[PATCH v4 0/1] Test for clock_nanosleep() with CLOCK_MONOTONIC option
Gedare Bloom
gedare at rtems.org
Mon Nov 30 17:35:46 UTC 2020
I don't have time to try it out, if no one else gets back to you by early
January ping me on it. I'll have more time to look at it.
On Mon, Nov 30, 2020 at 8:40 AM Utkarsh Rai <utkarsh.rai60 at gmail.com> wrote:
> Hello,
> Is there any update on this patch?
> On Wed, Oct 28, 2020 at 7:04 PM Utkarsh Rai <utkarsh.rai60 at gmail.com>
> wrote:
>> Ping.
>> On Wed, Oct 21, 2020 at 8:58 AM Utkarsh Rai <utkarsh.rai60 at gmail.com>
>> wrote:
>>> This patch has the tests for clock_nanosleep with the CLOCK_MONOTONIC
>>> option.
>>> The psxtests/psxclocknanosleep01/.. tests for valid timeout values as
>>> well as
>>> for the effect on timeout delay when REALTIME clock is modified(no
>>> effect).
>>> The timing tests are the similar to that for the REALTIME
>>> option(yielding and
>>> blocking).
>>> Utkarsh Rai (1):
>>> .../psxtests/psxclocknanosleep01.yml | 19 +++
>>> spec/build/testsuites/psxtmtests/grp.yml | 4 +
>>> .../psxtmtests/psxtmclocknanosleep04.yml | 19 +++
>>> .../psxtmtests/psxtmclocknanosleep05.yml | 19 +++
>>> .../psxtests/psxclocknanosleep01/init.c | 145 ++++++++++++++++++
>>> .../psxclocknanosleep01.doc | 13 ++
>>> .../psxclocknanosleep01.scn | 50 ++++++
>>> .../psxtmtests/psxtmclocknanosleep04/init.c | 70 +++++++++
>>> .../psxtmtests/psxtmclocknanosleep05/init.c | 116 ++++++++++++++
>>> 9 files changed, 455 insertions(+)
>>> create mode 100644
>>> spec/build/testsuites/psxtests/psxclocknanosleep01.yml
>>> create mode 100644
>>> spec/build/testsuites/psxtmtests/psxtmclocknanosleep04.yml
>>> create mode 100644
>>> spec/build/testsuites/psxtmtests/psxtmclocknanosleep05.yml
>>> create mode 100644 testsuites/psxtests/psxclocknanosleep01/init.c
>>> create mode 100644
>>> testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc
>>> create mode 100644
>>> testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn
>>> create mode 100644 testsuites/psxtmtests/psxtmclocknanosleep04/init.c
>>> create mode 100644 testsuites/psxtmtests/psxtmclocknanosleep05/init.c
>>> 2.25.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201130/e02cd272/attachment.html>
