RTEMS_MINIMUM_STACK_SIZE, /* init task stack size */
> - 1, /* init task priority */
> - RTEMS_DEFAULT_ATTRIBUTES, /* init task attributes */
> - Init, /* init task entry point */
> - RTEMS_NO_PREEMPT, /* init task initial mode */
> - 0 /* init task argument list */
> -#ifdef CONFIGURE_MP_APPLICATION
> - * NODE_NUMBER is assumed to be set on the compile line.
> -rtems_multiprocessing_table Multiprocessing_configuration = {
> - NODE_NUMBER, /* local node number */
> - 2, /* maximum # nodes in system */
> - 32, /* maximum # global objects */
> - 32, /* maximum # proxies */
> - &MPCI_table /* pointer to MPCI config table
> -#endif
> - * CONFIGURE_EXECUTIVE_RAM_SIZE is a rough guess based on the number of
> - * tasks in the system plus enough extra to get a whole 64K extra.
> - * The NULL address for the workspace area is assumed to be assigned
> - * at startup time by the BSP.
> -rtems_configuration_table Configuration = {
> - NULL, /* executive RAM work area */
> - CONFIGURE_EXECUTIVE_RAM_SIZE, /* executive RAM size */
> - 10, /* maximum # tasks */
> - 0, /* maximum # timers */
> - 0, /* maximum # semaphores */
> - 0, /* maximum # message queues */
> - 0, /* maximum # messages */
> - 0, /* maximum # partitions */
> - 0, /* maximum # regions */
> - 0, /* maximum # dp memory areas */
> - 0, /* maximum # periods */
> - 0, /* maximum # user extensions */
> - RTEMS_MILLISECONDS_TO_MICROSECONDS(10), /* # us in a tick */
> - 50, /* # ticks in a timeslice */
> - sizeof (Initialization_tasks) /
> sizeof(rtems_initialization_tasks_table),
> - /* number of init tasks */
> - Initialization_tasks, /* init task(s) table */
> - sizeof (Device_drivers) / sizeof(rtems_driver_address_table),
> - /* number of device drivers */
> - Device_drivers, /* pointer to driver address table */
> - NULL, /* pointer to initial extensions */
> - &Multiprocessing_configuration
> -#else
> - NULL /* ptr to MP config table */
> -#endif
> 2.26.2
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201130/4b8ac39c/attachment.html>
