[PATCH v1 0/1] xilinx_zynq: Enable support for 4kiB MMU pages
Jan Sommer
jan.sommer at dlr.de
Thu Nov 26 16:08:25 UTC 2020
Hello,
Thanks to the suggestions from Sebastian, here my first try to edit
things in the new build system.
This should enable the support for small MMU tables for the xilinx_zynq
based BSPs and enable it by default.
Would this also be something to backport to RTEMS5?
I could prepare a patch where it is not enabled by default, so that
there is no difference for users of 5.1.
Ideally, the patch here
https://lists.rtems.org/pipermail/devel/2020-November/063461.html is
merged beforehand.
Best regards,
Jan
Jan Sommer (1):
bsp/xilinx_zynq: Enable support for 4kiB MMU pages
c/src/lib/libbsp/arm/xilinx-zynq/configure.ac | 4 ++++
spec/build/bsps/arm/optmmusmallpages.yml | 10 ++++++++++
spec/build/bsps/arm/xilinx-zynq/grp.yml | 2 +-
3 files changed, 15 insertions(+), 1 deletion(-)
2.17.1
