[PATCH rtems-docs] shell: Document i2c and spi commands.
Gedare Bloom
gedare at rtems.org
Mon Nov 30 17:43:55 UTC 2020
On Mon, Nov 30, 2020 at 7:14 AM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> shell/general_commands.rst | 200 +++++++++++++++++++++++++++++++++++++
> 1 file changed, 200 insertions(+)
> diff --git a/shell/general_commands.rst b/shell/general_commands.rst
> index c74ae45..a6f7e18 100644
> --- a/shell/general_commands.rst
> +++ b/shell/general_commands.rst
> @@ -44,6 +44,14 @@ The RTEMS shell has the following general commands:
> - rtc_ - RTC driver configuration
> +- i2cdetect_ - detect I2C devices
> +- i2cget_ - get data from an EEPROM like I2C device
> +- i2cset_ - write data to an EEPROM like I2C device
> +- spi_ - read and write simple data to an SPI bus
> - exit_ - alias for logoff command
> Commands
> @@ -1179,6 +1187,198 @@ CONFIGURATION:
> \clearpage
> +.. _i2cdetect:
> +i2cdetect - detect I2C devices
> +.. index:: i2cdetect
> +SYNOPSYS:
> + .. code-block:: shell
> + i2cdetect <I2C_BUS>
> +.. index:: CONFIGURE_SHELL_NO_COMMAND_I2CDETECT
> +.. index:: CONFIGURE_SHELL_COMMAND_I2CDETECT
> +DESCRIPTION:
> + Tries to detect I2C devices connected to the I2C bus. To do that,
> write
> + requests with the length of 0 are used.
> + WARNING: This might confuse some I2C devices, so please use it only
> if you
> + know what you are doing.
What happens for devices that don't know how to respond? is it any kind of
undefined behavior?
> + The command supports a ``-h`` option to get usage details.
> + The command works only with I2C bus drivers that use the Linux-Style
> API.
> +EXAMPLES:
> + The following is an example where two I2C devices are detected. One
> on 0x1a
> + and one on 0x1f:
> + SHLL [/] # i2cdetect /dev/i2c1
> + x0 x1 x2 x3 x4 x5 x6 x7 x8 x9 xA xB xC xD xE xF
> + 0x -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
> + 1x -- -- -- -- -- -- -- -- -- -- 1a -- -- -- -- 1f
> + 2x -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
> + 3x -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
> + 4x -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
> + 5x -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
> + 6x -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
> + 7x -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
> + SHLL [/] #
> +CONFIGURATION:
> + This command is included in the default shell command set. When
> building a
If this is unsafe to use when you don't know what you're doing, then maybe
it should not be available without explicitly turning it on? (Safe
Defaults)
> + custom command set, define ``CONFIGURE_SHELL_COMMAND_I2CDETECT`` to
> have
> + this command included.
> + This command can be excluded from the shell command set by defining
> + ``CONFIGURE_SHELL_NO_COMMAND_I2CDETECT`` when all shell commands have
> been
> + configured.
> +.. raw:: latex
> + \clearpage
> +.. _i2cget:
> +i2cget - get data from an EEPROM like I2C device
> +.. index:: i2cget
> +SYNOPSYS:
> + i2cget <I2C_BUS> <CHIP-ADDRESS> <DATA-ADDRESS> [<NR-BYTES>]
> +.. index:: CONFIGURE_SHELL_NO_COMMAND_I2CGET
> +.. index:: CONFIGURE_SHELL_COMMAND_I2CGET
> +DESCRIPTION:
> + Get one or multiple bytes from an EEPROM like I2C device. If you read
> + multiple bytes (<NR-BYTES> given and > 1) the read will be done in one
Default is 1 byte? Please clarify
> + single request. An auto incrementing register pointer is assumed.
> API.
Would it make more sense to include all these under an
CONFIGURE_SHELL_COMMAND_I2CLINUX or something?
I don't use the shell though so take everything I say with a bit of
skepticism.
> +EXAMPLES:
> + The following is an example how to read a one byte register at 0xd
> from the
> + I2C device at 0x1f:
> + SHLL [/] # i2cget /dev/i2c1 0x1f 0x0d
Again, my shell ignorance: do the addresses need to be specified as Hex in
0x format?
> + 0xc7
> + SHLL [/] #
> +CONFIGURATION:
> building a
> + custom command set, define ``CONFIGURE_SHELL_COMMAND_I2CGET`` to have
> this
> + command included.
> + ``CONFIGURE_SHELL_NO_COMMAND_I2CGET`` when all shell commands have
> been
> + configured.
> +.. raw:: latex
> + \clearpage
> +.. _i2cset:
> +i2cset - write data to an EEPROM like I2C device
> +.. index:: i2cset
> +SYNOPSYS:
> + i2cset <I2C_BUS> <CHIP-ADDRESS> <DATA-ADDRESS> <VALUE> [<VALUE>
> +.. index:: CONFIGURE_SHELL_NO_COMMAND_I2CSET
> +.. index:: CONFIGURE_SHELL_COMMAND_I2CSET
> +DESCRIPTION:
> + Write one or multiple bytes to an EEPROM like I2C device. If you write
> + multiple bytes (multiple <VALUE> given) the write will be done in one
> single
Same for the values, do they need to be in 0x format, or is there already
documentation of what formats are accepted?
> + request. An auto incrementing register pointer is assumed.
> API.
> +EXAMPLES:
> + The following is an example how to write one byte of 0x00 to the
> register at
> + 0x11 of the I2C device at 0x1f:
> + SHLL [/] # i2cset /dev/i2c1 0x1f 0x11 0x00
> + SHLL [/] #
> +CONFIGURATION:
> building a
> + custom command set, define ``CONFIGURE_SHELL_COMMAND_I2CSET`` to have
> this
> + command included.
> + ``CONFIGURE_SHELL_NO_COMMAND_I2CSET`` when all shell commands have
> been
> + configured.
> +.. raw:: latex
> + \clearpage
> +.. _spi:
> +spi - read and write simple data to an SPI bus
> +.. index:: spi
> +SYNOPSYS:
> + spi [-loh] [-c <cs>] [-s <speed>] [-m <mode>] <SPI_BUS> xx [xx
> +.. index:: CONFIGURE_SHELL_NO_COMMAND_SPI
> +.. index:: CONFIGURE_SHELL_COMMAND_SPI
> +DESCRIPTION:
> + Write data to an SPI bus and read the responses.
> + The command works only with SPI bus drivers that use the Linux-Style
> API.
> +EXAMPLES:
> + The following is an example how to write multiple bytes (0x42 0x43
> 0x44) to
> + the bus. The response is three times 0x00 in this case because the
> bus has
> + been left open. Chip select 1 will be used.
> + SHLL [/] # spi /dev/spi1 -c 1 42 0x43 44
> + received: 00 00 00
> + SHLL [/] #
Provide an example to read?
Why not unify the i2c command the same way as spi? Just curious if there is
some rationale.
+CONFIGURATION:
> building a
> + custom command set, define ``CONFIGURE_SHELL_COMMAND_SPI`` to have
> this
> + command included.
> + ``CONFIGURE_SHELL_NO_COMMAND_SPI`` when all shell commands have been
> + configured.
> +.. raw:: latex
> + \clearpage
> .. _exit:
> exit - exit the shell
> 2.26.2
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201130/8c2cb7b0/attachment-0001.html>
