[PATCH v1 1/1] bsp/xilinx_zynq: Enable support for 4kiB MMU pages
Jan Sommer
jan.sommer at dlr.de
Thu Nov 26 16:08:26 UTC 2020
c/src/lib/libbsp/arm/xilinx-zynq/configure.ac | 4 ++++
spec/build/bsps/arm/optmmusmallpages.yml | 10 ++++++++++
spec/build/bsps/arm/xilinx-zynq/grp.yml | 2 +-
3 files changed, 15 insertions(+), 1 deletion(-)
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/configure.ac b/c/src/lib/libbsp/arm/xilinx-zynq/configure.ac
index 6599b34292..86e50d1503 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynq/configure.ac
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/configure.ac
@@ -70,11 +70,15 @@ RTEMS_BSPOPTS_SET([BSP_ZYNQ_RAM_LENGTH],[xilinx_zynq_zedboard],[512M])
RTEMS_BSPOPTS_SET([BSP_ZYNQ_RAM_LENGTH],[*],[256M])
RTEMS_BSPOPTS_HELP([BSP_ZYNQ_RAM_LENGTH],[override a BSP's default RAM length])
+RTEMS_BSPOPTS_SET([ARM_MMU_USE_SMALL_PAGES],[*],[1])
+RTEMS_BSPOPTS_HELP([ARM_MMU_USE_SMALL_PAGES],[use MMU with small pages (4KiB)])
RTEMS_BSPOPTS_SET([BSP_ZYNQ_NOCACHE_LENGTH],[*],[1M])
RTEMS_BSPOPTS_HELP([BSP_ZYNQ_NOCACHE_LENGTH],[length of nocache RAM region])
ZYNQ_RAM_ORIGIN="0x00100000"
ZYNQ_RAM_MMU_LENGTH="16k"
+AS_IF([test "x${ARM_MMU_USE_SMALL_PAGES}" == x1], [ZYNQ_RAM_MMU_LENGTH="(16k+4M)"])
ZYNQ_RAM_INT_0_ORIGIN="0x00000000"
ZYNQ_RAM_INT_0_LENGTH="64k + 64k + 64k"
ZYNQ_RAM_INT_1_ORIGIN="0xFFFF0000"
diff --git a/spec/build/bsps/arm/optmmusmallpages.yml b/spec/build/bsps/arm/optmmusmallpages.yml
index 5ef991e7d5..18d07255c6 100644
--- a/spec/build/bsps/arm/optmmusmallpages.yml
+++ b/spec/build/bsps/arm/optmmusmallpages.yml
@@ -2,6 +2,16 @@ SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
actions:
- get-boolean: null
- define-condition: null
+- script: |
+ if conf.is_defined('ARM_MMU_TRANSLATION_TABLE_SIZE'):
+ conf.fatal("ARM_MMU_TRANSLATION_TABLE_SIZE already defined by conflicting spec.")
+ tbl_sz = 16*1024
+ if value:
+ tbl_sz += 4*1024*1024
+ conf.env["ARM_MMU_TRANSLATION_TABLE_SIZE"] = tbl_sz
build-type: option
copyrights:
- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
diff --git a/spec/build/bsps/arm/xilinx-zynq/grp.yml b/spec/build/bsps/arm/xilinx-zynq/grp.yml
index 264308e6ad..b7efedc17b 100644
--- a/spec/build/bsps/arm/xilinx-zynq/grp.yml
+++ b/spec/build/bsps/arm/xilinx-zynq/grp.yml
@@ -42,7 +42,7 @@ links:
- role: build-dependency
uid: optint1ori
- uid: ../optmmusz
+ uid: ../optmmusmallpages
uid: optnocachelen
2.17.1
