[PATCH rtems-docs] shell: Document i2c and spi commands.
Christian Mauderer oss at c-mauderer.de
Mon Nov 30 19:14:03 UTC 2020
Hello Gedare,
thanks for the review.
On 30/11/2020 18:43, Gedare Bloom wrote:
> On Mon, Nov 30, 2020 at 7:14 AM Christian Mauderer
> <christian.mauderer at embedded-brains.de
> <mailto:christian.mauderer at embedded-brains.de>> wrote:
>       shell/general_commands.rst | 200 +++++++++++++++++++++++++++++++++++++
>       1 file changed, 200 insertions(+)
>     diff --git a/shell/general_commands.rst b/shell/general_commands.rst
>     index c74ae45..a6f7e18 100644
>     --- a/shell/general_commands.rst
>     +++ b/shell/general_commands.rst
>     @@ -44,6 +44,14 @@ The RTEMS shell has the following general commands:
>       - rtc_ - RTC driver configuration
>     +- i2cdetect_ - detect I2C devices
>     +- i2cget_ - get data from an EEPROM like I2C device
>     +- i2cset_ - write data to an EEPROM like I2C device
>     +- spi_ - read and write simple data to an SPI bus
>       - exit_ - alias for logoff command
>       Commands
>     @@ -1179,6 +1187,198 @@ CONFIGURATION:
>          \clearpage
>     +.. _i2cdetect:
>     +i2cdetect - detect I2C devices
>     +.. index:: i2cdetect
>     +SYNOPSYS:
>     +    .. code-block:: shell
>     +        i2cdetect <I2C_BUS>
>     +.. index:: CONFIGURE_SHELL_NO_COMMAND_I2CDETECT
>     +.. index:: CONFIGURE_SHELL_COMMAND_I2CDETECT
>     +DESCRIPTION:
>     +    Tries to detect I2C devices connected to the I2C bus. To do
>     that, write
>     +    requests with the length of 0 are used.
>     +    WARNING: This might confuse some I2C devices, so please use it
>     only if you
>     +    know what you are doing.
> What happens for devices that don't know how to respond? is it any kind
> of undefined behavior?
That depends on the devices. Basically everything can happen. For example:
- device is just not detected
- I2C bus hangs
- some random undefined behavior
The command uses the same method that is used by the Linux i2cdetect
command and therefore I added a similar warning:
    https://linux.die.net/man/8/i2cdetect
>     +    The command supports a ``-h`` option to get usage details.
>     +    The command works only with I2C bus drivers that use the
>     Linux-Style API.
>     +EXAMPLES:
>     +    The following is an example where two I2C devices are detected.
>     One on 0x1a
>     +    and one on 0x1f:
>     +        SHLL [/] # i2cdetect /dev/i2c1
>     +            x0 x1 x2 x3 x4 x5 x6 x7 x8 x9 xA xB xC xD xE xF
>     +        0x     -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
>     +        1x  -- -- -- -- -- -- -- -- -- -- 1a -- -- -- -- 1f
>     +        2x  -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
>     +        3x  -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
>     +        4x  -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
>     +        5x  -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
>     +        6x  -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
>     +        7x  -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
>     +        SHLL [/] #
>     +CONFIGURATION:
>     +    This command is included in the default shell command set.
>     When building a
> If this is unsafe to use when you don't know what you're doing, then
> maybe it should not be available without explicitly turning it on?
> (Safe Defaults)
I can do that if you want. It's more or less a diagnostic command (just
like the others here). But note that we have a lot of "unsafe if you
don't know what you are doing" commands. Like dd, mkrfs, mmove, fdisk,
and even exit can crash some systems ...
Aren't nearly all shell commands at least a bit unsafe? And we don't
have a lot of commands that have to be explicitly turned on if
CONFIGURE_SHELL_COMMANDS_ALL is already set. I found only networking
commands.
>     +    custom command set, define
>     ``CONFIGURE_SHELL_COMMAND_I2CDETECT`` to have
>     +    this command included.
>     +    This command can be excluded from the shell command set by defining
>     +    ``CONFIGURE_SHELL_NO_COMMAND_I2CDETECT`` when all shell
>     commands have been
>     +    configured.
>     +.. raw:: latex
>     +   \clearpage
>     +.. _i2cget:
>     +i2cget - get data from an EEPROM like I2C device
>     +.. index:: i2cget
>     +SYNOPSYS:
>     +        i2cget <I2C_BUS> <CHIP-ADDRESS> <DATA-ADDRESS> [<NR-BYTES>]
>     +.. index:: CONFIGURE_SHELL_NO_COMMAND_I2CGET
>     +.. index:: CONFIGURE_SHELL_COMMAND_I2CGET
>     +DESCRIPTION:
>     +    Get one or multiple bytes from an EEPROM like I2C device. If
>     you read
>     +    multiple bytes (<NR-BYTES> given and > 1) the read will be done
>     in one
> Default is 1 byte? Please clarify
OK.
>     +    single request. An auto incrementing register pointer is assumed.
>     Linux-Style API.
> Would it make more sense to include all these under an
> CONFIGURE_SHELL_COMMAND_I2CLINUX or something?
I'm quite indifferent regarding that. If you prefer it, I can collect them.
Beneath CONFIGURE_SHELL_COMMANDS_ALL and
CONFIGURE_SHELL_COMMANDS_ALL_NETWORKING there don't seem to be a lot of
groups. So I didn't start a new one ...
> I don't use the shell though so take everything I say with a bit of
> skepticism.
I'll wait for some more feedback.
>     +EXAMPLES:
>     +    The following is an example how to read a one byte register at
>     0xd from the
>     +    I2C device at 0x1f:
>     +        SHLL [/] # i2cget /dev/i2c1 0x1f 0x0d
> Again, my shell ignorance: do the addresses need to be specified as Hex
> in 0x format?
I wrote the commands in a way that they should accept hex (0x10),
decimal (16) or octal (020). I can add this as a comment.
>     +        0xc7
>     +        SHLL [/] #
>     +CONFIGURATION:
>     When building a
>     +    custom command set, define ``CONFIGURE_SHELL_COMMAND_I2CGET``
>     to have this
>     +    command included.
>     +    ``CONFIGURE_SHELL_NO_COMMAND_I2CGET`` when all shell commands
>     have been
>     +    configured.
>     +.. raw:: latex
>     +   \clearpage
>     +.. _i2cset:
>     +i2cset - write data to an EEPROM like I2C device
>     +.. index:: i2cset
>     +SYNOPSYS:
>     +        i2cset <I2C_BUS> <CHIP-ADDRESS> <DATA-ADDRESS> <VALUE>
>     [<VALUE> [...]]
>     +.. index:: CONFIGURE_SHELL_NO_COMMAND_I2CSET
>     +.. index:: CONFIGURE_SHELL_COMMAND_I2CSET
>     +DESCRIPTION:
>     +    Write one or multiple bytes to an EEPROM like I2C device. If
>     you write
>     +    multiple bytes (multiple <VALUE> given) the write will be done
>     in one single
> Same for the values, do they need to be in 0x format, or is there
> already documentation of what formats are accepted?
No there is no other documentation. Maybe I should add a bit. Do you
think it would be better to add it here or to the "-h" output?
>     +    request. An auto incrementing register pointer is assumed.
>     Linux-Style API.
>     +EXAMPLES:
>     +    The following is an example how to write one byte of 0x00 to
>     the register at
>     +    0x11 of the I2C device at 0x1f:
>     +        SHLL [/] # i2cset /dev/i2c1 0x1f 0x11 0x00
>     +        SHLL [/] #
>     +CONFIGURATION:
>     When building a
>     +    custom command set, define ``CONFIGURE_SHELL_COMMAND_I2CSET``
>     to have this
>     +    command included.
>     +    ``CONFIGURE_SHELL_NO_COMMAND_I2CSET`` when all shell commands
>     have been
>     +    configured.
>     +.. raw:: latex
>     +   \clearpage
>     +.. _spi:
>     +spi - read and write simple data to an SPI bus
>     +.. index:: spi
>     +SYNOPSYS:
>     +        spi [-loh] [-c <cs>] [-s <speed>] [-m <mode>] <SPI_BUS> xx
>     [xx [..]]
>     +.. index:: CONFIGURE_SHELL_NO_COMMAND_SPI
>     +.. index:: CONFIGURE_SHELL_COMMAND_SPI
>     +DESCRIPTION:
>     +    Write data to an SPI bus and read the responses.
>     +    The command works only with SPI bus drivers that use the
>     Linux-Style API.
>     +EXAMPLES:
>     +    The following is an example how to write multiple bytes (0x42
>     0x43 0x44) to
>     +    the bus. The response is three times 0x00 in this case because
>     the bus has
>     +    been left open. Chip select 1 will be used.
>     +        SHLL [/] # spi /dev/spi1 -c 1 42 0x43 44
>     +        received: 00 00 00
>     +        SHLL [/] #
> Provide an example to read?
Maybe I should have added some values other than 0x00 to the received
line. SPI can only do both at once (at least for the normal drivers).
> Why not unify the i2c command the same way as spi? Just curious if there
> is some rationale.
Rationale is that I used Linux I2C tools as a rough guide for the
syntax. For SPI I didn't have a template.
Beneath that I2C does have explicit read or write modes. So I would have
to set the direction with a parameter if I unified them. SPI on the
other hand does always receive and transmit at the same time. So it
wouldn't be useful to split it up.
Best regards
Christian
>     +CONFIGURATION:
>     When building a
>     +    custom command set, define ``CONFIGURE_SHELL_COMMAND_SPI`` to
>     have this
>     +    command included.
>     +    ``CONFIGURE_SHELL_NO_COMMAND_SPI`` when all shell commands have
>     been
>     +    configured.
>     +.. raw:: latex
>     +   \clearpage
>       .. _exit:
>       exit - exit the shell
>     2.26.2
>     _______________________________________________
>     devel mailing list
>     devel at rtems.org <mailto:devel at rtems.org>
>     http://lists.rtems.org/mailman/listinfo/devel
>     <http://lists.rtems.org/mailman/listinfo/devel>
> devel mailing list
> devel at rtems.org
